drm/i915: Rename local struct intel_engine_cs variables
Author: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Done by the Coccinelle script below plus a manual
intervention to GEN8_RING_SEMAPHORE_INIT.
expression E;
- struct intel_engine_cs *ring = E;
+ struct intel_engine_cs *engine = E;
- ring
+ engine
- struct intel_engine_cs *ring;
+ struct intel_engine_cs *engine;
- ring
+ engine
Signed-off-by: Tvrtko Ursulin
Reviewed-by: Chris Wilson
 drivers/gpu/drm/i915/i915_debugfs.c        | 203 ++++----
 drivers/gpu/drm/i915/i915_gem.c            | 136 ++---
 drivers/gpu/drm/i915/i915_gem_context.c    | 140 ++---
 drivers/gpu/drm/i915/i915_gem_debug.c      |  15 +-
 drivers/gpu/drm/i915/i915_gem_execbuffer.c |  74 +--
 drivers/gpu/drm/i915/i915_gem_gtt.c        |  90 ++--
 drivers/gpu/drm/i915/i915_gpu_error.c      |  35 +-
 drivers/gpu/drm/i915/i915_guc_submission.c |  30 +-
 drivers/gpu/drm/i915/i915_irq.c            |  84 +--
 drivers/gpu/drm/i915/intel_display.c       | 106 ++--
 drivers/gpu/drm/i915/intel_guc_loader.c    |  12 +-
 drivers/gpu/drm/i915/intel_lrc.c           | 216 ++++----
 drivers/gpu/drm/i915/intel_mocs.c          |   4 +-
 drivers/gpu/drm/i915/intel_overlay.c       |  60 +--
 drivers/gpu/drm/i915/intel_pm.c            |  36 +-
 drivers/gpu/drm/i915/intel_ringbuffer.c    | 785 +++++++++++++++--------------
 drivers/gpu/drm/i915/intel_ringbuffer.h    |  14 +-
 17 files changed, 1035 insertions(+), 1005 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_debugfs.c b/drivers/gpu/drm/i915/i915_debugfs.c
index 15aacd0..5037ccb 100644
--- a/drivers/gpu/drm/i915/i915_debugfs.c
+++ b/drivers/gpu/drm/i915/i915_debugfs.c
@@ -129,7 +129,7 @@ static void
 describe_obj(struct seq_file *m, struct drm_i915_gem_object *obj)
 	struct drm_i915_private *dev_priv = to_i915(obj->base.dev);
 	struct i915_vma *vma;
 	int pin_count = 0;
 	int i;
@@ -143,7 +143,7 @@ describe_obj(struct seq_file *m, struct drm_i915_gem_object *obj)
 		   obj->base.size / 1024,
 		   obj->base.read_domains,
 		   obj->base.write_domain);
-	for_each_ring(ring, dev_priv, i)
+	for_each_ring(engine, dev_priv, i)
 		seq_printf(m, "%x ",
 				i915_gem_request_get_seqno(obj->last_read_req[i]));
 	seq_printf(m, "] %x %x%s%s%s",
@@ -397,15 +397,15 @@ static void print_batch_pool_stats(struct seq_file *m,
 	struct drm_i915_gem_object *obj;
 	struct file_stats stats;
 	int i, j;
 	memset(&stats, 0, sizeof(stats));
-	for_each_ring(ring, dev_priv, i) {
-		for (j = 0; j < ARRAY_SIZE(ring->batch_pool.cache_list); j++) {
+	for_each_ring(engine, dev_priv, i) {
+		for (j = 0; j < ARRAY_SIZE(engine->batch_pool.cache_list); j++) {
 			list_for_each_entry(obj,
-					    &ring->batch_pool.cache_list[j],
+					    &engine->batch_pool.cache_list[j],
 					    batch_pool_link)
 				per_file_stats(0, obj, &stats);
@@ -591,14 +591,13 @@ static int i915_gem_pageflip_info(struct seq_file *m, void *data)
 					   pipe, plane);
 			if (work->flip_queued_req) {
-					i915_gem_request_get_ring(work->flip_queued_req);
+				struct intel_engine_cs *engine = i915_gem_request_get_ring(work->flip_queued_req);
 				seq_printf(m, "Flip queued on %s at seqno %x, next seqno %x [current breadcrumb %x], completed? %d\n",
-					   ring->name,
+					   engine->name,
 					   i915_gem_request_get_seqno(work->flip_queued_req),
 					   dev_priv->next_seqno,
-					   ring->get_seqno(ring, true),
+					   engine->get_seqno(engine, true),
 					   i915_gem_request_completed(work->flip_queued_req, true));
 			} else
 				seq_printf(m, "Flip not associated with any ring\n");
@@ -637,7 +636,7 @@ static int i915_gem_batch_pool_info(struct seq_file *m, void *data)
 	struct drm_device *dev = node->minor->dev;
 	struct drm_i915_private *dev_priv = dev->dev_private;
 	int total = 0;
 	int ret, i, j;
@@ -645,20 +644,20 @@ static int i915_gem_batch_pool_info(struct seq_file *m, void *data)
 	if (ret)
 		return ret;
 			int count;
 			count = 0;
 					    batch_pool_link)
 				count++;
 			seq_printf(m, "%s cache[%d]: %d objects\n",
-				   ring->name, j, count);
+				   engine->name, j, count);
 					    batch_pool_link) {
 				seq_puts(m, "   ");
 				describe_obj(m, obj);
@@ -681,7 +680,7 @@ static int i915_gem_request_info(struct seq_file *m, void *data)
 	struct drm_info_node *node = m->private;
 	struct drm_i915_gem_request *req;
 	int ret, any, i;
@@ -690,17 +689,17 @@ static int i915_gem_request_info(struct seq_file *m, void *data)
 		return ret;
 	any = 0;
 		int count;
 		count = 0;
-		list_for_each_entry(req, &ring->request_list, list)
+		list_for_each_entry(req, &engine->request_list, list)
 			count++;
 		if (count == 0)
 			continue;
-		seq_printf(m, "%s requests: %d\n", ring->name, count);
-		list_for_each_entry(req, &ring->request_list, list) {
+		seq_printf(m, "%s requests: %d\n", engine->name, count);
+		list_for_each_entry(req, &engine->request_list, list) {
 			struct task_struct *task;
 			rcu_read_lock();
@@ -739,7 +738,7 @@ static int i915_gem_seqno_info(struct seq_file *m, void *data)
 	int ret, i;
 	ret = mutex_lock_interruptible(&dev->struct_mutex);
@@ -747,8 +746,8 @@ static int i915_gem_seqno_info(struct seq_file *m, void *data)
 		return ret;
 	intel_runtime_pm_get(dev_priv);
-		i915_ring_seqno_info(m, ring);
+		i915_ring_seqno_info(m, engine);
 	intel_runtime_pm_put(dev_priv);
 	mutex_unlock(&dev->struct_mutex);
@@ -762,7 +761,7 @@ static int i915_interrupt_info(struct seq_file *m, void *data)
 	int ret, i, pipe;
@@ -934,13 +933,13 @@ static int i915_interrupt_info(struct seq_file *m, void *data)
 		seq_printf(m, "Graphics Interrupt mask:		%08x\n",
 			   I915_READ(GTIMR));
 		if (INTEL_INFO(dev)->gen >= 6) {
 			seq_printf(m,
 				   "Graphics Interrupt mask (%s):	%08x\n",
-				   ring->name, I915_READ_IMR(ring));
+				   engine->name, I915_READ_IMR(engine));
@@ -981,12 +980,12 @@ static int i915_hws_info(struct seq_file *m, void *data)
 	const u32 *hws;
 	int i;
-	ring = &dev_priv->ring[(uintptr_t)node->info_ent->data];
-	hws = ring->status_page.page_addr;
+	engine = &dev_priv->ring[(uintptr_t)node->info_ent->data];
+	hws = engine->status_page.page_addr;
 	if (hws == NULL)
 		return 0;
@@ -1331,7 +1330,7 @@ static int i915_hangcheck_info(struct seq_file *m, void *unused)
 	u64 acthd[I915_NUM_RINGS];
 	u32 seqno[I915_NUM_RINGS];
 	u32 instdone[I915_NUM_INSTDONE_REG];
@@ -1344,9 +1343,9 @@ static int i915_hangcheck_info(struct seq_file *m, void *unused)
-		seqno[i] = ring->get_seqno(ring, false);
-		acthd[i] = intel_ring_get_active_head(ring);
+		seqno[i] = engine->get_seqno(engine, false);
+		acthd[i] = intel_ring_get_active_head(engine);
 	i915_get_extra_instdone(dev, instdone);
@@ -1360,17 +1359,17 @@ static int i915_hangcheck_info(struct seq_file *m, void *unused)
 	} else
 		seq_printf(m, "Hangcheck inactive\n");
-		seq_printf(m, "%s:\n", ring->name);
+		seq_printf(m, "%s:\n", engine->name);
 		seq_printf(m, "\tseqno = %x [current %x]\n",
-			   ring->hangcheck.seqno, seqno[i]);
+			   engine->hangcheck.seqno, seqno[i]);
 		seq_printf(m, "\tACTHD = 0x%08llx [current 0x%08llx]\n",
-			   (long long)ring->hangcheck.acthd,
+			   (long long)engine->hangcheck.acthd,
 			   (long long)acthd[i]);
-		seq_printf(m, "\tscore = %d\n", ring->hangcheck.score);
-		seq_printf(m, "\taction = %d\n", ring->hangcheck.action);
+		seq_printf(m, "\tscore = %d\n", engine->hangcheck.score);
+		seq_printf(m, "\taction = %d\n", engine->hangcheck.action);
-		if (ring->id == RCS) {
+		if (engine->id == RCS) {
 			seq_puts(m, "\tinstdone read =");
 			for (j = 0; j < I915_NUM_INSTDONE_REG; j++)
@@ -1380,7 +1379,7 @@ static int i915_hangcheck_info(struct seq_file *m, void *unused)
 				seq_printf(m, " 0x%08x",
-					   ring->hangcheck.instdone[j]);
+					   engine->hangcheck.instdone[j]);
 			seq_puts(m, "\n");
@@ -1946,7 +1945,7 @@ static int i915_context_status(struct seq_file *m, void *unused)
 	struct intel_context *ctx;
 	int ret, i;
@@ -1966,13 +1965,13 @@ static int i915_context_status(struct seq_file *m, void *unused)
 		if (i915.enable_execlists) {
 			seq_putc(m, '\n');
 				struct drm_i915_gem_object *ctx_obj =
 					ctx->engine[i].state;
 				struct intel_ringbuffer *ringbuf =
 					ctx->engine[i].ringbuf;
-				seq_printf(m, "%s: ", ring->name);
+				seq_printf(m, "%s: ", engine->name);
 				if (ctx_obj)
 					describe_obj(m, ctx_obj);
 				if (ringbuf)
@@ -2041,7 +2040,7 @@ static int i915_dump_lrc(struct seq_file *m, void *unused)
 	struct drm_info_node *node = (struct drm_info_node *) m->private;
 	int ret, i;
@@ -2056,8 +2055,8 @@ static int i915_dump_lrc(struct seq_file *m, void *unused)
 	list_for_each_entry(ctx, &dev_priv->context_list, link)
 		if (ctx != dev_priv->kernel_context)
-				i915_dump_lrc_obj(m, ctx, ring);
+				i915_dump_lrc_obj(m, ctx, engine);
@@ -2069,7 +2068,7 @@ static int i915_execlists(struct seq_file *m, void *data)
 	struct drm_info_node *node = (struct drm_info_node *)m->private;
 	u32 status_pointer;
 	u8 read_pointer;
 	u8 write_pointer;
@@ -2090,22 +2089,22 @@ static int i915_execlists(struct seq_file *m, void *data)
-	for_each_ring(ring, dev_priv, ring_id) {
+	for_each_ring(engine, dev_priv, ring_id) {
 		struct drm_i915_gem_request *head_req = NULL;
 		int count = 0;
 		unsigned long flags;
-		seq_printf(m, "%s\n", ring->name);
+		seq_printf(m, "%s\n", engine->name);
-		status = I915_READ(RING_EXECLIST_STATUS_LO(ring));
-		ctx_id = I915_READ(RING_EXECLIST_STATUS_HI(ring));
+		status = I915_READ(RING_EXECLIST_STATUS_LO(engine));
+		ctx_id = I915_READ(RING_EXECLIST_STATUS_HI(engine));
 		seq_printf(m, "\tExeclist status: 0x%08X, context: %u\n",
 			   status, ctx_id);
-		status_pointer = I915_READ(RING_CONTEXT_STATUS_PTR(ring));
+		status_pointer = I915_READ(RING_CONTEXT_STATUS_PTR(engine));
 		seq_printf(m, "\tStatus pointer: 0x%08X\n", status_pointer);
-		read_pointer = ring->next_context_status_buffer;
+		read_pointer = engine->next_context_status_buffer;
 		write_pointer = GEN8_CSB_WRITE_PTR(status_pointer);
 		if (read_pointer > write_pointer)
 			write_pointer += GEN8_CSB_ENTRIES;
@@ -2113,24 +2112,25 @@ static int i915_execlists(struct seq_file *m, void *data)
 			   read_pointer, write_pointer);
 		for (i = 0; i < GEN8_CSB_ENTRIES; i++) {
-			status = I915_READ(RING_CONTEXT_STATUS_BUF_LO(ring, i));
-			ctx_id = I915_READ(RING_CONTEXT_STATUS_BUF_HI(ring, i));
+			status = I915_READ(RING_CONTEXT_STATUS_BUF_LO(engine, i));
+			ctx_id = I915_READ(RING_CONTEXT_STATUS_BUF_HI(engine, i));
 			seq_printf(m, "\tStatus buffer %d: 0x%08X, context: %u\n",
 				   i, status, ctx_id);
-		spin_lock_irqsave(&ring->execlist_lock, flags);
-		list_for_each(cursor, &ring->execlist_queue)
+		spin_lock_irqsave(&engine->execlist_lock, flags);
+		list_for_each(cursor, &engine->execlist_queue)
 			count++;
-		head_req = list_first_entry_or_null(&ring->execlist_queue,
-				struct drm_i915_gem_request, execlist_link);
-		spin_unlock_irqrestore(&ring->execlist_lock, flags);
+		head_req = list_first_entry_or_null(&engine->execlist_queue,
+						    struct drm_i915_gem_request,
+						    execlist_link);
+		spin_unlock_irqrestore(&engine->execlist_lock, flags);
 		seq_printf(m, "\t%d requests in queue\n", count);
 		if (head_req) {
 			seq_printf(m, "\tHead request id: %u\n",
-				   intel_execlists_ctx_id(head_req->ctx, ring));
+				   intel_execlists_ctx_id(head_req->ctx, engine));
 			seq_printf(m, "\tHead request tail: %u\n",
 				   head_req->tail);
@@ -2246,19 +2246,19 @@ static int per_file_ctx(int id, void *ptr, void *data)
 static void gen8_ppgtt_info(struct seq_file *m, struct drm_device *dev)
 	struct i915_hw_ppgtt *ppgtt = dev_priv->mm.aliasing_ppgtt;
 	int unused, i;
 	if (!ppgtt)
 		return;
-	for_each_ring(ring, dev_priv, unused) {
+	for_each_ring(engine, dev_priv, unused) {
 		for (i = 0; i < 4; i++) {
-			u64 pdp = I915_READ(GEN8_RING_PDP_UDW(ring, i));
+			u64 pdp = I915_READ(GEN8_RING_PDP_UDW(engine, i));
 			pdp <<= 32;
-			pdp |= I915_READ(GEN8_RING_PDP_LDW(ring, i));
+			pdp |= I915_READ(GEN8_RING_PDP_LDW(engine, i));
 			seq_printf(m, "\tPDP%d 0x%016llx\n", i, pdp);
@@ -2267,19 +2267,23 @@ static void gen8_ppgtt_info(struct seq_file *m, struct drm_device *dev)
 static void gen6_ppgtt_info(struct seq_file *m, struct drm_device *dev)
 	int i;
 	if (INTEL_INFO(dev)->gen == 6)
 		seq_printf(m, "GFX_MODE: 0x%08x\n", I915_READ(GFX_MODE));
 		if (INTEL_INFO(dev)->gen == 7)
-			seq_printf(m, "GFX_MODE: 0x%08x\n", I915_READ(RING_MODE_GEN7(ring)));
-		seq_printf(m, "PP_DIR_BASE: 0x%08x\n", I915_READ(RING_PP_DIR_BASE(ring)));
-		seq_printf(m, "PP_DIR_BASE_READ: 0x%08x\n", I915_READ(RING_PP_DIR_BASE_READ(ring)));
-		seq_printf(m, "PP_DIR_DCLV: 0x%08x\n", I915_READ(RING_PP_DIR_DCLV(ring)));
+			seq_printf(m, "GFX_MODE: 0x%08x\n",
+				   I915_READ(RING_MODE_GEN7(engine)));
+		seq_printf(m, "PP_DIR_BASE: 0x%08x\n",
+			   I915_READ(RING_PP_DIR_BASE(engine)));
+		seq_printf(m, "PP_DIR_BASE_READ: 0x%08x\n",
+			   I915_READ(RING_PP_DIR_BASE_READ(engine)));
+		seq_printf(m, "PP_DIR_DCLV: 0x%08x\n",
+			   I915_READ(RING_PP_DIR_DCLV(engine)));
 	if (dev_priv->mm.aliasing_ppgtt) {
@@ -2334,12 +2338,12 @@ out_put:
 static int count_irq_waiters(struct drm_i915_private *i915)
 	int count = 0;
 	int i;
-	for_each_ring(ring, i915, i)
-		count += ring->irq_refcount;
+	for_each_ring(engine, i915, i)
+		count += engine->irq_refcount;
 	return count;
@@ -2447,7 +2451,7 @@ static void i915_guc_client_info(struct seq_file *m,
 				 struct drm_i915_private *dev_priv,
 				 struct i915_guc_client *client)
