drm/i915: Mass convert dev->dev_private to to_i915(dev)
Author: Chris Wilson <chris@chris-wilson.co.uk>
Since we now subclass struct drm_device, we can save pointer dances by
noting the equivalence of struct drm_device and struct drm_i915_private,
i.e. by using to_i915().
   text    data     bss     dec     hex filename
1073824    4562     416 1078802  107612 drivers/gpu/drm/i915/i915.ko
1068976    4562     416 1073954  106322 drivers/gpu/drm/i915/i915.ko
Created by the coccinelle script:
expression E;
identifier p;
- struct drm_i915_private *p = E->dev_private;
+ struct drm_i915_private *p = to_i915(E);
Signed-off-by: Chris Wilson
Reviewed-by: Dave Gordon
Link: http://patchwork.freedesktop.org/patch/msgid/1467628477-25379-1-git-send-email-chris@chris-wilson.co.uk
 drivers/gpu/drm/i915/i915_debugfs.c            | 172 +++++++--------
 drivers/gpu/drm/i915/i915_drv.c                |  28 +--
 drivers/gpu/drm/i915/i915_gem.c                |  54 ++---
 drivers/gpu/drm/i915/i915_gem_context.c        |  10 +-
 drivers/gpu/drm/i915/i915_gem_execbuffer.c     |   4 +-
 drivers/gpu/drm/i915/i915_gem_fence.c          |  24 +--
 drivers/gpu/drm/i915/i915_gem_gtt.c            |  20 +-
 drivers/gpu/drm/i915/i915_gem_stolen.c         |   6 +-
 drivers/gpu/drm/i915/i915_gem_tiling.c         |   4 +-
 drivers/gpu/drm/i915/i915_gpu_error.c          |   6 +-
 drivers/gpu/drm/i915/i915_guc_submission.c     |   4 +-
 drivers/gpu/drm/i915/i915_irq.c                |  92 ++++----
 drivers/gpu/drm/i915/i915_suspend.c            |   8 +-
 drivers/gpu/drm/i915/i915_sysfs.c              |  22 +-
 drivers/gpu/drm/i915/intel_audio.c             |  18 +-
 drivers/gpu/drm/i915/intel_color.c             |  18 +-
 drivers/gpu/drm/i915/intel_crt.c               |  24 +--
 drivers/gpu/drm/i915/intel_ddi.c               |  36 ++--
 drivers/gpu/drm/i915/intel_display.c           | 286 ++++++++++++-------------
 drivers/gpu/drm/i915/intel_dp.c                | 107 +++++----
 drivers/gpu/drm/i915/intel_dp_mst.c            |   6 +-
 drivers/gpu/drm/i915/intel_dpio_phy.c          |  10 +-
 drivers/gpu/drm/i915/intel_dpll_mgr.c          |  12 +-
 drivers/gpu/drm/i915/intel_drv.h               |   4 +-
 drivers/gpu/drm/i915/intel_dsi.c               |  36 ++--
 drivers/gpu/drm/i915/intel_dsi_dcs_backlight.c |   2 +-
 drivers/gpu/drm/i915/intel_dsi_panel_vbt.c     |   6 +-
 drivers/gpu/drm/i915/intel_dsi_pll.c           |  12 +-
 drivers/gpu/drm/i915/intel_dvo.c               |  18 +-
 drivers/gpu/drm/i915/intel_fbc.c               |  24 +--
 drivers/gpu/drm/i915/intel_fbdev.c             |  10 +-
 drivers/gpu/drm/i915/intel_fifo_underrun.c     |  18 +-
 drivers/gpu/drm/i915/intel_guc_loader.c        |   6 +-
 drivers/gpu/drm/i915/intel_hdmi.c              |  48 ++---
 drivers/gpu/drm/i915/intel_i2c.c               |   6 +-
 drivers/gpu/drm/i915/intel_lrc.c               |   4 +-
 drivers/gpu/drm/i915/intel_lvds.c              |  16 +-
 drivers/gpu/drm/i915/intel_modes.c             |   4 +-
 drivers/gpu/drm/i915/intel_overlay.c           |   4 +-
 drivers/gpu/drm/i915/intel_panel.c             |   6 +-
 drivers/gpu/drm/i915/intel_pm.c                | 110 +++++-----
 drivers/gpu/drm/i915/intel_psr.c               |  36 ++--
 drivers/gpu/drm/i915/intel_ringbuffer.c        |  10 +-
 drivers/gpu/drm/i915/intel_sdvo.c              |  22 +-
 drivers/gpu/drm/i915/intel_sprite.c            |  18 +-
 drivers/gpu/drm/i915/intel_tv.c                |  12 +-
 drivers/gpu/drm/i915/intel_uncore.c            |   2 +-
 47 files changed, 702 insertions(+), 703 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_debugfs.c b/drivers/gpu/drm/i915/i915_debugfs.c
index 3464c23..8cc4537 100644
--- a/drivers/gpu/drm/i915/i915_debugfs.c
+++ b/drivers/gpu/drm/i915/i915_debugfs.c
@@ -265,7 +265,7 @@ static int i915_gem_stolen_list_info(struct seq_file *m, void *data)
 	struct drm_info_node *node = m->private;
 	struct drm_device *dev = node->minor->dev;
-	struct drm_i915_private *dev_priv = dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(dev);
 	struct drm_i915_gem_object *obj;
 	u64 total_obj_size, total_gtt_size;
 	LIST_HEAD(stolen);
@@ -591,7 +591,7 @@ static int i915_gem_gtt_info(struct seq_file *m, void *data)
 	uintptr_t list = (uintptr_t) node->info_ent->data;
 	int count, ret;
@@ -625,7 +625,7 @@ static int i915_gem_pageflip_info(struct seq_file *m, void *data)
 	struct intel_crtc *crtc;
 	int ret;
@@ -695,7 +695,7 @@ static int i915_gem_batch_pool_info(struct seq_file *m, void *data)
 	struct intel_engine_cs *engine;
 	int total = 0;
@@ -740,7 +740,7 @@ static int i915_gem_request_info(struct seq_file *m, void *data)
 	struct drm_i915_gem_request *req;
 	int ret, any;
@@ -810,7 +810,7 @@ static int i915_gem_seqno_info(struct seq_file *m, void *data)
 	int ret;
@@ -833,7 +833,7 @@ static int i915_interrupt_info(struct seq_file *m, void *data)
 	int ret, i, pipe;
@@ -1024,7 +1024,7 @@ static int i915_gem_fence_regs_info(struct seq_file *m, void *data)
 	int i, ret;
 	ret = mutex_lock_interruptible(&dev->struct_mutex);
@@ -1052,7 +1052,7 @@ static int i915_hws_info(struct seq_file *m, void *data)
 	const u32 *hws;
 	int i;
@@ -1163,7 +1163,7 @@ static int
 i915_next_seqno_get(void *data, u64 *val)
 	struct drm_device *dev = data;
 	int ret;
@@ -1200,7 +1200,7 @@ static int i915_frequency_info(struct seq_file *m, void *unused)
 	int ret = 0;
 	intel_runtime_pm_get(dev_priv);
@@ -1403,7 +1403,7 @@ static int i915_hangcheck_info(struct seq_file *m, void *unused)
 	u64 acthd[I915_NUM_ENGINES];
 	u32 seqno[I915_NUM_ENGINES];
@@ -1474,7 +1474,7 @@ static int ironlake_drpc_info(struct seq_file *m)
 	u32 rgvmodectl, rstdbyctl;
 	u16 crstandvid;
 	int ret;
@@ -1542,7 +1542,7 @@ static int i915_forcewake_domains(struct seq_file *m, void *data)
 	struct intel_uncore_forcewake_domain *fw_domain;
 	spin_lock_irq(&dev_priv->uncore.lock);
@@ -1560,7 +1560,7 @@ static int vlv_drpc_info(struct seq_file *m)
 	u32 rpmodectl1, rcctl1, pw_status;
@@ -1600,7 +1600,7 @@ static int gen6_drpc_info(struct seq_file *m)
 	u32 rpmodectl1, gt_core_status, rcctl1, rc6vids = 0;
 	unsigned forcewake_count;
 	int count = 0, ret;
@@ -1712,7 +1712,7 @@ static int i915_frontbuffer_tracking(struct seq_file *m, void *unused)
 	seq_printf(m, "FB tracking busy bits: 0x%08x\n",
 		   dev_priv->fb_tracking.busy_bits);
@@ -1727,7 +1727,7 @@ static int i915_fbc_status(struct seq_file *m, void *unused)
 	if (!HAS_FBC(dev)) {
 		seq_puts(m, "FBC unsupported on this chipset\n");
@@ -1757,7 +1757,7 @@ static int i915_fbc_status(struct seq_file *m, void *unused)
 static int i915_fbc_fc_get(void *data, u64 *val)
 	if (INTEL_INFO(dev)->gen < 7 || !HAS_FBC(dev))
 		return -ENODEV;
@@ -1770,7 +1770,7 @@ static int i915_fbc_fc_get(void *data, u64 *val)
 static int i915_fbc_fc_set(void *data, u64 val)
 	u32 reg;
@@ -1797,7 +1797,7 @@ static int i915_ips_status(struct seq_file *m, void *unused)
 	if (!HAS_IPS(dev)) {
 		seq_puts(m, "not supported\n");
@@ -1827,7 +1827,7 @@ static int i915_sr_status(struct seq_file *m, void *unused)
 	bool sr_enabled = false;
@@ -1856,7 +1856,7 @@ static int i915_emon_status(struct seq_file *m, void *unused)
 	unsigned long temp, chipset, gfx;
 	int ret;
@@ -1884,7 +1884,7 @@ static int i915_ring_freq_table(struct seq_file *m, void *unused)
 	int ret = 0;
 	int gpu_freq, ia_freq;
 	unsigned int max_gpu_freq, min_gpu_freq;
@@ -1939,7 +1939,7 @@ static int i915_opregion(struct seq_file *m, void *unused)
 	struct intel_opregion *opregion = &dev_priv->opregion;
 	int ret;
@@ -1960,7 +1960,7 @@ static int i915_vbt(struct seq_file *m, void *unused)
 	if (opregion->vbt)
@@ -2031,7 +2031,7 @@ static int i915_context_status(struct seq_file *m, void *unused)
 	struct i915_gem_context *ctx;
 	int ret;
@@ -2128,7 +2128,7 @@ static int i915_dump_lrc(struct seq_file *m, void *unused)
 	struct drm_info_node *node = (struct drm_info_node *) m->private;
 	int ret;
@@ -2155,7 +2155,7 @@ static int i915_execlists(struct seq_file *m, void *data)
 	struct drm_info_node *node = (struct drm_info_node *)m->private;
 	u32 status_pointer;
 	u8 read_pointer;
@@ -2258,7 +2258,7 @@ static int i915_swizzle_info(struct seq_file *m, void *data)
 	int ret;
@@ -2331,7 +2331,7 @@ static int per_file_ctx(int id, void *ptr, void *data)
 static void gen8_ppgtt_info(struct seq_file *m, struct drm_device *dev)
 	struct i915_hw_ppgtt *ppgtt = dev_priv->mm.aliasing_ppgtt;
 	int i;
@@ -2352,7 +2352,7 @@ static void gen8_ppgtt_info(struct seq_file *m, struct drm_device *dev)
 static void gen6_ppgtt_info(struct seq_file *m, struct drm_device *dev)
 	if (IS_GEN6(dev_priv))
@@ -2386,7 +2386,7 @@ static int i915_ppgtt_info(struct seq_file *m, void *data)
 	struct drm_file *file;
 	int ret = mutex_lock_interruptible(&dev->struct_mutex);
@@ -2438,7 +2438,7 @@ static int i915_rps_boost_info(struct seq_file *m, void *data)
 	seq_printf(m, "RPS enabled? %d\n", dev_priv->rps.enabled);
@@ -2484,7 +2484,7 @@ static int i915_llc(struct seq_file *m, void *data)
 	const bool edram = INTEL_GEN(dev_priv) > 8;
 	seq_printf(m, "LLC: %s\n", yesno(HAS_LLC(dev)));
@@ -2497,7 +2497,7 @@ static int i915_llc(struct seq_file *m, void *data)
 static int i915_guc_load_status_info(struct seq_file *m, void *data)
-	struct drm_i915_private *dev_priv = node->minor->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(node->minor->dev);
 	struct intel_guc_fw *guc_fw = &dev_priv->guc.guc_fw;
 	u32 tmp, i;
@@ -2570,7 +2570,7 @@ static int i915_guc_info(struct seq_file *m, void *data)
 	struct intel_guc guc;
 	struct i915_guc_client client = {};
@@ -2620,7 +2620,7 @@ static int i915_guc_log_dump(struct seq_file *m, void *data)
 	struct drm_i915_gem_object *log_obj = dev_priv->guc.log_obj;
 	u32 *log;
 	int i = 0, pg;
@@ -2648,7 +2648,7 @@ static int i915_edp_psr_status(struct seq_file *m, void *data)
 	u32 psrperf = 0;
 	u32 stat[3];
 	enum pipe pipe;
@@ -2756,7 +2756,7 @@ static int i915_energy_uJ(struct seq_file *m, void *data)
 	u64 power;
 	u32 units;
@@ -2782,7 +2782,7 @@ static int i915_runtime_pm_status(struct seq_file *m, void *unused)
 	if (!HAS_RUNTIME_PM(dev_priv))
 		seq_puts(m, "Runtime power management not supported\n");
@@ -2807,7 +2807,7 @@ static int i915_power_domain_info(struct seq_file *m, void *unused)
 	struct i915_power_domains *power_domains = &dev_priv->power_domains;
 	int i;
@@ -2842,7 +2842,7 @@ static int i915_dmc_info(struct seq_file *m, void *unused)
 	struct intel_csr *csr;
 	if (!HAS_CSR(dev)) {
@@ -3033,7 +3033,7 @@ static void intel_connector_info(struct seq_file *m,
 static bool cursor_active(struct drm_device *dev, int pipe)
 	u32 state;
 	if (IS_845G(dev) || IS_I865G(dev))
@@ -3046,7 +3046,7 @@ static bool cursor_active(struct drm_device *dev, int pipe)
 static bool cursor_position(struct drm_device *dev, int pipe, int *x, int *y)
 	u32 pos;
 	pos = I915_READ(CURPOS(pipe));
@@ -3167,7 +3167,7 @@ static int i915_display_info(struct seq_file *m, void *unused)
 	struct drm_connector *connector;
@@ -3222,7 +3222,7 @@ static int i915_semaphore_status(struct seq_file *m, void *unused)
 	int num_rings = hweight32(INTEL_INFO(dev)->ring_mask);
 	enum intel_engine_id id;
@@ -3295,7 +3295,7 @@ static int i915_shared_dplls_info(struct seq_file *m, void *unused)
 	int i;
 	drm_modeset_lock_all(dev);
@@ -3325,7 +3325,7 @@ static int i915_wa_registers(struct seq_file *m, void *unused)
 	struct i915_workarounds *workarounds = &dev_priv->workarounds;
@@ -3363,7 +3363,7 @@ static int i915_ddb_info(struct seq_file *m, void *unused)
 	struct skl_ddb_allocation *ddb;
 	struct skl_ddb_entry *entry;
 	enum pipe pipe;
@@ -3401,7 +3401,7 @@ static int i915_ddb_info(struct seq_file *m, void *unused)
 static void drrs_status_per_crtc(struct seq_file *m,
 		struct drm_device *dev, struct intel_crtc *intel_crtc)
 	struct i915_drrs *drrs = &dev_priv->drrs;
 	int vrefresh = 0;
@@ -3528,7 +3528,7 @@ static int i915_dp_mst_info(struct seq_file *m, void *unused)
 static int i915_pipe_crc_open(struct inode *inode, struct file *filep)
 	struct pipe_crc_info *info = inode->i_private;
-	struct drm_i915_private *dev_priv = info->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(info->dev);
