drm/i915: Rename struct intel_crtc_config to intel_crtc_state
Author: Ander Conselvan de Oliveira <ander.conselvan.de.oliveira@intel.com>
The objective is to make this structure usable with the atomic helpers,
so let's start with the rename. Patch generated with coccinelle:
-struct intel_crtc_config {
+struct intel_crtc_state {
v2: Completely generate the patch with cocci. (Ander)
Signed-off-by: Ander Conselvan de Oliveira
Reviewed-by: Matt Roper
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/i915_drv.h      |   4 +-
 drivers/gpu/drm/i915/intel_crt.c     |   6 +--
 drivers/gpu/drm/i915/intel_ddi.c     |  10 ++--
 drivers/gpu/drm/i915/intel_display.c | 100 +++++++++++++++++------------------
 drivers/gpu/drm/i915/intel_dp.c      |  12 ++---
 drivers/gpu/drm/i915/intel_dp_mst.c  |   4 +-
 drivers/gpu/drm/i915/intel_drv.h     |  28 +++++-----
 drivers/gpu/drm/i915/intel_dsi.c     |   4 +-
 drivers/gpu/drm/i915/intel_dvo.c     |   6 +--
 drivers/gpu/drm/i915/intel_hdmi.c    |   4 +-
 drivers/gpu/drm/i915/intel_lvds.c    |   4 +-
 drivers/gpu/drm/i915/intel_panel.c   |   8 +--
 drivers/gpu/drm/i915/intel_pm.c      |   2 +-
 drivers/gpu/drm/i915/intel_sdvo.c    |   6 +--
 drivers/gpu/drm/i915/intel_tv.c      |   4 +-
 15 files changed, 101 insertions(+), 101 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_drv.h b/drivers/gpu/drm/i915/i915_drv.h
index 2d3355a..a80bd13 100644
--- a/drivers/gpu/drm/i915/i915_drv.h
+++ b/drivers/gpu/drm/i915/i915_drv.h
@@ -499,7 +499,7 @@ struct drm_i915_error_state {
 struct intel_connector;
 struct intel_encoder;
-struct intel_crtc_config;
+struct intel_crtc_state;
 struct intel_plane_config;
 struct intel_crtc;
 struct intel_limit;
@@ -538,7 +538,7 @@ struct drm_i915_display_funcs {
 	/* Returns the active state of the crtc, and if the crtc is active,
 	 * fills out the pipe-config with the hw state. */
 	bool (*get_pipe_config)(struct intel_crtc *,
-				struct intel_crtc_config *);
+				struct intel_crtc_state *);
 	void (*get_plane_config)(struct intel_crtc *,
 				 struct intel_plane_config *);
 	int (*crtc_compute_clock)(struct intel_crtc *crtc);
diff --git a/drivers/gpu/drm/i915/intel_crt.c b/drivers/gpu/drm/i915/intel_crt.c
index a9af9a4..675b85a 100644
--- a/drivers/gpu/drm/i915/intel_crt.c
+++ b/drivers/gpu/drm/i915/intel_crt.c
@@ -110,7 +110,7 @@ static unsigned int intel_crt_get_flags(struct intel_encoder *encoder)
 static void intel_crt_get_config(struct intel_encoder *encoder,
-				 struct intel_crtc_config *pipe_config)
+				 struct intel_crtc_state *pipe_config)
 	struct drm_device *dev = encoder->base.dev;
 	int dotclock;
@@ -126,7 +126,7 @@ static void intel_crt_get_config(struct intel_encoder *encoder,
 static void hsw_crt_get_config(struct intel_encoder *encoder,
 	intel_ddi_get_config(encoder, pipe_config);
@@ -303,7 +303,7 @@ intel_crt_mode_valid(struct drm_connector *connector,
 static bool intel_crt_compute_config(struct intel_encoder *encoder,
diff --git a/drivers/gpu/drm/i915/intel_ddi.c b/drivers/gpu/drm/i915/intel_ddi.c
index 1c92ad4..1cc38eb 100644
--- a/drivers/gpu/drm/i915/intel_ddi.c
+++ b/drivers/gpu/drm/i915/intel_ddi.c
@@ -732,7 +732,7 @@ static int skl_calc_wrpll_link(struct drm_i915_private *dev_priv,
 static void skl_ddi_clock_get(struct intel_encoder *encoder,
