drm/rockchip: Delete an unnecessary check before drm_gem_object_unreference_unlocked()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_gem_object_unreference_unlocked() function tests whether
its argument is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
drivers/gpu/drm/rockchip/rockchip_drm_fb.c | 8 ++------
1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/gpu/drm/rockchip/rockchip_drm_fb.c b/drivers/gpu/drm/rockchip/rockchip_drm_fb.c
index b33debc..55c5273 100644
--- a/drivers/gpu/drm/rockchip/rockchip_drm_fb.c
+++ b/drivers/gpu/drm/rockchip/rockchip_drm_fb.c
@@ -44,14 +44,10 @@ struct drm_gem_object *rockchip_fb_get_gem_obj(struct drm_framebuffer *fb,
static void rockchip_drm_fb_destroy(struct drm_framebuffer *fb)
struct rockchip_drm_fb *rockchip_fb = to_rockchip_fb(fb);
- struct drm_gem_object *obj;
int i;
- for (i = 0; i < ROCKCHIP_MAX_FB_BUFFER; i++) {
- obj = rockchip_fb->obj[i];
- if (obj)
- drm_gem_object_unreference_unlocked(obj);
+ for (i = 0; i < ROCKCHIP_MAX_FB_BUFFER; i++)
+ drm_gem_object_unreference_unlocked(rockchip_fb->obj[i]);
drm_framebuffer_cleanup(fb);
kfree(rockchip_fb); |
int i;
- if (obj)
kfree(rockchip_fb);