 	struct intel_pipe_crc *pipe_crc = &dev_priv->pipe_crc[info->pipe];
 	if (info->pipe >= INTEL_INFO(info->dev)->num_pipes)
@@ -3552,7 +3552,7 @@ static int i915_pipe_crc_open(struct inode *inode, struct file *filep)
 static int i915_pipe_crc_release(struct inode *inode, struct file *filep)
 	spin_lock_irq(&pipe_crc->lock);
@@ -3580,7 +3580,7 @@ i915_pipe_crc_read(struct file *filep, char __user *user_buf, size_t count,
 	struct pipe_crc_info *info = filep->private_data;
 	struct drm_device *dev = info->dev;
 	char buf[PIPE_CRC_BUFFER_LEN];
 	int n_entries;
@@ -3713,7 +3713,7 @@ static const char *pipe_crc_source_name(enum intel_pipe_crc_source source)
 static int display_crc_ctl_show(struct seq_file *m, void *data)
 	struct drm_device *dev = m->private;
 	int i;
 	for (i = 0; i < I915_MAX_PIPES; i++)
@@ -3807,7 +3807,7 @@ static int vlv_pipe_crc_ctl_reg(struct drm_device *dev,
 				enum intel_pipe_crc_source *source,
 				uint32_t *val)
 	bool need_stable_symbols = false;
 	if (*source == INTEL_PIPE_CRC_SOURCE_AUTO) {
@@ -3878,7 +3878,7 @@ static int i9xx_pipe_crc_ctl_reg(struct drm_device *dev,
 				 uint32_t *val)
@@ -3952,7 +3952,7 @@ static int i9xx_pipe_crc_ctl_reg(struct drm_device *dev,
 static void vlv_undo_pipe_scramble_reset(struct drm_device *dev,
 					 enum pipe pipe)
 	uint32_t tmp = I915_READ(PORT_DFT2_G4X);
 	switch (pipe) {
@@ -3977,7 +3977,7 @@ static void vlv_undo_pipe_scramble_reset(struct drm_device *dev,
 static void g4x_undo_pipe_scramble_reset(struct drm_device *dev,
 					 enum pipe pipe)
 	if (pipe == PIPE_A)
@@ -4020,7 +4020,7 @@ static int ilk_pipe_crc_ctl_reg(enum intel_pipe_crc_source *source,
 static void hsw_trans_edp_pipe_A_crc_wa(struct drm_device *dev, bool enable)
 	struct intel_crtc *crtc =
 		to_intel_crtc(dev_priv->pipe_to_crtc_mapping[PIPE_A]);
 	struct intel_crtc_state *pipe_config;
@@ -4088,7 +4088,7 @@ static int ivb_pipe_crc_ctl_reg(struct drm_device *dev,
 static int pipe_crc_set_source(struct drm_device *dev, enum pipe pipe,
 	struct intel_pipe_crc *pipe_crc = &dev_priv->pipe_crc[pipe];
 	struct intel_crtc *crtc = to_intel_crtc(intel_get_crtc_for_pipe(dev,
 									pipe));
@@ -4595,7 +4595,7 @@ static void wm_latency_show(struct seq_file *m, const uint16_t wm[8])
 static int pri_wm_latency_show(struct seq_file *m, void *data)
 	const uint16_t *latencies;
 	if (INTEL_INFO(dev)->gen >= 9)
@@ -4611,7 +4611,7 @@ static int pri_wm_latency_show(struct seq_file *m, void *data)
 static int spr_wm_latency_show(struct seq_file *m, void *data)
@@ -4627,7 +4627,7 @@ static int spr_wm_latency_show(struct seq_file *m, void *data)
 static int cur_wm_latency_show(struct seq_file *m, void *data)
@@ -4718,7 +4718,7 @@ static ssize_t pri_wm_latency_write(struct file *file, const char __user *ubuf,
 	struct seq_file *m = file->private_data;
@@ -4734,7 +4734,7 @@ static ssize_t spr_wm_latency_write(struct file *file, const char __user *ubuf,
@@ -4750,7 +4750,7 @@ static ssize_t cur_wm_latency_write(struct file *file, const char __user *ubuf,
@@ -4792,7 +4792,7 @@ static int
 i915_wedged_get(void *data, u64 *val)
 	*val = i915_terminally_wedged(&dev_priv->gpu_error);
@@ -4803,7 +4803,7 @@ static int
 i915_wedged_set(void *data, u64 val)
 	 * There is no safeguard against this debugfs entry colliding
@@ -4834,7 +4834,7 @@ static int
 i915_ring_missed_irq_get(void *data, u64 *val)
 	*val = dev_priv->gpu_error.missed_irq_rings;
 	return 0;
@@ -4844,7 +4844,7 @@ static int
 i915_ring_missed_irq_set(void *data, u64 val)
 	int ret;
 	/* Lock against concurrent debugfs callers */
@@ -4865,7 +4865,7 @@ static int
 i915_ring_test_irq_get(void *data, u64 *val)
 	*val = dev_priv->gpu_error.test_irq_rings;
@@ -4876,7 +4876,7 @@ static int
 i915_ring_test_irq_set(void *data, u64 val)
 	val &= INTEL_INFO(dev_priv)->ring_mask;
 	DRM_DEBUG_DRIVER("Masking interrupts on rings 0x%08llx\n", val);
@@ -4909,7 +4909,7 @@ static int
 i915_drop_caches_set(void *data, u64 val)
 	int ret;
 	DRM_DEBUG("Dropping caches: 0x%08llx\n", val);
@@ -4949,7 +4949,7 @@ static int
 i915_max_freq_get(void *data, u64 *val)
 	int ret;
 	if (INTEL_INFO(dev)->gen < 6)
@@ -4971,7 +4971,7 @@ static int
 i915_max_freq_set(void *data, u64 val)
 	u32 hw_max, hw_min;
 	int ret;
@@ -5016,7 +5016,7 @@ static int
 i915_min_freq_get(void *data, u64 *val)
 	int ret;
@@ -5038,7 +5038,7 @@ static int
 i915_min_freq_set(void *data, u64 val)
 	u32 hw_max, hw_min;
 	int ret;
@@ -5083,7 +5083,7 @@ static int
 i915_cache_sharing_get(void *data, u64 *val)
 	u32 snpcr;
 	int ret;
@@ -5109,7 +5109,7 @@ static int
 i915_cache_sharing_set(void *data, u64 val)
 	u32 snpcr;
 	if (!(IS_GEN6(dev) || IS_GEN7(dev)))
@@ -5146,7 +5146,7 @@ struct sseu_dev_status {
 static void cherryview_sseu_device_status(struct drm_device *dev,
 					  struct sseu_dev_status *stat)
 	int ss_max = 2;
 	int ss;
 	u32 sig1[ss_max], sig2[ss_max];
@@ -5178,7 +5178,7 @@ static void cherryview_sseu_device_status(struct drm_device *dev,
 static void gen9_sseu_device_status(struct drm_device *dev,
 	int s_max = 3, ss_max = 4;
 	int s, ss;
 	u32 s_reg[s_max], eu_reg[2*s_max], eu_mask[2];
@@ -5243,7 +5243,7 @@ static void gen9_sseu_device_status(struct drm_device *dev,
 static void broadwell_sseu_device_status(struct drm_device *dev,
 	int s;
 	u32 slice_info = I915_READ(GEN8_GT_SLICE_INFO);
@@ -5322,7 +5322,7 @@ static int i915_sseu_status(struct seq_file *m, void *unused)
 static int i915_forcewake_open(struct inode *inode, struct file *file)
 	struct drm_device *dev = inode->i_private;
 		return 0;
@@ -5336,7 +5336,7 @@ static int i915_forcewake_open(struct inode *inode, struct file *file)
 static int i915_forcewake_release(struct inode *inode, struct file *file)
 		return 0;
@@ -5469,7 +5469,7 @@ static const struct i915_debugfs_files {
 void intel_display_crc_init(struct drm_device *dev)
 	enum pipe pipe;
 	for_each_pipe(dev_priv, pipe) {
diff --git a/drivers/gpu/drm/i915/i915_drv.c b/drivers/gpu/drm/i915/i915_drv.c
index 7b9b6f9..695001f 100644
--- a/drivers/gpu/drm/i915/i915_drv.c
+++ b/drivers/gpu/drm/i915/i915_drv.c
@@ -144,7 +144,7 @@ static enum intel_pch intel_virt_detect_pch(struct drm_device *dev)
 static void intel_detect_pch(struct drm_device *dev)
 	struct pci_dev *pch = NULL;
 	/* In all current cases, num_pipes is equivalent to the PCH_NOP setting
@@ -248,7 +248,7 @@ bool i915_semaphore_is_enabled(struct drm_i915_private *dev_priv)
 static int i915_getparam(struct drm_device *dev, void *data,
 			 struct drm_file *file_priv)
 	drm_i915_getparam_t *param = data;
 	int value;
@@ -384,7 +384,7 @@ static int i915_getparam(struct drm_device *dev, void *data,
 static int i915_get_bridge_dev(struct drm_device *dev)
 	dev_priv->bridge_dev = pci_get_bus_and_slot(0, PCI_DEVFN(0, 0));
 	if (!dev_priv->bridge_dev) {
@@ -398,7 +398,7 @@ static int i915_get_bridge_dev(struct drm_device *dev)
 static int
 intel_alloc_mchbar_resource(struct drm_device *dev)
 	int reg = INTEL_INFO(dev)->gen >= 4 ? MCHBAR_I965 : MCHBAR_I915;
 	u32 temp_lo, temp_hi = 0;
 	u64 mchbar_addr;
@@ -444,7 +444,7 @@ intel_alloc_mchbar_resource(struct drm_device *dev)
 static void
 intel_setup_mchbar(struct drm_device *dev)
 	int mchbar_reg = INTEL_INFO(dev)->gen >= 4 ? MCHBAR_I965 : MCHBAR_I915;
 	u32 temp;
 	bool enabled;
@@ -484,7 +484,7 @@ intel_setup_mchbar(struct drm_device *dev)
 static void
 intel_teardown_mchbar(struct drm_device *dev)
 	if (dev_priv->mchbar_need_disable) {
@@ -601,7 +601,7 @@ static void i915_gem_fini(struct drm_device *dev)
 static int i915_load_modeset_init(struct drm_device *dev)
 	int ret;
 	if (i915_inject_load_failure())
@@ -1671,7 +1671,7 @@ out_free_priv:
 void i915_driver_unload(struct drm_device *dev)
 	intel_fbdev_fini(dev);
@@ -1797,7 +1797,7 @@ static bool suspend_to_idle(struct drm_i915_private *dev_priv)
 static int i915_drm_suspend(struct drm_device *dev)
 	pci_power_t opregion_target_state;
 	int error;
@@ -1864,7 +1864,7 @@ out:
 static int i915_drm_suspend_late(struct drm_device *drm_dev, bool hibernation)
-	struct drm_i915_private *dev_priv = drm_dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(drm_dev);
 	bool fw_csr;
 	int ret;
@@ -1948,7 +1948,7 @@ int i915_suspend_switcheroo(struct drm_device *dev, pm_message_t state)
 static int i915_drm_resume(struct drm_device *dev)
 	int ret;
 	disable_rpm_wakeref_asserts(dev_priv);
@@ -2028,7 +2028,7 @@ static int i915_drm_resume(struct drm_device *dev)
 static int i915_drm_resume_early(struct drm_device *dev)
 	int ret;
@@ -2684,7 +2684,7 @@ static int intel_runtime_suspend(struct device *device)
 	struct pci_dev *pdev = to_pci_dev(device);
 	struct drm_device *dev = pci_get_drvdata(pdev);
 	int ret;
 	if (WARN_ON_ONCE(!(dev_priv->rps.enabled && intel_enable_rc6())))
@@ -2788,7 +2788,7 @@ static int intel_runtime_resume(struct device *device)
 	int ret = 0;
 	if (WARN_ON_ONCE(!HAS_RUNTIME_PM(dev)))
diff --git a/drivers/gpu/drm/i915/i915_gem.c b/drivers/gpu/drm/i915/i915_gem.c
index 94d68f9..7a88840 100644
--- a/drivers/gpu/drm/i915/i915_gem.c
+++ b/drivers/gpu/drm/i915/i915_gem.c
@@ -128,7 +128,7 @@ i915_gem_wait_for_error(struct i915_gpu_error *error)
 int i915_mutex_lock_interruptible(struct drm_device *dev)
 	int ret;
 	ret = i915_gem_wait_for_error(&dev_priv->gpu_error);
@@ -377,13 +377,13 @@ out:
 void *i915_gem_object_alloc(struct drm_device *dev)
 	return kmem_cache_zalloc(dev_priv->objects, GFP_KERNEL);
 void i915_gem_object_free(struct drm_i915_gem_object *obj)
-	struct drm_i915_private *dev_priv = obj->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(obj->base.dev);
 	kmem_cache_free(dev_priv->objects, obj);
@@ -636,7 +636,7 @@ i915_gem_gtt_pread(struct drm_device *dev,
 		   struct drm_i915_gem_object *obj, uint64_t size,
 		   uint64_t data_offset, uint64_t data_ptr)
 	struct i915_ggtt *ggtt = &dev_priv->ggtt;
 	struct drm_mm_node node;
 	char __user *user_data;
@@ -1250,7 +1250,7 @@ int
 i915_gem_pwrite_ioctl(struct drm_device *dev, void *data,
 		      struct drm_file *file)
 	struct drm_i915_gem_pwrite *args = data;
 	int ret;
@@ -1761,7 +1761,7 @@ i915_gem_object_wait_rendering__nonblocking(struct drm_i915_gem_object *obj,
 					    bool readonly)
 	struct drm_device *dev = obj->base.dev;
 	struct drm_i915_gem_request *requests[I915_NUM_ENGINES];
 	int ret, i, n = 0;
@@ -2273,7 +2273,7 @@ i915_gem_get_gtt_alignment(struct drm_device *dev, uint32_t size,
 static int i915_gem_object_create_mmap_offset(struct drm_i915_gem_object *obj)
 	int ret;
 	dev_priv->mm.shrinker_no_lock_stealing = true;
@@ -2489,7 +2489,7 @@ i915_gem_object_put_pages(struct drm_i915_gem_object *obj)
 static int
 i915_gem_object_get_pages_gtt(struct drm_i915_gem_object *obj)
 	int page_count, i;
 	struct address_space *mapping;
 	struct sg_table *st;
@@ -2620,7 +2620,7 @@ err_pages:
 int
 i915_gem_object_get_pages(struct drm_i915_gem_object *obj)
 	const struct drm_i915_gem_object_ops *ops = obj->ops;
 	int ret;
@@ -2800,7 +2800,7 @@ i915_gem_init_seqno(struct drm_i915_private *dev_priv, u32 seqno)
 int i915_gem_set_seqno(struct drm_device *dev, u32 seqno)
 	int ret;
 	if (seqno == 0)
@@ -3182,7 +3182,7 @@ static void i915_gem_reset_engine_cleanup(struct intel_engine_cs *engine)
 void i915_gem_reset(struct drm_device *dev)
@@ -3632,7 +3632,7 @@ static void __i915_vma_iounmap(struct i915_vma *vma)
 static int __i915_vma_unbind(struct i915_vma *vma, bool wait)
 	struct drm_i915_gem_object *obj = vma->obj;
 	int ret;
 	if (list_empty(&vma->obj_link))
@@ -4250,7 +4250,7 @@ int i915_gem_get_caching_ioctl(struct drm_device *dev, void *data,
 int i915_gem_set_caching_ioctl(struct drm_device *dev, void *data,
 	struct drm_i915_gem_caching *args = data;
 	enum i915_cache_level level;
@@ -4444,7 +4444,7 @@ i915_gem_object_set_to_cpu_domain(struct drm_i915_gem_object *obj, bool write)
 static int
 i915_gem_ring_throttle(struct drm_device *dev, struct drm_file *file)
 	struct drm_i915_file_private *file_priv = file->driver_priv;
 	unsigned long recent_enough = jiffies - DRM_I915_THROTTLE_JIFFIES;
 	struct drm_i915_gem_request *request, *target = NULL;
@@ -4538,7 +4538,7 @@ i915_gem_object_do_pin(struct drm_i915_gem_object *obj,
 		       uint32_t alignment,
 		       uint64_t flags)
 	struct i915_vma *vma;
 	unsigned bound;
 	int ret;
