drm/msm: Move call to PTR_ERR_OR_ZERO after reassignment
Author: Vaishali Thakkar <vaishali.thakkar@oracle.com>
Here, a location is reset to NULL before being passed to PTR_ERR.
So, PTR_ERR should be called before its argument is reassigned
to NULL. Further to simplify things use PTR_ERR_OR_ZERO instead
of PTR_ERR and IS_ERR.
Problem found using Coccinelle.
Signed-off-by: Vaishali Thakkar
Reviewed-by: Eric Engestrom
[fixed fmt string warning (s/%ld/%d/)]
Signed-off-by: Rob Clark
drivers/gpu/drm/msm/edp/edp_ctrl.c | 19 +++++++++++--------
1 file changed, 11 insertions(+), 8 deletions(-)
diff --git a/drivers/gpu/drm/msm/edp/edp_ctrl.c b/drivers/gpu/drm/msm/edp/edp_ctrl.c
index 81200e9..4f7457b 100644
--- a/drivers/gpu/drm/msm/edp/edp_ctrl.c
+++ b/drivers/gpu/drm/msm/edp/edp_ctrl.c
@@ -302,21 +302,24 @@ static void edp_clk_disable(struct edp_ctrl *ctrl, u32 clk_mask)
static int edp_regulator_init(struct edp_ctrl *ctrl)
struct device *dev = &ctrl->pdev->dev;
+ int ret;
DBG("");
ctrl->vdda_vreg = devm_regulator_get(dev, "vdda");
- if (IS_ERR(ctrl->vdda_vreg)) {
- pr_err("%s: Could not get vdda reg, ret = %ld\n", __func__,
- PTR_ERR(ctrl->vdda_vreg));
+ ret = PTR_ERR_OR_ZERO(ctrl->vdda_vreg);
+ if (ret) {
+ pr_err("%s: Could not get vdda reg, ret = %d\n", __func__,
+ ret);
ctrl->vdda_vreg = NULL;
- return PTR_ERR(ctrl->vdda_vreg);
+ return ret;
ctrl->lvl_vreg = devm_regulator_get(dev, "lvl-vdd");
- if (IS_ERR(ctrl->lvl_vreg)) {
- pr_err("Could not get lvl-vdd reg, %ld",
- PTR_ERR(ctrl->lvl_vreg));
+ ret = PTR_ERR_OR_ZERO(ctrl->lvl_vreg);
+ if (ret) {
+ pr_err("%s: Could not get lvl-vdd reg, ret = %d\n", __func__,
+ ret);
ctrl->lvl_vreg = NULL;
- return PTR_ERR(ctrl->lvl_vreg);
+ return ret;
return 0; |
+ int ret;
DBG("");
+ if (ret) {
+ ret);
+ return ret;
+ if (ret) {
+ ret);
+ return ret;
return 0;
