drm/rockchip: Delete an unnecessary check before drm_gem_object_unreference_unlocked()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_gem_object_unreference_unlocked() function tests whether
its argument is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/b66399ed-278b-b85d-4a21-b34164936ef6@users.sourceforge.net
 drivers/gpu/drm/rockchip/rockchip_drm_fb.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/gpu/drm/rockchip/rockchip_drm_fb.c b/drivers/gpu/drm/rockchip/rockchip_drm_fb.c
index 20f12bc..6f64e79 100644
--- a/drivers/gpu/drm/rockchip/rockchip_drm_fb.c
+++ b/drivers/gpu/drm/rockchip/rockchip_drm_fb.c
@@ -43,14 +43,10 @@ struct drm_gem_object *rockchip_fb_get_gem_obj(struct drm_framebuffer *fb,
 static void rockchip_drm_fb_destroy(struct drm_framebuffer *fb)
 	struct rockchip_drm_fb *rockchip_fb = to_rockchip_fb(fb);
-	struct drm_gem_object *obj;
 	int i;
-	for (i = 0; i < ROCKCHIP_MAX_FB_BUFFER; i++) {
-		obj = rockchip_fb->obj[i];
-		if (obj)
-			drm_gem_object_unreference_unlocked(obj);
+	for (i = 0; i < ROCKCHIP_MAX_FB_BUFFER; i++)
+		drm_gem_object_unreference_unlocked(rockchip_fb->obj[i]);
 	drm_framebuffer_cleanup(fb);
 	kfree(rockchip_fb);
BtrLinux
Privacy Overview