 	struct drm_i915_private *dev_priv = encoder->base.dev->dev_private;
 	int link_clock = 0;
@@ -776,7 +776,7 @@ static void skl_ddi_clock_get(struct intel_encoder *encoder,
 static void hsw_ddi_clock_get(struct intel_encoder *encoder,
 	int link_clock = 0;
@@ -832,7 +832,7 @@ static void hsw_ddi_clock_get(struct intel_encoder *encoder,
 void intel_ddi_clock_get(struct intel_encoder *encoder,
@@ -2027,7 +2027,7 @@ static void intel_ddi_hot_plug(struct intel_encoder *intel_encoder)
 void intel_ddi_get_config(struct intel_encoder *encoder,
 	struct intel_crtc *intel_crtc = to_intel_crtc(encoder->base.crtc);
@@ -2120,7 +2120,7 @@ static void intel_ddi_destroy(struct drm_encoder *encoder)
 static bool intel_ddi_compute_config(struct intel_encoder *encoder,
 	int type = encoder->type;
 	int port = intel_ddi_get_encoder_port(encoder);
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index cc3b9d8..536a66a 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -76,9 +76,9 @@ static const uint32_t intel_cursor_formats[] = {
 static void intel_crtc_update_cursor(struct drm_crtc *crtc, bool on);
 static void i9xx_crtc_clock_get(struct intel_crtc *crtc,
-				struct intel_crtc_config *pipe_config);
+				struct intel_crtc_state *pipe_config);
 static void ironlake_pch_clock_get(struct intel_crtc *crtc,
 static int intel_set_mode(struct drm_crtc *crtc, struct drm_display_mode *mode,
 			  int x, int y, struct drm_framebuffer *old_fb);
@@ -95,9 +95,9 @@ static void ironlake_set_pipeconf(struct drm_crtc *crtc);
 static void haswell_set_pipeconf(struct drm_crtc *crtc);
 static void intel_set_pipe_csc(struct drm_crtc *crtc);
 static void vlv_prepare_pll(struct intel_crtc *crtc,
-			    const struct intel_crtc_config *pipe_config);
+			    const struct intel_crtc_state *pipe_config);
 static void chv_prepare_pll(struct intel_crtc *crtc,
 static void intel_begin_crtc_commit(struct drm_crtc *crtc);
 static void intel_finish_crtc_commit(struct drm_crtc *crtc);
@@ -1507,7 +1507,7 @@ static void intel_init_dpio(struct drm_device *dev)
 static void vlv_enable_pll(struct intel_crtc *crtc,
 	struct drm_device *dev = crtc->base.dev;
 	struct drm_i915_private *dev_priv = dev->dev_private;
@@ -1546,7 +1546,7 @@ static void vlv_enable_pll(struct intel_crtc *crtc,
 static void chv_enable_pll(struct intel_crtc *crtc,
@@ -4602,7 +4602,7 @@ static void i9xx_pfit_enable(struct intel_crtc *crtc)
-	struct intel_crtc_config *pipe_config = &crtc->config;
+	struct intel_crtc_state *pipe_config = &crtc->config;
 	if (!crtc->config.gmch_pfit.control)
 		return;
@@ -5367,7 +5367,7 @@ bool intel_connector_get_hw_state(struct intel_connector *connector)
 static bool ironlake_check_fdi_lanes(struct drm_device *dev, enum pipe pipe,
 	struct intel_crtc *pipe_B_crtc =
@@ -5426,7 +5426,7 @@ static bool ironlake_check_fdi_lanes(struct drm_device *dev, enum pipe pipe,
 #define RETRY 1
 static int ironlake_fdi_compute_config(struct intel_crtc *intel_crtc,
 	struct drm_device *dev = intel_crtc->base.dev;
 	struct drm_display_mode *adjusted_mode = &pipe_config->adjusted_mode;
@@ -5472,7 +5472,7 @@ retry:
 static void hsw_compute_ips_config(struct intel_crtc *crtc,
 	pipe_config->ips_enabled = i915.enable_ips &&
 				   hsw_crtc_supports_ips(crtc) &&
