drm/i915: Split the ringbuffers from the rings (2/3)
Author: Oscar Mateo <oscar.mateo@intel.com>
This refactoring has been performed using the following Coccinelle
semantic script:
    struct intel_engine_cs r;
    - (r).obj
    + r.buffer->obj
    - (r).virtual_start
    + r.buffer->virtual_start
    - (r).head
    + r.buffer->head
    - (r).tail
    + r.buffer->tail
    - (r).space
    + r.buffer->space
    - (r).size
    + r.buffer->size
    - (r).effective_size
    + r.buffer->effective_size
    - (r).last_retired_head
    + r.buffer->last_retired_head
    struct intel_engine_cs *r;
    - (r)->obj
    + r->buffer->obj
    - (r)->virtual_start
    + r->buffer->virtual_start
    - (r)->head
    + r->buffer->head
    - (r)->tail
    + r->buffer->tail
    - (r)->space
    + r->buffer->space
    - (r)->size
    + r->buffer->size
    - (r)->effective_size
    + r->buffer->effective_size
    - (r)->last_retired_head
    + r->buffer->last_retired_head
    expression E;
    - LP_RING(E)->obj
    + LP_RING(E)->buffer->obj
    - LP_RING(E)->virtual_start
    + LP_RING(E)->buffer->virtual_start
    - LP_RING(E)->head
    + LP_RING(E)->buffer->head
    - LP_RING(E)->tail
    + LP_RING(E)->buffer->tail
    - LP_RING(E)->space
    + LP_RING(E)->buffer->space
    - LP_RING(E)->size
    + LP_RING(E)->buffer->size
    - LP_RING(E)->effective_size
    + LP_RING(E)->buffer->effective_size
    - LP_RING(E)->last_retired_head
    + LP_RING(E)->buffer->last_retired_head
Note: On top of this this patch also removes the now unused ringbuffer
fields in intel_engine_cs.
Signed-off-by: Oscar Mateo
[danvet: Add note about fixup patch included here.]
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/i915_dma.c         |  22 +++----
 drivers/gpu/drm/i915/i915_gem.c         |   2 +-
 drivers/gpu/drm/i915/i915_gpu_error.c   |   6 +-
 drivers/gpu/drm/i915/i915_irq.c         |   8 +--
 drivers/gpu/drm/i915/intel_ringbuffer.c | 102 ++++++++++++++++----------------
 drivers/gpu/drm/i915/intel_ringbuffer.h |  27 ++-------
 6 files changed, 75 insertions(+), 92 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_dma.c b/drivers/gpu/drm/i915/i915_dma.c
index 13784fe..234d454 100644
--- a/drivers/gpu/drm/i915/i915_dma.c
+++ b/drivers/gpu/drm/i915/i915_dma.c
@@ -64,7 +64,7 @@
  * has access to the ring.
 #define RING_LOCK_TEST_WITH_RETURN(dev, file) do {			\
-	if (LP_RING(dev->dev_private)->obj == NULL)			\
+	if (LP_RING(dev->dev_private)->buffer->obj == NULL)			\
 		LOCK_TEST_WITH_RETURN(dev, file);			\
 } while (0)
@@ -149,17 +149,17 @@ void i915_kernel_lost_context(struct drm_device * dev)
 	if (drm_core_check_feature(dev, DRIVER_MODESET))
 		return;
-	ring->head = I915_READ_HEAD(ring) & HEAD_ADDR;
-	ring->tail = I915_READ_TAIL(ring) & TAIL_ADDR;
-	ring->space = ring->head - (ring->tail + I915_RING_FREE_SPACE);
-	if (ring->space < 0)
-		ring->space += ring->size;
+	ring->buffer->head = I915_READ_HEAD(ring) & HEAD_ADDR;
+	ring->buffer->tail = I915_READ_TAIL(ring) & TAIL_ADDR;
+	ring->buffer->space = ring->buffer->head - (ring->buffer->tail + I915_RING_FREE_SPACE);
+	if (ring->buffer->space < 0)
+		ring->buffer->space += ring->buffer->size;
 	if (!dev->primary->master)
 		return;
 	master_priv = dev->primary->master->driver_priv;
-	if (ring->head == ring->tail && master_priv->sarea_priv)