 	uint64_t tot = 0;
 	uint32_t i;
@@ -2462,11 +2466,11 @@ static void i915_guc_client_info(struct seq_file *m,
 	seq_printf(m, "\tFailed doorbell: %u\n", client->b_fail);
 	seq_printf(m, "\tLast submission result: %d\n", client->retcode);
 		seq_printf(m, "\tSubmissions: %llu %s\n",
-				client->submissions[ring->guc_id],
-				ring->name);
-		tot += client->submissions[ring->guc_id];
+				client->submissions[engine->guc_id],
+				engine->name);
+		tot += client->submissions[engine->guc_id];
 	seq_printf(m, "\tTotal: %llu\n", tot);
@@ -2478,7 +2482,7 @@ static int i915_guc_info(struct seq_file *m, void *data)
 	struct intel_guc guc;
 	struct i915_guc_client client = {};
 	enum intel_ring_id i;
 	u64 total = 0;
@@ -2502,11 +2506,11 @@ static int i915_guc_info(struct seq_file *m, void *data)
 	seq_printf(m, "GuC last action error code: %d\n", guc.action_err);
 	seq_printf(m, "\nGuC submissions:\n");
 		seq_printf(m, "\t%-24s: %10llu, last seqno 0x%08x\n",
-			ring->name, guc.submissions[ring->guc_id],
-			guc.last_seqno[ring->guc_id]);
-		total += guc.submissions[ring->guc_id];
+			engine->name, guc.submissions[engine->guc_id],
+			guc.last_seqno[engine->guc_id]);
+		total += guc.submissions[engine->guc_id];
 	seq_printf(m, "\t%s: %llu\n", "Total", total);
@@ -3128,7 +3132,7 @@ static int i915_semaphore_status(struct seq_file *m, void *unused)
 	int num_rings = hweight32(INTEL_INFO(dev)->ring_mask);
 	int i, j, ret;
@@ -3149,10 +3153,10 @@ static int i915_semaphore_status(struct seq_file *m, void *unused)
 		page = i915_gem_object_get_page(dev_priv->semaphore_obj, 0);
 		seqno = (uint64_t *)kmap_atomic(page);
 			uint64_t offset;
 			seq_puts(m, "  Last signal:");
 			for (j = 0; j < num_rings; j++) {
@@ -3174,17 +3178,18 @@ static int i915_semaphore_status(struct seq_file *m, void *unused)
 		kunmap_atomic(seqno);
 	} else {
 				seq_printf(m, "0x%08x\n",
-					   I915_READ(ring->semaphore.mbox.signal[j]));
+					   I915_READ(engine->semaphore.mbox.signal[j]));
 		seq_putc(m, '\n');
 	seq_puts(m, "\nSync seqno:\n");
-			seq_printf(m, "  0x%08x ", ring->semaphore.sync_seqno[j]);
+			seq_printf(m, "  0x%08x ",
+				   engine->semaphore.sync_seqno[j]);
 		seq_putc(m, '\n');
@@ -3226,7 +3231,7 @@ static int i915_wa_registers(struct seq_file *m, void *unused)
 	int i;
 	int ret;
@@ -3239,9 +3244,9 @@ static int i915_wa_registers(struct seq_file *m, void *unused)
 	seq_printf(m, "Workarounds applied: %d\n", workarounds->count);
 		seq_printf(m, "HW whitelist count for %s: %d\n",
-			   ring->name, workarounds->hw_whitelist_count[i]);
+			   engine->name, workarounds->hw_whitelist_count[i]);
 	for (i = 0; i < workarounds->count; ++i) {
 		i915_reg_t addr;
 		u32 mask, value, read;
diff --git a/drivers/gpu/drm/i915/i915_gem.c b/drivers/gpu/drm/i915/i915_gem.c
index b854af2..5a7f603 100644
--- a/drivers/gpu/drm/i915/i915_gem.c
+++ b/drivers/gpu/drm/i915/i915_gem.c
@@ -1243,11 +1243,11 @@ int __i915_wait_request(struct drm_i915_gem_request *req,
 			s64 *timeout,
 			struct intel_rps_client *rps)
-	struct intel_engine_cs *ring = i915_gem_request_get_ring(req);
-	struct drm_device *dev = ring->dev;
+	struct intel_engine_cs *engine = i915_gem_request_get_ring(req);
+	struct drm_device *dev = engine->dev;
 	const bool irq_test_in_progress =
-		ACCESS_ONCE(dev_priv->gpu_error.test_irq_rings) & intel_ring_flag(ring);
+		ACCESS_ONCE(dev_priv->gpu_error.test_irq_rings) & intel_ring_flag(engine);
 	int state = interruptible ? TASK_INTERRUPTIBLE : TASK_UNINTERRUPTIBLE;
 	DEFINE_WAIT(wait);
 	unsigned long timeout_expire;
@@ -1288,7 +1288,7 @@ int __i915_wait_request(struct drm_i915_gem_request *req,
 	if (ret == 0)
 		goto out;
-	if (!irq_test_in_progress && WARN_ON(!ring->irq_get(ring))) {
+	if (!irq_test_in_progress && WARN_ON(!engine->irq_get(engine))) {
 		ret = -ENODEV;
 		goto out;
@@ -1296,7 +1296,7 @@ int __i915_wait_request(struct drm_i915_gem_request *req,
 	for (;;) {
 		struct timer_list timer;
-		prepare_to_wait(&ring->irq_queue, &wait, state);
+		prepare_to_wait(&engine->irq_queue, &wait, state);
 		/* We need to check whether any gpu reset happened in between
 		 * the caller grabbing the seqno and now ... */
@@ -1325,11 +1325,11 @@ int __i915_wait_request(struct drm_i915_gem_request *req,
 		timer.function = NULL;
-		if (timeout || missed_irq(dev_priv, ring)) {
+		if (timeout || missed_irq(dev_priv, engine)) {
 			unsigned long expire;
 			setup_timer_on_stack(&timer, fake_irq, (unsigned long)current);
-			expire = missed_irq(dev_priv, ring) ? jiffies + 1 : timeout_expire;
+			expire = missed_irq(dev_priv, engine) ? jiffies + 1 : timeout_expire;
 			mod_timer(&timer, expire);
@@ -1341,9 +1341,9 @@ int __i915_wait_request(struct drm_i915_gem_request *req,
 	if (!irq_test_in_progress)
-		ring->irq_put(ring);
+		engine->irq_put(engine);
-	finish_wait(&ring->irq_queue, &wait);
+	finish_wait(&engine->irq_queue, &wait);
 out:
 	trace_i915_gem_request_wait_end(req);
@@ -2404,17 +2404,17 @@ void i915_vma_move_to_active(struct i915_vma *vma,
 			     struct drm_i915_gem_request *req)
 	struct drm_i915_gem_object *obj = vma->obj;
-	ring = i915_gem_request_get_ring(req);
+	engine = i915_gem_request_get_ring(req);
 	/* Add a reference if we're newly entering the active list. */
 	if (obj->active == 0)
 		drm_gem_object_reference(&obj->base);
-	obj->active |= intel_ring_flag(ring);
+	obj->active |= intel_ring_flag(engine);
-	list_move_tail(&obj->ring_list[ring->id], &ring->active_list);
-	i915_gem_request_assign(&obj->last_read_req[ring->id], req);
+	list_move_tail(&obj->ring_list[engine->id], &engine->active_list);
+	i915_gem_request_assign(&obj->last_read_req[engine->id], req);
 	list_move_tail(&vma->vm_link, &vma->vm->active_list);
@@ -2467,23 +2467,23 @@ static int
 i915_gem_init_seqno(struct drm_device *dev, u32 seqno)
 	int ret, i, j;
 	/* Carefully retire all requests without writing to the rings */
-		ret = intel_ring_idle(ring);
+		ret = intel_ring_idle(engine);
 		if (ret)
 			return ret;
 	i915_gem_retire_requests(dev);
 	/* Finally reset hw state */
-		intel_ring_init_seqno(ring, seqno);
+		intel_ring_init_seqno(engine, seqno);
-		for (j = 0; j < ARRAY_SIZE(ring->semaphore.sync_seqno); j++)
-			ring->semaphore.sync_seqno[j] = 0;
+		for (j = 0; j < ARRAY_SIZE(engine->semaphore.sync_seqno); j++)
+			engine->semaphore.sync_seqno[j] = 0;
 	return 0;
@@ -2542,7 +2542,7 @@ void __i915_add_request(struct drm_i915_gem_request *request,
 			struct drm_i915_gem_object *obj,
 			bool flush_caches)
 	struct drm_i915_private *dev_priv;
 	struct intel_ringbuffer *ringbuf;
 	u32 request_start;
@@ -2551,8 +2551,8 @@ void __i915_add_request(struct drm_i915_gem_request *request,
 	if (WARN_ON(request == NULL))
 		return;
-	ring = request->ring;
-	dev_priv = ring->dev->dev_private;
+	engine = request->ring;
+	dev_priv = engine->dev->dev_private;
 	ringbuf = request->ringbuf;
@@ -2587,9 +2587,9 @@ void __i915_add_request(struct drm_i915_gem_request *request,
 	request->postfix = intel_ring_get_tail(ringbuf);
-		ret = ring->emit_request(request);
+		ret = engine->emit_request(request);
 	else {
-		ret = ring->add_request(request);
+		ret = engine->add_request(request);
 		request->tail = intel_ring_get_tail(ringbuf);
@@ -2607,13 +2607,13 @@ void __i915_add_request(struct drm_i915_gem_request *request,
 	request->batch_obj = obj;
 	request->emitted_jiffies = jiffies;
-	request->previous_seqno = ring->last_submitted_seqno;
-	ring->last_submitted_seqno = request->seqno;
-	list_add_tail(&request->list, &ring->request_list);
+	request->previous_seqno = engine->last_submitted_seqno;
+	engine->last_submitted_seqno = request->seqno;
+	list_add_tail(&request->list, &engine->request_list);
 	trace_i915_gem_request_add(request);
-	i915_queue_hangcheck(ring->dev);
+	i915_queue_hangcheck(engine->dev);
 	queue_delayed_work(dev_priv->wq,
 			   &dev_priv->mm.retire_work,
@@ -2885,7 +2885,7 @@ static void i915_gem_reset_ring_cleanup(struct drm_i915_private *dev_priv,
 void i915_gem_reset(struct drm_device *dev)
 	int i;
@@ -2893,11 +2893,11 @@ void i915_gem_reset(struct drm_device *dev)
 	 * them for finding the guilty party. As the requests only borrow
 	 * their reference to the objects, the inspection must be done first.
-		i915_gem_reset_ring_status(dev_priv, ring);
+		i915_gem_reset_ring_status(dev_priv, engine);
-		i915_gem_reset_ring_cleanup(dev_priv, ring);
+		i915_gem_reset_ring_cleanup(dev_priv, engine);
 	i915_gem_context_reset(dev);
@@ -2962,19 +2962,19 @@ bool
 i915_gem_retire_requests(struct drm_device *dev)
 	bool idle = true;
 	int i;
-		i915_gem_retire_requests_ring(ring);
-		idle &= list_empty(&ring->request_list);
+		i915_gem_retire_requests_ring(engine);
+		idle &= list_empty(&engine->request_list);
-			spin_lock_irq(&ring->execlist_lock);
-			idle &= list_empty(&ring->execlist_queue);
-			spin_unlock_irq(&ring->execlist_lock);
+			spin_lock_irq(&engine->execlist_lock);
+			idle &= list_empty(&engine->execlist_queue);
+			spin_unlock_irq(&engine->execlist_lock);
-			intel_execlists_retire_requests(ring);
+			intel_execlists_retire_requests(engine);
@@ -3025,11 +3025,11 @@ i915_gem_idle_work_handler(struct work_struct *work)
 	intel_mark_idle(dev);
 	if (mutex_trylock(&dev->struct_mutex)) {
 		int i;
-			i915_gem_batch_pool_fini(&ring->batch_pool);
+			i915_gem_batch_pool_fini(&engine->batch_pool);
@@ -3391,15 +3391,15 @@ int __i915_vma_unbind_no_wait(struct i915_vma *vma)
 int i915_gpu_idle(struct drm_device *dev)
 	int ret, i;
 	/* Flush everything onto the inactive list. */
 		if (!i915.enable_execlists) {
-			req = i915_gem_request_alloc(ring, NULL);
+			req = i915_gem_request_alloc(engine, NULL);
 			if (IS_ERR(req))
 				return PTR_ERR(req);
@@ -3412,7 +3412,7 @@ int i915_gpu_idle(struct drm_device *dev)
 			i915_add_request_no_flush(req);
 		if (ret)
 			return ret;
@@ -4656,11 +4656,11 @@ static void
 i915_gem_stop_ringbuffers(struct drm_device *dev)
 	int i;
-		dev_priv->gt.stop_ring(ring);
+		dev_priv->gt.stop_ring(engine);
 int
@@ -4697,8 +4697,8 @@ err:
 int i915_gem_l3_remap(struct drm_i915_gem_request *req, int slice)
-	struct intel_engine_cs *ring = req->ring;
+	struct intel_engine_cs *engine = req->ring;
 	u32 *remap_info = dev_priv->l3_parity.remap_info[slice];
 	int i, ret;
@@ -4716,12 +4716,12 @@ int i915_gem_l3_remap(struct drm_i915_gem_request *req, int slice)
 	 * at initialization time.
 	for (i = 0; i < GEN7_L3LOG_SIZE / 4; i++) {
-		intel_ring_emit(ring, MI_LOAD_REGISTER_IMM(1));
-		intel_ring_emit_reg(ring, GEN7_L3LOG(slice, i));
-		intel_ring_emit(ring, remap_info[i]);
+		intel_ring_emit(engine, MI_LOAD_REGISTER_IMM(1));
+		intel_ring_emit_reg(engine, GEN7_L3LOG(slice, i));
+		intel_ring_emit(engine, remap_info[i]);
-	intel_ring_advance(ring);
+	intel_ring_advance(engine);
 	return ret;
@@ -4829,7 +4829,7 @@ int
 i915_gem_init_hw(struct drm_device *dev)
 	int ret, i, j;
 	if (INTEL_INFO(dev)->gen < 6 && !intel_enable_gtt())
@@ -4876,8 +4876,8 @@ i915_gem_init_hw(struct drm_device *dev)
 	/* Need to do basic initialisation of all rings first: */
-		ret = ring->init_hw(ring);
+		ret = engine->init_hw(engine);
 		if (ret)
 			goto out;
@@ -4901,17 +4901,17 @@ i915_gem_init_hw(struct drm_device *dev)
 		goto out;
 	/* Now it is safe to go back round and do everything else: */
 		if (IS_ERR(req)) {
 			ret = PTR_ERR(req);
 			i915_gem_cleanup_ringbuffer(dev);
 			goto out;
 			for (j = 0; j < NUM_L3_SLICES(dev); j++)
 				i915_gem_l3_remap(req, j);
@@ -5006,11 +5006,11 @@ void
 i915_gem_cleanup_ringbuffer(struct drm_device *dev)
 	int i;
-		dev_priv->gt.cleanup_ring(ring);
+		dev_priv->gt.cleanup_ring(engine);
diff --git a/drivers/gpu/drm/i915/i915_gem_context.c b/drivers/gpu/drm/i915/i915_gem_context.c
index 5dd84e1..cc07666 100644
--- a/drivers/gpu/drm/i915/i915_gem_context.c
+++ b/drivers/gpu/drm/i915/i915_gem_context.c
@@ -346,11 +346,11 @@ void i915_gem_context_reset(struct drm_device *dev)
 	for (i = 0; i < I915_NUM_RINGS; i++) {
-		struct intel_engine_cs *ring = &dev_priv->ring[i];
+		struct intel_engine_cs *engine = &dev_priv->ring[i];
-		if (ring->last_context) {
-			i915_gem_context_unpin(ring->last_context, ring);
-			ring->last_context = NULL;
+		if (engine->last_context) {
+			i915_gem_context_unpin(engine->last_context, engine);
+			engine->last_context = NULL;
@@ -427,11 +427,11 @@ void i915_gem_context_fini(struct drm_device *dev)
 	for (i = I915_NUM_RINGS; --i >= 0;) {
@@ -441,14 +441,14 @@ void i915_gem_context_fini(struct drm_device *dev)
 int i915_gem_context_enable(struct drm_i915_gem_request *req)
 	int ret;
-		if (ring->init_context == NULL)
+		if (engine->init_context == NULL)
 			return 0;
-		ret = ring->init_context(req);
+		ret = engine->init_context(req);
 	} else
 		ret = i915_switch_context(req);
@@ -510,12 +510,12 @@ i915_gem_context_get(struct drm_i915_file_private *file_priv, u32 id)
 static inline int
 mi_set_context(struct drm_i915_gem_request *req, u32 hw_flags)
 	u32 flags = hw_flags | MI_MM_SPACE_GTT;
 	const int num_rings =
 		/* Use an extended w/a on ivb+ if signalling from other rings */
-		i915_semaphore_is_enabled(ring->dev) ?
-		hweight32(INTEL_INFO(ring->dev)->ring_mask) - 1 :
+		i915_semaphore_is_enabled(engine->dev) ?
+		hweight32(INTEL_INFO(engine->dev)->ring_mask) - 1 :
 		0;
 	int len, i, ret;
@@ -524,21 +524,21 @@ mi_set_context(struct drm_i915_gem_request *req, u32 hw_flags)
 	 * explicitly, so we rely on the value at ring init, stored in
 	 * itlb_before_ctx_switch.