@@ -5480,7 +5480,7 @@ static void hsw_compute_ips_config(struct intel_crtc *crtc,
 static int intel_crtc_compute_config(struct intel_crtc *crtc,
@@ -5842,7 +5842,7 @@ void intel_dp_set_m_n(struct intel_crtc *crtc)
 static void vlv_update_pll(struct intel_crtc *crtc,
 	u32 dpll, dpll_md;
@@ -5865,7 +5865,7 @@ static void vlv_update_pll(struct intel_crtc *crtc,
@@ -5956,7 +5956,7 @@ static void vlv_prepare_pll(struct intel_crtc *crtc,
 static void chv_update_pll(struct intel_crtc *crtc,
 	pipe_config->dpll_hw_state.dpll = DPLL_SSC_REF_CLOCK_CHV |
 		DPLL_REFA_CLK_ENABLE_VLV | DPLL_VGA_MODE_DIS |
@@ -5969,7 +5969,7 @@ static void chv_update_pll(struct intel_crtc *crtc,
@@ -6054,7 +6054,7 @@ void vlv_force_pll_on(struct drm_device *dev, enum pipe pipe,
 	struct intel_crtc *crtc =
 		to_intel_crtc(intel_get_crtc_for_pipe(dev, pipe));
-	struct intel_crtc_config pipe_config = {
+	struct intel_crtc_state pipe_config = {
 		.pixel_multiplier = 1,
 		.dpll = *dpll,
@@ -6269,7 +6269,7 @@ static void intel_set_pipe_timings(struct intel_crtc *intel_crtc)
 static void intel_get_pipe_timings(struct intel_crtc *crtc,
@@ -6311,7 +6311,7 @@ static void intel_get_pipe_timings(struct intel_crtc *crtc,
 void intel_mode_from_pipe_config(struct drm_display_mode *mode,
 	mode->hdisplay = pipe_config->adjusted_mode.crtc_hdisplay;
 	mode->htotal = pipe_config->adjusted_mode.crtc_htotal;
@@ -6481,7 +6481,7 @@ static int i9xx_crtc_compute_clock(struct intel_crtc *crtc)
 static void i9xx_get_pfit_config(struct intel_crtc *crtc,
@@ -6511,7 +6511,7 @@ static void i9xx_get_pfit_config(struct intel_crtc *crtc,
 static void vlv_crtc_clock_get(struct intel_crtc *crtc,
@@ -6602,7 +6602,7 @@ static void i9xx_get_plane_config(struct intel_crtc *crtc,
 static void chv_crtc_clock_get(struct intel_crtc *crtc,
@@ -6632,7 +6632,7 @@ static void chv_crtc_clock_get(struct intel_crtc *crtc,
 static bool i9xx_get_pipe_config(struct intel_crtc *crtc,
@@ -7534,7 +7534,7 @@ static void intel_cpu_transcoder_get_m_n(struct intel_crtc *crtc,
 void intel_dp_get_m_n(struct intel_crtc *crtc,
 	if (crtc->config.has_pch_encoder)
 		intel_pch_transcoder_get_m_n(crtc, &pipe_config->dp_m_n);
@@ -7545,14 +7545,14 @@ void intel_dp_get_m_n(struct intel_crtc *crtc,
 static void ironlake_get_fdi_m_n_config(struct intel_crtc *crtc,
 	intel_cpu_transcoder_get_m_n(crtc, pipe_config->cpu_transcoder,
 				     &pipe_config->fdi_m_n, NULL);
 static void skylake_get_pfit_config(struct intel_crtc *crtc,
@@ -7568,7 +7568,7 @@ static void skylake_get_pfit_config(struct intel_crtc *crtc,
 static void ironlake_get_pfit_config(struct intel_crtc *crtc,
@@ -7652,7 +7652,7 @@ static void ironlake_get_plane_config(struct intel_crtc *crtc,
 static bool ironlake_get_pipe_config(struct intel_crtc *crtc,
@@ -7982,7 +7982,7 @@ static int haswell_crtc_compute_clock(struct intel_crtc *crtc)
 static void skylake_get_ddi_pll(struct drm_i915_private *dev_priv,
 				enum port port,
 	u32 temp, dpll_ctl1;
@@ -8013,7 +8013,7 @@ static void skylake_get_ddi_pll(struct drm_i915_private *dev_priv,
 static void haswell_get_ddi_pll(struct drm_i915_private *dev_priv,
 				enum port port,
 	pipe_config->ddi_pll_sel = I915_READ(PORT_CLK_SEL(port));
@@ -8028,7 +8028,7 @@ static void haswell_get_ddi_pll(struct drm_i915_private *dev_priv,