+	if (ring->buffer->head == ring->buffer->tail && master_priv->sarea_priv)
 		master_priv->sarea_priv->perf_boxes |= I915_BOX_RING_EMPTY;
@@ -202,7 +202,7 @@ static int i915_initialize(struct drm_device * dev, drm_i915_init_t * init)
 	if (init->ring_size != 0) {
-		if (LP_RING(dev_priv)->obj != NULL) {
+		if (LP_RING(dev_priv)->buffer->obj != NULL) {
 			i915_dma_cleanup(dev);
 			DRM_ERROR("Client tried to initialize ringbuffer in "
 				  "GEM mode\n");
@@ -239,7 +239,7 @@ static int i915_dma_resume(struct drm_device * dev)
 	DRM_DEBUG_DRIVER("%s\n", __func__);
-	if (ring->virtual_start == NULL) {
+	if (ring->buffer->virtual_start == NULL) {
 		DRM_ERROR("can not ioremap virtual address for"
 			  " ring buffer\n");
 		return -ENOMEM;
@@ -361,7 +361,7 @@ static int i915_emit_cmds(struct drm_device * dev, int *buffer, int dwords)
 	struct drm_i915_private *dev_priv = dev->dev_private;
 	int i, ret;
-	if ((dwords+1) * sizeof(int) >= LP_RING(dev_priv)->size - 8)
+	if ((dwords+1) * sizeof(int) >= LP_RING(dev_priv)->buffer->size - 8)
 		return -EINVAL;
 	for (i = 0; i < dwords;) {
@@ -824,7 +824,7 @@ static int i915_irq_emit(struct drm_device *dev, void *data,
 		return -ENODEV;
-	if (!dev_priv || !LP_RING(dev_priv)->virtual_start) {
+	if (!dev_priv || !LP_RING(dev_priv)->buffer->virtual_start) {
 		DRM_ERROR("called with no initialization\n");
 		return -EINVAL;
diff --git a/drivers/gpu/drm/i915/i915_gem.c b/drivers/gpu/drm/i915/i915_gem.c
index 382eae7..db7796b 100644
--- a/drivers/gpu/drm/i915/i915_gem.c
+++ b/drivers/gpu/drm/i915/i915_gem.c
@@ -2523,7 +2523,7 @@ i915_gem_retire_requests_ring(struct intel_engine_cs *ring)
 		 * of tail of the request to update the last known position
 		 * of the GPU head.
-		ring->last_retired_head = request->tail;
+		ring->buffer->last_retired_head = request->tail;
 		i915_gem_free_request(request);
diff --git a/drivers/gpu/drm/i915/i915_gpu_error.c b/drivers/gpu/drm/i915/i915_gpu_error.c
index 632db42..87ec60e 100644
--- a/drivers/gpu/drm/i915/i915_gpu_error.c
+++ b/drivers/gpu/drm/i915/i915_gpu_error.c
@@ -825,8 +825,8 @@ static void i915_record_ring_state(struct drm_device *dev,
 		ering->hws = I915_READ(mmio);
-	ering->cpu_ring_head = ring->head;
-	ering->cpu_ring_tail = ring->tail;
+	ering->cpu_ring_head = ring->buffer->head;
+	ering->cpu_ring_tail = ring->buffer->tail;
 	ering->hangcheck_score = ring->hangcheck.score;
 	ering->hangcheck_action = ring->hangcheck.action;
@@ -930,7 +930,7 @@ static void i915_gem_record_rings(struct drm_device *dev,
 		error->ring[i].ringbuffer =
-			i915_error_ggtt_object_create(dev_priv, ring->obj);
+			i915_error_ggtt_object_create(dev_priv, ring->buffer->obj);
 		if (ring->status_page.obj)
 			error->ring[i].hws_page =
diff --git a/drivers/gpu/drm/i915/i915_irq.c b/drivers/gpu/drm/i915/i915_irq.c
index c28e0da..152ba12 100644
--- a/drivers/gpu/drm/i915/i915_irq.c
+++ b/drivers/gpu/drm/i915/i915_irq.c
@@ -1219,7 +1219,7 @@ static void ironlake_rps_change_irq_handler(struct drm_device *dev)
 static void notify_ring(struct drm_device *dev,
-	if (ring->obj == NULL)
+	if (ring->buffer->obj == NULL)
 		return;
 	trace_i915_gem_request_complete(ring);
@@ -2837,10 +2837,10 @@ semaphore_waits_for(struct intel_engine_cs *ring, u32 *seqno)
 		 * our ring is smaller than what the hardware (and hence
 		 * HEAD_ADDR) allows. Also handles wrap-around.