-	if (IS_GEN6(ring->dev)) {
-		ret = ring->flush(req, I915_GEM_GPU_DOMAINS, 0);
+	if (IS_GEN6(engine->dev)) {
+		ret = engine->flush(req, I915_GEM_GPU_DOMAINS, 0);
 		if (ret)
 			return ret;
 	/* These flags are for resource streamer on HSW+ */
-	if (IS_HASWELL(ring->dev) || INTEL_INFO(ring->dev)->gen >= 8)
+	if (IS_HASWELL(engine->dev) || INTEL_INFO(engine->dev)->gen >= 8)
 		flags |= (HSW_MI_RS_SAVE_STATE_EN | HSW_MI_RS_RESTORE_STATE_EN);
-	else if (INTEL_INFO(ring->dev)->gen < 8)
+	else if (INTEL_INFO(engine->dev)->gen < 8)
 		flags |= (MI_SAVE_EXT_STATE_EN | MI_RESTORE_EXT_STATE_EN);
 	len = 4;
-	if (INTEL_INFO(ring->dev)->gen >= 7)
+	if (INTEL_INFO(engine->dev)->gen >= 7)
 		len += 2 + (num_rings ? 4*num_rings + 2 : 0);
 	ret = intel_ring_begin(req, len);
@@ -546,49 +546,56 @@ mi_set_context(struct drm_i915_gem_request *req, u32 hw_flags)
 		return ret;
 	/* WaProgramMiArbOnOffAroundMiSetContext:ivb,vlv,hsw,bdw,chv */
-	if (INTEL_INFO(ring->dev)->gen >= 7) {
-		intel_ring_emit(ring, MI_ARB_ON_OFF | MI_ARB_DISABLE);
+	if (INTEL_INFO(engine->dev)->gen >= 7) {
+		intel_ring_emit(engine, MI_ARB_ON_OFF | MI_ARB_DISABLE);
 		if (num_rings) {
 			struct intel_engine_cs *signaller;
-			intel_ring_emit(ring, MI_LOAD_REGISTER_IMM(num_rings));
-			for_each_ring(signaller, to_i915(ring->dev), i) {
-				if (signaller == ring)
+					MI_LOAD_REGISTER_IMM(num_rings));
+			for_each_ring(signaller, to_i915(engine->dev), i) {
+				if (signaller == engine)
 					continue;
-				intel_ring_emit_reg(ring, RING_PSMI_CTL(signaller->mmio_base));
-				intel_ring_emit(ring, _MASKED_BIT_ENABLE(GEN6_PSMI_SLEEP_MSG_DISABLE));
+						    RING_PSMI_CTL(signaller->mmio_base));
+						_MASKED_BIT_ENABLE(GEN6_PSMI_SLEEP_MSG_DISABLE));
-	intel_ring_emit(ring, MI_NOOP);
-	intel_ring_emit(ring, MI_SET_CONTEXT);
-	intel_ring_emit(ring, i915_gem_obj_ggtt_offset(req->ctx->legacy_hw_ctx.rcs_state) |
+	intel_ring_emit(engine, MI_NOOP);
+	intel_ring_emit(engine, MI_SET_CONTEXT);
+			i915_gem_obj_ggtt_offset(req->ctx->legacy_hw_ctx.rcs_state) |
 			flags);
 	 * w/a: MI_SET_CONTEXT must always be followed by MI_NOOP
 	 * WaMiSetContext_Hang:snb,ivb,vlv
 		if (num_rings) {
 					continue;
-				intel_ring_emit(ring, _MASKED_BIT_DISABLE(GEN6_PSMI_SLEEP_MSG_DISABLE));
+						_MASKED_BIT_DISABLE(GEN6_PSMI_SLEEP_MSG_DISABLE));
-		intel_ring_emit(ring, MI_ARB_ON_OFF | MI_ARB_ENABLE);
+		intel_ring_emit(engine, MI_ARB_ON_OFF | MI_ARB_ENABLE);
 	return ret;
@@ -648,25 +655,26 @@ needs_pd_load_post(struct intel_engine_cs *ring, struct intel_context *to,
 static int do_switch(struct drm_i915_gem_request *req)
 	struct intel_context *to = req->ctx;
-	struct drm_i915_private *dev_priv = ring->dev->dev_private;
-	struct intel_context *from = ring->last_context;
+	struct drm_i915_private *dev_priv = engine->dev->dev_private;
+	struct intel_context *from = engine->last_context;
 	u32 hw_flags = 0;
 	bool uninitialized = false;
 	int ret, i;
-	if (from != NULL && ring == &dev_priv->ring[RCS]) {
+	if (from != NULL && engine == &dev_priv->ring[RCS]) {
 		BUG_ON(from->legacy_hw_ctx.rcs_state == NULL);
 		BUG_ON(!i915_gem_obj_is_pinned(from->legacy_hw_ctx.rcs_state));
-	if (should_skip_switch(ring, from, to))
+	if (should_skip_switch(engine, from, to))
 		return 0;
 	/* Trying to pin first makes error handling easier. */
-	if (ring == &dev_priv->ring[RCS]) {
+	if (engine == &dev_priv->ring[RCS]) {
 		ret = i915_gem_obj_ggtt_pin(to->legacy_hw_ctx.rcs_state,
-					    get_context_alignment(ring->dev), 0);
+					    get_context_alignment(engine->dev),
+					    0);
 		if (ret)
 			return ret;
@@ -676,23 +684,23 @@ static int do_switch(struct drm_i915_gem_request *req)
 	 * evict_everything - as a last ditch gtt defrag effort that also
 	 * switches to the default context. Hence we need to reload from here.
-	from = ring->last_context;
+	from = engine->last_context;
-	if (needs_pd_load_pre(ring, to)) {
+	if (needs_pd_load_pre(engine, to)) {
 		/* Older GENs and non render rings still want the load first,
 		 * "PP_DCLV followed by PP_DIR_BASE register through Load
 		 * Register Immediate commands in Ring Buffer before submitting
 		 * a context."*/
-		trace_switch_mm(ring, to);
+		trace_switch_mm(engine, to);
 		ret = to->ppgtt->switch_mm(to->ppgtt, req);
 		if (ret)
 			goto unpin_out;
 		/* Doing a PD load always reloads the page dirs */
-		to->ppgtt->pd_dirty_rings &= ~intel_ring_flag(ring);
+		to->ppgtt->pd_dirty_rings &= ~intel_ring_flag(engine);
-	if (ring != &dev_priv->ring[RCS]) {
+	if (engine != &dev_priv->ring[RCS]) {
 		if (from)
 			i915_gem_context_unreference(from);
 		goto done;
@@ -717,14 +725,14 @@ static int do_switch(struct drm_i915_gem_request *req)
 		 * space. This means we must enforce that a page table load
 		 * occur when this occurs. */
 	} else if (to->ppgtt &&
-		   (intel_ring_flag(ring) & to->ppgtt->pd_dirty_rings)) {
+		   (intel_ring_flag(engine) & to->ppgtt->pd_dirty_rings)) {
 		hw_flags |= MI_FORCE_RESTORE;
 	/* We should never emit switch_mm more than once */
-	WARN_ON(needs_pd_load_pre(ring, to) &&
-		needs_pd_load_post(ring, to, hw_flags));
+	WARN_ON(needs_pd_load_pre(engine, to) &&
+		needs_pd_load_post(engine, to, hw_flags));
 	ret = mi_set_context(req, hw_flags);
 	if (ret)
@@ -733,8 +741,8 @@ static int do_switch(struct drm_i915_gem_request *req)
 	/* GEN8 does *not* require an explicit reload if the PDPs have been
 	 * setup, and we do not wish to move them.
-	if (needs_pd_load_post(ring, to, hw_flags)) {
+	if (needs_pd_load_post(engine, to, hw_flags)) {
 		/* The hardware context switch is emitted, but we haven't
 		 * actually changed the state - so it's probably safe to bail
@@ -787,11 +795,11 @@ static int do_switch(struct drm_i915_gem_request *req)
 done:
 	i915_gem_context_reference(to);
-	ring->last_context = to;
+	engine->last_context = to;
 	if (uninitialized) {
-		if (ring->init_context) {
+		if (engine->init_context) {
 			if (ret)
 				DRM_ERROR("ring init context: %d\n", ret);
@@ -800,7 +808,7 @@ done:
 	return 0;
 unpin_out:
 		i915_gem_object_ggtt_unpin(to->legacy_hw_ctx.rcs_state);
 	return ret;
@@ -820,18 +828,18 @@ unpin_out:
 int i915_switch_context(struct drm_i915_gem_request *req)
 	WARN_ON(i915.enable_execlists);
 	WARN_ON(!mutex_is_locked(&dev_priv->dev->struct_mutex));
 	if (req->ctx->legacy_hw_ctx.rcs_state == NULL) { /* We have the fake context */
-		if (req->ctx != ring->last_context) {
+		if (req->ctx != engine->last_context) {
 			i915_gem_context_reference(req->ctx);
-				i915_gem_context_unreference(ring->last_context);
-			ring->last_context = req->ctx;
+				i915_gem_context_unreference(engine->last_context);
+			engine->last_context = req->ctx;
 		return 0;
diff --git a/drivers/gpu/drm/i915/i915_gem_debug.c b/drivers/gpu/drm/i915/i915_gem_debug.c
index 17299d0..202a7e6 100644
--- a/drivers/gpu/drm/i915/i915_gem_debug.c
+++ b/drivers/gpu/drm/i915/i915_gem_debug.c
@@ -36,29 +36,30 @@ i915_verify_lists(struct drm_device *dev)
 	static int warned;
 	struct drm_i915_private *dev_priv = to_i915(dev);
 	int err = 0;
 	int i;
 	if (warned)
 		return 0;
-		list_for_each_entry(obj, &ring->active_list, ring_list[ring->id]) {
+		list_for_each_entry(obj, &engine->active_list,
+				    ring_list[engine->id]) {
 			if (obj->base.dev != dev ||
 			    !atomic_read(&obj->base.refcount.refcount)) {
 				DRM_ERROR("%s: freed active obj %p\n",
-					  ring->name, obj);
+					  engine->name, obj);
 				err++;
 				break;
 			} else if (!obj->active ||
-				   obj->last_read_req[ring->id] == NULL) {
+				   obj->last_read_req[engine->id] == NULL) {
 				DRM_ERROR("%s: invalid active obj %p\n",
-					  ring->name, obj);
 				err++;
 			} else if (obj->base.write_domain) {
 				DRM_ERROR("%s: invalid write obj %p (w %x)\n",
-					  ring->name,
+					  engine->name,
 					  obj, obj->base.write_domain);
 				err++;
diff --git a/drivers/gpu/drm/i915/i915_gem_execbuffer.c b/drivers/gpu/drm/i915/i915_gem_execbuffer.c
index 1328bc5..b73496e 100644
--- a/drivers/gpu/drm/i915/i915_gem_execbuffer.c
+++ b/drivers/gpu/drm/i915/i915_gem_execbuffer.c
@@ -1095,7 +1095,7 @@ void
 i915_gem_execbuffer_move_to_active(struct list_head *vmas,
 	list_for_each_entry(vma, vmas, exec_list) {
@@ -1122,7 +1122,7 @@ i915_gem_execbuffer_move_to_active(struct list_head *vmas,
 		if (entry->flags & EXEC_OBJECT_NEEDS_FENCE) {
 			i915_gem_request_assign(&obj->last_fenced_req, req);
 			if (entry->flags & __EXEC_OBJECT_HAS_FENCE) {
-				struct drm_i915_private *dev_priv = to_i915(ring->dev);
+				struct drm_i915_private *dev_priv = to_i915(engine->dev);
 				list_move_tail(&dev_priv->fence_regs[obj->fence_reg].lru_list,
 					       &dev_priv->mm.fence_list);
@@ -1146,11 +1146,11 @@ static int
 i915_reset_gen7_sol_offsets(struct drm_device *dev,
 	int ret, i;
-	if (!IS_GEN7(dev) || ring != &dev_priv->ring[RCS]) {
+	if (!IS_GEN7(dev) || engine != &dev_priv->ring[RCS]) {
 		DRM_DEBUG("sol reset is gen7/rcs only\n");
 		return -EINVAL;
@@ -1160,12 +1160,12 @@ i915_reset_gen7_sol_offsets(struct drm_device *dev,
 		return ret;
-		intel_ring_emit_reg(ring, GEN7_SO_WRITE_OFFSET(i));
-		intel_ring_emit(ring, 0);
+		intel_ring_emit_reg(engine, GEN7_SO_WRITE_OFFSET(i));
+		intel_ring_emit(engine, 0);
 	return 0;
@@ -1229,7 +1229,7 @@ i915_gem_ringbuffer_submission(struct i915_execbuffer_params *params,
 			       struct list_head *vmas)
 	struct drm_device *dev = params->dev;
-	struct intel_engine_cs *ring = params->ring;
+	struct intel_engine_cs *engine = params->ring;
 	u64 exec_start, exec_len;
 	int instp_mode;
@@ -1244,8 +1244,8 @@ i915_gem_ringbuffer_submission(struct i915_execbuffer_params *params,
 	if (ret)
 		return ret;
-	WARN(params->ctx->ppgtt && params->ctx->ppgtt->pd_dirty_rings & (1<<ring->id),
-	     "%s didn't clear reload\n", ring->name);
+	WARN(params->ctx->ppgtt && params->ctx->ppgtt->pd_dirty_rings & (1<<engine->id),
+	     "%s didn't clear reload\n", engine->name);
 	instp_mode = args->flags & I915_EXEC_CONSTANTS_MASK;
 	instp_mask = I915_EXEC_CONSTANTS_MASK;
@@ -1253,7 +1253,7 @@ i915_gem_ringbuffer_submission(struct i915_execbuffer_params *params,
 	case I915_EXEC_CONSTANTS_REL_GENERAL:
 	case I915_EXEC_CONSTANTS_ABSOLUTE:
 	case I915_EXEC_CONSTANTS_REL_SURFACE:
-		if (instp_mode != 0 && ring != &dev_priv->ring[RCS]) {
+		if (instp_mode != 0 && engine != &dev_priv->ring[RCS]) {
 			DRM_DEBUG("non-0 rel constants mode on non-RCS\n");
 			return -EINVAL;
@@ -1280,17 +1280,17 @@ i915_gem_ringbuffer_submission(struct i915_execbuffer_params *params,
 		return -EINVAL;
-	if (ring == &dev_priv->ring[RCS] &&
+	if (engine == &dev_priv->ring[RCS] &&
 	    instp_mode != dev_priv->relative_constants_mode) {
 		ret = intel_ring_begin(params->request, 4);
 		if (ret)
 			return ret;
-		intel_ring_emit_reg(ring, INSTPM);
-		intel_ring_emit(ring, instp_mask << 16 | instp_mode);
+		intel_ring_emit_reg(engine, INSTPM);
+		intel_ring_emit(engine, instp_mask << 16 | instp_mode);
 		dev_priv->relative_constants_mode = instp_mode;
@@ -1308,7 +1308,7 @@ i915_gem_ringbuffer_submission(struct i915_execbuffer_params *params,
 	if (exec_len == 0)
 		exec_len = params->batch_obj->base.size;
-	ret = ring->dispatch_execbuffer(params->request,
+	ret = engine->dispatch_execbuffer(params->request,
 					exec_start, exec_len,
 					params->dispatch_flags);
 	if (ret)
@@ -1432,7 +1432,7 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 	struct eb_vmas *eb;
 	struct drm_i915_gem_object *batch_obj;
 	struct drm_i915_gem_exec_object2 shadow_exec_entry;
 	struct i915_address_space *vm;
 	struct i915_execbuffer_params params_master; /* XXX: will be removed later */
@@ -1459,7 +1459,7 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 	if (args->flags & I915_EXEC_IS_PINNED)
 		dispatch_flags |= I915_DISPATCH_PINNED;
-	ret = eb_select_ring(dev_priv, file, args, &ring);
+	ret = eb_select_ring(dev_priv, file, args, &engine);
 	if (ret)
 		return ret;
@@ -1473,9 +1473,9 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 			DRM_DEBUG("RS is only allowed for Haswell, Gen8 and above\n");
 			return -EINVAL;
-		if (ring->id != RCS) {
+		if (engine->id != RCS) {
 			DRM_DEBUG("RS is not available on %s\n",
-				 ring->name);
+				 engine->name);
 			return -EINVAL;
@@ -1488,7 +1488,7 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 	if (ret)
 		goto pre_mutex_err;
-	ctx = i915_gem_validate_context(dev, file, ring, ctx_id);
+	ctx = i915_gem_validate_context(dev, file, engine, ctx_id);
 	if (IS_ERR(ctx)) {
 		ret = PTR_ERR(ctx);
@@ -1522,7 +1522,8 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 	/* Move the objects en-masse into the GTT, evicting if necessary. */
 	need_relocs = (args->flags & I915_EXEC_NO_RELOC) == 0;
-	ret = i915_gem_execbuffer_reserve(ring, &eb->vmas, ctx, &need_relocs);
+	ret = i915_gem_execbuffer_reserve(engine, &eb->vmas, ctx,
+					  &need_relocs);
 	if (ret)
 		goto err;
@@ -1531,7 +1532,8 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 		ret = i915_gem_execbuffer_relocate(eb);
 	if (ret) {
 		if (ret == -EFAULT) {
-			ret = i915_gem_execbuffer_relocate_slow(dev, args, file, ring,
+			ret = i915_gem_execbuffer_relocate_slow(dev, args, file,
+								engine,
 								eb, exec, ctx);
 			BUG_ON(!mutex_is_locked(&dev->struct_mutex));
@@ -1547,16 +1549,16 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 	params->args_batch_start_offset = args->batch_start_offset;
-	if (i915_needs_cmd_parser(ring) && args->batch_len) {
+	if (i915_needs_cmd_parser(engine) && args->batch_len) {
 		struct drm_i915_gem_object *parsed_batch_obj;
-		parsed_batch_obj = i915_gem_execbuffer_parse(ring,
-						      &shadow_exec_entry,
-						      eb,
-						      batch_obj,
-						      args->batch_start_offset,
-						      args->batch_len,
-						      file->is_master);
+		parsed_batch_obj = i915_gem_execbuffer_parse(engine,
+							     &shadow_exec_entry,
+							     eb,
+							     batch_obj,
+							     args->batch_start_offset,
+							     args->batch_len,
+							     file->is_master);
 		if (IS_ERR(parsed_batch_obj)) {
 			ret = PTR_ERR(parsed_batch_obj);
 			goto err;
@@ -1608,7 +1610,7 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 		params->batch_obj_vm_offset = i915_gem_obj_offset(batch_obj, vm);
 	/* Allocate a request for this batch buffer nice and early. */
-	req = i915_gem_request_alloc(ring, ctx);
+	req = i915_gem_request_alloc(engine, ctx);
 	if (IS_ERR(req)) {
 		ret = PTR_ERR(req);
 		goto err_batch_unpin;
@@ -1626,7 +1628,7 @@ i915_gem_do_execbuffer(struct drm_device *dev, void *data,
 	params->dev                     = dev;
 	params->file                    = file;
-	params->ring                    = ring;
+	params->ring                    = engine;
 	params->dispatch_flags          = dispatch_flags;