 static void haswell_get_ddi_port_state(struct intel_crtc *crtc,
@@ -8070,7 +8070,7 @@ static void haswell_get_ddi_port_state(struct intel_crtc *crtc,
 static bool haswell_get_pipe_config(struct intel_crtc *crtc,
@@ -8652,7 +8652,7 @@ void intel_release_load_detect_pipe(struct drm_connector *connector,
 static int i9xx_pll_refclk(struct drm_device *dev,
 	u32 dpll = pipe_config->dpll_hw_state.dpll;
@@ -8669,7 +8669,7 @@ static int i9xx_pll_refclk(struct drm_device *dev,
 /* Returns the clock of the currently programmed mode of the given pipe. */
@@ -8776,7 +8776,7 @@ int intel_dotclock_calculate(int link_freq,
@@ -8802,7 +8802,7 @@ struct drm_display_mode *intel_crtc_mode_get(struct drm_device *dev,
 	struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
 	enum transcoder cpu_transcoder = intel_crtc->config.cpu_transcoder;
 	struct drm_display_mode *mode;
-	struct intel_crtc_config pipe_config;
+	struct intel_crtc_state pipe_config;
 	int htot = I915_READ(HTOTAL(cpu_transcoder));
 	int hsync = I915_READ(HSYNC(cpu_transcoder));
 	int vtot = I915_READ(VTOTAL(cpu_transcoder));
@@ -9851,7 +9851,7 @@ static void intel_modeset_commit_output_state(struct drm_device *dev)
 static void
 connected_sink_compute_bpp(struct intel_connector *connector,
 	int bpp = pipe_config->pipe_bpp;
@@ -9878,7 +9878,7 @@ connected_sink_compute_bpp(struct intel_connector *connector,
 static int
 compute_baseline_pipe_bpp(struct intel_crtc *crtc,
 			  struct drm_framebuffer *fb,
 	struct intel_connector *connector;
@@ -9947,7 +9947,7 @@ static void intel_dump_crtc_timings(const struct drm_display_mode *mode)
 static void intel_dump_pipe_config(struct intel_crtc *crtc,
-				   struct intel_crtc_config *pipe_config,
+				   struct intel_crtc_state *pipe_config,
 				   const char *context)
 	DRM_DEBUG_KMS("[CRTC:%d]%s config for pipe %c\n", crtc->base.base.id,
@@ -10083,14 +10083,14 @@ static bool check_digital_port_conflicts(struct drm_device *dev)
 	return true;
-static struct intel_crtc_config *
+static struct intel_crtc_state *
 intel_modeset_pipe_config(struct drm_crtc *crtc,
 	struct drm_device *dev = crtc->dev;
 	struct intel_encoder *encoder;
-	struct intel_crtc_config *pipe_config;
+	struct intel_crtc_state *pipe_config;
 	int plane_bpp, ret = -EINVAL;
 	bool retry = true;
@@ -10384,8 +10384,8 @@ static bool intel_fuzzy_clock_check(int clock1, int clock2)
 static bool
 intel_pipe_config_compare(struct drm_device *dev,
-			  struct intel_crtc_config *current_config,
+			  struct intel_crtc_state *current_config,
 #define PIPE_CONF_CHECK_X(name)	\
 	if (current_config->name != pipe_config->name) { \
@@ -10709,7 +10709,7 @@ check_crtc_state(struct drm_device *dev)
 	struct intel_crtc *crtc;
 	for_each_intel_crtc(dev, crtc) {
 		bool enabled = false;
@@ -10828,7 +10828,7 @@ intel_modeset_check_state(struct drm_device *dev)
 	check_shared_dpll_state(dev);
-void ironlake_check_encoder_dotclock(const struct intel_crtc_config *pipe_config,
+void ironlake_check_encoder_dotclock(const struct intel_crtc_state *pipe_config,
 				     int dotclock)
@@ -10878,7 +10878,7 @@ static void update_scanline_offset(struct intel_crtc *crtc)
 		crtc->scanline_offset = 1;
 intel_modeset_compute_config(struct drm_crtc *crtc,
@@ -10886,7 +10886,7 @@ intel_modeset_compute_config(struct drm_crtc *crtc,
