drm/tilcdc: Deletion of an unnecessary check before the function call “drm_fbdev_cma_hotplug_event”
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_fbdev_cma_hotplug_event() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Reviewed-by: Thierry Reding
Signed-off-by: Dave Airlie
 drivers/gpu/drm/tilcdc/tilcdc_drv.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/tilcdc/tilcdc_drv.c b/drivers/gpu/drm/tilcdc/tilcdc_drv.c
index 79a34cb..d56d3f8 100644
--- a/drivers/gpu/drm/tilcdc/tilcdc_drv.c
+++ b/drivers/gpu/drm/tilcdc/tilcdc_drv.c
@@ -58,8 +58,7 @@ static struct drm_framebuffer *tilcdc_fb_create(struct drm_device *dev,
 static void tilcdc_fb_output_poll_changed(struct drm_device *dev)
 	struct tilcdc_drm_private *priv = dev->dev_private;
-	if (priv->fbdev)
-		drm_fbdev_cma_hotplug_event(priv->fbdev);
+	drm_fbdev_cma_hotplug_event(priv->fbdev);
 static const struct drm_mode_config_funcs mode_config_funcs = {
BtrLinux
Privacy Overview