@@ -4702,7 +4702,7 @@ int
 i915_gem_madvise_ioctl(struct drm_device *dev, void *data,
 	struct drm_i915_gem_madvise *args = data;
 	int ret;
@@ -4867,7 +4867,7 @@ void i915_gem_free_object(struct drm_gem_object *gem_obj)
 	struct drm_i915_gem_object *obj = to_intel_bo(gem_obj);
 	struct i915_vma *vma, *next;
@@ -4971,7 +4971,7 @@ void i915_gem_vma_destroy(struct i915_vma *vma)
 static void
 i915_gem_stop_engines(struct drm_device *dev)
 	for_each_engine(engine, dev_priv)
@@ -4981,7 +4981,7 @@ i915_gem_stop_engines(struct drm_device *dev)
 int
 i915_gem_suspend(struct drm_device *dev)
 	int ret = 0;
 	mutex_lock(&dev->struct_mutex);
@@ -5013,7 +5013,7 @@ err:
 void i915_gem_init_swizzling(struct drm_device *dev)
 	if (INTEL_INFO(dev)->gen < 5 ||
 	    dev_priv->mm.bit_6_swizzle_x == I915_BIT_6_SWIZZLE_NONE)
@@ -5038,7 +5038,7 @@ void i915_gem_init_swizzling(struct drm_device *dev)
 static void init_unused_ring(struct drm_device *dev, u32 base)
 	I915_WRITE(RING_CTL(base), 0);
 	I915_WRITE(RING_HEAD(base), 0);
@@ -5065,7 +5065,7 @@ static void init_unused_rings(struct drm_device *dev)
 int i915_gem_init_engines(struct drm_device *dev)
 	int ret;
 	ret = intel_init_render_ring_buffer(dev);
@@ -5113,7 +5113,7 @@ cleanup_render_ring:
 int
 i915_gem_init_hw(struct drm_device *dev)
 	int ret;
@@ -5178,7 +5178,7 @@ out:
 int i915_gem_init(struct drm_device *dev)
 	int ret;
@@ -5235,7 +5235,7 @@ out_unlock:
 void
 i915_gem_cleanup_engines(struct drm_device *dev)
@@ -5276,7 +5276,7 @@ i915_gem_load_init_fences(struct drm_i915_private *dev_priv)
 void
 i915_gem_load_init(struct drm_device *dev)
 	int i;
 	dev_priv->objects =
@@ -5444,7 +5444,7 @@ void i915_gem_track_fb(struct drm_i915_gem_object *old,
 u64 i915_gem_obj_offset(struct drm_i915_gem_object *o,
 			struct i915_address_space *vm)
-	struct drm_i915_private *dev_priv = o->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(o->base.dev);
 	WARN_ON(vm == &dev_priv->mm.aliasing_ppgtt->base);
diff --git a/drivers/gpu/drm/i915/i915_gem_context.c b/drivers/gpu/drm/i915/i915_gem_context.c
index 8e952b1..b4bba8a 100644
--- a/drivers/gpu/drm/i915/i915_gem_context.c
+++ b/drivers/gpu/drm/i915/i915_gem_context.c
@@ -250,7 +250,7 @@ static struct i915_gem_context *
 __create_hw_context(struct drm_device *dev,
 		    struct drm_i915_file_private *file_priv)
 	int ret;
@@ -396,7 +396,7 @@ static void i915_gem_context_unpin(struct i915_gem_context *ctx,
 void i915_gem_context_reset(struct drm_device *dev)
 	lockdep_assert_held(&dev->struct_mutex);
@@ -412,7 +412,7 @@ void i915_gem_context_reset(struct drm_device *dev)
 int i915_gem_context_init(struct drm_device *dev)
 	/* Init should only be called once per module load. Eventually the
@@ -499,7 +499,7 @@ void i915_gem_context_lost(struct drm_i915_private *dev_priv)
 void i915_gem_context_fini(struct drm_device *dev)
 	struct i915_gem_context *dctx = dev_priv->kernel_context;
@@ -1096,7 +1096,7 @@ int i915_gem_context_setparam_ioctl(struct drm_device *dev, void *data,
 int i915_gem_context_reset_stats_ioctl(struct drm_device *dev,
 				       void *data, struct drm_file *file)
 	struct drm_i915_reset_stats *args = data;
 	struct i915_ctx_hang_stats *hs;
diff --git a/drivers/gpu/drm/i915/i915_gem_execbuffer.c b/drivers/gpu/drm/i915/i915_gem_execbuffer.c
index 39c53d9..3a04d37 100644
--- a/drivers/gpu/drm/i915/i915_gem_execbuffer.c
+++ b/drivers/gpu/drm/i915/i915_gem_execbuffer.c
@@ -1142,7 +1142,7 @@ i915_reset_gen7_sol_offsets(struct drm_device *dev,
 			    struct drm_i915_gem_request *req)
 	struct intel_engine_cs *engine = req->engine;
 	int ret, i;
 	if (!IS_GEN7(dev) || engine != &dev_priv->engine[RCS]) {
@@ -1225,7 +1225,7 @@ i915_gem_ringbuffer_submission(struct i915_execbuffer_params *params,
 	struct drm_device *dev = params->dev;
 	struct intel_engine_cs *engine = params->engine;
 	u64 exec_start, exec_len;
 	int instp_mode;
 	u32 instp_mask;
diff --git a/drivers/gpu/drm/i915/i915_gem_fence.c b/drivers/gpu/drm/i915/i915_gem_fence.c
index 2b6bdc2..251d7a9 100644
--- a/drivers/gpu/drm/i915/i915_gem_fence.c
+++ b/drivers/gpu/drm/i915/i915_gem_fence.c
@@ -58,7 +58,7 @@
 static void i965_write_fence_reg(struct drm_device *dev, int reg,
 	i915_reg_t fence_reg_lo, fence_reg_hi;
 	int fence_pitch_shift;
@@ -117,7 +117,7 @@ static void i965_write_fence_reg(struct drm_device *dev, int reg,
 static void i915_write_fence_reg(struct drm_device *dev, int reg,
 	u32 val;
 	if (obj) {
@@ -156,7 +156,7 @@ static void i915_write_fence_reg(struct drm_device *dev, int reg,
 static void i830_write_fence_reg(struct drm_device *dev, int reg,
 	uint32_t val;
 	if (obj) {
@@ -193,7 +193,7 @@ inline static bool i915_gem_object_needs_mb(struct drm_i915_gem_object *obj)
 static void i915_gem_write_fence(struct drm_device *dev, int reg,
 	/* Ensure that all CPU reads are completed before installing a fence
 	 * and all writes before removing the fence.
@@ -229,7 +229,7 @@ static void i915_gem_object_update_fence(struct drm_i915_gem_object *obj,
 					 struct drm_i915_fence_reg *fence,
 					 bool enable)
 	int reg = fence_number(dev_priv, fence);
 	i915_gem_write_fence(obj->base.dev, reg, enable ? obj : NULL);
@@ -286,7 +286,7 @@ i915_gem_object_wait_fence(struct drm_i915_gem_object *obj)
 int
 i915_gem_object_put_fence(struct drm_i915_gem_object *obj)
 	struct drm_i915_fence_reg *fence;
 	int ret;
@@ -311,7 +311,7 @@ i915_gem_object_put_fence(struct drm_i915_gem_object *obj)
 static struct drm_i915_fence_reg *
 i915_find_fence_reg(struct drm_device *dev)
 	struct drm_i915_fence_reg *reg, *avail;
 	int i;
@@ -367,7 +367,7 @@ int
 i915_gem_object_get_fence(struct drm_i915_gem_object *obj)
 	bool enable = obj->tiling_mode != I915_TILING_NONE;
 	struct drm_i915_fence_reg *reg;
 	int ret;
@@ -433,7 +433,7 @@ bool
 i915_gem_object_pin_fence(struct drm_i915_gem_object *obj)
 	if (obj->fence_reg != I915_FENCE_REG_NONE) {
 		struct i915_vma *ggtt_vma = i915_gem_obj_to_ggtt(obj);
 		WARN_ON(!ggtt_vma ||
@@ -457,7 +457,7 @@ void
 i915_gem_object_unpin_fence(struct drm_i915_gem_object *obj)
 		WARN_ON(dev_priv->fence_regs[obj->fence_reg].pin_count <= 0);
 		dev_priv->fence_regs[obj->fence_reg].pin_count--;
@@ -472,7 +472,7 @@ i915_gem_object_unpin_fence(struct drm_i915_gem_object *obj)
 void i915_gem_restore_fences(struct drm_device *dev)
 	int i;
 	for (i = 0; i < dev_priv->num_fence_regs; i++) {
@@ -549,7 +549,7 @@ void i915_gem_restore_fences(struct drm_device *dev)
 void
 i915_gem_detect_bit_6_swizzle(struct drm_device *dev)
 	uint32_t swizzle_x = I915_BIT_6_SWIZZLE_UNKNOWN;
 	uint32_t swizzle_y = I915_BIT_6_SWIZZLE_UNKNOWN;
diff --git a/drivers/gpu/drm/i915/i915_gem_gtt.c b/drivers/gpu/drm/i915/i915_gem_gtt.c
index 0bb18b8..cf6fdcb 100644
--- a/drivers/gpu/drm/i915/i915_gem_gtt.c
+++ b/drivers/gpu/drm/i915/i915_gem_gtt.c
@@ -1732,7 +1732,7 @@ static int gen6_mm_switch(struct i915_hw_ppgtt *ppgtt,
 	struct drm_device *dev = ppgtt->base.dev;
 	I915_WRITE(RING_PP_DIR_DCLV(engine), PP_DIR_DCLV_2G);
@@ -1745,7 +1745,7 @@ static int gen6_mm_switch(struct i915_hw_ppgtt *ppgtt,
 static void gen8_ppgtt_enable(struct drm_device *dev)
 	for_each_engine(engine, dev_priv) {
@@ -1757,7 +1757,7 @@ static void gen8_ppgtt_enable(struct drm_device *dev)
 static void gen7_ppgtt_enable(struct drm_device *dev)
 	uint32_t ecochk, ecobits;
@@ -1782,7 +1782,7 @@ static void gen7_ppgtt_enable(struct drm_device *dev)
 static void gen6_ppgtt_enable(struct drm_device *dev)
 	uint32_t ecochk, gab_ctl, ecobits;
 	ecobits = I915_READ(GAC_ECO_BITS);
@@ -2142,7 +2142,7 @@ static void i915_address_space_init(struct i915_address_space *vm,
 static void gtt_write_workarounds(struct drm_device *dev)
 	/* This function is for gtt related workarounds. This function is
 	 * called on driver load and after a GPU reset, so you can place
@@ -2161,7 +2161,7 @@ static void gtt_write_workarounds(struct drm_device *dev)
 static int i915_ppgtt_init(struct drm_device *dev, struct i915_hw_ppgtt *ppgtt)
 	int ret = 0;
 	ret = __hw_ppgtt_init(dev, ppgtt);
@@ -2611,7 +2611,7 @@ static void i915_ggtt_insert_entries(struct i915_address_space *vm,
 				     uint64_t start,
 				     enum i915_cache_level cache_level, u32 unused)
-	struct drm_i915_private *dev_priv = vm->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(vm->dev);
 	unsigned int flags = (cache_level == I915_CACHE_NONE) ?
 		AGP_USER_MEMORY : AGP_USER_CACHED_MEMORY;
 	int rpm_atomic_seq;
@@ -2629,7 +2629,7 @@ static void i915_ggtt_clear_range(struct i915_address_space *vm,
 				  uint64_t length,
 				  bool unused)
 	unsigned first_entry = start >> PAGE_SHIFT;
 	unsigned num_entries = length >> PAGE_SHIFT;
 	int rpm_atomic_seq;
@@ -2710,7 +2710,7 @@ static int aliasing_gtt_bind_vma(struct i915_vma *vma,
 static void ggtt_unbind_vma(struct i915_vma *vma)
 	struct drm_device *dev = vma->vm->dev;
 	const uint64_t size = min_t(uint64_t,
 				    obj->base.size,
@@ -2736,7 +2736,7 @@ static void ggtt_unbind_vma(struct i915_vma *vma)
 void i915_gem_gtt_finish_object(struct drm_i915_gem_object *obj)
 	bool interruptible;
 	interruptible = do_idling(dev_priv);
diff --git a/drivers/gpu/drm/i915/i915_gem_stolen.c b/drivers/gpu/drm/i915/i915_gem_stolen.c
index e9cd822..66be299a1 100644
--- a/drivers/gpu/drm/i915/i915_gem_stolen.c
+++ b/drivers/gpu/drm/i915/i915_gem_stolen.c
@@ -270,7 +270,7 @@ static unsigned long i915_stolen_to_physical(struct drm_device *dev)
 void i915_gem_cleanup_stolen(struct drm_device *dev)
 	if (!drm_mm_initialized(&dev_priv->mm.stolen))
 		return;
@@ -550,7 +550,7 @@ static void i915_gem_object_put_pages_stolen(struct drm_i915_gem_object *obj)
 static void
 i915_gem_object_release_stolen(struct drm_i915_gem_object *obj)
 	if (obj->stolen) {
 		i915_gem_stolen_remove_node(dev_priv, obj->stolen);
@@ -601,7 +601,7 @@ cleanup:
 i915_gem_object_create_stolen(struct drm_device *dev, u32 size)
 	struct drm_mm_node *stolen;
 	int ret;
diff --git a/drivers/gpu/drm/i915/i915_gem_tiling.c b/drivers/gpu/drm/i915/i915_gem_tiling.c
index a6eb5c4..8030199 100644
--- a/drivers/gpu/drm/i915/i915_gem_tiling.c
+++ b/drivers/gpu/drm/i915/i915_gem_tiling.c
@@ -162,7 +162,7 @@ i915_gem_set_tiling(struct drm_device *dev, void *data,
 	struct drm_i915_gem_set_tiling *args = data;
 	int ret = 0;
@@ -294,7 +294,7 @@ i915_gem_get_tiling(struct drm_device *dev, void *data,
 	struct drm_i915_gem_get_tiling *args = data;
 	obj = to_intel_bo(drm_gem_object_lookup(file, args->handle));
diff --git a/drivers/gpu/drm/i915/i915_gpu_error.c b/drivers/gpu/drm/i915/i915_gpu_error.c
index c6e05cc..1d9aa3e 100644
--- a/drivers/gpu/drm/i915/i915_gpu_error.c
+++ b/drivers/gpu/drm/i915/i915_gpu_error.c
@@ -332,7 +332,7 @@ int i915_error_state_to_str(struct drm_i915_error_state_buf *m,
 			    const struct i915_error_state_file_priv *error_priv)
 	struct drm_device *dev = error_priv->dev;
 	struct drm_i915_error_state *error = error_priv->error;
 	struct drm_i915_error_object *obj;
 	int i, j, offset, elt;
@@ -1451,7 +1451,7 @@ void i915_capture_error_state(struct drm_i915_private *dev_priv,
 void i915_error_state_get(struct drm_device *dev,
 	spin_lock_irq(&dev_priv->gpu_error.lock);
 	error_priv->error = dev_priv->gpu_error.first_error;
@@ -1469,7 +1469,7 @@ void i915_error_state_put(struct i915_error_state_file_priv *error_priv)
 void i915_destroy_error_state(struct drm_device *dev)
 	struct drm_i915_error_state *error;
diff --git a/drivers/gpu/drm/i915/i915_guc_submission.c b/drivers/gpu/drm/i915/i915_guc_submission.c
index 355b647..3f9e3fe 100644
--- a/drivers/gpu/drm/i915/i915_guc_submission.c
+++ b/drivers/gpu/drm/i915/i915_guc_submission.c
@@ -1033,7 +1033,7 @@ void i915_guc_submission_fini(struct drm_i915_private *dev_priv)
 int intel_guc_suspend(struct drm_device *dev)
 	struct intel_guc *guc = &dev_priv->guc;
 	u32 data[3];
@@ -1059,7 +1059,7 @@ int intel_guc_suspend(struct drm_device *dev)
 int intel_guc_resume(struct drm_device *dev)
 	u32 data[3];
diff --git a/drivers/gpu/drm/i915/i915_irq.c b/drivers/gpu/drm/i915/i915_irq.c
index f0535df..f6de8dd 100644
--- a/drivers/gpu/drm/i915/i915_irq.c
+++ b/drivers/gpu/drm/i915/i915_irq.c
@@ -667,7 +667,7 @@ static u32 i8xx_get_vblank_counter(struct drm_device *dev, unsigned int pipe)