 			     unsigned *prepare_pipes,
 			     unsigned *disable_pipes)
-	struct intel_crtc_config *pipe_config = NULL;
+	struct intel_crtc_state *pipe_config = NULL;
 	intel_modeset_affected_pipes(crtc, modeset_pipes,
 				     prepare_pipes, disable_pipes);
@@ -10914,7 +10914,7 @@ out:
 static int __intel_set_mode(struct drm_crtc *crtc,
 			    int x, int y, struct drm_framebuffer *fb,
 			    unsigned modeset_pipes,
 			    unsigned prepare_pipes,
 			    unsigned disable_pipes)
@@ -11036,7 +11036,7 @@ done:
 static int intel_set_mode_pipes(struct drm_crtc *crtc,
@@ -11056,7 +11056,7 @@ static int intel_set_mode(struct drm_crtc *crtc,
 			  int x, int y, struct drm_framebuffer *fb)
 	unsigned modeset_pipes, prepare_pipes, disable_pipes;
 	pipe_config = intel_modeset_compute_config(crtc, mode, fb,
@@ -11400,7 +11400,7 @@ static int intel_crtc_set_config(struct drm_mode_set *set)
 	struct drm_device *dev;
 	struct drm_mode_set save_set;
 	struct intel_set_config *config;
 	int ret;
diff --git a/drivers/gpu/drm/i915/intel_dp.c b/drivers/gpu/drm/i915/intel_dp.c
index 003437d..28ba283 100644
--- a/drivers/gpu/drm/i915/intel_dp.c
+++ b/drivers/gpu/drm/i915/intel_dp.c
@@ -1074,7 +1074,7 @@ intel_dp_connector_unregister(struct intel_connector *intel_connector)
 static void
-skl_edp_set_pll_config(struct intel_crtc_config *pipe_config, int link_bw)
+skl_edp_set_pll_config(struct intel_crtc_state *pipe_config, int link_bw)
 	u32 ctrl1;
@@ -1101,7 +1101,7 @@ skl_edp_set_pll_config(struct intel_crtc_config *pipe_config, int link_bw)
 static void
-hsw_dp_set_ddi_pll_sel(struct intel_crtc_config *pipe_config, int link_bw)
+hsw_dp_set_ddi_pll_sel(struct intel_crtc_state *pipe_config, int link_bw)
 	switch (link_bw) {
 	case DP_LINK_BW_1_62:
@@ -1118,7 +1118,7 @@ hsw_dp_set_ddi_pll_sel(struct intel_crtc_config *pipe_config, int link_bw)
 static void
 intel_dp_set_clock(struct intel_encoder *encoder,
-		   struct intel_crtc_config *pipe_config, int link_bw)
+		   struct intel_crtc_state *pipe_config, int link_bw)
 	const struct dp_link_dpll *divisor = NULL;
@@ -1151,7 +1151,7 @@ intel_dp_set_clock(struct intel_encoder *encoder,
 bool
 intel_dp_compute_config(struct intel_encoder *encoder,
@@ -2013,7 +2013,7 @@ static bool intel_dp_get_hw_state(struct intel_encoder *encoder,
 static void intel_dp_get_config(struct intel_encoder *encoder,
 	struct intel_dp *intel_dp = enc_to_intel_dp(&encoder->base);
 	u32 tmp, flags = 0;
@@ -4751,7 +4751,7 @@ static void intel_dp_set_drrs_state(struct drm_device *dev, int refresh_rate)
 	struct intel_digital_port *dig_port = NULL;
 	struct intel_dp *intel_dp = dev_priv->drrs.dp;
-	struct intel_crtc_config *config = NULL;
+	struct intel_crtc_state *config = NULL;
 	struct intel_crtc *intel_crtc = NULL;
 	u32 reg, val;
 	enum drrs_refresh_rate_type index = DRRS_HIGH_RR;
diff --git a/drivers/gpu/drm/i915/intel_dp_mst.c b/drivers/gpu/drm/i915/intel_dp_mst.c
index 7f8c6a6..2e8951a 100644
--- a/drivers/gpu/drm/i915/intel_dp_mst.c
+++ b/drivers/gpu/drm/i915/intel_dp_mst.c
@@ -30,7 +30,7 @@
 #include <drm/drm_edid.h>
 static bool intel_dp_mst_compute_config(struct intel_encoder *encoder,
 	struct intel_dp_mst_encoder *intel_mst = enc_to_mst(&encoder->base);
 	struct intel_digital_port *intel_dig_port = intel_mst->primary;