 	params->batch_obj               = batch_obj;
 	params->ctx                     = ctx;
diff --git a/drivers/gpu/drm/i915/i915_gem_gtt.c b/drivers/gpu/drm/i915/i915_gem_gtt.c
index 7b8de85..1bc7779 100644
--- a/drivers/gpu/drm/i915/i915_gem_gtt.c
+++ b/drivers/gpu/drm/i915/i915_gem_gtt.c
@@ -658,7 +658,7 @@ static int gen8_write_pdp(struct drm_i915_gem_request *req,
 			  unsigned entry,
 			  dma_addr_t addr)
 	int ret;
 	BUG_ON(entry >= 4);
@@ -667,13 +667,13 @@ static int gen8_write_pdp(struct drm_i915_gem_request *req,
 	if (ret)
 		return ret;
-	intel_ring_emit_reg(ring, GEN8_RING_PDP_UDW(ring, entry));
-	intel_ring_emit(ring, upper_32_bits(addr));
-	intel_ring_emit_reg(ring, GEN8_RING_PDP_LDW(ring, entry));
-	intel_ring_emit(ring, lower_32_bits(addr));
+	intel_ring_emit_reg(engine, GEN8_RING_PDP_UDW(engine, entry));
+	intel_ring_emit(engine, upper_32_bits(addr));
+	intel_ring_emit_reg(engine, GEN8_RING_PDP_LDW(engine, entry));
+	intel_ring_emit(engine, lower_32_bits(addr));
 	return 0;
@@ -1650,11 +1650,11 @@ static uint32_t get_pd_offset(struct i915_hw_ppgtt *ppgtt)
 static int hsw_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	int ret;
 	/* NB: TLBs must be flushed and invalidated before a switch */
-	ret = ring->flush(req, I915_GEM_GPU_DOMAINS, I915_GEM_GPU_DOMAINS);
+	ret = engine->flush(req, I915_GEM_GPU_DOMAINS, I915_GEM_GPU_DOMAINS);
 	if (ret)
 		return ret;
@@ -1662,13 +1662,13 @@ static int hsw_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, MI_LOAD_REGISTER_IMM(2));
-	intel_ring_emit_reg(ring, RING_PP_DIR_DCLV(ring));
-	intel_ring_emit(ring, PP_DIR_DCLV_2G);
-	intel_ring_emit_reg(ring, RING_PP_DIR_BASE(ring));
-	intel_ring_emit(ring, get_pd_offset(ppgtt));
+	intel_ring_emit(engine, MI_LOAD_REGISTER_IMM(2));
+	intel_ring_emit_reg(engine, RING_PP_DIR_DCLV(engine));
+	intel_ring_emit(engine, PP_DIR_DCLV_2G);
+	intel_ring_emit_reg(engine, RING_PP_DIR_BASE(engine));
+	intel_ring_emit(engine, get_pd_offset(ppgtt));
 	return 0;
@@ -1676,22 +1676,22 @@ static int hsw_mm_switch(struct i915_hw_ppgtt *ppgtt,
 static int vgpu_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	struct drm_i915_private *dev_priv = to_i915(ppgtt->base.dev);
-	I915_WRITE(RING_PP_DIR_DCLV(ring), PP_DIR_DCLV_2G);
-	I915_WRITE(RING_PP_DIR_BASE(ring), get_pd_offset(ppgtt));
+	I915_WRITE(RING_PP_DIR_DCLV(engine), PP_DIR_DCLV_2G);
+	I915_WRITE(RING_PP_DIR_BASE(engine), get_pd_offset(ppgtt));
 	return 0;
 static int gen7_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	int ret;
 	if (ret)
 		return ret;
@@ -1699,17 +1699,17 @@ static int gen7_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	if (ret)
 		return ret;
 	/* XXX: RCS is the only one to auto invalidate the TLBs? */
 		if (ret)
 			return ret;
@@ -1720,15 +1720,15 @@ static int gen7_mm_switch(struct i915_hw_ppgtt *ppgtt,
 static int gen6_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	struct drm_device *dev = ppgtt->base.dev;
-	POSTING_READ(RING_PP_DIR_DCLV(ring));
+	POSTING_READ(RING_PP_DIR_DCLV(engine));
 	return 0;
@@ -1736,12 +1736,12 @@ static int gen6_mm_switch(struct i915_hw_ppgtt *ppgtt,
 static void gen8_ppgtt_enable(struct drm_device *dev)
 	int j;
-	for_each_ring(ring, dev_priv, j) {
+	for_each_ring(engine, dev_priv, j) {
 		u32 four_level = USES_FULL_48BIT_PPGTT(dev) ? GEN8_GFX_PPGTT_48B : 0;
-		I915_WRITE(RING_MODE_GEN7(ring),
+		I915_WRITE(RING_MODE_GEN7(engine),
 			   _MASKED_BIT_ENABLE(GFX_PPGTT_ENABLE | four_level));
@@ -1749,7 +1749,7 @@ static void gen8_ppgtt_enable(struct drm_device *dev)
 static void gen7_ppgtt_enable(struct drm_device *dev)
 	uint32_t ecochk, ecobits;
 	int i;
@@ -1765,9 +1765,9 @@ static void gen7_ppgtt_enable(struct drm_device *dev)
 	I915_WRITE(GAM_ECOCHK, ecochk);
 		/* GFX_MODE is per-ring on gen7+ */
 			   _MASKED_BIT_ENABLE(GFX_PPGTT_ENABLE));
@@ -2286,15 +2286,15 @@ static void undo_idling(struct drm_i915_private *dev_priv, bool interruptible)
 void i915_check_and_clear_faults(struct drm_device *dev)
 	int i;
 	if (INTEL_INFO(dev)->gen < 6)
 		return;
 		u32 fault_reg;
-		fault_reg = I915_READ(RING_FAULT_REG(ring));
+		fault_reg = I915_READ(RING_FAULT_REG(engine));
 		if (fault_reg & RING_FAULT_VALID) {
 			DRM_DEBUG_DRIVER("Unexpected fault\n"
 					 "\tAddr: 0x%08lx\n"
@@ -2305,7 +2305,7 @@ void i915_check_and_clear_faults(struct drm_device *dev)
 					 fault_reg & RING_FAULT_GTTSEL_MASK ? "GGTT" : "PPGTT",
 					 RING_FAULT_SRCID(fault_reg),
 					 RING_FAULT_FAULT_TYPE(fault_reg));
-			I915_WRITE(RING_FAULT_REG(ring),
+			I915_WRITE(RING_FAULT_REG(engine),
 				   fault_reg & ~RING_FAULT_VALID);
diff --git a/drivers/gpu/drm/i915/i915_gpu_error.c b/drivers/gpu/drm/i915/i915_gpu_error.c
index 13b5f3a..d97cadc 100644
--- a/drivers/gpu/drm/i915/i915_gpu_error.c
+++ b/drivers/gpu/drm/i915/i915_gpu_error.c
@@ -495,9 +495,9 @@ int i915_error_state_to_str(struct drm_i915_error_state_buf *m,
 		if (obj) {
 			u64 wa_ctx_offset = obj->gtt_offset;
 			u32 *wa_ctx_page = &obj->pages[0][0];
-			struct intel_engine_cs *ring = &dev_priv->ring[RCS];
-			u32 wa_ctx_size = (ring->wa_ctx.indirect_ctx.size +
-					   ring->wa_ctx.per_ctx.size);
+			struct intel_engine_cs *engine = &dev_priv->ring[RCS];
+			u32 wa_ctx_size = (engine->wa_ctx.indirect_ctx.size +
+					   engine->wa_ctx.per_ctx.size);
 			err_printf(m, "%s --- WA ctx batch buffer = 0x%08llx\n",
 				   dev_priv->ring[i].name, wa_ctx_offset);
@@ -1019,19 +1019,19 @@ static void i915_gem_record_rings(struct drm_device *dev,
 	int i, count;
 		struct intel_ringbuffer *rbuf;
 		error->ring[i].pid = -1;
-		if (ring->dev == NULL)
+		if (engine->dev == NULL)
 			continue;
 		error->ring[i].valid = true;
-		i915_record_ring_state(dev, error, ring, &error->ring[i]);
+		i915_record_ring_state(dev, error, engine, &error->ring[i]);
-		request = i915_gem_find_active_request(ring);
+		request = i915_gem_find_active_request(engine);
 		if (request) {
@@ -1051,7 +1051,7 @@ static void i915_gem_record_rings(struct drm_device *dev,
 			if (HAS_BROKEN_CS_TLB(dev_priv->dev))
 				error->ring[i].wa_batchbuffer =
 					i915_error_ggtt_object_create(dev_priv,
-							     ring->scratch.obj);
+							     engine->scratch.obj);
 			if (request->pid) {
@@ -1073,11 +1073,11 @@ static void i915_gem_record_rings(struct drm_device *dev,
 			 * executed).
 			if (request)
-				rbuf = request->ctx->engine[ring->id].ringbuf;
+				rbuf = request->ctx->engine[engine->id].ringbuf;
 			else
-				rbuf = dev_priv->kernel_context->engine[ring->id].ringbuf;
+				rbuf = dev_priv->kernel_context->engine[engine->id].ringbuf;
 		} else
-			rbuf = ring->buffer;
+			rbuf = engine->buffer;
 		error->ring[i].cpu_ring_head = rbuf->head;
 		error->ring[i].cpu_ring_tail = rbuf->tail;
@@ -1086,18 +1086,19 @@ static void i915_gem_record_rings(struct drm_device *dev,
 			i915_error_ggtt_object_create(dev_priv, rbuf->obj);
 		error->ring[i].hws_page =
-			i915_error_ggtt_object_create(dev_priv, ring->status_page.obj);
+			i915_error_ggtt_object_create(dev_priv,
+						      engine->status_page.obj);
-		if (ring->wa_ctx.obj) {
+		if (engine->wa_ctx.obj) {
 			error->ring[i].wa_ctx =
-							      ring->wa_ctx.obj);
+							      engine->wa_ctx.obj);
-		i915_gem_record_active_context(ring, error, &error->ring[i]);
+		i915_gem_record_active_context(engine, error, &error->ring[i]);
 		count = 0;
-		list_for_each_entry(request, &ring->request_list, list)
+		list_for_each_entry(request, &engine->request_list, list)
 			count++;
 		error->ring[i].num_requests = count;
@@ -1110,7 +1111,7 @@ static void i915_gem_record_rings(struct drm_device *dev,
 		count = 0;
-		list_for_each_entry(request, &ring->request_list, list) {
+		list_for_each_entry(request, &engine->request_list, list) {
 			struct drm_i915_error_request *erq;
 			if (count >= error->ring[i].num_requests) {
diff --git a/drivers/gpu/drm/i915/i915_guc_submission.c b/drivers/gpu/drm/i915/i915_guc_submission.c
index d7543ef..15a4beb 100644
--- a/drivers/gpu/drm/i915/i915_guc_submission.c
+++ b/drivers/gpu/drm/i915/i915_guc_submission.c
@@ -377,7 +377,7 @@ static void guc_init_ctx_desc(struct intel_guc *guc,
 	struct drm_i915_private *dev_priv = guc_to_i915(guc);
 	struct intel_context *ctx = client->owner;
 	struct guc_context_desc desc;
 	struct sg_table *sg;
@@ -390,8 +390,8 @@ static void guc_init_ctx_desc(struct intel_guc *guc,
 	desc.priority = client->priority;
 	desc.db_id = client->doorbell_id;
-		struct guc_execlist_context *lrc = &desc.lrc[ring->guc_id];
+		struct guc_execlist_context *lrc = &desc.lrc[engine->guc_id];
 		uint64_t ctx_desc;
@@ -406,14 +406,14 @@ static void guc_init_ctx_desc(struct intel_guc *guc,
 		if (!obj)
 			break;	/* XXX: continue? */
-		ctx_desc = intel_lr_context_descriptor(ctx, ring);
+		ctx_desc = intel_lr_context_descriptor(ctx, engine);
 		lrc->context_desc = (u32)ctx_desc;
 		/* The state page is after PPHWSP */
 		lrc->ring_lcra = i915_gem_obj_ggtt_offset(obj) +
 				LRC_STATE_PN * PAGE_SIZE;
 		lrc->context_id = (client->ctx_index << GUC_ELC_CTXID_OFFSET) |
-				(ring->guc_id << GUC_ELC_ENGINE_OFFSET);
+				(engine->guc_id << GUC_ELC_ENGINE_OFFSET);
 		obj = ctx->engine[i].ringbuf->obj;
@@ -422,7 +422,7 @@ static void guc_init_ctx_desc(struct intel_guc *guc,
 		lrc->ring_next_free_location = lrc->ring_begin;
 		lrc->ring_current_tail_pointer_value = 0;
-		desc.engines_used |= (1 << ring->guc_id);
+		desc.engines_used |= (1 << engine->guc_id);
 	WARN_ON(desc.engines_used == 0);
@@ -839,7 +839,7 @@ static void guc_create_ads(struct intel_guc *guc)
 	struct guc_ads *ads;
 	struct guc_policies *policies;
 	struct guc_mmio_reg_state *reg_state;
 	struct page *page;
 	u32 size, i;
@@ -867,11 +867,11 @@ static void guc_create_ads(struct intel_guc *guc)
 	 * so its address won't change after we've told the GuC where
 	 * to find it.
-	ring = &dev_priv->ring[RCS];
-	ads->golden_context_lrca = ring->status_page.gfx_addr;
+	engine = &dev_priv->ring[RCS];
+	ads->golden_context_lrca = engine->status_page.gfx_addr;
-		ads->eng_state_size[ring->guc_id] = intel_lr_context_size(ring);
+		ads->eng_state_size[engine->guc_id] = intel_lr_context_size(engine);
 	/* GuC scheduling policies */
 	policies = (void *)ads + sizeof(struct guc_ads);
@@ -883,12 +883,12 @@ static void guc_create_ads(struct intel_guc *guc)
 	/* MMIO reg state */
 	reg_state = (void *)policies + sizeof(struct guc_policies);
-		reg_state->mmio_white_list[ring->guc_id].mmio_start =
-			ring->mmio_base + GUC_MMIO_WHITE_LIST_START;
+		reg_state->mmio_white_list[engine->guc_id].mmio_start =
+			engine->mmio_base + GUC_MMIO_WHITE_LIST_START;
 		/* Nothing to be saved or restored for now. */
-		reg_state->mmio_white_list[ring->guc_id].count = 0;
+		reg_state->mmio_white_list[engine->guc_id].count = 0;
 	ads->reg_state_addr = ads->scheduler_policies +
diff --git a/drivers/gpu/drm/i915/i915_irq.c b/drivers/gpu/drm/i915/i915_irq.c
index 53e5104..f172de0 100644
--- a/drivers/gpu/drm/i915/i915_irq.c
+++ b/drivers/gpu/drm/i915/i915_irq.c
@@ -1079,11 +1079,11 @@ static u32 vlv_wa_c0_ei(struct drm_i915_private *dev_priv, u32 pm_iir)
 static bool any_waiters(struct drm_i915_private *dev_priv)
 	int i;
-		if (ring->irq_refcount)
+		if (engine->irq_refcount)
 			return true;
 	return false;
@@ -2449,7 +2449,7 @@ static irqreturn_t gen8_irq_handler(int irq, void *arg)
 static void i915_error_wake_up(struct drm_i915_private *dev_priv,
 			       bool reset_completed)
 	int i;
@@ -2460,8 +2460,8 @@ static void i915_error_wake_up(struct drm_i915_private *dev_priv,
 	/* Wake up __wait_seqno, potentially holding dev->struct_mutex. */
-		wake_up_all(&ring->irq_queue);
+		wake_up_all(&engine->irq_queue);
 	/* Wake up intel_crtc_wait_for_pending_flips, holding crtc->mutex. */
 	wake_up_all(&dev_priv->pending_flip_queue);
@@ -2956,11 +2956,11 @@ static int semaphore_passed(struct intel_engine_cs *ring)
 static void semaphore_clear_deadlocks(struct drm_i915_private *dev_priv)
 	int i;
-		ring->hangcheck.deadlock = 0;
+		engine->hangcheck.deadlock = 0;
 static bool subunits_stuck(struct intel_engine_cs *ring)
@@ -3071,7 +3071,7 @@ static void i915_hangcheck_elapsed(struct work_struct *work)
 		container_of(work, typeof(*dev_priv),
 			     gpu_error.hangcheck_work.work);
 	struct drm_device *dev = dev_priv->dev;
 	int i;
 	int busy_count = 0, rings_hung = 0;
 	bool stuck[I915_NUM_RINGS] = { 0 };
@@ -3096,33 +3096,33 @@ static void i915_hangcheck_elapsed(struct work_struct *work)
 	intel_uncore_arm_unclaimed_mmio_detection(dev_priv);
 		u64 acthd;
 		u32 seqno;
 		bool busy = true;
 		semaphore_clear_deadlocks(dev_priv);
-		seqno = ring->get_seqno(ring, false);
-		acthd = intel_ring_get_active_head(ring);
+		seqno = engine->get_seqno(engine, false);
+		acthd = intel_ring_get_active_head(engine);
-		if (ring->hangcheck.seqno == seqno) {
-			if (ring_idle(ring, seqno)) {
-				ring->hangcheck.action = HANGCHECK_IDLE;
+		if (engine->hangcheck.seqno == seqno) {
+			if (ring_idle(engine, seqno)) {
+				engine->hangcheck.action = HANGCHECK_IDLE;
-				if (waitqueue_active(&ring->irq_queue)) {
+				if (waitqueue_active(&engine->irq_queue)) {
 					/* Issue a wake-up to catch stuck h/w. */
-					if (!test_and_set_bit(ring->id, &dev_priv->gpu_error.missed_irq_rings)) {
-						if (!(dev_priv->gpu_error.test_irq_rings & intel_ring_flag(ring)))
+					if (!test_and_set_bit(engine->id, &dev_priv->gpu_error.missed_irq_rings)) {
+						if (!(dev_priv->gpu_error.test_irq_rings & intel_ring_flag(engine)))
 							DRM_ERROR("Hangcheck timer elapsed... %s idle\n",
-								  ring->name);
+								  engine->name);
 						else
 							DRM_INFO("Fake missed irq on %s\n",
-								 ring->name);
+								 engine->name);
 					/* Safeguard against driver failure */
-					ring->hangcheck.score += BUSY;
+					engine->hangcheck.score += BUSY;
 				} else
 					busy = false;
 			} else {
@@ -3141,53 +3141,53 @@ static void i915_hangcheck_elapsed(struct work_struct *work)
 				 * being repeatedly kicked and so responsible
 				 * for stalling the machine.
-				ring->hangcheck.action = ring_stuck(ring,
-								    acthd);
+				engine->hangcheck.action = ring_stuck(engine,
+								      acthd);
-				switch (ring->hangcheck.action) {
+				switch (engine->hangcheck.action) {
 				case HANGCHECK_IDLE:
 				case HANGCHECK_WAIT:
 					break;
 				case HANGCHECK_ACTIVE:
 					break;
 				case HANGCHECK_KICK:
-					ring->hangcheck.score += KICK;
+					engine->hangcheck.score += KICK;
 					break;
 				case HANGCHECK_HUNG:
-					ring->hangcheck.score += HUNG;
+					engine->hangcheck.score += HUNG;
 					stuck[i] = true;
 					break;
 		} else {
-			ring->hangcheck.action = HANGCHECK_ACTIVE;
+			engine->hangcheck.action = HANGCHECK_ACTIVE;
 			/* Gradually reduce the count so that we catch DoS
 			 * attempts across multiple batches.