 static u32 i915_get_vblank_counter(struct drm_device *dev, unsigned int pipe)
 	i915_reg_t high_frame, low_frame;
 	u32 high1, high2, low, pixel, vbl_start, hsync_start, htotal;
 	struct intel_crtc *intel_crtc =
@@ -714,7 +714,7 @@ static u32 i915_get_vblank_counter(struct drm_device *dev, unsigned int pipe)
 static u32 g4x_get_vblank_counter(struct drm_device *dev, unsigned int pipe)
 	return I915_READ(PIPE_FRMCOUNT_G4X(pipe));
@@ -723,7 +723,7 @@ static u32 g4x_get_vblank_counter(struct drm_device *dev, unsigned int pipe)
 static int __intel_get_crtc_scanline(struct intel_crtc *crtc)
 	struct drm_device *dev = crtc->base.dev;
 	const struct drm_display_mode *mode = &crtc->base.hwmode;
 	enum pipe pipe = crtc->pipe;
 	int position, vtotal;
@@ -775,7 +775,7 @@ static int i915_get_crtc_scanoutpos(struct drm_device *dev, unsigned int pipe,
 				    ktime_t *stime, ktime_t *etime,
 				    const struct drm_display_mode *mode)
 	struct drm_crtc *crtc = dev_priv->pipe_to_crtc_mapping[pipe];
 	struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
 	int position;
@@ -896,7 +896,7 @@ static int i915_get_crtc_scanoutpos(struct drm_device *dev, unsigned int pipe,
 int intel_get_crtc_scanline(struct intel_crtc *crtc)
-	struct drm_i915_private *dev_priv = crtc->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(crtc->base.dev);
 	unsigned long irqflags;
 	int position;
@@ -1744,7 +1744,7 @@ static void i9xx_hpd_irq_handler(struct drm_i915_private *dev_priv,
 static irqreturn_t valleyview_irq_handler(int irq, void *arg)
 	struct drm_device *dev = arg;
 	irqreturn_t ret = IRQ_NONE;
 	if (!intel_irqs_enabled(dev_priv))
@@ -1827,7 +1827,7 @@ static irqreturn_t valleyview_irq_handler(int irq, void *arg)
 static irqreturn_t cherryview_irq_handler(int irq, void *arg)
@@ -2212,7 +2212,7 @@ static void ivb_display_irq_handler(struct drm_i915_private *dev_priv,
 static irqreturn_t ironlake_irq_handler(int irq, void *arg)
 	u32 de_iir, gt_iir, de_ier, sde_ier = 0;
@@ -2444,7 +2444,7 @@ gen8_de_irq_handler(struct drm_i915_private *dev_priv, u32 master_ctl)
 static irqreturn_t gen8_irq_handler(int irq, void *arg)
 	u32 master_ctl;
 	u32 gt_iir[4] = {};
 	irqreturn_t ret;
@@ -2701,7 +2701,7 @@ void i915_handle_error(struct drm_i915_private *dev_priv,
 static int i915_enable_vblank(struct drm_device *dev, unsigned int pipe)
 	spin_lock_irqsave(&dev_priv->irq_lock, irqflags);
@@ -2718,7 +2718,7 @@ static int i915_enable_vblank(struct drm_device *dev, unsigned int pipe)
 static int ironlake_enable_vblank(struct drm_device *dev, unsigned int pipe)
 	uint32_t bit = (INTEL_INFO(dev)->gen >= 7) ? DE_PIPE_VBLANK_IVB(pipe) :
 						     DE_PIPE_VBLANK(pipe);
@@ -2732,7 +2732,7 @@ static int ironlake_enable_vblank(struct drm_device *dev, unsigned int pipe)
 static int valleyview_enable_vblank(struct drm_device *dev, unsigned int pipe)
@@ -2745,7 +2745,7 @@ static int valleyview_enable_vblank(struct drm_device *dev, unsigned int pipe)
 static int gen8_enable_vblank(struct drm_device *dev, unsigned int pipe)
@@ -2760,7 +2760,7 @@ static int gen8_enable_vblank(struct drm_device *dev, unsigned int pipe)
 static void i915_disable_vblank(struct drm_device *dev, unsigned int pipe)
@@ -2772,7 +2772,7 @@ static void i915_disable_vblank(struct drm_device *dev, unsigned int pipe)
 static void ironlake_disable_vblank(struct drm_device *dev, unsigned int pipe)
@@ -2784,7 +2784,7 @@ static void ironlake_disable_vblank(struct drm_device *dev, unsigned int pipe)
 static void valleyview_disable_vblank(struct drm_device *dev, unsigned int pipe)
@@ -2795,7 +2795,7 @@ static void valleyview_disable_vblank(struct drm_device *dev, unsigned int pipe)
 static void gen8_disable_vblank(struct drm_device *dev, unsigned int pipe)
@@ -3214,7 +3214,7 @@ static void i915_hangcheck_elapsed(struct work_struct *work)
 static void ibx_irq_reset(struct drm_device *dev)
 	if (HAS_PCH_NOP(dev))
 		return;
@@ -3235,7 +3235,7 @@ static void ibx_irq_reset(struct drm_device *dev)
 static void ibx_irq_pre_postinstall(struct drm_device *dev)
 		return;
@@ -3247,7 +3247,7 @@ static void ibx_irq_pre_postinstall(struct drm_device *dev)
 static void gen5_gt_irq_reset(struct drm_device *dev)
 	GEN5_IRQ_RESET(GT);
 	if (INTEL_INFO(dev)->gen >= 6)
@@ -3307,7 +3307,7 @@ static void vlv_display_irq_postinstall(struct drm_i915_private *dev_priv)
 static void ironlake_irq_reset(struct drm_device *dev)
 	I915_WRITE(HWSTAM, 0xffffffff);
@@ -3322,7 +3322,7 @@ static void ironlake_irq_reset(struct drm_device *dev)
 static void valleyview_irq_preinstall(struct drm_device *dev)
 	I915_WRITE(VLV_MASTER_IER, 0);
 	POSTING_READ(VLV_MASTER_IER);
@@ -3345,7 +3345,7 @@ static void gen8_gt_irq_reset(struct drm_i915_private *dev_priv)
 static void gen8_irq_reset(struct drm_device *dev)
 	int pipe;
 	I915_WRITE(GEN8_MASTER_IRQ, 0);
@@ -3396,7 +3396,7 @@ void gen8_irq_power_well_pre_disable(struct drm_i915_private *dev_priv,
 static void cherryview_irq_preinstall(struct drm_device *dev)
 	POSTING_READ(GEN8_MASTER_IRQ);
@@ -3548,7 +3548,7 @@ static void bxt_hpd_irq_setup(struct drm_i915_private *dev_priv)
 static void ibx_irq_postinstall(struct drm_device *dev)
 	u32 mask;
@@ -3565,7 +3565,7 @@ static void ibx_irq_postinstall(struct drm_device *dev)
 static void gen5_gt_irq_postinstall(struct drm_device *dev)
 	u32 pm_irqs, gt_irqs;
 	pm_irqs = gt_irqs = 0;
@@ -3601,7 +3601,7 @@ static void gen5_gt_irq_postinstall(struct drm_device *dev)
 static int ironlake_irq_postinstall(struct drm_device *dev)
 	u32 display_mask, extra_mask;
 	if (INTEL_INFO(dev)->gen >= 7) {
@@ -3680,7 +3680,7 @@ void valleyview_disable_display_irqs(struct drm_i915_private *dev_priv)
 static int valleyview_irq_postinstall(struct drm_device *dev)
 	gen5_gt_irq_postinstall(dev);
@@ -3773,7 +3773,7 @@ static void gen8_de_irq_postinstall(struct drm_i915_private *dev_priv)
 static int gen8_irq_postinstall(struct drm_device *dev)
 	if (HAS_PCH_SPLIT(dev))
 		ibx_irq_pre_postinstall(dev);
@@ -3792,7 +3792,7 @@ static int gen8_irq_postinstall(struct drm_device *dev)
 static int cherryview_irq_postinstall(struct drm_device *dev)
 	gen8_gt_irq_postinstall(dev_priv);
@@ -3809,7 +3809,7 @@ static int cherryview_irq_postinstall(struct drm_device *dev)
 static void gen8_irq_uninstall(struct drm_device *dev)
 	if (!dev_priv)
 		return;
@@ -3819,7 +3819,7 @@ static void gen8_irq_uninstall(struct drm_device *dev)
 static void valleyview_irq_uninstall(struct drm_device *dev)
 	if (!dev_priv)
 		return;
@@ -3839,7 +3839,7 @@ static void valleyview_irq_uninstall(struct drm_device *dev)
 static void cherryview_irq_uninstall(struct drm_device *dev)
 	if (!dev_priv)
 		return;
@@ -3859,7 +3859,7 @@ static void cherryview_irq_uninstall(struct drm_device *dev)
 static void ironlake_irq_uninstall(struct drm_device *dev)
 	if (!dev_priv)
 		return;
@@ -3869,7 +3869,7 @@ static void ironlake_irq_uninstall(struct drm_device *dev)
 static void i8xx_irq_preinstall(struct drm_device * dev)
 	int pipe;
@@ -3881,7 +3881,7 @@ static void i8xx_irq_preinstall(struct drm_device * dev)
 static int i8xx_irq_postinstall(struct drm_device *dev)
 	I915_WRITE16(EMR,
 		     ~(I915_ERROR_PAGE_TABLE | I915_ERROR_MEMORY_REFRESH));
@@ -3944,7 +3944,7 @@ check_page_flip:
 static irqreturn_t i8xx_irq_handler(int irq, void *arg)
 	u16 iir, new_iir;
 	u32 pipe_stats[2];
 	int pipe;
@@ -4021,7 +4021,7 @@ out:
 static void i8xx_irq_uninstall(struct drm_device * dev)
 	int pipe;
@@ -4036,7 +4036,7 @@ static void i8xx_irq_uninstall(struct drm_device * dev)
 static void i915_irq_preinstall(struct drm_device * dev)
 	int pipe;
 	if (I915_HAS_HOTPLUG(dev)) {
@@ -4054,7 +4054,7 @@ static void i915_irq_preinstall(struct drm_device * dev)
 static int i915_irq_postinstall(struct drm_device *dev)
 	u32 enable_mask;
 	I915_WRITE(EMR, ~(I915_ERROR_PAGE_TABLE | I915_ERROR_MEMORY_REFRESH));
@@ -4133,7 +4133,7 @@ check_page_flip:
 static irqreturn_t i915_irq_handler(int irq, void *arg)
 	u32 iir, new_iir, pipe_stats[I915_MAX_PIPES];
 	u32 flip_mask =
 		I915_DISPLAY_PLANE_A_FLIP_PENDING_INTERRUPT |
@@ -4238,7 +4238,7 @@ static irqreturn_t i915_irq_handler(int irq, void *arg)
 static void i915_irq_uninstall(struct drm_device * dev)
 	int pipe;
@@ -4260,7 +4260,7 @@ static void i915_irq_uninstall(struct drm_device * dev)
 static void i965_irq_preinstall(struct drm_device * dev)
 	int pipe;
 	i915_hotplug_interrupt_update(dev_priv, 0xffffffff, 0);
@@ -4276,7 +4276,7 @@ static void i965_irq_preinstall(struct drm_device * dev)
 static int i965_irq_postinstall(struct drm_device *dev)
 	u32 enable_mask;
 	u32 error_mask;
@@ -4360,7 +4360,7 @@ static void i915_hpd_irq_setup(struct drm_i915_private *dev_priv)
 static irqreturn_t i965_irq_handler(int irq, void *arg)
 	u32 iir, new_iir;
 	u32 pipe_stats[I915_MAX_PIPES];
 	int ret = IRQ_NONE, pipe;
@@ -4469,7 +4469,7 @@ static irqreturn_t i965_irq_handler(int irq, void *arg)
 static void i965_irq_uninstall(struct drm_device * dev)
 	int pipe;
 	if (!dev_priv)
diff --git a/drivers/gpu/drm/i915/i915_suspend.c b/drivers/gpu/drm/i915/i915_suspend.c
index 34e061a..5cfe4c7 100644
--- a/drivers/gpu/drm/i915/i915_suspend.c
+++ b/drivers/gpu/drm/i915/i915_suspend.c
@@ -31,7 +31,7 @@
 static void i915_save_display(struct drm_device *dev)
 	/* Display arbitration control */
 	if (INTEL_INFO(dev)->gen <= 4)
@@ -63,7 +63,7 @@ static void i915_save_display(struct drm_device *dev)
 static void i915_restore_display(struct drm_device *dev)
 	u32 mask = 0xffffffff;
 	/* Display arbitration */
@@ -103,7 +103,7 @@ static void i915_restore_display(struct drm_device *dev)
 int i915_save_state(struct drm_device *dev)
 	int i;
@@ -148,7 +148,7 @@ int i915_save_state(struct drm_device *dev)
 int i915_restore_state(struct drm_device *dev)
 	int i;
diff --git a/drivers/gpu/drm/i915/i915_sysfs.c b/drivers/gpu/drm/i915/i915_sysfs.c
index a6e90fe..d61829e 100644
--- a/drivers/gpu/drm/i915/i915_sysfs.c
+++ b/drivers/gpu/drm/i915/i915_sysfs.c
@@ -38,7 +38,7 @@
 static u32 calc_residency(struct drm_device *dev,
 			  i915_reg_t reg)
 	u64 raw_time; /* 32b value may overflow during fixed point math */
 	u64 units = 128ULL, div = 100000ULL;
 	u32 ret;
@@ -166,7 +166,7 @@ i915_l3_read(struct file *filp, struct kobject *kobj,
 	struct device *dev = kobj_to_dev(kobj);
 	struct drm_minor *dminor = dev_to_drm_minor(dev);
 	struct drm_device *drm_dev = dminor->dev;
 	int slice = (int)(uintptr_t)attr->private;
 	int ret;
@@ -202,7 +202,7 @@ i915_l3_write(struct file *filp, struct kobject *kobj,
 	u32 *temp = NULL; /* Just here to make handling failures easy */
@@ -268,7 +268,7 @@ static ssize_t gt_act_freq_mhz_show(struct device *kdev,
 	struct drm_minor *minor = dev_to_drm_minor(kdev);
 	struct drm_device *dev = minor->dev;
 	int ret;
 	flush_delayed_work(&dev_priv->rps.delayed_resume_work);
@@ -302,7 +302,7 @@ static ssize_t gt_cur_freq_mhz_show(struct device *kdev,
 	int ret;
@@ -323,7 +323,7 @@ static ssize_t vlv_rpe_freq_mhz_show(struct device *kdev,
 	return snprintf(buf, PAGE_SIZE,
 			"%d\n",
@@ -334,7 +334,7 @@ static ssize_t gt_max_freq_mhz_show(struct device *kdev, struct device_attribute
 	int ret;
@@ -352,7 +352,7 @@ static ssize_t gt_max_freq_mhz_store(struct device *kdev,
 	u32 val;
 	ssize_t ret;
@@ -402,7 +402,7 @@ static ssize_t gt_min_freq_mhz_show(struct device *kdev, struct device_attribute
 	int ret;
@@ -420,7 +420,7 @@ static ssize_t gt_min_freq_mhz_store(struct device *kdev,
 	u32 val;
 	ssize_t ret;
@@ -480,7 +480,7 @@ static ssize_t gt_rp_mhz_show(struct device *kdev, struct device_attribute *attr
 	u32 val;
 	if (attr == &dev_attr_gt_RP0_freq_mhz)
diff --git a/drivers/gpu/drm/i915/intel_audio.c b/drivers/gpu/drm/i915/intel_audio.c
index b9329c2..e2e4d4c 100644
--- a/drivers/gpu/drm/i915/intel_audio.c
+++ b/drivers/gpu/drm/i915/intel_audio.c
@@ -165,7 +165,7 @@ static bool intel_eld_uptodate(struct drm_connector *connector,
 			       i915_reg_t reg_elda, uint32_t bits_elda,
 			       i915_reg_t reg_edid)
-	struct drm_i915_private *dev_priv = connector->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(connector->dev);
 	uint8_t *eld = connector->eld;
 	uint32_t tmp;
 	int i;
@@ -189,7 +189,7 @@ static bool intel_eld_uptodate(struct drm_connector *connector,
