drm/i915: Remove spurious semicolons
Author: Damien Lespiau <damien.lespiau@intel.com>
Found by running the semicolon.cocci spatch:
  https://github.com/coccinelle/coccinellery/blob/master/semicolon/semicolon.cocci
Signed-off-by: Damien Lespiau
Reviewed-by: Jani Nikula
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/dvo_ch7xxx.c | 2 +-
 drivers/gpu/drm/i915/dvo_ivch.c   | 2 +-
 drivers/gpu/drm/i915/dvo_ns2501.c | 2 +-
 drivers/gpu/drm/i915/dvo_sil164.c | 2 +-
 drivers/gpu/drm/i915/dvo_tfp410.c | 2 +-
 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/gpu/drm/i915/dvo_ch7xxx.c b/drivers/gpu/drm/i915/dvo_ch7xxx.c
index a0f5bdd..80449f4 100644
--- a/drivers/gpu/drm/i915/dvo_ch7xxx.c
+++ b/drivers/gpu/drm/i915/dvo_ch7xxx.c
@@ -160,7 +160,7 @@ static bool ch7xxx_readb(struct intel_dvo_device *dvo, int addr, uint8_t *ch)
 	if (i2c_transfer(adapter, msgs, 2) == 2) {
 		*ch = in_buf[0];
 		return true;
 	if (!ch7xxx->quiet) {
 		DRM_DEBUG_KMS("Unable to read register 0x%02x from %s:%02x.\n",
diff --git a/drivers/gpu/drm/i915/dvo_ivch.c b/drivers/gpu/drm/i915/dvo_ivch.c
index 0f1865d..0f2587f 100644
--- a/drivers/gpu/drm/i915/dvo_ivch.c
+++ b/drivers/gpu/drm/i915/dvo_ivch.c
@@ -195,7 +195,7 @@ static bool ivch_read(struct intel_dvo_device *dvo, int addr, uint16_t *data)
 	if (i2c_transfer(adapter, msgs, 3) == 3) {
 		*data = (in_buf[1] << 8) | in_buf[0];
 		return true;
 	if (!priv->quiet) {
 		DRM_DEBUG_KMS("Unable to read register 0x%02x from "
diff --git a/drivers/gpu/drm/i915/dvo_ns2501.c b/drivers/gpu/drm/i915/dvo_ns2501.c
index ccac3a1..74f2af7 100644
--- a/drivers/gpu/drm/i915/dvo_ns2501.c
+++ b/drivers/gpu/drm/i915/dvo_ns2501.c
@@ -121,7 +121,7 @@ static bool ns2501_readb(struct intel_dvo_device *dvo, int addr, uint8_t * ch)
 		*ch = in_buf[0];
 		return true;
 	if (!ns->quiet) {
 		DRM_DEBUG_KMS
diff --git a/drivers/gpu/drm/i915/dvo_sil164.c b/drivers/gpu/drm/i915/dvo_sil164.c
index 7b3e9e9..fa01149 100644
--- a/drivers/gpu/drm/i915/dvo_sil164.c
+++ b/drivers/gpu/drm/i915/dvo_sil164.c
@@ -93,7 +93,7 @@ static bool sil164_readb(struct intel_dvo_device *dvo, int addr, uint8_t *ch)
 		*ch = in_buf[0];
 		return true;
 	if (!sil->quiet) {
diff --git a/drivers/gpu/drm/i915/dvo_tfp410.c b/drivers/gpu/drm/i915/dvo_tfp410.c
index 12ea4b1..7853719 100644
--- a/drivers/gpu/drm/i915/dvo_tfp410.c
+++ b/drivers/gpu/drm/i915/dvo_tfp410.c
@@ -118,7 +118,7 @@ static bool tfp410_readb(struct intel_dvo_device *dvo, int addr, uint8_t *ch)
 		*ch = in_buf[0];
 		return true;
 	if (!tfp->quiet) {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