-		head &= ring->size - 1;
+		head &= ring->buffer->size - 1;
 		/* This here seems to blow up */
-		cmd = ioread32(ring->virtual_start + head);
+		cmd = ioread32(ring->buffer->virtual_start + head);
 		if (cmd == ipehr)
 			break;
@@ -2850,7 +2850,7 @@ semaphore_waits_for(struct intel_engine_cs *ring, u32 *seqno)
 	if (!i)
 		return NULL;
-	*seqno = ioread32(ring->virtual_start + head + 4) + 1;
+	*seqno = ioread32(ring->buffer->virtual_start + head + 4) + 1;
 	return semaphore_wait_to_signaller_ring(ring, ipehr);
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.c b/drivers/gpu/drm/i915/intel_ringbuffer.c
index 9b406e42..70f1b88 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.c
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.c
@@ -50,7 +50,7 @@ static inline int __ring_space(int head, int tail, int size)
 static inline int ring_space(struct intel_engine_cs *ring)
-	return __ring_space(ring->head & HEAD_ADDR, ring->tail, ring->size);
+	return __ring_space(ring->buffer->head & HEAD_ADDR, ring->buffer->tail, ring->buffer->size);
 static bool intel_ring_stopped(struct intel_engine_cs *ring)
@@ -61,10 +61,10 @@ static bool intel_ring_stopped(struct intel_engine_cs *ring)
 void __intel_ring_advance(struct intel_engine_cs *ring)
-	ring->tail &= ring->size - 1;
+	ring->buffer->tail &= ring->buffer->size - 1;
 	if (intel_ring_stopped(ring))
 		return;
-	ring->write_tail(ring, ring->tail);
+	ring->write_tail(ring, ring->buffer->tail);
 static int
@@ -481,7 +481,7 @@ static int init_ring_common(struct intel_engine_cs *ring)
 	struct drm_device *dev = ring->dev;
-	struct drm_i915_gem_object *obj = ring->obj;
+	struct drm_i915_gem_object *obj = ring->buffer->obj;
 	int ret = 0;
 	gen6_gt_force_wake_get(dev_priv, FORCEWAKE_ALL);
@@ -520,7 +520,7 @@ static int init_ring_common(struct intel_engine_cs *ring)
 	 * register values. */
 	I915_WRITE_START(ring, i915_gem_obj_ggtt_offset(obj));
 	I915_WRITE_CTL(ring,
-			((ring->size - PAGE_SIZE) & RING_NR_PAGES)
+			((ring->buffer->size - PAGE_SIZE) & RING_NR_PAGES)
 			| RING_VALID);
 	/* If the head is still not zero, the ring is dead */
@@ -540,10 +540,10 @@ static int init_ring_common(struct intel_engine_cs *ring)
 	if (!drm_core_check_feature(ring->dev, DRIVER_MODESET))
 		i915_kernel_lost_context(ring->dev);
 	else {
-		ring->head = I915_READ_HEAD(ring);
-		ring->space = ring_space(ring);
-		ring->last_retired_head = -1;
+		ring->buffer->head = I915_READ_HEAD(ring);
+		ring->buffer->space = ring_space(ring);
+		ring->buffer->last_retired_head = -1;
 	memset(&ring->hangcheck, 0, sizeof(ring->hangcheck));
@@ -1382,14 +1382,14 @@ static int allocate_ring_buffer(struct intel_engine_cs *ring)
 	struct drm_i915_gem_object *obj;
 	int ret;
-	if (ring->obj)
+	if (ring->buffer->obj)
 		return 0;
 	obj = NULL;
 	if (!HAS_LLC(dev))
-		obj = i915_gem_object_create_stolen(dev, ring->size);
+		obj = i915_gem_object_create_stolen(dev, ring->buffer->size);
 	if (obj == NULL)
-		obj = i915_gem_alloc_object(dev, ring->size);
+		obj = i915_gem_alloc_object(dev, ring->buffer->size);
 	if (obj == NULL)
 		return -ENOMEM;
@@ -1401,15 +1401,15 @@ static int allocate_ring_buffer(struct intel_engine_cs *ring)
 	if (ret)
 		goto err_unpin;
-	ring->virtual_start =
+	ring->buffer->virtual_start =
 		ioremap_wc(dev_priv->gtt.mappable_base + i915_gem_obj_ggtt_offset(obj),
-			   ring->size);
+			   ring->buffer->size);
 		ret = -EINVAL;
 		goto err_unpin;
-	ring->obj = obj;
+	ring->buffer->obj = obj;
 	return 0;
 err_unpin:
@@ -1435,7 +1435,7 @@ static int intel_init_ring_buffer(struct drm_device *dev,
 	ring->dev = dev;
 	INIT_LIST_HEAD(&ring->active_list);
 	INIT_LIST_HEAD(&ring->request_list);
-	ring->size = 32 * PAGE_SIZE;
+	ring->buffer->size = 32 * PAGE_SIZE;
 	memset(ring->semaphore.sync_seqno, 0, sizeof(ring->semaphore.sync_seqno));
 	init_waitqueue_head(&ring->irq_queue);
@@ -1461,9 +1461,9 @@ static int intel_init_ring_buffer(struct drm_device *dev,
 	 * the TAIL pointer points to within the last 2 cachelines
 	 * of the buffer.