 static void g4x_audio_codec_disable(struct intel_encoder *encoder)
-	struct drm_i915_private *dev_priv = encoder->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(encoder->base.dev);
 	uint32_t eldv, tmp;
 	DRM_DEBUG_KMS("Disable audio codec\n");
@@ -210,7 +210,7 @@ static void g4x_audio_codec_enable(struct drm_connector *connector,
 				   struct intel_encoder *encoder,
 				   const struct drm_display_mode *adjusted_mode)
 	uint32_t eldv;
 	uint32_t tmp;
@@ -247,7 +247,7 @@ static void g4x_audio_codec_enable(struct drm_connector *connector,
 static void hsw_audio_codec_disable(struct intel_encoder *encoder)
 	struct intel_crtc *intel_crtc = to_intel_crtc(encoder->base.crtc);
 	enum pipe pipe = intel_crtc->pipe;
 	uint32_t tmp;
@@ -279,7 +279,7 @@ static void hsw_audio_codec_enable(struct drm_connector *connector,
 	struct i915_audio_component *acomp = dev_priv->audio_component;
@@ -357,7 +357,7 @@ static void hsw_audio_codec_enable(struct drm_connector *connector,
 static void ilk_audio_codec_disable(struct intel_encoder *encoder)
 	struct intel_digital_port *intel_dig_port =
 		enc_to_dig_port(&encoder->base);
@@ -405,7 +405,7 @@ static void ilk_audio_codec_enable(struct drm_connector *connector,
@@ -496,7 +496,7 @@ void intel_audio_codec_enable(struct intel_encoder *intel_encoder)
 	const struct drm_display_mode *adjusted_mode = &crtc->config->base.adjusted_mode;
 	struct drm_device *dev = encoder->dev;
 	struct intel_digital_port *intel_dig_port = enc_to_dig_port(encoder);
 	enum port port = intel_dig_port->port;
@@ -543,7 +543,7 @@ void intel_audio_codec_disable(struct intel_encoder *intel_encoder)
 	struct drm_encoder *encoder = &intel_encoder->base;
diff --git a/drivers/gpu/drm/i915/intel_color.c b/drivers/gpu/drm/i915/intel_color.c
index 522f5a2..2523a5b 100644
--- a/drivers/gpu/drm/i915/intel_color.c
+++ b/drivers/gpu/drm/i915/intel_color.c
@@ -96,7 +96,7 @@ static void i9xx_load_csc_matrix(struct drm_crtc_state *crtc_state)
 	struct drm_crtc *crtc = crtc_state->crtc;
 	struct drm_device *dev = crtc->dev;
 	int i, pipe = intel_crtc->pipe;
 	uint16_t coeffs[9] = { 0, };
@@ -207,7 +207,7 @@ static void cherryview_load_csc_matrix(struct drm_crtc_state *state)
 	struct drm_crtc *crtc = state->crtc;
 	int pipe = to_intel_crtc(crtc)->pipe;
 	uint32_t mode;
@@ -255,7 +255,7 @@ static void cherryview_load_csc_matrix(struct drm_crtc_state *state)
 void intel_color_set_csc(struct drm_crtc_state *crtc_state)
 	struct drm_device *dev = crtc_state->crtc->dev;
 	if (dev_priv->display.load_csc_matrix)
 		dev_priv->display.load_csc_matrix(crtc_state);
@@ -266,7 +266,7 @@ static void i9xx_load_luts_internal(struct drm_crtc *crtc,
 				    struct drm_property_blob *blob)
 	int i;
@@ -313,7 +313,7 @@ static void haswell_load_luts(struct drm_crtc_state *crtc_state)
 	struct intel_crtc_state *intel_crtc_state =
 		to_intel_crtc_state(crtc_state);
@@ -343,7 +343,7 @@ static void broadwell_load_luts(struct drm_crtc_state *state)
 	struct intel_crtc_state *intel_state = to_intel_crtc_state(state);
 	enum pipe pipe = to_intel_crtc(crtc)->pipe;
 	uint32_t i, lut_size = INTEL_INFO(dev)->color.degamma_lut_size;
@@ -426,7 +426,7 @@ static void cherryview_load_luts(struct drm_crtc_state *state)
 	struct drm_color_lut *lut;
 	uint32_t i, lut_size;
@@ -485,7 +485,7 @@ static void cherryview_load_luts(struct drm_crtc_state *state)
 void intel_color_load_luts(struct drm_crtc_state *crtc_state)
 	dev_priv->display.load_luts(crtc_state);
@@ -526,7 +526,7 @@ int intel_color_check(struct drm_crtc *crtc,
 void intel_color_init(struct drm_crtc *crtc)
 	drm_mode_crtc_set_gamma_size(crtc, 256);
diff --git a/drivers/gpu/drm/i915/intel_crt.c b/drivers/gpu/drm/i915/intel_crt.c
index 0c8036e..5819d52 100644
--- a/drivers/gpu/drm/i915/intel_crt.c
+++ b/drivers/gpu/drm/i915/intel_crt.c
@@ -67,7 +67,7 @@ static bool intel_crt_get_hw_state(struct intel_encoder *encoder,
 				   enum pipe *pipe)
 	struct drm_device *dev = encoder->base.dev;
 	struct intel_crt *crt = intel_encoder_to_crt(encoder);
 	enum intel_display_power_domain power_domain;
 	u32 tmp;
@@ -98,7 +98,7 @@ out:
 static unsigned int intel_crt_get_flags(struct intel_encoder *encoder)
 	u32 tmp, flags = 0;
@@ -146,7 +146,7 @@ static void hsw_crt_get_config(struct intel_encoder *encoder,
 static void intel_crt_set_dpms(struct intel_encoder *encoder, int mode)
 	struct intel_crtc *crtc = to_intel_crtc(encoder->base.crtc);
@@ -281,7 +281,7 @@ static bool intel_ironlake_crt_detect_hotplug(struct drm_connector *connector)
 	struct drm_device *dev = connector->dev;
 	struct intel_crt *crt = intel_attached_crt(connector);
 	u32 adpa;
 	bool ret;
@@ -328,7 +328,7 @@ static bool valleyview_crt_detect_hotplug(struct drm_connector *connector)
 	u32 adpa;
 	bool ret;
 	u32 save_adpa;
@@ -371,7 +371,7 @@ static bool valleyview_crt_detect_hotplug(struct drm_connector *connector)
 static bool intel_crt_detect_hotplug(struct drm_connector *connector)
 	u32 stat;
 	bool ret = false;
 	int i, tries = 0;
@@ -453,7 +453,7 @@ static int intel_crt_ddc_get_modes(struct drm_connector *connector,
 static bool intel_crt_detect_ddc(struct drm_connector *connector)
-	struct drm_i915_private *dev_priv = crt->base.base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(crt->base.base.dev);
 	struct edid *edid;
 	struct i2c_adapter *i2c;
@@ -489,7 +489,7 @@ static enum drm_connector_status
 intel_crt_load_detect(struct intel_crt *crt, uint32_t pipe)
 	struct drm_device *dev = crt->base.base.dev;
 	uint32_t save_bclrpat;
 	uint32_t save_vtotal;
 	uint32_t vtotal, vactive;
@@ -604,7 +604,7 @@ static enum drm_connector_status
 intel_crt_detect(struct drm_connector *connector, bool force)
 	struct intel_encoder *intel_encoder = &crt->base;
@@ -685,7 +685,7 @@ static void intel_crt_destroy(struct drm_connector *connector)
 static int intel_crt_get_modes(struct drm_connector *connector)
@@ -720,7 +720,7 @@ static int intel_crt_set_property(struct drm_connector *connector,
 static void intel_crt_reset(struct drm_connector *connector)
 	if (INTEL_INFO(dev)->gen >= 5) {
@@ -796,7 +796,7 @@ void intel_crt_init(struct drm_device *dev)
 	struct intel_crt *crt;
 	struct intel_connector *intel_connector;
 	i915_reg_t adpa_reg;
 	u32 adpa;
diff --git a/drivers/gpu/drm/i915/intel_ddi.c b/drivers/gpu/drm/i915/intel_ddi.c
index 6bcd7ff..d6efe8b 100644
--- a/drivers/gpu/drm/i915/intel_ddi.c
+++ b/drivers/gpu/drm/i915/intel_ddi.c
@@ -543,7 +543,7 @@ static void intel_wait_ddi_buf_idle(struct drm_i915_private *dev_priv,
 void hsw_fdi_link_train(struct drm_crtc *crtc)
 	struct intel_encoder *encoder;
 	u32 temp, i, rx_ctl_val;
@@ -851,7 +851,7 @@ static void ddi_dotclock_get(struct intel_crtc_state *pipe_config)
 static void skl_ddi_clock_get(struct intel_encoder *encoder,
 	int link_clock = 0;
 	uint32_t dpll_ctl1, dpll;
@@ -899,7 +899,7 @@ static void skl_ddi_clock_get(struct intel_encoder *encoder,
 static void hsw_ddi_clock_get(struct intel_encoder *encoder,
 	int link_clock = 0;
 	u32 val, pll;
@@ -971,7 +971,7 @@ static int bxt_calc_pll_link(struct drm_i915_private *dev_priv,
 static void bxt_ddi_clock_get(struct intel_encoder *encoder,
 	enum port port = intel_ddi_get_encoder_port(encoder);
 	uint32_t dpll = port;
@@ -1061,7 +1061,7 @@ bool intel_ddi_pll_select(struct intel_crtc *intel_crtc,
 void intel_ddi_set_pipe_settings(struct drm_crtc *crtc)
-	struct drm_i915_private *dev_priv = crtc->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(crtc->dev);
 	struct intel_encoder *intel_encoder = intel_ddi_get_crtc_encoder(crtc);
 	enum transcoder cpu_transcoder = intel_crtc->config->cpu_transcoder;
@@ -1096,7 +1096,7 @@ void intel_ddi_set_vc_payload_alloc(struct drm_crtc *crtc, bool state)
 	uint32_t temp;
 	temp = I915_READ(TRANS_DDI_FUNC_CTL(cpu_transcoder));
@@ -1113,7 +1113,7 @@ void intel_ddi_enable_transcoder_func(struct drm_crtc *crtc)
 	enum port port = intel_ddi_get_encoder_port(intel_encoder);
@@ -1223,7 +1223,7 @@ void intel_ddi_disable_transcoder_func(struct drm_i915_private *dev_priv,
 bool intel_ddi_connector_get_hw_state(struct intel_connector *intel_connector)
 	struct drm_device *dev = intel_connector->base.dev;
 	struct intel_encoder *intel_encoder = intel_connector->encoder;
 	int type = intel_connector->base.connector_type;
@@ -1285,7 +1285,7 @@ bool intel_ddi_get_hw_state(struct intel_encoder *encoder,
 			    enum pipe *pipe)
 	u32 tmp;
@@ -1359,7 +1359,7 @@ void intel_ddi_enable_pipe_clock(struct intel_crtc *intel_crtc)
 	struct drm_crtc *crtc = &intel_crtc->base;
@@ -1371,7 +1371,7 @@ void intel_ddi_enable_pipe_clock(struct intel_crtc *intel_crtc)
 void intel_ddi_disable_pipe_clock(struct intel_crtc *intel_crtc)
-	struct drm_i915_private *dev_priv = intel_crtc->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(intel_crtc->base.dev);
 	if (cpu_transcoder != TRANSCODER_EDP)
@@ -1648,7 +1648,7 @@ static void intel_ddi_post_disable(struct intel_encoder *intel_encoder)
 	int type = intel_encoder->type;
 	uint32_t val;
@@ -1695,7 +1695,7 @@ static void intel_enable_ddi(struct intel_encoder *intel_encoder)
 	struct drm_crtc *crtc = encoder->crtc;
@@ -1734,7 +1734,7 @@ static void intel_disable_ddi(struct intel_encoder *intel_encoder)
 	if (intel_crtc->config->has_audio) {
 		intel_audio_codec_disable(intel_encoder);
@@ -2124,7 +2124,7 @@ void intel_ddi_prepare_link_retrain(struct intel_dp *intel_dp)
 void intel_ddi_fdi_disable(struct drm_crtc *crtc)
 	uint32_t val;
@@ -2157,7 +2157,7 @@ void intel_ddi_fdi_disable(struct drm_crtc *crtc)
 void intel_ddi_get_config(struct intel_encoder *encoder,
 	enum transcoder cpu_transcoder = pipe_config->cpu_transcoder;
 	struct intel_hdmi *intel_hdmi;
@@ -2256,7 +2256,7 @@ void intel_ddi_get_config(struct intel_encoder *encoder,
 static bool intel_ddi_compute_config(struct intel_encoder *encoder,
 	int type = encoder->type;
 	int port = intel_ddi_get_encoder_port(encoder);
 	int ret;
@@ -2322,7 +2322,7 @@ intel_ddi_init_hdmi_connector(struct intel_digital_port *intel_dig_port)
 void intel_ddi_init(struct drm_device *dev, enum port port)
 	struct intel_digital_port *intel_dig_port;
 	struct intel_encoder *intel_encoder;
 	struct drm_encoder *encoder;
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index acb89e7..c3c620b 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -1080,7 +1080,7 @@ enum transcoder intel_pipe_to_cpu_transcoder(struct drm_i915_private *dev_priv,
 static bool pipe_dsl_stopped(struct drm_device *dev, enum pipe pipe)
 	i915_reg_t reg = PIPEDSL(pipe);
 	u32 line1, line2;
 	u32 line_mask;
@@ -1116,7 +1116,7 @@ static bool pipe_dsl_stopped(struct drm_device *dev, enum pipe pipe)
 static void intel_wait_for_pipe_off(struct intel_crtc *crtc)
 	enum transcoder cpu_transcoder = crtc->config->cpu_transcoder;
@@ -1656,7 +1656,7 @@ static int intel_num_dvo_pipes(struct drm_device *dev)
 static void i9xx_enable_pll(struct intel_crtc *crtc)
 	i915_reg_t reg = DPLL(crtc->pipe);
 	u32 dpll = crtc->config->dpll_hw_state.dpll;
@@ -1728,7 +1728,7 @@ static void i9xx_enable_pll(struct intel_crtc *crtc)
 static void i9xx_disable_pll(struct intel_crtc *crtc)
 	/* Disable DVO 2x clock on both PLLs if necessary */
@@ -1980,7 +1980,7 @@ static void lpt_disable_pch_transcoder(struct drm_i915_private *dev_priv)
 static void intel_enable_pipe(struct intel_crtc *crtc)
 	enum pipe pch_transcoder;
@@ -2053,7 +2053,7 @@ static void intel_enable_pipe(struct intel_crtc *crtc)
 static void intel_disable_pipe(struct intel_crtc *crtc)
 	i915_reg_t reg;
@@ -2264,7 +2264,7 @@ intel_pin_and_fence_fb_obj(struct drm_framebuffer *fb,
 			   unsigned int rotation)
 	struct drm_device *dev = fb->dev;
 	struct drm_i915_gem_object *obj = intel_fb_obj(fb);
 	struct i915_ggtt_view view;
 	u32 alignment;
@@ -2566,7 +2566,7 @@ intel_find_initial_plane_obj(struct intel_crtc *intel_crtc,
 			     struct intel_initial_plane_config *plane_config)
 	struct drm_device *dev = intel_crtc->base.dev;
 	struct drm_crtc *c;
 	struct intel_crtc *i;
@@ -2662,7 +2662,7 @@ static void i9xx_update_primary_plane(struct drm_plane *primary,
 				      const struct intel_plane_state *plane_state)
 	struct drm_device *dev = primary->dev;