-			if (ring->hangcheck.score > 0)
-				ring->hangcheck.score -= ACTIVE_DECAY;
-			if (ring->hangcheck.score < 0)
-				ring->hangcheck.score = 0;
+			if (engine->hangcheck.score > 0)
+				engine->hangcheck.score -= ACTIVE_DECAY;
+			if (engine->hangcheck.score < 0)
+				engine->hangcheck.score = 0;
 			/* Clear head and subunit states on seqno movement */
-			ring->hangcheck.acthd = 0;
+			engine->hangcheck.acthd = 0;
-			memset(ring->hangcheck.instdone, 0,
-			       sizeof(ring->hangcheck.instdone));
+			memset(engine->hangcheck.instdone, 0,
+			       sizeof(engine->hangcheck.instdone));
-		ring->hangcheck.seqno = seqno;
-		ring->hangcheck.acthd = acthd;
+		engine->hangcheck.seqno = seqno;
+		engine->hangcheck.acthd = acthd;
 		busy_count += busy;
-		if (ring->hangcheck.score >= HANGCHECK_SCORE_RING_HUNG) {
+		if (engine->hangcheck.score >= HANGCHECK_SCORE_RING_HUNG) {
 			DRM_INFO("%s on %s\n",
 				 stuck[i] ? "stuck" : "no progress",
-				 ring->name);
+				 engine->name);
 			rings_hung++;
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index 4c04dab..e95f2b7 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -10984,7 +10984,7 @@ static int intel_gen2_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
 	struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
 	u32 flip_mask;
 	int ret;
@@ -11000,13 +11000,13 @@ static int intel_gen2_queue_flip(struct drm_device *dev,
 		flip_mask = MI_WAIT_FOR_PLANE_B_FLIP;
 	else
 		flip_mask = MI_WAIT_FOR_PLANE_A_FLIP;
-	intel_ring_emit(ring, MI_WAIT_FOR_EVENT | flip_mask);
-	intel_ring_emit(ring, MI_DISPLAY_FLIP |
+	intel_ring_emit(engine, MI_WAIT_FOR_EVENT | flip_mask);
+	intel_ring_emit(engine, MI_DISPLAY_FLIP |
 			MI_DISPLAY_FLIP_PLANE(intel_crtc->plane));
-	intel_ring_emit(ring, fb->pitches[0]);
-	intel_ring_emit(ring, intel_crtc->unpin_work->gtt_offset);
-	intel_ring_emit(ring, 0); /* aux display base address, unused */
+	intel_ring_emit(engine, fb->pitches[0]);
+	intel_ring_emit(engine, intel_crtc->unpin_work->gtt_offset);
+	intel_ring_emit(engine, 0); /* aux display base address, unused */
 	intel_mark_page_flip_active(intel_crtc->unpin_work);
 	return 0;
@@ -11019,7 +11019,7 @@ static int intel_gen3_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
 	u32 flip_mask;
 	int ret;
@@ -11032,13 +11032,13 @@ static int intel_gen3_queue_flip(struct drm_device *dev,
 	else
-	intel_ring_emit(ring, MI_DISPLAY_FLIP_I915 |
+	intel_ring_emit(engine, MI_DISPLAY_FLIP_I915 |
 	return 0;
@@ -11051,7 +11051,7 @@ static int intel_gen4_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
 	uint32_t pf, pipesrc;
@@ -11065,10 +11065,10 @@ static int intel_gen4_queue_flip(struct drm_device *dev,
 	 * Display Registers (which do not change across a page-flip)
 	 * so we need only reprogram the base address.
-	intel_ring_emit(ring, intel_crtc->unpin_work->gtt_offset |
+	intel_ring_emit(engine, intel_crtc->unpin_work->gtt_offset |
 			obj->tiling_mode);
 	/* XXX Enabling the panel-fitter across page-flip is so far
@@ -11077,7 +11077,7 @@ static int intel_gen4_queue_flip(struct drm_device *dev,
 	pf = 0;
 	pipesrc = I915_READ(PIPESRC(intel_crtc->pipe)) & 0x0fff0fff;
-	intel_ring_emit(ring, pf | pipesrc);
+	intel_ring_emit(engine, pf | pipesrc);
 	return 0;
@@ -11090,7 +11090,7 @@ static int intel_gen6_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
@@ -11100,10 +11100,10 @@ static int intel_gen6_queue_flip(struct drm_device *dev,
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, fb->pitches[0] | obj->tiling_mode);
+	intel_ring_emit(engine, fb->pitches[0] | obj->tiling_mode);
 	/* Contrary to the suggestions in the documentation,
 	 * "Enable Panel Fitter" does not seem to be required when page
@@ -11113,7 +11113,7 @@ static int intel_gen6_queue_flip(struct drm_device *dev,
 	pf = 0;
 	return 0;
@@ -11126,7 +11126,7 @@ static int intel_gen7_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
 	uint32_t plane_bit = 0;
 	int len, ret;
@@ -11147,7 +11147,7 @@ static int intel_gen7_queue_flip(struct drm_device *dev,
 	len = 4;
 		len += 6;
 		 * On Gen 8, SRM is now taking an extra dword to accommodate
@@ -11185,30 +11185,30 @@ static int intel_gen7_queue_flip(struct drm_device *dev,
 	 * for the RCS also doesn't appear to drop events. Setting the DERRMR
 	 * to zero does lead to lockups within MI_DISPLAY_FLIP.
-		intel_ring_emit_reg(ring, DERRMR);
-		intel_ring_emit(ring, ~(DERRMR_PIPEA_PRI_FLIP_DONE |
-					DERRMR_PIPEB_PRI_FLIP_DONE |
-					DERRMR_PIPEC_PRI_FLIP_DONE));
+		intel_ring_emit_reg(engine, DERRMR);
+		intel_ring_emit(engine, ~(DERRMR_PIPEA_PRI_FLIP_DONE |
+					  DERRMR_PIPEB_PRI_FLIP_DONE |
+					  DERRMR_PIPEC_PRI_FLIP_DONE));
 		if (IS_GEN8(dev))
-			intel_ring_emit(ring, MI_STORE_REGISTER_MEM_GEN8 |
+			intel_ring_emit(engine, MI_STORE_REGISTER_MEM_GEN8 |
 					      MI_SRM_LRM_GLOBAL_GTT);
 		else
-			intel_ring_emit(ring, MI_STORE_REGISTER_MEM |
+			intel_ring_emit(engine, MI_STORE_REGISTER_MEM |
-		intel_ring_emit(ring, ring->scratch.gtt_offset + 256);
+		intel_ring_emit(engine, engine->scratch.gtt_offset + 256);
 		if (IS_GEN8(dev)) {
-	intel_ring_emit(ring, MI_DISPLAY_FLIP_I915 | plane_bit);
-	intel_ring_emit(ring, (fb->pitches[0] | obj->tiling_mode));
-	intel_ring_emit(ring, (MI_NOOP));
+	intel_ring_emit(engine, MI_DISPLAY_FLIP_I915 | plane_bit);
+	intel_ring_emit(engine, (fb->pitches[0] | obj->tiling_mode));
+	intel_ring_emit(engine, (MI_NOOP));
 	return 0;
@@ -11488,7 +11488,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	struct drm_plane *primary = crtc->primary;
 	enum pipe pipe = intel_crtc->pipe;
 	struct intel_unpin_work *work;
 	bool mmio_flip;
 	struct drm_i915_gem_request *request = NULL;
 	int ret;
@@ -11575,21 +11575,21 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 		work->flip_count = I915_READ(PIPE_FLIPCOUNT_G4X(pipe)) + 1;
 	if (IS_VALLEYVIEW(dev) || IS_CHERRYVIEW(dev)) {
-		ring = &dev_priv->ring[BCS];
+		engine = &dev_priv->ring[BCS];
 		if (obj->tiling_mode != intel_fb_obj(work->old_fb)->tiling_mode)
 			/* vlv: DISPLAY_FLIP fails to change tiling */
-			ring = NULL;
+			engine = NULL;
 	} else if (IS_IVYBRIDGE(dev) || IS_HASWELL(dev)) {
 	} else if (INTEL_INFO(dev)->gen >= 7) {
-		ring = i915_gem_request_get_ring(obj->last_write_req);
-		if (ring == NULL || ring->id != RCS)
+		engine = i915_gem_request_get_ring(obj->last_write_req);
+		if (engine == NULL || engine->id != RCS)
 	} else {
-	mmio_flip = use_mmio_flip(ring, obj);
+	mmio_flip = use_mmio_flip(engine, obj);
 	/* When using CS flips, we want to emit semaphores between rings.
 	 * However, when using mmio flips we will create a task to do the
@@ -11597,7 +11597,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	 * into the display plane and skip any waits.
 	if (!mmio_flip) {
-		ret = i915_gem_object_sync(obj, ring, &request);
+		ret = i915_gem_object_sync(obj, engine, &request);
 		if (ret)
 			goto cleanup_pending;
@@ -11619,7 +11619,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 	} else {
 		if (!request) {
-			request = i915_gem_request_alloc(ring, NULL);
+			request = i915_gem_request_alloc(engine, NULL);
 			if (IS_ERR(request)) {
 				ret = PTR_ERR(request);
 				goto cleanup_unpin;
diff --git a/drivers/gpu/drm/i915/intel_guc_loader.c b/drivers/gpu/drm/i915/intel_guc_loader.c
index 82a3c03..fc2c518 100644
--- a/drivers/gpu/drm/i915/intel_guc_loader.c
+++ b/drivers/gpu/drm/i915/intel_guc_loader.c
@@ -81,14 +81,14 @@ const char *intel_guc_fw_status_repr(enum intel_guc_fw_status status)
 static void direct_interrupts_to_host(struct drm_i915_private *dev_priv)
-	struct intel_engine_cs *ring;
+	struct intel_engine_cs *engine;
 	int i, irqs;
 	/* tell all command streamers NOT to forward interrupts and vblank to GuC */
 	irqs = _MASKED_FIELD(GFX_FORWARD_VBLANK_MASK, GFX_FORWARD_VBLANK_NEVER);
 	irqs |= _MASKED_BIT_DISABLE(GFX_INTERRUPT_STEERING);
-		I915_WRITE(RING_MODE_GEN7(ring), irqs);
+		I915_WRITE(RING_MODE_GEN7(engine), irqs);
 	/* route all GT interrupts to the host */
 	I915_WRITE(GUC_BCS_RCS_IER, 0);
@@ -98,14 +98,14 @@ static void direct_interrupts_to_host(struct drm_i915_private *dev_priv)
 static void direct_interrupts_to_guc(struct drm_i915_private *dev_priv)
 	int i, irqs;
 	/* tell all command streamers to forward interrupts and vblank to GuC */
 	irqs = _MASKED_FIELD(GFX_FORWARD_VBLANK_MASK, GFX_FORWARD_VBLANK_ALWAYS);
 	irqs |= _MASKED_BIT_ENABLE(GFX_INTERRUPT_STEERING);
 	/* route USER_INTERRUPT to Host, all others are sent to GuC. */
 	irqs = GT_RENDER_USER_INTERRUPT << GEN8_RCS_IRQ_SHIFT |
diff --git a/drivers/gpu/drm/i915/intel_lrc.c b/drivers/gpu/drm/i915/intel_lrc.c
index 6fcbf6b..448c68e 100644
--- a/drivers/gpu/drm/i915/intel_lrc.c
+++ b/drivers/gpu/drm/i915/intel_lrc.c
@@ -360,8 +360,8 @@ static void execlists_elsp_write(struct drm_i915_gem_request *rq0,
 				 struct drm_i915_gem_request *rq1)
-	struct intel_engine_cs *ring = rq0->ring;
+	struct intel_engine_cs *engine = rq0->ring;
 	uint64_t desc[2];
@@ -376,15 +376,15 @@ static void execlists_elsp_write(struct drm_i915_gem_request *rq0,
 	rq0->elsp_submitted++;
 	/* You must always write both descriptors in the order below. */
-	I915_WRITE_FW(RING_ELSP(ring), upper_32_bits(desc[1]));
-	I915_WRITE_FW(RING_ELSP(ring), lower_32_bits(desc[1]));
+	I915_WRITE_FW(RING_ELSP(engine), upper_32_bits(desc[1]));
+	I915_WRITE_FW(RING_ELSP(engine), lower_32_bits(desc[1]));
-	I915_WRITE_FW(RING_ELSP(ring), upper_32_bits(desc[0]));
+	I915_WRITE_FW(RING_ELSP(engine), upper_32_bits(desc[0]));
 	/* The context is automatically loaded after the following */
-	I915_WRITE_FW(RING_ELSP(ring), lower_32_bits(desc[0]));
+	I915_WRITE_FW(RING_ELSP(engine), lower_32_bits(desc[0]));
 	/* ELSP is a wo register, use another nearby reg for posting */
-	POSTING_READ_FW(RING_EXECLIST_STATUS_LO(ring));
+	POSTING_READ_FW(RING_EXECLIST_STATUS_LO(engine));
 static void
@@ -398,9 +398,9 @@ execlists_update_context_pdps(struct i915_hw_ppgtt *ppgtt, u32 *reg_state)
 static void execlists_update_context(struct drm_i915_gem_request *rq)
-	struct intel_engine_cs *ring = rq->ring;
+	struct intel_engine_cs *engine = rq->ring;
 	struct i915_hw_ppgtt *ppgtt = rq->ctx->ppgtt;
-	uint32_t *reg_state = rq->ctx->engine[ring->id].lrc_reg_state;
+	uint32_t *reg_state = rq->ctx->engine[engine->id].lrc_reg_state;
 	reg_state[CTX_RING_TAIL+1] = rq->tail;
@@ -609,25 +609,25 @@ void intel_lrc_irq_handler(struct intel_engine_cs *ring)
 static void execlists_context_queue(struct drm_i915_gem_request *request)
-	struct intel_engine_cs *ring = request->ring;
+	struct intel_engine_cs *engine = request->ring;
 	struct drm_i915_gem_request *cursor;
 	int num_elements = 0;
 	if (request->ctx != request->i915->kernel_context)
-		intel_lr_context_pin(request->ctx, ring);
+		intel_lr_context_pin(request->ctx, engine);
 	i915_gem_request_reference(request);
-	list_for_each_entry(cursor, &ring->execlist_queue, execlist_link)
+	list_for_each_entry(cursor, &engine->execlist_queue, execlist_link)
 		if (++num_elements > 2)
 			break;
 	if (num_elements > 2) {
 		struct drm_i915_gem_request *tail_req;
-		tail_req = list_last_entry(&ring->execlist_queue,
+		tail_req = list_last_entry(&engine->execlist_queue,
 					   execlist_link);
@@ -635,32 +635,32 @@ static void execlists_context_queue(struct drm_i915_gem_request *request)
 			WARN(tail_req->elsp_submitted != 0,
 				"More than 2 already-submitted reqs queued\n");
 			list_move_tail(&tail_req->execlist_link,
-				       &ring->execlist_retired_req_list);
+				       &engine->execlist_retired_req_list);
-	list_add_tail(&request->execlist_link, &ring->execlist_queue);
+	list_add_tail(&request->execlist_link, &engine->execlist_queue);
 	if (num_elements == 0)
-		execlists_context_unqueue(ring);
+		execlists_context_unqueue(engine);
 static int logical_ring_invalidate_all_caches(struct drm_i915_gem_request *req)
 	uint32_t flush_domains;
 	int ret;
 	flush_domains = 0;
-	if (ring->gpu_caches_dirty)
+	if (engine->gpu_caches_dirty)
 		flush_domains = I915_GEM_GPU_DOMAINS;
-	ret = ring->emit_flush(req, I915_GEM_GPU_DOMAINS, flush_domains);
+	ret = engine->emit_flush(req, I915_GEM_GPU_DOMAINS, flush_domains);
 	if (ret)
 		return ret;
-	ring->gpu_caches_dirty = false;
+	engine->gpu_caches_dirty = false;
 	return 0;
@@ -726,7 +726,7 @@ static int logical_ring_wait_for_space(struct drm_i915_gem_request *req,
 				       int bytes)
 	struct intel_ringbuffer *ringbuf = req->ringbuf;
 	struct drm_i915_gem_request *target;
 	unsigned space;
 	int ret;
@@ -737,7 +737,7 @@ static int logical_ring_wait_for_space(struct drm_i915_gem_request *req,
 	/* The whole point of reserving space is to not wait! */
 	WARN_ON(ringbuf->reserved_in_use);
-	list_for_each_entry(target, &ring->request_list, list) {
+	list_for_each_entry(target, &engine->request_list, list) {
 		 * The request queue is per-engine, so can contain requests
 		 * from multiple ringbuffers. Here, we must ignore any that
@@ -753,7 +753,7 @@ static int logical_ring_wait_for_space(struct drm_i915_gem_request *req,
 			break;
-	if (WARN_ON(&target->list == &ring->request_list))
+	if (WARN_ON(&target->list == &engine->request_list))
 		return -ENOSPC;
 	ret = i915_wait_request(target);
@@ -947,9 +947,9 @@ int intel_execlists_submission(struct i915_execbuffer_params *params,
 	struct drm_i915_private *dev_priv = dev->dev_private;
-	struct intel_ringbuffer *ringbuf = params->ctx->engine[ring->id].ringbuf;
+	struct intel_ringbuffer *ringbuf = params->ctx->engine[engine->id].ringbuf;
 	u64 exec_start;
 	int instp_mode;
 	u32 instp_mask;
@@ -961,7 +961,7 @@ int intel_execlists_submission(struct i915_execbuffer_params *params,
 			return -EINVAL;
@@ -990,7 +990,7 @@ int intel_execlists_submission(struct i915_execbuffer_params *params,
 	if (ret)
 		return ret;
 		ret = intel_logical_ring_begin(params->request, 4);
 		if (ret)
@@ -1008,7 +1008,7 @@ int intel_execlists_submission(struct i915_execbuffer_params *params,
 	exec_start = params->batch_obj_vm_offset +
-	ret = ring->emit_bb_start(params->request, exec_start, params->dispatch_flags);
+	ret = engine->emit_bb_start(params->request, exec_start, params->dispatch_flags);
 	if (ret)
 		return ret;
@@ -1071,17 +1071,17 @@ void intel_logical_ring_stop(struct intel_engine_cs *ring)
 int logical_ring_flush_all_caches(struct drm_i915_gem_request *req)
 	int ret;
-	if (!ring->gpu_caches_dirty)
+	if (!engine->gpu_caches_dirty)
 		return 0;
-	ret = ring->emit_flush(req, 0, I915_GEM_GPU_DOMAINS);
+	ret = engine->emit_flush(req, 0, I915_GEM_GPU_DOMAINS);
 	if (ret)
 		return ret;
 	return 0;
@@ -1172,16 +1172,16 @@ void intel_lr_context_unpin(struct intel_context *ctx,
 static int intel_logical_ring_workarounds_emit(struct drm_i915_gem_request *req)
 	int ret, i;
 	struct i915_workarounds *w = &dev_priv->workarounds;
 	if (w->count == 0)
 		return 0;
-	ring->gpu_caches_dirty = true;
+	engine->gpu_caches_dirty = true;
 	ret = logical_ring_flush_all_caches(req);
 	if (ret)
 		return ret;
@@ -1199,7 +1199,7 @@ static int intel_logical_ring_workarounds_emit(struct drm_i915_gem_request *req)
 	intel_logical_ring_advance(ringbuf);
 	if (ret)
 		return ret;
@@ -1643,7 +1643,7 @@ static int gen9_init_render_ring(struct intel_engine_cs *ring)
 static int intel_logical_ring_emit_pdps(struct drm_i915_gem_request *req)
 	struct i915_hw_ppgtt *ppgtt = req->ctx->ppgtt;
 	const int num_lri_cmds = GEN8_LEGACY_PDPES * 2;
 	int i, ret;
@@ -1656,9 +1656,11 @@ static int intel_logical_ring_emit_pdps(struct drm_i915_gem_request *req)
 	for (i = GEN8_LEGACY_PDPES - 1; i >= 0; i--) {
 		const dma_addr_t pd_daddr = i915_page_dir_dma_addr(ppgtt, i);
-		intel_logical_ring_emit_reg(ringbuf, GEN8_RING_PDP_UDW(ring, i));
+		intel_logical_ring_emit_reg(ringbuf,
+					    GEN8_RING_PDP_UDW(engine, i));
 		intel_logical_ring_emit(ringbuf, upper_32_bits(pd_daddr));
-		intel_logical_ring_emit_reg(ringbuf, GEN8_RING_PDP_LDW(ring, i));
+					    GEN8_RING_PDP_LDW(engine, i));
 		intel_logical_ring_emit(ringbuf, lower_32_bits(pd_daddr));
@@ -1748,8 +1750,8 @@ static int gen8_emit_flush(struct drm_i915_gem_request *request,
 			   u32 unused)
 	struct intel_ringbuffer *ringbuf = request->ringbuf;
-	struct intel_engine_cs *ring = ringbuf->ring;
+	struct intel_engine_cs *engine = ringbuf->ring;
 	uint32_t cmd;
 	int ret;
@@ -1769,7 +1771,7 @@ static int gen8_emit_flush(struct drm_i915_gem_request *request,
 	if (invalidate_domains & I915_GEM_GPU_DOMAINS) {
 		cmd |= MI_INVALIDATE_TLB;
-		if (ring == &dev_priv->ring[VCS])
+		if (engine == &dev_priv->ring[VCS])
 			cmd |= MI_INVALIDATE_BSD;
@@ -1789,8 +1791,8 @@ static int gen8_emit_flush_render(struct drm_i915_gem_request *request,
 				  u32 flush_domains)
-	u32 scratch_addr = ring->scratch.gtt_offset + 2 * CACHELINE_BYTES;
+	u32 scratch_addr = engine->scratch.gtt_offset + 2 * CACHELINE_BYTES;
 	bool vf_flush_wa = false;
 	u32 flags = 0;
 	int ret;
@@ -1818,7 +1820,7 @@ static int gen8_emit_flush_render(struct drm_i915_gem_request *request,
 		 * On GEN9: before VF_CACHE_INVALIDATE we need to emit a NULL
 		 * pipe control.
