drm/msm: Delete an unnecessary check before drm_gem_object_unreference()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_gem_object_unreference() function tests whether its argument
is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Rob Clark
 drivers/gpu/drm/msm/msm_gem.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/gpu/drm/msm/msm_gem.c b/drivers/gpu/drm/msm/msm_gem.c
index 9a713fb..6cd4af4 100644
--- a/drivers/gpu/drm/msm/msm_gem.c
+++ b/drivers/gpu/drm/msm/msm_gem.c
@@ -830,9 +830,7 @@ struct drm_gem_object *msm_gem_new(struct drm_device *dev,
 	return obj;
 fail:
-	if (obj)
-		drm_gem_object_unreference(obj);
+	drm_gem_object_unreference(obj);
 	return ERR_PTR(ret);
BtrLinux
Privacy Overview