@@ -216,7 +216,7 @@ static bool intel_dp_mst_enc_get_hw_state(struct intel_encoder *encoder,
 static void intel_dp_mst_enc_get_config(struct intel_encoder *encoder,
diff --git a/drivers/gpu/drm/i915/intel_drv.h b/drivers/gpu/drm/i915/intel_drv.h
index bd4d514..9ecac55 100644
--- a/drivers/gpu/drm/i915/intel_drv.h
+++ b/drivers/gpu/drm/i915/intel_drv.h
@@ -143,7 +143,7 @@ struct intel_encoder {
 	bool connectors_active;
 	void (*hot_plug)(struct intel_encoder *);
 	bool (*compute_config)(struct intel_encoder *,
 	void (*pre_pll_enable)(struct intel_encoder *);
 	void (*pre_enable)(struct intel_encoder *);
 	void (*enable)(struct intel_encoder *);
@@ -159,7 +159,7 @@ struct intel_encoder {
 	 * pre-filled the pipe config. Note that intel_encoder->base.crtc must
 	 * be set correctly before calling this function. */
 	void (*get_config)(struct intel_encoder *,
 	 * Called during system suspend after all pending requests for the
 	 * encoder are flushed (for example for DP AUX transactions) and
@@ -263,7 +263,7 @@ struct intel_plane_config {
 	u32 base;
 	 * quirks - bitfield with hw state readout quirks
@@ -477,8 +477,8 @@ struct intel_crtc {
 	uint32_t cursor_base;
 	struct intel_plane_config plane_config;
-	struct intel_crtc_config config;
-	struct intel_crtc_config *new_config;
+	struct intel_crtc_state config;
+	struct intel_crtc_state *new_config;
 	bool new_enabled;
 	/* reset counter value when the last flip was submitted */
@@ -845,11 +845,11 @@ void intel_ddi_prepare_link_retrain(struct drm_encoder *encoder);
 bool intel_ddi_connector_get_hw_state(struct intel_connector *intel_connector);
 void intel_ddi_fdi_disable(struct drm_crtc *crtc);
 void intel_ddi_init_dp_buf_reg(struct intel_encoder *encoder);
 void intel_ddi_set_vc_payload_alloc(struct drm_crtc *crtc, bool state);
 /* intel_frontbuffer.c */
@@ -982,11 +982,11 @@ void intel_finish_reset(struct drm_device *dev);
 void hsw_enable_pc8(struct drm_i915_private *dev_priv);
 void hsw_disable_pc8(struct drm_i915_private *dev_priv);
 void intel_dp_set_m_n(struct intel_crtc *crtc);
 int intel_dotclock_calculate(int link_freq, const struct intel_link_m_n *m_n);
 void
-ironlake_check_encoder_dotclock(const struct intel_crtc_config *pipe_config,
+ironlake_check_encoder_dotclock(const struct intel_crtc_state *pipe_config,
 				int dotclock);
 bool intel_crtc_active(struct drm_crtc *crtc);
 void hsw_enable_ips(struct intel_crtc *crtc);
@@ -994,7 +994,7 @@ void hsw_disable_ips(struct intel_crtc *crtc);
 enum intel_display_power_domain
 intel_display_port_power_domain(struct intel_encoder *intel_encoder);
 int intel_format_to_fourcc(int format);
 void intel_crtc_wait_for_pending_flips(struct drm_crtc *crtc);
 void intel_modeset_preclose(struct drm_device *dev, struct drm_file *file);
@@ -1011,7 +1011,7 @@ void intel_dp_encoder_destroy(struct drm_encoder *encoder);
 void intel_dp_check_link_status(struct intel_dp *intel_dp);
 int intel_dp_sink_crc(struct intel_dp *intel_dp, u8 *crc);
 bool intel_dp_compute_config(struct intel_encoder *encoder,
 bool intel_dp_is_edp(struct drm_device *dev, enum port port);
 bool intel_dp_hpd_pulse(struct intel_digital_port *intel_dig_port,
 			bool long_hpd);
@@ -1091,7 +1091,7 @@ void intel_hdmi_init_connector(struct intel_digital_port *intel_dig_port,