-		if (IS_GEN9(ring->dev))
+		if (IS_GEN9(engine->dev))
 			vf_flush_wa = true;
@@ -2109,38 +2111,38 @@ error:
 static int logical_render_ring_init(struct drm_device *dev)
 	int ret;
-	ring->name = "render ring";
-	ring->id = RCS;
-	ring->exec_id = I915_EXEC_RENDER;
-	ring->guc_id = GUC_RENDER_ENGINE;
-	ring->mmio_base = RENDER_RING_BASE;
+	engine->name = "render ring";
+	engine->id = RCS;
+	engine->exec_id = I915_EXEC_RENDER;
+	engine->guc_id = GUC_RENDER_ENGINE;
+	engine->mmio_base = RENDER_RING_BASE;
-	logical_ring_default_irqs(ring, GEN8_RCS_IRQ_SHIFT);
+	logical_ring_default_irqs(engine, GEN8_RCS_IRQ_SHIFT);
 	if (HAS_L3_DPF(dev))
-		ring->irq_keep_mask |= GT_RENDER_L3_PARITY_ERROR_INTERRUPT;
+		engine->irq_keep_mask |= GT_RENDER_L3_PARITY_ERROR_INTERRUPT;
-	logical_ring_default_vfuncs(dev, ring);
+	logical_ring_default_vfuncs(dev, engine);
 	/* Override some for render ring. */
 	if (INTEL_INFO(dev)->gen >= 9)
-		ring->init_hw = gen9_init_render_ring;
+		engine->init_hw = gen9_init_render_ring;
 	else
-		ring->init_hw = gen8_init_render_ring;
-	ring->init_context = gen8_init_rcs_context;
-	ring->cleanup = intel_fini_pipe_control;
-	ring->emit_flush = gen8_emit_flush_render;
-	ring->emit_request = gen8_emit_request_render;
+		engine->init_hw = gen8_init_render_ring;
+	engine->init_context = gen8_init_rcs_context;
+	engine->cleanup = intel_fini_pipe_control;
+	engine->emit_flush = gen8_emit_flush_render;
+	engine->emit_request = gen8_emit_request_render;
-	ring->dev = dev;
+	engine->dev = dev;
-	ret = intel_init_pipe_control(ring);
+	ret = intel_init_pipe_control(engine);
 	if (ret)
 		return ret;
-	ret = intel_init_workaround_bb(ring);
+	ret = intel_init_workaround_bb(engine);
 	if (ret) {
 		 * We continue even if we fail to initialize WA batch
@@ -2151,9 +2153,9 @@ static int logical_render_ring_init(struct drm_device *dev)
 			  ret);
-	ret = logical_ring_init(dev, ring);
+	ret = logical_ring_init(dev, engine);
 	if (ret) {
-		lrc_destroy_wa_ctx_obj(ring);
+		lrc_destroy_wa_ctx_obj(engine);
 	return ret;
@@ -2162,69 +2164,69 @@ static int logical_render_ring_init(struct drm_device *dev)
 static int logical_bsd_ring_init(struct drm_device *dev)
-	struct intel_engine_cs *ring = &dev_priv->ring[VCS];
+	struct intel_engine_cs *engine = &dev_priv->ring[VCS];
-	ring->name = "bsd ring";
-	ring->id = VCS;
-	ring->exec_id = I915_EXEC_BSD;
-	ring->guc_id = GUC_VIDEO_ENGINE;
-	ring->mmio_base = GEN6_BSD_RING_BASE;
+	engine->name = "bsd ring";
+	engine->id = VCS;
+	engine->exec_id = I915_EXEC_BSD;
+	engine->guc_id = GUC_VIDEO_ENGINE;
+	engine->mmio_base = GEN6_BSD_RING_BASE;
-	logical_ring_default_irqs(ring, GEN8_VCS1_IRQ_SHIFT);
+	logical_ring_default_irqs(engine, GEN8_VCS1_IRQ_SHIFT);
-	return logical_ring_init(dev, ring);
+	return logical_ring_init(dev, engine);
 static int logical_bsd2_ring_init(struct drm_device *dev)
-	struct intel_engine_cs *ring = &dev_priv->ring[VCS2];
+	struct intel_engine_cs *engine = &dev_priv->ring[VCS2];
-	ring->name = "bsd2 ring";
-	ring->id = VCS2;
-	ring->guc_id = GUC_VIDEO_ENGINE2;
-	ring->mmio_base = GEN8_BSD2_RING_BASE;
+	engine->name = "bsd2 ring";
+	engine->id = VCS2;
+	engine->guc_id = GUC_VIDEO_ENGINE2;
+	engine->mmio_base = GEN8_BSD2_RING_BASE;
-	logical_ring_default_irqs(ring, GEN8_VCS2_IRQ_SHIFT);
+	logical_ring_default_irqs(engine, GEN8_VCS2_IRQ_SHIFT);
 static int logical_blt_ring_init(struct drm_device *dev)
-	struct intel_engine_cs *ring = &dev_priv->ring[BCS];
+	struct intel_engine_cs *engine = &dev_priv->ring[BCS];
-	ring->name = "blitter ring";
-	ring->id = BCS;
-	ring->exec_id = I915_EXEC_BLT;
-	ring->guc_id = GUC_BLITTER_ENGINE;
-	ring->mmio_base = BLT_RING_BASE;
+	engine->name = "blitter ring";
+	engine->id = BCS;
+	engine->exec_id = I915_EXEC_BLT;
+	engine->guc_id = GUC_BLITTER_ENGINE;
+	engine->mmio_base = BLT_RING_BASE;
-	logical_ring_default_irqs(ring, GEN8_BCS_IRQ_SHIFT);
+	logical_ring_default_irqs(engine, GEN8_BCS_IRQ_SHIFT);
 static int logical_vebox_ring_init(struct drm_device *dev)
-	struct intel_engine_cs *ring = &dev_priv->ring[VECS];
+	struct intel_engine_cs *engine = &dev_priv->ring[VECS];
-	ring->name = "video enhancement ring";
-	ring->id = VECS;
-	ring->exec_id = I915_EXEC_VEBOX;
-	ring->guc_id = GUC_VIDEOENHANCE_ENGINE;
-	ring->mmio_base = VEBOX_RING_BASE;
+	engine->name = "video enhancement ring";
+	engine->id = VECS;
+	engine->exec_id = I915_EXEC_VEBOX;
+	engine->guc_id = GUC_VIDEOENHANCE_ENGINE;
+	engine->mmio_base = VEBOX_RING_BASE;
-	logical_ring_default_irqs(ring, GEN8_VECS_IRQ_SHIFT);
+	logical_ring_default_irqs(engine, GEN8_VECS_IRQ_SHIFT);
@@ -2639,14 +2641,14 @@ void intel_lr_context_reset(struct drm_device *dev,
 			struct intel_context *ctx)
 	int i;
-	for_each_ring(ring, dev_priv, i) {
+	for_each_ring(engine, dev_priv, i) {
 		struct drm_i915_gem_object *ctx_obj =
-				ctx->engine[ring->id].state;
+				ctx->engine[engine->id].state;
-				ctx->engine[ring->id].ringbuf;
+				ctx->engine[engine->id].ringbuf;
 		uint32_t *reg_state;
 		struct page *page;
diff --git a/drivers/gpu/drm/i915/intel_mocs.c b/drivers/gpu/drm/i915/intel_mocs.c
index fed7bea..d559259 100644
--- a/drivers/gpu/drm/i915/intel_mocs.c
+++ b/drivers/gpu/drm/i915/intel_mocs.c
@@ -324,11 +324,11 @@ int intel_rcs_context_init_mocs(struct drm_i915_gem_request *req)
 	if (get_mocs_settings(req->ring->dev, &t)) {
 		struct drm_i915_private *dev_priv = req->i915;
 		enum intel_ring_id ring_id;
 		/* Program the control registers */
-		for_each_ring(ring, dev_priv, ring_id) {
+		for_each_ring(engine, dev_priv, ring_id) {
 			ret = emit_mocs_control_table(req, &t, ring_id);
 			if (ret)
 				return ret;
diff --git a/drivers/gpu/drm/i915/intel_overlay.c b/drivers/gpu/drm/i915/intel_overlay.c
index 9168413..13b2763 100644
--- a/drivers/gpu/drm/i915/intel_overlay.c
+++ b/drivers/gpu/drm/i915/intel_overlay.c
@@ -233,14 +233,14 @@ static int intel_overlay_on(struct intel_overlay *overlay)
 	struct drm_device *dev = overlay->dev;
 	struct drm_i915_gem_request *req;
 	int ret;
 	WARN_ON(overlay->active);
 	WARN_ON(IS_I830(dev) && !(dev_priv->quirks & QUIRK_PIPEA_FORCE));
 	if (IS_ERR(req))
@@ -252,11 +252,11 @@ static int intel_overlay_on(struct intel_overlay *overlay)
 	overlay->active = true;
-	intel_ring_emit(ring, MI_OVERLAY_FLIP | MI_OVERLAY_ON);
-	intel_ring_emit(ring, overlay->flip_addr | OFC_UPDATE);
-	intel_ring_emit(ring, MI_WAIT_FOR_EVENT | MI_WAIT_FOR_OVERLAY_FLIP);
+	intel_ring_emit(engine, MI_OVERLAY_FLIP | MI_OVERLAY_ON);
+	intel_ring_emit(engine, overlay->flip_addr | OFC_UPDATE);
+	intel_ring_emit(engine, MI_WAIT_FOR_EVENT | MI_WAIT_FOR_OVERLAY_FLIP);
 	return intel_overlay_do_wait_request(overlay, req, NULL);
@@ -267,7 +267,7 @@ static int intel_overlay_continue(struct intel_overlay *overlay,
 	u32 flip_addr = overlay->flip_addr;
 	u32 tmp;
@@ -283,7 +283,7 @@ static int intel_overlay_continue(struct intel_overlay *overlay,
 	if (tmp & (1 << 17))
 		DRM_DEBUG("overlay underrun, DOVSTA: %x\n", tmp);
 	if (IS_ERR(req))
@@ -293,9 +293,9 @@ static int intel_overlay_continue(struct intel_overlay *overlay,
 		return ret;
-	intel_ring_emit(ring, MI_OVERLAY_FLIP | MI_OVERLAY_CONTINUE);
-	intel_ring_emit(ring, flip_addr);
+	intel_ring_emit(engine, MI_OVERLAY_FLIP | MI_OVERLAY_CONTINUE);
+	intel_ring_emit(engine, flip_addr);
 	WARN_ON(overlay->last_flip_req);
 	i915_gem_request_assign(&overlay->last_flip_req, req);
@@ -336,7 +336,7 @@ static int intel_overlay_off(struct intel_overlay *overlay)
 	int ret;
@@ -349,7 +349,7 @@ static int intel_overlay_off(struct intel_overlay *overlay)
 	 * of the hw. Do it in both cases */
 	flip_addr |= OFC_UPDATE;
 	if (IS_ERR(req))
@@ -360,22 +360,23 @@ static int intel_overlay_off(struct intel_overlay *overlay)
 	/* wait for overlay to go idle */
 	/* turn overlay off */
 	if (IS_I830(dev)) {
 		/* Workaround: Don't disable the overlay fully, since otherwise
 		 * it dies on the next OVERLAY_ON cmd. */
 	} else {
-		intel_ring_emit(ring, MI_OVERLAY_FLIP | MI_OVERLAY_OFF);
+		intel_ring_emit(engine, MI_OVERLAY_FLIP | MI_OVERLAY_OFF);
+				MI_WAIT_FOR_EVENT | MI_WAIT_FOR_OVERLAY_FLIP);
 	return intel_overlay_do_wait_request(overlay, req, intel_overlay_off_tail);
@@ -408,7 +409,7 @@ static int intel_overlay_release_old_vid(struct intel_overlay *overlay)
 	int ret;
 	WARN_ON(!mutex_is_locked(&dev->struct_mutex));
@@ -423,7 +424,7 @@ static int intel_overlay_release_old_vid(struct intel_overlay *overlay)
 		/* synchronous slowpath */
 		if (IS_ERR(req))
@@ -433,9 +434,10 @@ static int intel_overlay_release_old_vid(struct intel_overlay *overlay)
 			return ret;
 		ret = intel_overlay_do_wait_request(overlay, req,
 						    intel_overlay_release_old_vid_tail);
diff --git a/drivers/gpu/drm/i915/intel_pm.c b/drivers/gpu/drm/i915/intel_pm.c
index d7aef17..c54a7df 100644
--- a/drivers/gpu/drm/i915/intel_pm.c
+++ b/drivers/gpu/drm/i915/intel_pm.c
@@ -4815,7 +4815,7 @@ static void gen9_enable_rps(struct drm_device *dev)
 static void gen9_enable_rc6(struct drm_device *dev)
 	uint32_t rc6_mask = 0;
 	int unused;
@@ -4838,8 +4838,8 @@ static void gen9_enable_rc6(struct drm_device *dev)
 		I915_WRITE(GEN6_RC6_WAKE_RATE_LIMIT, 54 << 16);
 	I915_WRITE(GEN6_RC_EVALUATION_INTERVAL, 125000); /* 12500 * 1280ns */
 	I915_WRITE(GEN6_RC_IDLE_HYSTERSIS, 25); /* 25 * 1280ns */
-	for_each_ring(ring, dev_priv, unused)
-		I915_WRITE(RING_MAX_IDLE(ring->mmio_base), 10);
+	for_each_ring(engine, dev_priv, unused)
+		I915_WRITE(RING_MAX_IDLE(engine->mmio_base), 10);
 	if (HAS_GUC_UCODE(dev))
 		I915_WRITE(GUC_MAX_IDLE_COUNT, 0xA);
@@ -4885,7 +4885,7 @@ static void gen9_enable_rc6(struct drm_device *dev)
 static void gen8_enable_rps(struct drm_device *dev)
 	int unused;
@@ -4906,8 +4906,8 @@ static void gen8_enable_rps(struct drm_device *dev)
 	I915_WRITE(GEN6_RC6_WAKE_RATE_LIMIT, 40 << 16);
 	I915_WRITE(GEN6_RC_SLEEP, 0);
 	if (IS_BROADWELL(dev))
 		I915_WRITE(GEN6_RC6_THRESHOLD, 625); /* 800us/1.28 for TO */
@@ -4967,7 +4967,7 @@ static void gen8_enable_rps(struct drm_device *dev)
 static void gen6_enable_rps(struct drm_device *dev)
 	u32 rc6vids, pcu_mbox = 0, rc6_mask = 0;
 	u32 gtfifodbg;
 	int rc6_mode;
@@ -5003,8 +5003,8 @@ static void gen6_enable_rps(struct drm_device *dev)
 	I915_WRITE(GEN6_RC1e_THRESHOLD, 1000);
@@ -5495,7 +5495,7 @@ static void valleyview_cleanup_gt_powersave(struct drm_device *dev)
 static void cherryview_enable_rps(struct drm_device *dev)
 	u32 gtfifodbg, val, rc6_mode = 0, pcbr;
 	int i;
@@ -5522,8 +5522,8 @@ static void cherryview_enable_rps(struct drm_device *dev)
 	/* TO threshold set to 500 us ( 0x186 * 1.28 us) */
@@ -5593,7 +5593,7 @@ static void cherryview_enable_rps(struct drm_device *dev)
 static void valleyview_enable_rps(struct drm_device *dev)
 	u32 gtfifodbg, val, rc6_mode = 0;
 	int i;
@@ -5633,8 +5633,8 @@ static void valleyview_enable_rps(struct drm_device *dev)
 	I915_WRITE(GEN6_RC6_THRESHOLD, 0x557);
@@ -6010,7 +6010,7 @@ EXPORT_SYMBOL_GPL(i915_gpu_lower);
 bool i915_gpu_busy(void)
 	struct drm_i915_private *dev_priv;
 	bool ret = false;
 	int i;
@@ -6019,8 +6019,8 @@ bool i915_gpu_busy(void)
 		goto out_unlock;
 	dev_priv = i915_mch_dev;
-		ret |= !list_empty(&ring->request_list);
+		ret |= !list_empty(&engine->request_list);
 out_unlock:
 	spin_unlock_irq(&mchdev_lock);
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.c b/drivers/gpu/drm/i915/intel_ringbuffer.c
index 45ce45a..688773a 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.c
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.c