 	struct intel_crtc *intel_crtc = to_intel_crtc(crtc_state->base.crtc);
 	struct drm_framebuffer *fb = plane_state->base.fb;
@@ -2775,7 +2775,7 @@ static void i9xx_disable_primary_plane(struct drm_plane *primary,
 	int plane = intel_crtc->plane;
@@ -2792,7 +2792,7 @@ static void ironlake_update_primary_plane(struct drm_plane *primary,
@@ -2920,7 +2920,7 @@ u32 intel_plane_obj_offset(struct intel_plane *intel_plane,
 static void skl_detach_scaler(struct intel_crtc *intel_crtc, int id)
 	I915_WRITE(SKL_PS_CTRL(intel_crtc->pipe, id), 0);
 	I915_WRITE(SKL_PS_WIN_POS(intel_crtc->pipe, id), 0);
@@ -3030,7 +3030,7 @@ static void skylake_update_primary_plane(struct drm_plane *plane,
 	struct drm_device *dev = plane->dev;
@@ -3114,7 +3114,7 @@ static void skylake_disable_primary_plane(struct drm_plane *primary,
 	I915_WRITE(PLANE_CTL(pipe, 0), 0);
@@ -3250,7 +3250,7 @@ static void intel_update_pipe_config(struct intel_crtc *crtc,
 				     struct intel_crtc_state *old_crtc_state)
 	struct intel_crtc_state *pipe_config =
 		to_intel_crtc_state(crtc->base.state);
@@ -3291,7 +3291,7 @@ static void intel_update_pipe_config(struct intel_crtc *crtc,
 static void intel_fdi_normal_train(struct drm_crtc *crtc)
 	int pipe = intel_crtc->pipe;
 	i915_reg_t reg;
@@ -3334,7 +3334,7 @@ static void intel_fdi_normal_train(struct drm_crtc *crtc)
 static void ironlake_fdi_link_train(struct drm_crtc *crtc)
 	i915_reg_t reg;
@@ -3435,7 +3435,7 @@ static const int snb_b_fdi_train_param[] = {
 static void gen6_fdi_link_train(struct drm_crtc *crtc)
 	i915_reg_t reg;
@@ -3568,7 +3568,7 @@ static void gen6_fdi_link_train(struct drm_crtc *crtc)
 static void ivb_manual_fdi_link_train(struct drm_crtc *crtc)
 	i915_reg_t reg;
@@ -3687,7 +3687,7 @@ train_done:
 static void ironlake_fdi_pll_enable(struct intel_crtc *intel_crtc)
 	i915_reg_t reg;
 	u32 temp;
@@ -3724,7 +3724,7 @@ static void ironlake_fdi_pll_enable(struct intel_crtc *intel_crtc)
 static void ironlake_fdi_pll_disable(struct intel_crtc *intel_crtc)
 	i915_reg_t reg;
 	u32 temp;
@@ -3754,7 +3754,7 @@ static void ironlake_fdi_pll_disable(struct intel_crtc *intel_crtc)
 static void ironlake_fdi_disable(struct drm_crtc *crtc)
 	i915_reg_t reg;
@@ -3850,7 +3850,7 @@ static void page_flip_completed(struct intel_crtc *intel_crtc)
 static int intel_crtc_wait_for_pending_flips(struct drm_crtc *crtc)
 	long ret;
 	WARN_ON(waitqueue_active(&dev_priv->pending_flip_queue));
@@ -4013,7 +4013,7 @@ static void ironlake_pch_transcoder_set_timings(struct intel_crtc *crtc,
 						enum pipe pch_transcoder)
 	I915_WRITE(PCH_TRANS_HTOTAL(pch_transcoder),
@@ -4035,7 +4035,7 @@ static void ironlake_pch_transcoder_set_timings(struct intel_crtc *crtc,
 static void cpt_set_fdi_bc_bifurcation(struct drm_device *dev, bool enable)
 	uint32_t temp;
 	temp = I915_READ(SOUTH_CHICKEN1);
@@ -4104,7 +4104,7 @@ intel_trans_dp_port_sel(struct drm_crtc *crtc)
 static void ironlake_pch_enable(struct drm_crtc *crtc)
 	u32 temp;
@@ -4194,7 +4194,7 @@ static void ironlake_pch_enable(struct drm_crtc *crtc)
 static void lpt_pch_enable(struct drm_crtc *crtc)
@@ -4210,7 +4210,7 @@ static void lpt_pch_enable(struct drm_crtc *crtc)
 static void cpt_verify_modeset(struct drm_device *dev, int pipe)
 	i915_reg_t dslreg = PIPEDSL(pipe);
 	u32 temp;
@@ -4388,7 +4388,7 @@ static void skylake_scaler_disable(struct intel_crtc *crtc)
 static void skylake_pfit_enable(struct intel_crtc *crtc)
 	int pipe = crtc->pipe;
 	struct intel_crtc_scaler_state *scaler_state =
 		&crtc->config->scaler_state;
@@ -4416,7 +4416,7 @@ static void skylake_pfit_enable(struct intel_crtc *crtc)
 static void ironlake_pfit_enable(struct intel_crtc *crtc)
 	if (crtc->config->pch_pfit.enabled) {
@@ -4437,7 +4437,7 @@ static void ironlake_pfit_enable(struct intel_crtc *crtc)
 void hsw_enable_ips(struct intel_crtc *crtc)
 	if (!crtc->config->ips_enabled)
 		return;
@@ -4475,7 +4475,7 @@ void hsw_enable_ips(struct intel_crtc *crtc)
 void hsw_disable_ips(struct intel_crtc *crtc)
 		return;
@@ -4503,7 +4503,7 @@ static void intel_crtc_dpms_overlay_disable(struct intel_crtc *intel_crtc)
 	if (intel_crtc->overlay) {
 		dev_priv->mm.interruptible = false;
@@ -4531,7 +4531,7 @@ static void
 intel_post_enable_primary(struct drm_crtc *crtc)
@@ -4563,7 +4563,7 @@ static void
 intel_pre_disable_primary(struct drm_crtc *crtc)
@@ -4590,7 +4590,7 @@ static void
 intel_pre_disable_primary_noatomic(struct drm_crtc *crtc)
@@ -4649,7 +4649,7 @@ static void intel_pre_plane_update(struct intel_crtc_state *old_crtc_state)
 	struct intel_crtc *crtc = to_intel_crtc(old_crtc_state->base.crtc);
-	struct drm_i915_private *dev_priv = dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(dev);
 	struct drm_atomic_state *old_state = old_crtc_state->base.state;
@@ -4752,7 +4752,7 @@ static void intel_crtc_disable_planes(struct drm_crtc *crtc, unsigned plane_mask
 static void ironlake_crtc_enable(struct drm_crtc *crtc)
@@ -4849,7 +4849,7 @@ static bool hsw_crtc_supports_ips(struct intel_crtc *crtc)
 static void haswell_crtc_enable(struct drm_crtc *crtc)
 	int pipe = intel_crtc->pipe, hsw_workaround_pipe;
@@ -4973,7 +4973,7 @@ static void haswell_crtc_enable(struct drm_crtc *crtc)
 static void ironlake_pfit_disable(struct intel_crtc *crtc, bool force)
 	/* To avoid upsetting the power well on haswell only disable the pfit if
@@ -4988,7 +4988,7 @@ static void ironlake_pfit_disable(struct intel_crtc *crtc, bool force)
 static void ironlake_crtc_disable(struct drm_crtc *crtc)
@@ -5051,7 +5051,7 @@ static void ironlake_crtc_disable(struct drm_crtc *crtc)
 static void haswell_crtc_disable(struct drm_crtc *crtc)
@@ -5103,7 +5103,7 @@ static void haswell_crtc_disable(struct drm_crtc *crtc)
 static void i9xx_pfit_enable(struct intel_crtc *crtc)
 	struct intel_crtc_state *pipe_config = crtc->config;
 	if (!pipe_config->gmch_pfit.control)
@@ -5255,7 +5255,7 @@ static unsigned long
 modeset_get_crtc_power_domains(struct drm_crtc *crtc,
 			       struct intel_crtc_state *crtc_state)
 	enum intel_display_power_domain domain;
 	unsigned long domains, new_domains, old_domains;
@@ -5300,7 +5300,7 @@ static int skl_calc_cdclk(int max_pixclk, int vco);
 static void intel_update_max_cdclk(struct drm_device *dev)
 	if (IS_SKYLAKE(dev) || IS_KABYLAKE(dev)) {
 		u32 limit = I915_READ(SKL_DFSM) & SKL_DFSM_CDCLK_LIMIT_MASK;
@@ -5361,7 +5361,7 @@ static void intel_update_max_cdclk(struct drm_device *dev)
 static void intel_update_cdclk(struct drm_device *dev)
 	dev_priv->cdclk_freq = dev_priv->display.get_display_clock_speed(dev);
@@ -5887,7 +5887,7 @@ sanitize:
 /* Adjust CDclk dividers to allow high res or save power if possible */
 static void valleyview_set_cdclk(struct drm_device *dev, int cdclk)
 	u32 val, cmd;
 	WARN_ON(dev_priv->display.get_display_clock_speed(dev)
@@ -5952,7 +5952,7 @@ static void valleyview_set_cdclk(struct drm_device *dev, int cdclk)
 static void cherryview_set_cdclk(struct drm_device *dev, int cdclk)
 	u32 val, cmd;
@@ -6040,7 +6040,7 @@ static int intel_mode_max_pixclk(struct drm_device *dev,
 				 struct drm_atomic_state *state)
 	struct intel_atomic_state *intel_state = to_intel_atomic_state(state);
 	struct drm_crtc *crtc;
 	struct drm_crtc_state *crtc_state;
 	unsigned max_pixclk = 0, i;
@@ -6067,7 +6067,7 @@ static int intel_mode_max_pixclk(struct drm_device *dev,
 static int valleyview_modeset_calc_cdclk(struct drm_atomic_state *state)
 	struct drm_device *dev = state->dev;
 	int max_pixclk = intel_mode_max_pixclk(dev, state);
@@ -6135,7 +6135,7 @@ static void vlv_program_pfi_credits(struct drm_i915_private *dev_priv)
 static void valleyview_modeset_commit_cdclk(struct drm_atomic_state *old_state)
 	struct drm_device *dev = old_state->dev;
 	struct intel_atomic_state *old_intel_state =
 		to_intel_atomic_state(old_state);
 	unsigned req_cdclk = old_intel_state->dev_cdclk;
@@ -6181,7 +6181,7 @@ static void valleyview_crtc_enable(struct drm_crtc *crtc)
 	intel_set_pipe_src_size(intel_crtc);
 	if (IS_CHERRYVIEW(dev) && pipe == PIPE_B) {
 		I915_WRITE(CHV_BLEND(pipe), CHV_BLEND_LEGACY);
 		I915_WRITE(CHV_CANVAS(pipe), 0);
@@ -6226,7 +6226,7 @@ static void valleyview_crtc_enable(struct drm_crtc *crtc)
 static void i9xx_set_pll_dividers(struct intel_crtc *crtc)
 	I915_WRITE(FP0(crtc->pipe), crtc->config->dpll_hw_state.fp0);
 	I915_WRITE(FP1(crtc->pipe), crtc->config->dpll_hw_state.fp1);
@@ -6283,7 +6283,7 @@ static void i9xx_crtc_enable(struct drm_crtc *crtc)
 static void i9xx_pfit_disable(struct intel_crtc *crtc)
 	if (!crtc->config->gmch_pfit.control)
 		return;
@@ -6298,7 +6298,7 @@ static void i9xx_pfit_disable(struct intel_crtc *crtc)
 static void i9xx_crtc_disable(struct drm_crtc *crtc)
@@ -6642,7 +6642,7 @@ static void hsw_compute_ips_config(struct intel_crtc *crtc,
 	pipe_config->ips_enabled = i915.enable_ips &&
 		hsw_crtc_supports_ips(crtc) &&
@@ -6662,7 +6662,7 @@ static int intel_crtc_compute_config(struct intel_crtc *crtc,
 	const struct drm_display_mode *adjusted_mode = &pipe_config->base.adjusted_mode;
 	int clock_limit = dev_priv->max_dotclk_freq;
@@ -6812,7 +6812,7 @@ static int broxton_get_display_clock_speed(struct drm_device *dev)
 static int broadwell_get_display_clock_speed(struct drm_device *dev)
 	uint32_t lcpll = I915_READ(LCPLL_CTL);
 	uint32_t freq = lcpll & LCPLL_CLK_FREQ_MASK;
@@ -6832,7 +6832,7 @@ static int broadwell_get_display_clock_speed(struct drm_device *dev)
 static int haswell_get_display_clock_speed(struct drm_device *dev)
@@ -6966,7 +6966,7 @@ static int i830_get_display_clock_speed(struct drm_device *dev)
 static unsigned int intel_hpll_vco(struct drm_device *dev)
 	static const unsigned int blb_vco[8] = {
 		[0] = 3200000,
 		[1] = 4000000,
@@ -7246,7 +7246,7 @@ static void intel_pch_transcoder_set_m_n(struct intel_crtc *crtc,
 					 struct intel_link_m_n *m_n)
 	I915_WRITE(PCH_TRANS_DATA_M1(pipe), TU_SIZE(m_n->tu) | m_n->gmch_m);
@@ -7260,7 +7260,7 @@ static void intel_cpu_transcoder_set_m_n(struct intel_crtc *crtc,
 					 struct intel_link_m_n *m2_n2)
 	enum transcoder transcoder = crtc->config->cpu_transcoder;
@@ -7351,7 +7351,7 @@ static void vlv_prepare_pll(struct intel_crtc *crtc,
 			    const struct intel_crtc_state *pipe_config)
 	u32 mdiv;
 	u32 bestn, bestm1, bestm2, bestp1, bestp2;
@@ -7451,7 +7451,7 @@ static void chv_prepare_pll(struct intel_crtc *crtc,
 	enum dpio_channel port = vlv_pipe_to_channel(pipe);
 	u32 loopfilter, tribuf_calcntr;
@@ -7613,7 +7613,7 @@ static void i9xx_compute_dpll(struct intel_crtc *crtc,
 			      struct dpll *reduced_clock)
 	u32 dpll;
 	bool is_sdvo;
 	struct dpll *clock = &crtc_state->dpll;
@@ -7689,7 +7689,7 @@ static void i8xx_compute_dpll(struct intel_crtc *crtc,
 	u32 dpll;
@@ -7724,7 +7724,7 @@ static void i8xx_compute_dpll(struct intel_crtc *crtc,
 static void intel_set_pipe_timings(struct intel_crtc *intel_crtc)
 	const struct drm_display_mode *adjusted_mode = &intel_crtc->config->base.adjusted_mode;
@@ -7786,7 +7786,7 @@ static void intel_set_pipe_timings(struct intel_crtc *intel_crtc)
 static void intel_set_pipe_src_size(struct intel_crtc *intel_crtc)
 	/* pipesrc controls the size that is scaled from, which should
@@ -7801,7 +7801,7 @@ static void intel_get_pipe_timings(struct intel_crtc *crtc,
 	uint32_t tmp;
@@ -7836,7 +7836,7 @@ static void intel_get_pipe_src_size(struct intel_crtc *crtc,
 	u32 tmp;
 	tmp = I915_READ(PIPESRC(crtc->pipe));
@@ -7874,7 +7874,7 @@ void intel_mode_from_pipe_config(struct drm_display_mode *mode,
 static void i9xx_set_pipeconf(struct intel_crtc *intel_crtc)
 	uint32_t pipeconf;
 	pipeconf = 0;
@@ -7939,7 +7939,7 @@ static int i8xx_crtc_compute_clock(struct intel_crtc *crtc,
 	const struct intel_limit *limit;
 	int refclk = 48000;
@@ -7975,7 +7975,7 @@ static int g4x_crtc_compute_clock(struct intel_crtc *crtc,
 	int refclk = 96000;
@@ -8018,7 +8018,7 @@ static int pnv_crtc_compute_clock(struct intel_crtc *crtc,
 	int refclk = 96000;
@@ -8052,7 +8052,7 @@ static int i9xx_crtc_compute_clock(struct intel_crtc *crtc,
 	int refclk = 96000;
@@ -8128,7 +8128,7 @@ static void i9xx_get_pfit_config(struct intel_crtc *crtc,
 	uint32_t tmp;
 	if (INTEL_INFO(dev)->gen <= 3 && (IS_I830(dev) || !IS_MOBILE(dev)))
@@ -8155,7 +8155,7 @@ static void vlv_crtc_clock_get(struct intel_crtc *crtc,