 struct intel_hdmi *enc_to_intel_hdmi(struct drm_encoder *encoder);
 bool intel_hdmi_compute_config(struct intel_encoder *encoder,
 /* intel_lvds.c */
@@ -1126,10 +1126,10 @@ void intel_panel_fini(struct intel_panel *panel);
 void intel_fixed_panel_mode(const struct drm_display_mode *fixed_mode,
 			    struct drm_display_mode *adjusted_mode);
 void intel_pch_panel_fitting(struct intel_crtc *crtc,
 			     int fitting_mode);
 void intel_gmch_panel_fitting(struct intel_crtc *crtc,
 			      int fitting_mode);
 void intel_panel_set_backlight_acpi(struct intel_connector *connector,
 				    u32 level, u32 max);
diff --git a/drivers/gpu/drm/i915/intel_dsi.c b/drivers/gpu/drm/i915/intel_dsi.c
index 42b6d6f..ac49daa 100644
--- a/drivers/gpu/drm/i915/intel_dsi.c
+++ b/drivers/gpu/drm/i915/intel_dsi.c
@@ -78,7 +78,7 @@ static void intel_dsi_hot_plug(struct intel_encoder *encoder)
 static bool intel_dsi_compute_config(struct intel_encoder *encoder,
-				     struct intel_crtc_config *config)
+				     struct intel_crtc_state *config)
 	struct intel_dsi *intel_dsi = container_of(encoder, struct intel_dsi,
 						   base);
@@ -437,7 +437,7 @@ static bool intel_dsi_get_hw_state(struct intel_encoder *encoder,
 static void intel_dsi_get_config(struct intel_encoder *encoder,
 	u32 pclk;
 	DRM_DEBUG_KMS("\n");
diff --git a/drivers/gpu/drm/i915/intel_dvo.c b/drivers/gpu/drm/i915/intel_dvo.c
index e40e3df..34bee56 100644
--- a/drivers/gpu/drm/i915/intel_dvo.c
+++ b/drivers/gpu/drm/i915/intel_dvo.c
@@ -144,7 +144,7 @@ static bool intel_dvo_get_hw_state(struct intel_encoder *encoder,
 static void intel_dvo_get_config(struct intel_encoder *encoder,
 	struct intel_dvo *intel_dvo = enc_to_dvo(encoder);
@@ -200,7 +200,7 @@ static void intel_dvo_dpms(struct drm_connector *connector, int mode)
 	struct intel_dvo *intel_dvo = intel_attached_dvo(connector);
 	struct drm_crtc *crtc;
-	struct intel_crtc_config *config;
+	struct intel_crtc_state *config;
 	/* dvo supports only 2 dpms states. */
 	if (mode != DRM_MODE_DPMS_ON)
@@ -261,7 +261,7 @@ intel_dvo_mode_valid(struct drm_connector *connector,
 static bool intel_dvo_compute_config(struct intel_encoder *encoder,
diff --git a/drivers/gpu/drm/i915/intel_hdmi.c b/drivers/gpu/drm/i915/intel_hdmi.c
index 3abc200..657452b 100644
--- a/drivers/gpu/drm/i915/intel_hdmi.c
+++ b/drivers/gpu/drm/i915/intel_hdmi.c
@@ -759,7 +759,7 @@ static bool intel_hdmi_get_hw_state(struct intel_encoder *encoder,
 static void intel_hdmi_get_config(struct intel_encoder *encoder,
 	struct intel_hdmi *intel_hdmi = enc_to_intel_hdmi(&encoder->base);
@@ -975,7 +975,7 @@ static bool hdmi_12bpc_possible(struct intel_crtc *crtc)
diff --git a/drivers/gpu/drm/i915/intel_lvds.c b/drivers/gpu/drm/i915/intel_lvds.c
index 14654d6..f8e2f13 100644
--- a/drivers/gpu/drm/i915/intel_lvds.c
+++ b/drivers/gpu/drm/i915/intel_lvds.c
@@ -93,7 +93,7 @@ static bool intel_lvds_get_hw_state(struct intel_encoder *encoder,
 static void intel_lvds_get_config(struct intel_encoder *encoder,
@@ -277,7 +277,7 @@ intel_lvds_mode_valid(struct drm_connector *connector,
 static bool intel_lvds_compute_config(struct intel_encoder *intel_encoder,
 	struct drm_device *dev = intel_encoder->base.dev;
 	struct intel_lvds_encoder *lvds_encoder =