@@ -79,7 +79,7 @@ gen2_render_ring_flush(struct drm_i915_gem_request *req,
 		       u32	invalidate_domains,
 		       u32	flush_domains)
 	u32 cmd;
 	int ret;
@@ -94,9 +94,9 @@ gen2_render_ring_flush(struct drm_i915_gem_request *req,
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, cmd);
+	intel_ring_emit(engine, cmd);
 	return 0;
@@ -106,8 +106,8 @@ gen4_render_ring_flush(struct drm_i915_gem_request *req,
 		       u32	flush_domains)
-	struct drm_device *dev = ring->dev;
+	struct drm_device *dev = engine->dev;
 	u32 cmd;
 	int ret;
@@ -153,9 +153,9 @@ gen4_render_ring_flush(struct drm_i915_gem_request *req,
 	if (ret)
 		return ret;
 	return 0;
@@ -200,34 +200,34 @@ gen4_render_ring_flush(struct drm_i915_gem_request *req,
 static int
 intel_emit_post_sync_nonzero_flush(struct drm_i915_gem_request *req)
 	int ret;
 	ret = intel_ring_begin(req, 6);
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, GFX_OP_PIPE_CONTROL(5));
-	intel_ring_emit(ring, PIPE_CONTROL_CS_STALL |
+	intel_ring_emit(engine, GFX_OP_PIPE_CONTROL(5));
+	intel_ring_emit(engine, PIPE_CONTROL_CS_STALL |
 			PIPE_CONTROL_STALL_AT_SCOREBOARD);
-	intel_ring_emit(ring, scratch_addr | PIPE_CONTROL_GLOBAL_GTT); /* address */
-	intel_ring_emit(ring, 0); /* low dword */
-	intel_ring_emit(ring, 0); /* high dword */
+	intel_ring_emit(engine, scratch_addr | PIPE_CONTROL_GLOBAL_GTT); /* address */
+	intel_ring_emit(engine, 0); /* low dword */
+	intel_ring_emit(engine, 0); /* high dword */
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, PIPE_CONTROL_QW_WRITE);
+	intel_ring_emit(engine, PIPE_CONTROL_QW_WRITE);
 	return 0;
@@ -236,9 +236,9 @@ static int
 gen6_render_ring_flush(struct drm_i915_gem_request *req,
 		       u32 invalidate_domains, u32 flush_domains)
-	struct intel_engine_cs *ring = req->ring;
+	struct intel_engine_cs *engine = req->ring;
 	u32 flags = 0;
 	int ret;
 	/* Force SNB workarounds for PIPE_CONTROL flushes */
@@ -276,11 +276,11 @@ gen6_render_ring_flush(struct drm_i915_gem_request *req,
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, GFX_OP_PIPE_CONTROL(4));
-	intel_ring_emit(ring, flags);
-	intel_ring_advance(ring);
+	intel_ring_emit(engine, GFX_OP_PIPE_CONTROL(4));
+	intel_ring_emit(engine, flags);
+	intel_ring_advance(engine);
 	return 0;
@@ -288,19 +288,19 @@ gen6_render_ring_flush(struct drm_i915_gem_request *req,
 static int
 gen7_render_ring_cs_stall_wa(struct drm_i915_gem_request *req)
 	int ret;
 	ret = intel_ring_begin(req, 4);
 	if (ret)
 		return ret;
 	return 0;
@@ -309,9 +309,9 @@ static int
 gen7_render_ring_flush(struct drm_i915_gem_request *req,
 	u32 flags = 0;
 	int ret;
@@ -360,11 +360,11 @@ gen7_render_ring_flush(struct drm_i915_gem_request *req,
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, scratch_addr);
+	intel_ring_emit(engine, scratch_addr);
 	return 0;
@@ -373,20 +373,20 @@ static int
 gen8_emit_pipe_control(struct drm_i915_gem_request *req,
 		       u32 flags, u32 scratch_addr)
 	int ret;
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, GFX_OP_PIPE_CONTROL(6));
+	intel_ring_emit(engine, GFX_OP_PIPE_CONTROL(6));
 	return 0;
@@ -700,15 +700,15 @@ err:
 static int intel_ring_workarounds_emit(struct drm_i915_gem_request *req)
 	int ret, i;
 	if (w->count == 0)
 		return 0;
 	ret = intel_ring_flush_all_caches(req);
 	if (ret)
 		return ret;
@@ -717,16 +717,16 @@ static int intel_ring_workarounds_emit(struct drm_i915_gem_request *req)
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, MI_LOAD_REGISTER_IMM(w->count));
+	intel_ring_emit(engine, MI_LOAD_REGISTER_IMM(w->count));
 	for (i = 0; i < w->count; i++) {
-		intel_ring_emit_reg(ring, w->reg[i].addr);
-		intel_ring_emit(ring, w->reg[i].value);
+		intel_ring_emit_reg(engine, w->reg[i].addr);
+		intel_ring_emit(engine, w->reg[i].value);
 	if (ret)
 		return ret;
@@ -1388,22 +1388,23 @@ static int gen6_signal(struct drm_i915_gem_request *signaller_req,
 static int
 gen6_add_request(struct drm_i915_gem_request *req)
 	int ret;
-	if (ring->semaphore.signal)
-		ret = ring->semaphore.signal(req, 4);
+	if (engine->semaphore.signal)
+		ret = engine->semaphore.signal(req, 4);
 	else
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, MI_STORE_DWORD_INDEX);
-	intel_ring_emit(ring, I915_GEM_HWS_INDEX << MI_STORE_DWORD_INDEX_SHIFT);
-	intel_ring_emit(ring, i915_gem_request_get_seqno(req));
-	intel_ring_emit(ring, MI_USER_INTERRUPT);
-	__intel_ring_advance(ring);
+	intel_ring_emit(engine, MI_STORE_DWORD_INDEX);
+			I915_GEM_HWS_INDEX << MI_STORE_DWORD_INDEX_SHIFT);
+	intel_ring_emit(engine, i915_gem_request_get_seqno(req));
+	intel_ring_emit(engine, MI_USER_INTERRUPT);
+	__intel_ring_advance(engine);
 	return 0;
@@ -1502,8 +1503,8 @@ do {									\
 static int
 pc_render_add_request(struct drm_i915_gem_request *req)
 	int ret;
 	/* For Ironlake, MI_USER_INTERRUPT was deprecated and apparently
@@ -1518,32 +1519,36 @@ pc_render_add_request(struct drm_i915_gem_request *req)
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, GFX_OP_PIPE_CONTROL(4) | PIPE_CONTROL_QW_WRITE |
+			GFX_OP_PIPE_CONTROL(4) | PIPE_CONTROL_QW_WRITE |
 			PIPE_CONTROL_WRITE_FLUSH |
 			PIPE_CONTROL_TEXTURE_CACHE_INVALIDATE);
-	intel_ring_emit(ring, ring->scratch.gtt_offset | PIPE_CONTROL_GLOBAL_GTT);
-	PIPE_CONTROL_FLUSH(ring, scratch_addr);
+			engine->scratch.gtt_offset | PIPE_CONTROL_GLOBAL_GTT);
+	PIPE_CONTROL_FLUSH(engine, scratch_addr);
 	scratch_addr += 2 * CACHELINE_BYTES; /* write to separate cachelines */
 			PIPE_CONTROL_TEXTURE_CACHE_INVALIDATE |
 			PIPE_CONTROL_NOTIFY);
 	return 0;
@@ -1696,34 +1701,35 @@ bsd_ring_flush(struct drm_i915_gem_request *req,
 	       u32     flush_domains)
 	int ret;
 	ret = intel_ring_begin(req, 2);
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, MI_FLUSH);
+	intel_ring_emit(engine, MI_FLUSH);
 	return 0;
 static int
 i9xx_add_request(struct drm_i915_gem_request *req)
 	int ret;
 	if (ret)
 		return ret;
 	return 0;
@@ -1857,20 +1863,20 @@ i965_dispatch_execbuffer(struct drm_i915_gem_request *req,
 			 u64 offset, u32 length,
 			 unsigned dispatch_flags)
 	int ret;
 	if (ret)
 		return ret;
 			MI_BATCH_BUFFER_START |
 			MI_BATCH_GTT |
 			(dispatch_flags & I915_DISPATCH_SECURE ?
 			 0 : MI_BATCH_NON_SECURE_I965));
-	intel_ring_emit(ring, offset);
+	intel_ring_emit(engine, offset);
 	return 0;
@@ -1884,8 +1890,8 @@ i830_dispatch_execbuffer(struct drm_i915_gem_request *req,
 			 u64 offset, u32 len,
-	u32 cs_offset = ring->scratch.gtt_offset;
+	u32 cs_offset = engine->scratch.gtt_offset;
 	int ret;
@@ -1893,13 +1899,13 @@ i830_dispatch_execbuffer(struct drm_i915_gem_request *req,
 		return ret;
 	/* Evict the invalid PTE TLBs */
-	intel_ring_emit(ring, COLOR_BLT_CMD | BLT_WRITE_RGBA);
-	intel_ring_emit(ring, BLT_DEPTH_32 | BLT_ROP_COLOR_COPY | 4096);
-	intel_ring_emit(ring, I830_TLB_ENTRIES << 16 | 4); /* load each page */
-	intel_ring_emit(ring, cs_offset);
-	intel_ring_emit(ring, 0xdeadbeef);
-	intel_ring_emit(ring, MI_NOOP);
+	intel_ring_emit(engine, COLOR_BLT_CMD | BLT_WRITE_RGBA);
+	intel_ring_emit(engine, BLT_DEPTH_32 | BLT_ROP_COLOR_COPY | 4096);
+	intel_ring_emit(engine, I830_TLB_ENTRIES << 16 | 4); /* load each page */
+	intel_ring_emit(engine, cs_offset);
+	intel_ring_emit(engine, 0xdeadbeef);
+	intel_ring_emit(engine, MI_NOOP);
 	if ((dispatch_flags & I915_DISPATCH_PINNED) == 0) {
 		if (len > I830_BATCH_LIMIT)
@@ -1913,16 +1919,17 @@ i830_dispatch_execbuffer(struct drm_i915_gem_request *req,
 		 * stable batch scratch bo area (so that the CS never
 		 * stumbles over its tlb invalidation bug) ...
-		intel_ring_emit(ring, SRC_COPY_BLT_CMD | BLT_WRITE_RGBA);
-		intel_ring_emit(ring, BLT_DEPTH_32 | BLT_ROP_SRC_COPY | 4096);
-		intel_ring_emit(ring, DIV_ROUND_UP(len, 4096) << 16 | 4096);
-		intel_ring_emit(ring, 4096);
+		intel_ring_emit(engine, SRC_COPY_BLT_CMD | BLT_WRITE_RGBA);
+				BLT_DEPTH_32 | BLT_ROP_SRC_COPY | 4096);
+		intel_ring_emit(engine, DIV_ROUND_UP(len, 4096) << 16 | 4096);
+		intel_ring_emit(engine, 4096);
 		/* ... and execute it. */
 		offset = cs_offset;
@@ -1932,10 +1939,10 @@ i830_dispatch_execbuffer(struct drm_i915_gem_request *req,
 	if (ret)
 		return ret;
-	intel_ring_emit(ring, MI_BATCH_BUFFER_START | MI_BATCH_GTT);
-	intel_ring_emit(ring, offset | (dispatch_flags & I915_DISPATCH_SECURE ?
-					0 : MI_BATCH_NON_SECURE));
+	intel_ring_emit(engine, MI_BATCH_BUFFER_START | MI_BATCH_GTT);
+	intel_ring_emit(engine, offset | (dispatch_flags & I915_DISPATCH_SECURE ?
+					  0 : MI_BATCH_NON_SECURE));
 	return 0;
@@ -1945,17 +1952,17 @@ i915_dispatch_execbuffer(struct drm_i915_gem_request *req,
 	int ret;
 	if (ret)
 		return ret;
 	return 0;
@@ -2480,32 +2487,32 @@ static int __intel_ring_prepare(struct intel_engine_cs *ring, int bytes)
 int intel_ring_begin(struct drm_i915_gem_request *req,
 		     int num_dwords)
 	int ret;
 	WARN_ON(req == NULL);
-	ring = req->ring;
-	dev_priv = ring->dev->dev_private;
+	engine = req->ring;
+	dev_priv = engine->dev->dev_private;
 	ret = i915_gem_check_wedge(&dev_priv->gpu_error,
 				   dev_priv->mm.interruptible);
 	if (ret)
 		return ret;
-	ret = __intel_ring_prepare(ring, num_dwords * sizeof(uint32_t));
+	ret = __intel_ring_prepare(engine, num_dwords * sizeof(uint32_t));
 	if (ret)
 		return ret;
-	ring->buffer->space -= num_dwords * sizeof(uint32_t);
+	engine->buffer->space -= num_dwords * sizeof(uint32_t);
 	return 0;
 /* Align the ring tail to a cacheline boundary */
 int intel_ring_cacheline_align(struct drm_i915_gem_request *req)
-	int num_dwords = (ring->buffer->tail & (CACHELINE_BYTES - 1)) / sizeof(uint32_t);
+	int num_dwords = (engine->buffer->tail & (CACHELINE_BYTES - 1)) / sizeof(uint32_t);
 	int ret;
 	if (num_dwords == 0)
@@ -2517,9 +2524,9 @@ int intel_ring_cacheline_align(struct drm_i915_gem_request *req)
 		return ret;
 	while (num_dwords--)
 	return 0;
@@ -2576,7 +2583,7 @@ static void gen6_bsd_ring_write_tail(struct intel_engine_cs *ring,
 static int gen6_bsd_ring_flush(struct drm_i915_gem_request *req,
 			       u32 invalidate, u32 flush)
 	uint32_t cmd;
 	int ret;
@@ -2585,7 +2592,7 @@ static int gen6_bsd_ring_flush(struct drm_i915_gem_request *req,
 		return ret;
 	cmd = MI_FLUSH_DW;
-	if (INTEL_INFO(ring->dev)->gen >= 8)
+	if (INTEL_INFO(engine->dev)->gen >= 8)
 		cmd += 1;
 	/* We always require a command barrier so that subsequent
@@ -2604,16 +2611,17 @@ static int gen6_bsd_ring_flush(struct drm_i915_gem_request *req,
 	if (invalidate & I915_GEM_GPU_DOMAINS)
 		cmd |= MI_INVALIDATE_TLB | MI_INVALIDATE_BSD;
-	intel_ring_emit(ring, I915_GEM_HWS_SCRATCH_ADDR | MI_FLUSH_DW_USE_GTT);
-	if (INTEL_INFO(ring->dev)->gen >= 8) {
-		intel_ring_emit(ring, 0); /* upper addr */
-		intel_ring_emit(ring, 0); /* value */
+			I915_GEM_HWS_SCRATCH_ADDR | MI_FLUSH_DW_USE_GTT);
+	if (INTEL_INFO(engine->dev)->gen >= 8) {
+		intel_ring_emit(engine, 0); /* upper addr */
+		intel_ring_emit(engine, 0); /* value */
 	} else  {
 	return 0;
@@ -2622,8 +2630,8 @@ gen8_ring_dispatch_execbuffer(struct drm_i915_gem_request *req,
-	bool ppgtt = USES_PPGTT(ring->dev) &&
+	bool ppgtt = USES_PPGTT(engine->dev) &&
 			!(dispatch_flags & I915_DISPATCH_SECURE);
 	int ret;
@@ -2632,13 +2640,13 @@ gen8_ring_dispatch_execbuffer(struct drm_i915_gem_request *req,
 		return ret;
 	/* FIXME(BDW): Address space and security selectors. */
-	intel_ring_emit(ring, MI_BATCH_BUFFER_START_GEN8 | (ppgtt<<8) |
+	intel_ring_emit(engine, MI_BATCH_BUFFER_START_GEN8 | (ppgtt<<8) |
 			(dispatch_flags & I915_DISPATCH_RS ?