 	int pipe = pipe_config->cpu_transcoder;
 	struct dpll clock;
 	u32 mdiv;
@@ -8183,7 +8183,7 @@ i9xx_get_initial_plane_config(struct intel_crtc *crtc,
 	u32 val, base, offset;
 	int pipe = crtc->pipe, plane = crtc->plane;
 	int fourcc, pixel_format;
@@ -8251,7 +8251,7 @@ static void chv_crtc_clock_get(struct intel_crtc *crtc,
 	struct dpll clock;
@@ -8285,7 +8285,7 @@ static bool i9xx_get_pipe_config(struct intel_crtc *crtc,
 	uint32_t tmp;
 	bool ret;
@@ -8396,7 +8396,7 @@ out:
 static void ironlake_init_pch_refclk(struct drm_device *dev)
 	int i;
 	u32 val, final;
@@ -8667,7 +8667,7 @@ static void lpt_program_fdi_mphy(struct drm_i915_private *dev_priv)
 static void lpt_enable_clkout_dp(struct drm_device *dev, bool with_spread,
 				 bool with_fdi)
 	uint32_t reg, tmp;
 	if (WARN(with_fdi && !with_spread, "FDI requires downspread\n"))
@@ -8706,7 +8706,7 @@ static void lpt_enable_clkout_dp(struct drm_device *dev, bool with_spread,
 /* Sequence to disable CLKOUT_DP */
 static void lpt_disable_clkout_dp(struct drm_device *dev)
 	uint32_t reg, tmp;
 	mutex_lock(&dev_priv->sb_lock);
@@ -8827,7 +8827,7 @@ void intel_init_pch_refclk(struct drm_device *dev)
 static void ironlake_set_pipeconf(struct drm_crtc *crtc)
 	uint32_t val;
@@ -8869,7 +8869,7 @@ static void ironlake_set_pipeconf(struct drm_crtc *crtc)
 static void haswell_set_pipeconf(struct drm_crtc *crtc)
 	u32 val = 0;
@@ -8888,7 +8888,7 @@ static void haswell_set_pipeconf(struct drm_crtc *crtc)
 static void haswell_set_pipemisc(struct drm_crtc *crtc)
 	if (IS_BROADWELL(dev_priv) || INTEL_INFO(dev_priv)->gen >= 9) {
@@ -8941,7 +8941,7 @@ static void ironlake_compute_dpll(struct intel_crtc *intel_crtc,
 	struct drm_atomic_state *state = crtc_state->base.state;
 	struct drm_connector *connector;
 	struct drm_connector_state *connector_state;
@@ -9044,7 +9044,7 @@ static int ironlake_crtc_compute_clock(struct intel_crtc *crtc,
 	struct dpll reduced_clock;
 	bool has_reduced_clock = false;
 	struct intel_shared_dpll *pll;
@@ -9110,7 +9110,7 @@ static void intel_pch_transcoder_get_m_n(struct intel_crtc *crtc,
 	m_n->link_m = I915_READ(PCH_TRANS_LINK_M1(pipe));
@@ -9128,7 +9128,7 @@ static void intel_cpu_transcoder_get_m_n(struct intel_crtc *crtc,
@@ -9186,7 +9186,7 @@ static void skylake_get_pfit_config(struct intel_crtc *crtc,
 	struct intel_crtc_scaler_state *scaler_state = &pipe_config->scaler_state;
 	uint32_t ps_ctrl = 0;
 	int id = -1;
@@ -9217,7 +9217,7 @@ skylake_get_initial_plane_config(struct intel_crtc *crtc,
 	u32 val, base, offset, stride_mult, tiling;
@@ -9300,7 +9300,7 @@ static void ironlake_get_pfit_config(struct intel_crtc *crtc,
 	uint32_t tmp;
 	tmp = I915_READ(PF_CTL(crtc->pipe));
@@ -9325,7 +9325,7 @@ ironlake_get_initial_plane_config(struct intel_crtc *crtc,
@@ -9393,7 +9393,7 @@ static bool ironlake_get_pipe_config(struct intel_crtc *crtc,
 	uint32_t tmp;
 	bool ret;
@@ -9723,7 +9723,7 @@ static void bxt_modeset_commit_cdclk(struct drm_atomic_state *old_state)
 static int ilk_max_pixel_rate(struct drm_atomic_state *state)
-	struct drm_i915_private *dev_priv = state->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(state->dev);
 	struct drm_crtc_state *cstate;
 	struct intel_crtc_state *crtc_state;
@@ -9759,7 +9759,7 @@ static int ilk_max_pixel_rate(struct drm_atomic_state *state)
 static void broadwell_set_cdclk(struct drm_device *dev, int cdclk)
 	uint32_t val, data;
 	int ret;
@@ -10041,7 +10041,7 @@ static bool hsw_get_transcoder_state(struct intel_crtc *crtc,
 				     unsigned long *power_domain_mask)
 	u32 tmp;
@@ -10092,7 +10092,7 @@ static bool bxt_get_dsi_transcoder_state(struct intel_crtc *crtc,
 	enum port port;
 	enum transcoder cpu_transcoder;
@@ -10142,7 +10142,7 @@ static void haswell_get_ddi_port_state(struct intel_crtc *crtc,
 	enum port port;
 	uint32_t tmp;
@@ -10185,7 +10185,7 @@ static bool haswell_get_pipe_config(struct intel_crtc *crtc,
 	unsigned long power_domain_mask;
 	bool active;
@@ -10261,7 +10261,7 @@ static void i845_update_cursor(struct drm_crtc *crtc, u32 base,
 	uint32_t cntl = 0, size = 0;
@@ -10324,7 +10324,7 @@ static void i9xx_update_cursor(struct drm_crtc *crtc, u32 base,
 	uint32_t cntl = 0;
@@ -10372,7 +10372,7 @@ static void intel_crtc_update_cursor(struct drm_crtc *crtc,
 	u32 base = intel_crtc->cursor_addr;
@@ -10539,7 +10539,7 @@ mode_fits_in_fbdev(struct drm_device *dev,
 #ifdef CONFIG_DRM_FBDEV_EMULATION
 	struct drm_i915_gem_object *obj;
 	struct drm_framebuffer *fb;
@@ -10809,7 +10809,7 @@ void intel_release_load_detect_pipe(struct drm_connector *connector,
 static int i9xx_pll_refclk(struct drm_device *dev,
 	u32 dpll = pipe_config->dpll_hw_state.dpll;
 	if ((dpll & PLL_REF_INPUT_MASK) == PLLB_REF_INPUT_SPREADSPECTRUMIN)
@@ -10827,7 +10827,7 @@ static void i9xx_crtc_clock_get(struct intel_crtc *crtc,
 	u32 fp;
@@ -10953,7 +10953,7 @@ static void ironlake_pch_clock_get(struct intel_crtc *crtc,
 struct drm_display_mode *intel_crtc_mode_get(struct drm_device *dev,
 	struct drm_display_mode *mode;
@@ -11066,7 +11066,7 @@ static bool __pageflip_finished_cs(struct intel_crtc *crtc,
 				   struct intel_flip_work *work)
 	unsigned reset_counter;
 	reset_counter = i915_reset_counter(&dev_priv->gpu_error);
@@ -11277,7 +11277,7 @@ static int intel_gen4_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
 	uint32_t pf, pipesrc;
 	int ret;
@@ -11315,7 +11315,7 @@ static int intel_gen6_queue_flip(struct drm_device *dev,
 				 uint32_t flags)
 	int ret;
@@ -11474,7 +11474,7 @@ static void skl_do_mmio_flip(struct intel_crtc *intel_crtc,
 	struct drm_framebuffer *fb = intel_crtc->base.primary->fb;
 	const enum pipe pipe = intel_crtc->pipe;
 	u32 ctl, stride, tile_height;
@@ -11526,7 +11526,7 @@ static void ilk_do_mmio_flip(struct intel_crtc *intel_crtc,
 	struct intel_framebuffer *intel_fb =
 		to_intel_framebuffer(intel_crtc->base.primary->fb);
 	struct drm_i915_gem_object *obj = intel_fb->obj;
@@ -11662,7 +11662,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
 				uint32_t page_flip_flags)
 	struct drm_framebuffer *old_fb = crtc->primary->fb;
@@ -12099,7 +12099,7 @@ static int intel_crtc_atomic_check(struct drm_crtc *crtc,
@@ -12960,7 +12960,7 @@ static void verify_wm_state(struct drm_crtc *crtc,
 			    struct drm_crtc_state *new_state)
 	struct skl_ddb_allocation hw_ddb, *sw_ddb;
 	struct skl_ddb_entry *hw_entry, *sw_entry;
@@ -13066,7 +13066,7 @@ verify_crtc_state(struct drm_crtc *crtc,
 		  struct drm_crtc_state *new_crtc_state)
 	struct intel_crtc_state *pipe_config, *sw_config;
@@ -13189,7 +13189,7 @@ verify_shared_dpll_state(struct drm_device *dev, struct drm_crtc *crtc,
 			 struct drm_crtc_state *old_crtc_state,
 	struct intel_crtc_state *old_state = to_intel_crtc_state(old_crtc_state);
 	struct intel_crtc_state *new_state = to_intel_crtc_state(new_crtc_state);
@@ -13228,7 +13228,7 @@ intel_modeset_verify_crtc(struct drm_crtc *crtc,
 static void
 verify_disabled_dpll_state(struct drm_device *dev)
 	int i;
 	for (i = 0; i < dev_priv->num_shared_dpll; i++)
@@ -13410,7 +13410,7 @@ static int intel_modeset_all_pipes(struct drm_atomic_state *state)
 static int intel_modeset_checks(struct drm_atomic_state *state)
 	int ret = 0, i;
@@ -13576,7 +13576,7 @@ static int intel_atomic_prepare_commit(struct drm_device *dev,
 				       struct drm_atomic_state *state,
 				       bool nonblock)
 	struct drm_plane_state *plane_state;
 	struct drm_plane *plane;
@@ -13705,7 +13705,7 @@ static void intel_atomic_commit_tail(struct drm_atomic_state *state)
 	struct drm_crtc_state *old_crtc_state;
 	struct intel_crtc_state *intel_cstate;
@@ -13937,7 +13937,7 @@ static int intel_atomic_commit(struct drm_device *dev,
 			       bool nonblock)
 	int ret = 0;
 	if (intel_state->modeset && nonblock) {
@@ -14542,7 +14542,7 @@ static void skl_init_scalers(struct drm_device *dev, struct intel_crtc *intel_cr
 static void intel_crtc_init(struct drm_device *dev, int pipe)
 	struct intel_crtc *intel_crtc;
 	struct intel_crtc_state *crtc_state = NULL;
 	struct drm_plane *primary = NULL;
@@ -14669,7 +14669,7 @@ static int intel_encoder_clones(struct intel_encoder *encoder)
 static bool has_edp_a(struct drm_device *dev)
 	if (!IS_MOBILE(dev))
 		return false;
@@ -14685,7 +14685,7 @@ static bool has_edp_a(struct drm_device *dev)
 static bool intel_crt_present(struct drm_device *dev)
 	if (INTEL_INFO(dev)->gen >= 9)
 		return false;
@@ -14711,7 +14711,7 @@ static bool intel_crt_present(struct drm_device *dev)
 static void intel_setup_outputs(struct drm_device *dev)
 	bool dpd_is_edp = false;
@@ -15364,7 +15364,7 @@ void intel_init_display_hooks(struct drm_i915_private *dev_priv)
 static void quirk_pipea_force(struct drm_device *dev)
 	dev_priv->quirks |= QUIRK_PIPEA_FORCE;
 	DRM_INFO("applying pipe a force quirk\n");
@@ -15372,7 +15372,7 @@ static void quirk_pipea_force(struct drm_device *dev)
 static void quirk_pipeb_force(struct drm_device *dev)
 	dev_priv->quirks |= QUIRK_PIPEB_FORCE;
 	DRM_INFO("applying pipe b force quirk\n");
@@ -15383,7 +15383,7 @@ static void quirk_pipeb_force(struct drm_device *dev)
 static void quirk_ssc_force_disable(struct drm_device *dev)
 	dev_priv->quirks |= QUIRK_LVDS_SSC_DISABLE;
 	DRM_INFO("applying lvds SSC disable quirk\n");
@@ -15394,7 +15394,7 @@ static void quirk_ssc_force_disable(struct drm_device *dev)
 static void quirk_invert_brightness(struct drm_device *dev)
 	dev_priv->quirks |= QUIRK_INVERT_BRIGHTNESS;
 	DRM_INFO("applying inverted panel brightness quirk\n");
@@ -15402,7 +15402,7 @@ static void quirk_invert_brightness(struct drm_device *dev)
 /* Some VBT's incorrectly indicate no backlight is present */
 static void quirk_backlight_present(struct drm_device *dev)
 	dev_priv->quirks |= QUIRK_BACKLIGHT_PRESENT;
 	DRM_INFO("applying backlight present quirk\n");
@@ -15528,7 +15528,7 @@ static void intel_init_quirks(struct drm_device *dev)
 /* Disable the VGA plane that we never use */
 static void i915_disable_vga(struct drm_device *dev)
 	u8 sr1;
 	i915_reg_t vga_reg = i915_vgacntrl_reg(dev);
@@ -15546,7 +15546,7 @@ static void i915_disable_vga(struct drm_device *dev)
 void intel_modeset_init_hw(struct drm_device *dev)
 	intel_update_cdclk(dev);
@@ -15794,7 +15794,7 @@ static bool
 intel_check_plane_mapping(struct intel_crtc *crtc)
 	u32 val;
 	if (INTEL_INFO(dev)->num_pipes == 1)
@@ -15834,7 +15834,7 @@ static bool intel_encoder_has_connectors(struct intel_encoder *encoder)
 static void intel_sanitize_crtc(struct intel_crtc *crtc)
 	/* Clear any frame start delays used for debugging left by the BIOS */
@@ -15959,7 +15959,7 @@ static void intel_sanitize_encoder(struct intel_encoder *encoder)
 void i915_redisable_vga_power_on(struct drm_device *dev)
 	if (!(I915_READ(vga_reg) & VGA_DISP_DISABLE)) {
@@ -15970,7 +15970,7 @@ void i915_redisable_vga_power_on(struct drm_device *dev)
 void i915_redisable_vga(struct drm_device *dev)
 	/* This function can be called both from intel_modeset_setup_hw_state or
 	 * at a very early point in our resume sequence, where the power well
@@ -16010,7 +16010,7 @@ static void readout_plane_state(struct intel_crtc *crtc)
 static void intel_modeset_readout_hw_state(struct drm_device *dev)
 	enum pipe pipe;
 	struct intel_crtc *crtc;
@@ -16163,7 +16163,7 @@ static void intel_modeset_readout_hw_state(struct drm_device *dev)
 static void
 intel_modeset_setup_hw_state(struct drm_device *dev)
 	enum pipe pipe;
@@ -16346,7 +16346,7 @@ void intel_connector_unregister(struct drm_connector *connector)
 void intel_modeset_cleanup(struct drm_device *dev)
 	intel_disable_gt_powersave(dev_priv);
@@ -16392,7 +16392,7 @@ void intel_connector_attach_encoder(struct intel_connector *connector,
 int intel_modeset_vga_set_state(struct drm_device *dev, bool state)
 	unsigned reg = INTEL_INFO(dev)->gen >= 6 ? SNB_GMCH_CTRL : INTEL_GMCH_CTRL;
 	u16 gmch_ctrl;
@@ -16548,7 +16548,7 @@ intel_display_print_error_state(struct drm_i915_error_state_buf *m,
 				struct intel_display_error_state *error)
 	int i;
 	if (!error)
diff --git a/drivers/gpu/drm/i915/intel_dp.c b/drivers/gpu/drm/i915/intel_dp.c
index 0757ee4..1083f5e 100644
--- a/drivers/gpu/drm/i915/intel_dp.c
+++ b/drivers/gpu/drm/i915/intel_dp.c