-	ring->effective_size = ring->size;
+	ring->buffer->effective_size = ring->buffer->size;
 	if (IS_I830(dev) || IS_845G(dev))
-		ring->effective_size -= 2 * CACHELINE_BYTES;
+		ring->buffer->effective_size -= 2 * CACHELINE_BYTES;
 	ret = i915_cmd_parser_init_ring(ring);
 	if (ret)
@@ -1485,17 +1485,17 @@ void intel_cleanup_ring_buffer(struct intel_engine_cs *ring)
 	struct drm_i915_private *dev_priv = to_i915(ring->dev);
 		return;
 	intel_stop_ring_buffer(ring);
 	WARN_ON((I915_READ_MODE(ring) & MODE_IDLE) == 0);
-	iounmap(ring->virtual_start);
+	iounmap(ring->buffer->virtual_start);
-	i915_gem_object_ggtt_unpin(ring->obj);
-	drm_gem_object_unreference(&ring->obj->base);
-	ring->obj = NULL;
+	i915_gem_object_ggtt_unpin(ring->buffer->obj);
+	drm_gem_object_unreference(&ring->buffer->obj->base);
+	ring->buffer->obj = NULL;
 	ring->preallocated_lazy_request = NULL;
 	ring->outstanding_lazy_seqno = 0;
@@ -1516,17 +1516,17 @@ static int intel_ring_wait_request(struct intel_engine_cs *ring, int n)
 	u32 seqno = 0;
 	int ret;
-	if (ring->last_retired_head != -1) {
-		ring->head = ring->last_retired_head;
+	if (ring->buffer->last_retired_head != -1) {
+		ring->buffer->head = ring->buffer->last_retired_head;
-		if (ring->space >= n)
+		if (ring->buffer->space >= n)
 			return 0;
 	list_for_each_entry(request, &ring->request_list, list) {
-		if (__ring_space(request->tail, ring->tail, ring->size) >= n) {
+		if (__ring_space(request->tail, ring->buffer->tail, ring->buffer->size) >= n) {
 			seqno = request->seqno;
 			break;
@@ -1540,10 +1540,10 @@ static int intel_ring_wait_request(struct intel_engine_cs *ring, int n)
 		return ret;
 	i915_gem_retire_requests_ring(ring);
 	return 0;
@@ -1570,9 +1570,9 @@ static int ring_wait_for_space(struct intel_engine_cs *ring, int n)
 	trace_i915_ring_wait_begin(ring);
 	do {
-		if (ring->space >= n) {
+		if (ring->buffer->space >= n) {
 			ret = 0;
 			break;
@@ -1608,21 +1608,21 @@ static int ring_wait_for_space(struct intel_engine_cs *ring, int n)
 static int intel_wrap_ring_buffer(struct intel_engine_cs *ring)
 	uint32_t __iomem *virt;
-	int rem = ring->size - ring->tail;
+	int rem = ring->buffer->size - ring->buffer->tail;
-	if (ring->space < rem) {
+	if (ring->buffer->space < rem) {
 		int ret = ring_wait_for_space(ring, rem);
 		if (ret)
 			return ret;
-	virt = ring->virtual_start + ring->tail;
+	virt = ring->buffer->virtual_start + ring->buffer->tail;
 	rem /= 4;
 	while (rem--)
 		iowrite32(MI_NOOP, virt++);
-	ring->tail = 0;
+	ring->buffer->tail = 0;
 	return 0;
@@ -1674,13 +1674,13 @@ static int __intel_ring_prepare(struct intel_engine_cs *ring,
 	int ret;
-	if (unlikely(ring->tail + bytes > ring->effective_size)) {
+	if (unlikely(ring->buffer->tail + bytes > ring->buffer->effective_size)) {
 		ret = intel_wrap_ring_buffer(ring);
 		if (unlikely(ret))
 			return ret;
-	if (unlikely(ring->space < bytes)) {
+	if (unlikely(ring->buffer->space < bytes)) {
 		ret = ring_wait_for_space(ring, bytes);
 		if (unlikely(ret))
 			return ret;
@@ -1709,14 +1709,14 @@ int intel_ring_begin(struct intel_engine_cs *ring,
 	if (ret)
 		return ret;
