drm/msm: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions framebuffer_release() and vunmap() perform also input
parameter validation. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Reviewed-by: Thierry Reding
Signed-off-by: Rob Clark
drivers/gpu/drm/msm/msm_fbdev.c | 3 +--
drivers/gpu/drm/msm/msm_gem.c | 3 +--
2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/gpu/drm/msm/msm_fbdev.c b/drivers/gpu/drm/msm/msm_fbdev.c
index 94d55e5..1f3af13 100644
--- a/drivers/gpu/drm/msm/msm_fbdev.c
+++ b/drivers/gpu/drm/msm/msm_fbdev.c
@@ -190,8 +190,7 @@ fail_unlock:
fail:
if (ret) {
- if (fbi)
- framebuffer_release(fbi);
+ framebuffer_release(fbi);
if (fb) {
drm_framebuffer_unregister_private(fb);
drm_framebuffer_remove(fb);
diff --git a/drivers/gpu/drm/msm/msm_gem.c b/drivers/gpu/drm/msm/msm_gem.c
index 4a6f0e4..49dea4f 100644
--- a/drivers/gpu/drm/msm/msm_gem.c
+++ b/drivers/gpu/drm/msm/msm_gem.c
@@ -535,8 +535,7 @@ void msm_gem_free_object(struct drm_gem_object *obj)
drm_free_large(msm_obj->pages);
} else {
- if (msm_obj->vaddr)
- vunmap(msm_obj->vaddr);
+ vunmap(msm_obj->vaddr);
put_pages(obj);
fail:
if (ret) {
- if (fbi)
if (fb) {
} else {
put_pages(obj);