 			 MI_BATCH_RESOURCE_STREAMER : 0));
-	intel_ring_emit(ring, lower_32_bits(offset));
-	intel_ring_emit(ring, upper_32_bits(offset));
+	intel_ring_emit(engine, lower_32_bits(offset));
+	intel_ring_emit(engine, upper_32_bits(offset));
 	return 0;
@@ -2648,22 +2656,22 @@ hsw_ring_dispatch_execbuffer(struct drm_i915_gem_request *req,
 	int ret;
 	if (ret)
 		return ret;
 			 0 : MI_BATCH_PPGTT_HSW | MI_BATCH_NON_SECURE_HSW) |
 	/* bit0-7 is the length on GEN6+ */
 	return 0;
@@ -2673,20 +2681,20 @@ gen6_ring_dispatch_execbuffer(struct drm_i915_gem_request *req,
 	int ret;
 	if (ret)
 		return ret;
 	return 0;
@@ -2696,8 +2704,8 @@ gen6_ring_dispatch_execbuffer(struct drm_i915_gem_request *req,
 static int gen6_ring_flush(struct drm_i915_gem_request *req,
 	uint32_t cmd;
 	int ret;
@@ -2724,16 +2732,17 @@ static int gen6_ring_flush(struct drm_i915_gem_request *req,
 	if (invalidate & I915_GEM_DOMAIN_RENDER)
 	if (INTEL_INFO(dev)->gen >= 8) {
 	} else  {
 	return 0;
@@ -2741,14 +2750,14 @@ static int gen6_ring_flush(struct drm_i915_gem_request *req,
 int intel_init_render_ring_buffer(struct drm_device *dev)
 	struct drm_i915_gem_object *obj;
 	int ret;
-	ring->id = RCS;
+	engine->id = RCS;
 		if (i915_semaphore_is_enabled(dev)) {
@@ -2768,34 +2777,34 @@ int intel_init_render_ring_buffer(struct drm_device *dev)
-		ring->init_context = intel_rcs_ctx_init;
-		ring->add_request = gen6_add_request;
-		ring->flush = gen8_render_ring_flush;
-		ring->irq_get = gen8_ring_get_irq;
-		ring->irq_put = gen8_ring_put_irq;
-		ring->irq_enable_mask = GT_RENDER_USER_INTERRUPT;
-		ring->get_seqno = gen6_ring_get_seqno;
-		ring->set_seqno = ring_set_seqno;
+		engine->init_context = intel_rcs_ctx_init;
+		engine->add_request = gen6_add_request;
+		engine->flush = gen8_render_ring_flush;
+		engine->irq_get = gen8_ring_get_irq;
+		engine->irq_put = gen8_ring_put_irq;
+		engine->irq_enable_mask = GT_RENDER_USER_INTERRUPT;
+		engine->get_seqno = gen6_ring_get_seqno;
+		engine->set_seqno = ring_set_seqno;
 			WARN_ON(!dev_priv->semaphore_obj);
-			ring->semaphore.sync_to = gen8_ring_sync;
-			ring->semaphore.signal = gen8_rcs_signal;
-			GEN8_RING_SEMAPHORE_INIT;
+			engine->semaphore.sync_to = gen8_ring_sync;
+			engine->semaphore.signal = gen8_rcs_signal;
+			GEN8_RING_SEMAPHORE_INIT(engine);
 	} else if (INTEL_INFO(dev)->gen >= 6) {
-		ring->flush = gen7_render_ring_flush;
+		engine->flush = gen7_render_ring_flush;
 		if (INTEL_INFO(dev)->gen == 6)
-			ring->flush = gen6_render_ring_flush;
-		ring->irq_get = gen6_ring_get_irq;
-		ring->irq_put = gen6_ring_put_irq;
+			engine->flush = gen6_render_ring_flush;
+		engine->irq_get = gen6_ring_get_irq;
+		engine->irq_put = gen6_ring_put_irq;
-			ring->semaphore.sync_to = gen6_ring_sync;
-			ring->semaphore.signal = gen6_signal;
+			engine->semaphore.sync_to = gen6_ring_sync;
+			engine->semaphore.signal = gen6_signal;
 			 * The current semaphore is only applied on pre-gen8
 			 * platform.  And there is no VCS2 ring on the pre-gen8
@@ -2803,59 +2812,59 @@ int intel_init_render_ring_buffer(struct drm_device *dev)
 			 * initialized as INVALID.  Gen8 will initialize the
 			 * sema between VCS2 and RCS later.
-			ring->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_INVALID;
-			ring->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_RV;
-			ring->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_RB;
-			ring->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_RVE;
-			ring->semaphore.mbox.wait[VCS2] = MI_SEMAPHORE_SYNC_INVALID;
-			ring->semaphore.mbox.signal[RCS] = GEN6_NOSYNC;
-			ring->semaphore.mbox.signal[VCS] = GEN6_VRSYNC;
-			ring->semaphore.mbox.signal[BCS] = GEN6_BRSYNC;
-			ring->semaphore.mbox.signal[VECS] = GEN6_VERSYNC;
-			ring->semaphore.mbox.signal[VCS2] = GEN6_NOSYNC;
+			engine->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_INVALID;
+			engine->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_RV;
+			engine->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_RB;
+			engine->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_RVE;
+			engine->semaphore.mbox.wait[VCS2] = MI_SEMAPHORE_SYNC_INVALID;
+			engine->semaphore.mbox.signal[RCS] = GEN6_NOSYNC;
+			engine->semaphore.mbox.signal[VCS] = GEN6_VRSYNC;
+			engine->semaphore.mbox.signal[BCS] = GEN6_BRSYNC;
+			engine->semaphore.mbox.signal[VECS] = GEN6_VERSYNC;
+			engine->semaphore.mbox.signal[VCS2] = GEN6_NOSYNC;
 	} else if (IS_GEN5(dev)) {
-		ring->add_request = pc_render_add_request;
-		ring->flush = gen4_render_ring_flush;
-		ring->get_seqno = pc_render_get_seqno;
-		ring->set_seqno = pc_render_set_seqno;
-		ring->irq_get = gen5_ring_get_irq;
-		ring->irq_put = gen5_ring_put_irq;
-		ring->irq_enable_mask = GT_RENDER_USER_INTERRUPT |
+		engine->add_request = pc_render_add_request;
+		engine->flush = gen4_render_ring_flush;
+		engine->get_seqno = pc_render_get_seqno;
+		engine->set_seqno = pc_render_set_seqno;
+		engine->irq_get = gen5_ring_get_irq;
+		engine->irq_put = gen5_ring_put_irq;
+		engine->irq_enable_mask = GT_RENDER_USER_INTERRUPT |
 					GT_RENDER_PIPECTL_NOTIFY_INTERRUPT;
 	} else {
-		ring->add_request = i9xx_add_request;
+		engine->add_request = i9xx_add_request;
 		if (INTEL_INFO(dev)->gen < 4)
-			ring->flush = gen2_render_ring_flush;
+			engine->flush = gen2_render_ring_flush;
 		else
-		ring->get_seqno = ring_get_seqno;
+		engine->get_seqno = ring_get_seqno;
 		if (IS_GEN2(dev)) {
-			ring->irq_get = i8xx_ring_get_irq;
-			ring->irq_put = i8xx_ring_put_irq;
+			engine->irq_get = i8xx_ring_get_irq;
+			engine->irq_put = i8xx_ring_put_irq;
 		} else {
-			ring->irq_get = i9xx_ring_get_irq;
-			ring->irq_put = i9xx_ring_put_irq;
+			engine->irq_get = i9xx_ring_get_irq;
+			engine->irq_put = i9xx_ring_put_irq;
-		ring->irq_enable_mask = I915_USER_INTERRUPT;
+		engine->irq_enable_mask = I915_USER_INTERRUPT;
-	ring->write_tail = ring_write_tail;
+	engine->write_tail = ring_write_tail;
 	if (IS_HASWELL(dev))
-		ring->dispatch_execbuffer = hsw_ring_dispatch_execbuffer;
+		engine->dispatch_execbuffer = hsw_ring_dispatch_execbuffer;
 	else if (IS_GEN8(dev))
-		ring->dispatch_execbuffer = gen8_ring_dispatch_execbuffer;
+		engine->dispatch_execbuffer = gen8_ring_dispatch_execbuffer;
-		ring->dispatch_execbuffer = gen6_ring_dispatch_execbuffer;
+		engine->dispatch_execbuffer = gen6_ring_dispatch_execbuffer;
 	else if (INTEL_INFO(dev)->gen >= 4)
-		ring->dispatch_execbuffer = i965_dispatch_execbuffer;
+		engine->dispatch_execbuffer = i965_dispatch_execbuffer;
 	else if (IS_I830(dev) || IS_845G(dev))
-		ring->dispatch_execbuffer = i830_dispatch_execbuffer;
+		engine->dispatch_execbuffer = i830_dispatch_execbuffer;
 	else
-		ring->dispatch_execbuffer = i915_dispatch_execbuffer;
-	ring->init_hw = init_render_ring;
-	ring->cleanup = render_ring_cleanup;
+		engine->dispatch_execbuffer = i915_dispatch_execbuffer;
+	engine->init_hw = init_render_ring;
+	engine->cleanup = render_ring_cleanup;
 	/* Workaround batchbuffer to combat CS tlb bug. */
 	if (HAS_BROKEN_CS_TLB(dev)) {
@@ -2872,16 +2881,16 @@ int intel_init_render_ring_buffer(struct drm_device *dev)
 			return ret;
-		ring->scratch.obj = obj;
-		ring->scratch.gtt_offset = i915_gem_obj_ggtt_offset(obj);
+		engine->scratch.obj = obj;
+		engine->scratch.gtt_offset = i915_gem_obj_ggtt_offset(obj);
-	ret = intel_init_ring_buffer(dev, ring);
+	ret = intel_init_ring_buffer(dev, engine);
 	if (ret)
 		return ret;
 	if (INTEL_INFO(dev)->gen >= 5) {
 		if (ret)
 			return ret;
@@ -2892,75 +2901,75 @@ int intel_init_render_ring_buffer(struct drm_device *dev)
 int intel_init_bsd_ring_buffer(struct drm_device *dev)
-	ring->id = VCS;
+	engine->id = VCS;
 		/* gen6 bsd needs a special wa for tail updates */
 		if (IS_GEN6(dev))
-			ring->write_tail = gen6_bsd_ring_write_tail;
-		ring->flush = gen6_bsd_ring_flush;
+			engine->write_tail = gen6_bsd_ring_write_tail;
+		engine->flush = gen6_bsd_ring_flush;
 				GT_RENDER_USER_INTERRUPT << GEN8_VCS1_IRQ_SHIFT;
-				ring->semaphore.signal = gen8_xcs_signal;
+				engine->semaphore.signal = gen8_xcs_signal;
 		} else {
-			ring->irq_enable_mask = GT_BSD_USER_INTERRUPT;
+			engine->irq_enable_mask = GT_BSD_USER_INTERRUPT;
-				ring->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_VR;
-				ring->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_INVALID;
-				ring->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_VB;
-				ring->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_VVE;
-				ring->semaphore.mbox.signal[RCS] = GEN6_RVSYNC;
-				ring->semaphore.mbox.signal[VCS] = GEN6_NOSYNC;
-				ring->semaphore.mbox.signal[BCS] = GEN6_BVSYNC;
-				ring->semaphore.mbox.signal[VECS] = GEN6_VEVSYNC;
+				engine->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_VR;
+				engine->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_INVALID;
+				engine->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_VB;
+				engine->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_VVE;
+				engine->semaphore.mbox.signal[RCS] = GEN6_RVSYNC;
+				engine->semaphore.mbox.signal[VCS] = GEN6_NOSYNC;
+				engine->semaphore.mbox.signal[BCS] = GEN6_BVSYNC;
+				engine->semaphore.mbox.signal[VECS] = GEN6_VEVSYNC;
 	} else {
-		ring->mmio_base = BSD_RING_BASE;
-		ring->flush = bsd_ring_flush;
+		engine->mmio_base = BSD_RING_BASE;
+		engine->flush = bsd_ring_flush;
 		if (IS_GEN5(dev)) {
-			ring->irq_enable_mask = ILK_BSD_USER_INTERRUPT;
+			engine->irq_enable_mask = ILK_BSD_USER_INTERRUPT;
 		} else {
-			ring->irq_enable_mask = I915_BSD_USER_INTERRUPT;
+			engine->irq_enable_mask = I915_BSD_USER_INTERRUPT;
-	ring->init_hw = init_ring_common;
+	engine->init_hw = init_ring_common;
-	return intel_init_ring_buffer(dev, ring);
+	return intel_init_ring_buffer(dev, engine);
@@ -2969,68 +2978,68 @@ int intel_init_bsd_ring_buffer(struct drm_device *dev)
 int intel_init_bsd2_ring_buffer(struct drm_device *dev)
-	ring->id = VCS2;
 			GT_RENDER_USER_INTERRUPT << GEN8_VCS2_IRQ_SHIFT;
 int intel_init_blt_ring_buffer(struct drm_device *dev)
-	ring->id = BCS;
-	ring->flush = gen6_ring_flush;
+	engine->id = BCS;
+	engine->flush = gen6_ring_flush;
 			GT_RENDER_USER_INTERRUPT << GEN8_BCS_IRQ_SHIFT;
 	} else {
-		ring->irq_enable_mask = GT_BLT_USER_INTERRUPT;
+		engine->irq_enable_mask = GT_BLT_USER_INTERRUPT;
@@ -3038,112 +3047,112 @@ int intel_init_blt_ring_buffer(struct drm_device *dev)
 			 * sema between BCS and VCS2 later.
-			ring->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_BR;
-			ring->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_BV;
-			ring->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_INVALID;
-			ring->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_BVE;
-			ring->semaphore.mbox.signal[RCS] = GEN6_RBSYNC;
-			ring->semaphore.mbox.signal[VCS] = GEN6_VBSYNC;
-			ring->semaphore.mbox.signal[BCS] = GEN6_NOSYNC;
-			ring->semaphore.mbox.signal[VECS] = GEN6_VEBSYNC;
+			engine->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_BR;
+			engine->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_BV;
+			engine->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_INVALID;
+			engine->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_BVE;
+			engine->semaphore.mbox.signal[RCS] = GEN6_RBSYNC;
+			engine->semaphore.mbox.signal[VCS] = GEN6_VBSYNC;
+			engine->semaphore.mbox.signal[BCS] = GEN6_NOSYNC;
+			engine->semaphore.mbox.signal[VECS] = GEN6_VEBSYNC;
 int intel_init_vebox_ring_buffer(struct drm_device *dev)
-	ring->id = VECS;
 			GT_RENDER_USER_INTERRUPT << GEN8_VECS_IRQ_SHIFT;
 	} else {
-		ring->irq_enable_mask = PM_VEBOX_USER_INTERRUPT;
-		ring->irq_get = hsw_vebox_get_irq;
-		ring->irq_put = hsw_vebox_put_irq;
+		engine->irq_enable_mask = PM_VEBOX_USER_INTERRUPT;
+		engine->irq_get = hsw_vebox_get_irq;
+		engine->irq_put = hsw_vebox_put_irq;
-			ring->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_VER;
-			ring->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_VEV;
-			ring->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_VEB;
-			ring->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_INVALID;
-			ring->semaphore.mbox.signal[RCS] = GEN6_RVESYNC;
-			ring->semaphore.mbox.signal[VCS] = GEN6_VVESYNC;
-			ring->semaphore.mbox.signal[BCS] = GEN6_BVESYNC;
-			ring->semaphore.mbox.signal[VECS] = GEN6_NOSYNC;
+			engine->semaphore.mbox.wait[RCS] = MI_SEMAPHORE_SYNC_VER;
+			engine->semaphore.mbox.wait[VCS] = MI_SEMAPHORE_SYNC_VEV;
+			engine->semaphore.mbox.wait[BCS] = MI_SEMAPHORE_SYNC_VEB;
+			engine->semaphore.mbox.wait[VECS] = MI_SEMAPHORE_SYNC_INVALID;
+			engine->semaphore.mbox.signal[RCS] = GEN6_RVESYNC;
+			engine->semaphore.mbox.signal[VCS] = GEN6_VVESYNC;
+			engine->semaphore.mbox.signal[BCS] = GEN6_BVESYNC;
+			engine->semaphore.mbox.signal[VECS] = GEN6_NOSYNC;
 int
 intel_ring_flush_all_caches(struct drm_i915_gem_request *req)
 	int ret;
 		return 0;
-	ret = ring->flush(req, 0, I915_GEM_GPU_DOMAINS);
+	ret = engine->flush(req, 0, I915_GEM_GPU_DOMAINS);
 	if (ret)
 		return ret;
 	trace_i915_gem_ring_flush(req, 0, I915_GEM_GPU_DOMAINS);
 	return 0;
 int
 intel_ring_invalidate_all_caches(struct drm_i915_gem_request *req)
 	int ret;
 	flush_domains = 0;
-	ret = ring->flush(req, I915_GEM_GPU_DOMAINS, flush_domains);
+	ret = engine->flush(req, I915_GEM_GPU_DOMAINS, flush_domains);
 	if (ret)
 		return ret;
 	trace_i915_gem_ring_flush(req, I915_GEM_GPU_DOMAINS, flush_domains);
 	return 0;
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.h b/drivers/gpu/drm/i915/intel_ringbuffer.h
index 4b1439d..24efb57 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.h
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.h
@@ -63,16 +63,16 @@ struct  intel_hw_status_page {
 	((from) * I915_NUM_RINGS * i915_semaphore_seqno_size) + \
 	(i915_semaphore_seqno_size * (__ring)->id))
-#define GEN8_RING_SEMAPHORE_INIT do { \
+#define GEN8_RING_SEMAPHORE_INIT(e) do { \
 	if (!dev_priv->semaphore_obj) { \
 		break; \
-	ring->semaphore.signal_ggtt[RCS] = GEN8_SIGNAL_OFFSET(ring, RCS); \
-	ring->semaphore.signal_ggtt[VCS] = GEN8_SIGNAL_OFFSET(ring, VCS); \
-	ring->semaphore.signal_ggtt[BCS] = GEN8_SIGNAL_OFFSET(ring, BCS); \
-	ring->semaphore.signal_ggtt[VECS] = GEN8_SIGNAL_OFFSET(ring, VECS); \
-	ring->semaphore.signal_ggtt[VCS2] = GEN8_SIGNAL_OFFSET(ring, VCS2); \
-	ring->semaphore.signal_ggtt[ring->id] = MI_SEMAPHORE_SYNC_INVALID; \
+	(e)->semaphore.signal_ggtt[RCS] = GEN8_SIGNAL_OFFSET((e), RCS); \
+	(e)->semaphore.signal_ggtt[VCS] = GEN8_SIGNAL_OFFSET((e), VCS); \
+	(e)->semaphore.signal_ggtt[BCS] = GEN8_SIGNAL_OFFSET((e), BCS); \
+	(e)->semaphore.signal_ggtt[VECS] = GEN8_SIGNAL_OFFSET((e), VECS); \
+	(e)->semaphore.signal_ggtt[VCS2] = GEN8_SIGNAL_OFFSET((e), VCS2); \
+	(e)->semaphore.signal_ggtt[(e)->id] = MI_SEMAPHORE_SYNC_INVALID; \
 	} while(0)
 enum intel_ring_hangcheck_action {
BtrLinux
Privacy Overview