-	ring->space -= num_dwords * sizeof(uint32_t);
+	ring->buffer->space -= num_dwords * sizeof(uint32_t);
 	return 0;
 /* Align the ring tail to a cacheline boundary */
 int intel_ring_cacheline_align(struct intel_engine_cs *ring)
-	int num_dwords = (ring->tail & (CACHELINE_BYTES - 1)) / sizeof(uint32_t);
+	int num_dwords = (ring->buffer->tail & (CACHELINE_BYTES - 1)) / sizeof(uint32_t);
 	int ret;
 	if (num_dwords == 0)
@@ -2094,13 +2094,13 @@ int intel_render_ring_init_dri(struct drm_device *dev, u64 start, u32 size)
-	ring->size = size;
+	ring->buffer->size = size;
 	if (IS_I830(ring->dev) || IS_845G(ring->dev))
-	ring->virtual_start = ioremap_wc(start, size);
+	ring->buffer->virtual_start = ioremap_wc(start, size);
 			  " ring buffer\n");
 		ret = -ENOMEM;
@@ -2116,7 +2116,7 @@ int intel_render_ring_init_dri(struct drm_device *dev, u64 start, u32 size)
 	return 0;
 err_vstart:
 err_ringbuf:
 	kfree(ringbuf);
 	ring->buffer = NULL;
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.h b/drivers/gpu/drm/i915/intel_ringbuffer.h
index a0ac668..c26def08 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.h
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.h
@@ -91,28 +91,11 @@ struct  intel_engine_cs {
 #define I915_NUM_RINGS 5
 #define LAST_USER_RING (VECS + 1)
 	u32		mmio_base;
-	void		__iomem *virtual_start;
 	struct		drm_device *dev;
-	struct		drm_i915_gem_object *obj;
 	struct intel_ringbuffer *buffer;
-	u32		head;
-	u32		tail;
-	int		space;
-	int		size;
-	int		effective_size;
 	struct intel_hw_status_page status_page;
-	/** We track the position of the requests in the ring buffer, and
-	 * when each is retired we increment last_retired_head as the GPU
-	 * must have finished processing the request and so we know we
-	 * can advance the ringbuffer up to that position.
-	 * last_retired_head is set to -1 after the value is consumed so
-	 * we can detect new retirements.
-	u32		last_retired_head;
 	unsigned irq_refcount; /* protected by dev_priv->irq_lock */
 	u32		irq_enable_mask;	/* bitmask to enable ring interrupt */
 	u32		trace_irq_seqno;
@@ -239,7 +222,7 @@ struct  intel_engine_cs {
 static inline bool
 intel_ring_initialized(struct intel_engine_cs *ring)
-	return ring->buffer && ring->obj;
+	return ring->buffer && ring->buffer->obj;
 static inline unsigned
@@ -310,12 +293,12 @@ int __must_check intel_ring_cacheline_align(struct intel_engine_cs *ring);
 static inline void intel_ring_emit(struct intel_engine_cs *ring,
 				   u32 data)
-	iowrite32(data, ring->virtual_start + ring->tail);
-	ring->tail += 4;
+	iowrite32(data, ring->buffer->virtual_start + ring->buffer->tail);
+	ring->buffer->tail += 4;
 static inline void intel_ring_advance(struct intel_engine_cs *ring)
 void __intel_ring_advance(struct intel_engine_cs *ring);
@@ -335,7 +318,7 @@ void intel_ring_setup_status_page(struct intel_engine_cs *ring);
 static inline u32 intel_ring_get_tail(struct intel_engine_cs *ring)
-	return ring->tail;
+	return ring->buffer->tail;
 static inline u32 intel_ring_get_seqno(struct intel_engine_cs *ring)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
