drm/qxl: Delete an unnecessary check before drm_gem_object_unreference_unlocked()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_gem_object_unreference_unlocked() function tests whether
its argument is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Sean Paul
Link: http://patchwork.freedesktop.org/patch/msgid/913198fa-2aa4-4804-8616-dd495428c0a5@users.sourceforge.net
 drivers/gpu/drm/qxl/qxl_display.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/qxl/qxl_display.c b/drivers/gpu/drm/qxl/qxl_display.c
index ad42968..3aef127 100644
--- a/drivers/gpu/drm/qxl/qxl_display.c
+++ b/drivers/gpu/drm/qxl/qxl_display.c
@@ -468,8 +468,7 @@ void qxl_user_framebuffer_destroy(struct drm_framebuffer *fb)
 	struct qxl_framebuffer *qxl_fb = to_qxl_framebuffer(fb);
-	if (qxl_fb->obj)
-		drm_gem_object_unreference_unlocked(qxl_fb->obj);
+	drm_gem_object_unreference_unlocked(qxl_fb->obj);
 	drm_framebuffer_cleanup(fb);
 	kfree(qxl_fb);
BtrLinux
Privacy Overview