diff --git a/drivers/gpu/drm/i915/intel_panel.c b/drivers/gpu/drm/i915/intel_panel.c
index 4d63839..c3c5ed4 100644
--- a/drivers/gpu/drm/i915/intel_panel.c
+++ b/drivers/gpu/drm/i915/intel_panel.c
@@ -98,7 +98,7 @@ intel_find_panel_downclock(struct drm_device *dev,
 /* adjusted_mode has been preset to be the panel's fixed mode */
 void
 intel_pch_panel_fitting(struct intel_crtc *intel_crtc,
 			int fitting_mode)
 	struct drm_display_mode *adjusted_mode;
@@ -223,7 +223,7 @@ static inline u32 panel_fitter_scaling(u32 source, u32 target)
 	return (FACTOR * ratio + FACTOR/2) / FACTOR;
-static void i965_scale_aspect(struct intel_crtc_config *pipe_config,
+static void i965_scale_aspect(struct intel_crtc_state *pipe_config,
 			      u32 *pfit_control)
@@ -243,7 +243,7 @@ static void i965_scale_aspect(struct intel_crtc_config *pipe_config,
 		*pfit_control |= PFIT_ENABLE | PFIT_SCALING_AUTO;
-static void i9xx_scale_aspect(struct intel_crtc_config *pipe_config,
+static void i9xx_scale_aspect(struct intel_crtc_state *pipe_config,
 			      u32 *pfit_control, u32 *pfit_pgm_ratios,
 			      u32 *border)
@@ -301,7 +301,7 @@ static void i9xx_scale_aspect(struct intel_crtc_config *pipe_config,
 void intel_gmch_panel_fitting(struct intel_crtc *intel_crtc,
 			      int fitting_mode)
diff --git a/drivers/gpu/drm/i915/intel_pm.c b/drivers/gpu/drm/i915/intel_pm.c
index 8ee65da..933b32c 100644
--- a/drivers/gpu/drm/i915/intel_pm.c
+++ b/drivers/gpu/drm/i915/intel_pm.c
@@ -2556,7 +2556,7 @@ skl_allocate_pipe_ddb(struct drm_crtc *crtc,
-static uint32_t skl_pipe_pixel_rate(const struct intel_crtc_config *config)
+static uint32_t skl_pipe_pixel_rate(const struct intel_crtc_state *config)
 	/* TODO: Take into account the scalers once we support them */
 	return config->adjusted_mode.crtc_clock;
diff --git a/drivers/gpu/drm/i915/intel_sdvo.c b/drivers/gpu/drm/i915/intel_sdvo.c
index 4e3d362..cced048 100644
--- a/drivers/gpu/drm/i915/intel_sdvo.c
+++ b/drivers/gpu/drm/i915/intel_sdvo.c
@@ -1085,7 +1085,7 @@ intel_sdvo_get_preferred_input_mode(struct intel_sdvo *intel_sdvo,
 	return true;
-static void i9xx_adjust_sdvo_tv_clock(struct intel_crtc_config *pipe_config)
+static void i9xx_adjust_sdvo_tv_clock(struct intel_crtc_state *pipe_config)
 	unsigned dotclock = pipe_config->port_clock;
 	struct dpll *clock = &pipe_config->dpll;
@@ -1112,7 +1112,7 @@ static void i9xx_adjust_sdvo_tv_clock(struct intel_crtc_config *pipe_config)
 static bool intel_sdvo_compute_config(struct intel_encoder *encoder,
 	struct intel_sdvo *intel_sdvo = to_sdvo(encoder);
@@ -1338,7 +1338,7 @@ static bool intel_sdvo_get_hw_state(struct intel_encoder *encoder,
 static void intel_sdvo_get_config(struct intel_encoder *encoder,
diff --git a/drivers/gpu/drm/i915/intel_tv.c b/drivers/gpu/drm/i915/intel_tv.c
index 6f5f59b..1a57236 100644
--- a/drivers/gpu/drm/i915/intel_tv.c
+++ b/drivers/gpu/drm/i915/intel_tv.c
@@ -908,14 +908,14 @@ intel_tv_mode_valid(struct drm_connector *connector,
 static void
 intel_tv_get_config(struct intel_encoder *encoder,
 	pipe_config->adjusted_mode.crtc_clock = pipe_config->port_clock;
 static bool
 intel_tv_compute_config(struct intel_encoder *encoder,
 	struct intel_tv *intel_tv = enc_to_tv(encoder);
 	const struct tv_mode *tv_mode = intel_tv_mode_find(intel_tv);
BtrLinux
Privacy Overview