@@ -262,7 +262,7 @@ static void pps_lock(struct intel_dp *intel_dp)
 	struct intel_digital_port *intel_dig_port = dp_to_dig_port(intel_dp);
 	struct intel_encoder *encoder = &intel_dig_port->base;
@@ -280,7 +280,7 @@ static void pps_unlock(struct intel_dp *intel_dp)
 	mutex_unlock(&dev_priv->pps_mutex);
@@ -294,7 +294,7 @@ vlv_power_sequencer_kick(struct intel_dp *intel_dp)
 	struct drm_device *dev = intel_dig_port->base.base.dev;
 	enum pipe pipe = intel_dp->pps_pipe;
 	bool pll_enabled, release_cl_override = false;
 	enum dpio_phy phy = DPIO_PHY(pipe);
@@ -368,7 +368,7 @@ vlv_power_sequencer_pipe(struct intel_dp *intel_dp)
 	unsigned int pipes = (1 << PIPE_A) | (1 << PIPE_B);
 	enum pipe pipe;
@@ -431,7 +431,7 @@ bxt_power_sequencer_idx(struct intel_dp *intel_dp)
 	lockdep_assert_held(&dev_priv->pps_mutex);
@@ -506,7 +506,7 @@ vlv_initial_power_sequencer_setup(struct intel_dp *intel_dp)
@@ -639,7 +639,7 @@ static int edp_notify_handler(struct notifier_block *this, unsigned long code,
 	struct intel_dp *intel_dp = container_of(this, typeof(* intel_dp),
 						 edp_notifier);
 	struct drm_device *dev = intel_dp_to_dev(intel_dp);
 	if (!is_edp(intel_dp) || code != SYS_RESTART)
 		return 0;
@@ -670,7 +670,7 @@ static int edp_notify_handler(struct notifier_block *this, unsigned long code,
 static bool edp_have_panel_power(struct intel_dp *intel_dp)
@@ -684,7 +684,7 @@ static bool edp_have_panel_power(struct intel_dp *intel_dp)
 static bool edp_have_panel_vdd(struct intel_dp *intel_dp)
@@ -699,7 +699,7 @@ static void
 intel_dp_check_edp(struct intel_dp *intel_dp)
 	if (!is_edp(intel_dp))
 		return;
@@ -717,7 +717,7 @@ intel_dp_aux_wait_done(struct intel_dp *intel_dp, bool has_aux_irq)
 	i915_reg_t ch_ctl = intel_dp->aux_ch_ctl_reg;
 	uint32_t status;
 	bool done;
@@ -850,7 +850,7 @@ intel_dp_aux_ch(struct intel_dp *intel_dp,
 	uint32_t aux_clock_divider;
 	int i, ret, recv_bytes;
@@ -1473,7 +1473,7 @@ intel_dp_compute_config(struct intel_encoder *encoder,
 	struct intel_dp *intel_dp = enc_to_intel_dp(&encoder->base);
 	enum port port = dp_to_dig_port(intel_dp)->port;
@@ -1657,7 +1657,7 @@ void intel_dp_set_link_params(struct intel_dp *intel_dp,
 static void intel_dp_prepare(struct intel_encoder *encoder)
@@ -1753,7 +1753,7 @@ static void wait_panel_status(struct intel_dp *intel_dp,
 				       u32 value)
 	i915_reg_t pp_stat_reg, pp_ctrl_reg;
@@ -1830,7 +1830,7 @@ static void edp_wait_backlight_off(struct intel_dp *intel_dp)
 static  u32 ironlake_get_pp_control(struct intel_dp *intel_dp)
 	u32 control;
@@ -1853,7 +1853,7 @@ static bool edp_panel_vdd_on(struct intel_dp *intel_dp)
 	struct intel_encoder *intel_encoder = &intel_dig_port->base;
 	u32 pp;
@@ -1926,7 +1926,7 @@ void intel_edp_panel_vdd_on(struct intel_dp *intel_dp)
 static void edp_panel_vdd_off_sync(struct intel_dp *intel_dp)
@@ -1995,8 +1995,7 @@ static void edp_panel_vdd_schedule_off(struct intel_dp *intel_dp)
 static void edp_panel_vdd_off(struct intel_dp *intel_dp, bool sync)
-		intel_dp_to_dev(intel_dp)->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(intel_dp_to_dev(intel_dp));
@@ -2017,7 +2016,7 @@ static void edp_panel_vdd_off(struct intel_dp *intel_dp, bool sync)
 static void edp_panel_on(struct intel_dp *intel_dp)
 	u32 pp;
 	i915_reg_t pp_ctrl_reg;
@@ -2078,7 +2077,7 @@ static void edp_panel_off(struct intel_dp *intel_dp)
 	u32 pp;
@@ -2130,7 +2129,7 @@ static void _intel_edp_backlight_on(struct intel_dp *intel_dp)
 	u32 pp;
@@ -2171,7 +2170,7 @@ void intel_edp_backlight_on(struct intel_dp *intel_dp)
 static void _intel_edp_backlight_off(struct intel_dp *intel_dp)
 	u32 pp;
@@ -2352,7 +2351,7 @@ static bool intel_dp_get_hw_state(struct intel_encoder *encoder,
 	u32 tmp;
 	bool ret;
@@ -2405,7 +2404,7 @@ static void intel_dp_get_config(struct intel_encoder *encoder,
 	u32 tmp, flags = 0;
@@ -2529,7 +2528,7 @@ static void chv_post_disable_dp(struct intel_encoder *encoder)
 	intel_dp_link_down(intel_dp);
@@ -2548,7 +2547,7 @@ _intel_dp_set_link_train(struct intel_dp *intel_dp,
 	if (HAS_DDI(dev)) {
@@ -2628,7 +2627,7 @@ _intel_dp_set_link_train(struct intel_dp *intel_dp,
 static void intel_dp_enable_port(struct intel_dp *intel_dp)
 		to_intel_crtc(dp_to_dig_port(intel_dp)->base.base.crtc);
@@ -2657,7 +2656,7 @@ static void intel_enable_dp(struct intel_encoder *encoder)
 	uint32_t dp_reg = I915_READ(intel_dp->output_reg);
@@ -2730,7 +2729,7 @@ static void g4x_pre_enable_dp(struct intel_encoder *encoder)
 static void vlv_detach_power_sequencer(struct intel_dp *intel_dp)
-	struct drm_i915_private *dev_priv = intel_dig_port->base.base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(intel_dig_port->base.base.dev);
 	i915_reg_t pp_on_reg = VLV_PIPE_PP_ON_DELAYS(pipe);
@@ -2756,7 +2755,7 @@ static void vlv_detach_power_sequencer(struct intel_dp *intel_dp)
 static void vlv_steal_power_sequencer(struct drm_device *dev,
 				      enum pipe pipe)
@@ -2794,7 +2793,7 @@ static void vlv_init_panel_power_sequencer(struct intel_dp *intel_dp)
@@ -2882,7 +2881,7 @@ uint8_t
 intel_dp_voltage_max(struct intel_dp *intel_dp)
 	if (IS_BROXTON(dev))
@@ -3300,7 +3299,7 @@ void intel_dp_set_idle_link_train(struct intel_dp *intel_dp)
 	uint32_t val;
@@ -3336,7 +3335,7 @@ intel_dp_link_down(struct intel_dp *intel_dp)
 	struct intel_crtc *crtc = to_intel_crtc(intel_dig_port->base.base.crtc);
 	uint32_t DP = intel_dp->DP;
 	if (WARN_ON(HAS_DDI(dev)))
@@ -3403,7 +3402,7 @@ intel_dp_get_dpcd(struct intel_dp *intel_dp)
 	struct intel_digital_port *dig_port = dp_to_dig_port(intel_dp);
 	struct drm_device *dev = dig_port->base.base.dev;
 	if (drm_dp_dpcd_read(&intel_dp->aux, 0x000, intel_dp->dpcd,
 			     sizeof(intel_dp->dpcd)) < 0)
@@ -4418,7 +4417,7 @@ intel_dp_set_property(struct drm_connector *connector,
 		      struct drm_property *property,
 		      uint64_t val)
 	struct intel_connector *intel_connector = to_intel_connector(connector);
 	struct intel_encoder *intel_encoder = intel_attached_encoder(connector);
 	struct intel_dp *intel_dp = enc_to_intel_dp(&intel_encoder->base);
@@ -4600,7 +4599,7 @@ static void intel_edp_panel_vdd_sanitize(struct intel_dp *intel_dp)
@@ -4676,7 +4675,7 @@ intel_dp_hpd_pulse(struct intel_digital_port *intel_dig_port, bool long_hpd)
 	struct intel_dp *intel_dp = &intel_dig_port->dp;
 	enum irqreturn ret = IRQ_NONE;
@@ -4744,7 +4743,7 @@ put_power:
 /* check the VBT to see whether the eDP is on another port */
 bool intel_dp_is_edp(struct drm_device *dev, enum port port)
 	 * eDP not supported on g4x. so bail out early just
@@ -4860,7 +4859,7 @@ static void
 intel_dp_init_panel_power_sequencer(struct drm_device *dev,
 	struct edp_power_seq cur, vbt, spec,
 		*final = &intel_dp->pps_delays;
@@ -4932,7 +4931,7 @@ static void
 intel_dp_init_panel_power_sequencer_registers(struct drm_device *dev,
 	u32 pp_on, pp_off, pp_div, port_sel = 0;
 	int div = dev_priv->rawclk_freq / 1000;
 	struct pps_registers regs;
@@ -5002,7 +5001,7 @@ intel_dp_init_panel_power_sequencer_registers(struct drm_device *dev,
 static void intel_dp_set_drrs_state(struct drm_device *dev, int refresh_rate)
 	struct intel_digital_port *dig_port = NULL;
 	struct intel_dp *intel_dp = dev_priv->drrs.dp;
@@ -5101,7 +5100,7 @@ static void intel_dp_set_drrs_state(struct drm_device *dev, int refresh_rate)
 void intel_edp_drrs_enable(struct intel_dp *intel_dp)
 	struct drm_crtc *crtc = dig_port->base.base.crtc;
@@ -5133,7 +5132,7 @@ unlock:
 void intel_edp_drrs_disable(struct intel_dp *intel_dp)
@@ -5201,7 +5200,7 @@ unlock:
 void intel_edp_drrs_invalidate(struct drm_device *dev,
 		unsigned frontbuffer_bits)
 	enum pipe pipe;
@@ -5246,7 +5245,7 @@ void intel_edp_drrs_invalidate(struct drm_device *dev,
 void intel_edp_drrs_flush(struct drm_device *dev,
 	enum pipe pipe;
@@ -5339,7 +5338,7 @@ intel_dp_drrs_init(struct intel_connector *intel_connector,
 	struct drm_connector *connector = &intel_connector->base;
 	struct drm_display_mode *downclock_mode = NULL;
 	INIT_DELAYED_WORK(&dev_priv->drrs.work, intel_edp_drrs_downclock_work);
@@ -5377,7 +5376,7 @@ static bool intel_edp_init_connector(struct intel_dp *intel_dp,
 	struct drm_device *dev = intel_encoder->base.dev;
 	struct drm_display_mode *fixed_mode = NULL;
 	bool has_dpcd;
@@ -5519,7 +5518,7 @@ intel_dp_init_connector(struct intel_digital_port *intel_dig_port,
 	int type;
@@ -5650,7 +5649,7 @@ bool intel_dp_init(struct drm_device *dev,
 		   i915_reg_t output_reg,
 		   enum port port)
@@ -5728,7 +5727,7 @@ err_connector_alloc:
 void intel_dp_mst_suspend(struct drm_device *dev)
 	int i;
 	/* disable MST */
@@ -5748,7 +5747,7 @@ void intel_dp_mst_suspend(struct drm_device *dev)
 void intel_dp_mst_resume(struct drm_device *dev)
 	int i;
 	for (i = 0; i < I915_MAX_PORTS; i++) {
diff --git a/drivers/gpu/drm/i915/intel_dp_mst.c b/drivers/gpu/drm/i915/intel_dp_mst.c
index c1d3186..8180087 100644
--- a/drivers/gpu/drm/i915/intel_dp_mst.c
+++ b/drivers/gpu/drm/i915/intel_dp_mst.c
@@ -140,7 +140,7 @@ static void intel_mst_pre_enable_dp(struct intel_encoder *encoder)
 	struct intel_digital_port *intel_dig_port = intel_mst->primary;
 	int ret;
 	uint32_t temp;
@@ -207,7 +207,7 @@ static void intel_mst_enable_dp(struct intel_encoder *encoder)
 	int ret;
@@ -242,7 +242,7 @@ static void intel_dp_mst_enc_get_config(struct intel_encoder *encoder,
 	u32 temp, flags = 0;
diff --git a/drivers/gpu/drm/i915/intel_dpio_phy.c b/drivers/gpu/drm/i915/intel_dpio_phy.c
index 288da35..047f487 100644
--- a/drivers/gpu/drm/i915/intel_dpio_phy.c
+++ b/drivers/gpu/drm/i915/intel_dpio_phy.c
@@ -168,7 +168,7 @@ void chv_phy_pre_pll_enable(struct intel_encoder *encoder)
 	struct intel_digital_port *dport = enc_to_dig_port(&encoder->base);
 	enum dpio_channel ch = vlv_dport_to_channel(dport);
@@ -250,7 +250,7 @@ void chv_phy_pre_encoder_enable(struct intel_encoder *encoder)
 	struct intel_digital_port *dport = dp_to_dig_port(intel_dp);
@@ -400,7 +400,7 @@ void vlv_phy_pre_pll_enable(struct intel_encoder *encoder)
 	enum dpio_channel port = vlv_dport_to_channel(dport);
@@ -429,7 +429,7 @@ void vlv_phy_pre_encoder_enable(struct intel_encoder *encoder)
@@ -457,7 +457,7 @@ void vlv_phy_pre_encoder_enable(struct intel_encoder *encoder)
 void vlv_phy_reset_lanes(struct intel_encoder *encoder)
diff --git a/drivers/gpu/drm/i915/intel_dpll_mgr.c b/drivers/gpu/drm/i915/intel_dpll_mgr.c
index e19757c..8a4dac9 100644
--- a/drivers/gpu/drm/i915/intel_dpll_mgr.c
+++ b/drivers/gpu/drm/i915/intel_dpll_mgr.c
@@ -83,7 +83,7 @@ void assert_shared_dpll(struct drm_i915_private *dev_priv,
 void intel_prepare_shared_dpll(struct intel_crtc *crtc)
 	struct intel_shared_dpll *pll = crtc->config->shared_dpll;
 	if (WARN_ON(pll == NULL))
@@ -112,7 +112,7 @@ void intel_prepare_shared_dpll(struct intel_crtc *crtc)
 void intel_enable_shared_dpll(struct intel_crtc *crtc)
 	unsigned crtc_mask = 1 << drm_crtc_index(&crtc->base);
 	unsigned old_mask;
@@ -151,7 +151,7 @@ out:
 void intel_disable_shared_dpll(struct intel_crtc *crtc)
@@ -191,7 +191,7 @@ intel_find_shared_dpll(struct intel_crtc *crtc,
 		       enum intel_dpll_id range_min,
 		       enum intel_dpll_id range_max)
 	struct intel_shared_dpll_config *shared_dpll;
 	enum intel_dpll_id i;
@@ -1636,7 +1636,7 @@ static const struct intel_shared_dpll_funcs bxt_ddi_pll_funcs = {
 static void intel_ddi_pll_init(struct drm_device *dev)
 	if (INTEL_GEN(dev_priv) < 9) {
 		uint32_t val = I915_READ(LCPLL_CTL);
@@ -1723,7 +1723,7 @@ static const struct intel_dpll_mgr bxt_pll_mgr = {
 void intel_shared_dpll_init(struct drm_device *dev)
 	const struct intel_dpll_mgr *dpll_mgr = NULL;
 	const struct dpll_info *dpll_info;
 	int i;
diff --git a/drivers/gpu/drm/i915/intel_drv.h b/drivers/gpu/drm/i915/intel_drv.h
index 98a5be4..e6a24d2 100644
--- a/drivers/gpu/drm/i915/intel_drv.h
+++ b/drivers/gpu/drm/i915/intel_drv.h
@@ -987,14 +987,14 @@ vlv_pipe_to_channel(enum pipe pipe)
 static inline struct drm_crtc *
 intel_get_crtc_for_pipe(struct drm_device *dev, int pipe)
 	return dev_priv->pipe_to_crtc_mapping[pipe];
 intel_get_crtc_for_plane(struct drm_device *dev, int plane)
 	return dev_priv->plane_to_crtc_mapping[plane];
diff --git a/drivers/gpu/drm/i915/intel_dsi.c b/drivers/gpu/drm/i915/intel_dsi.c
index 448741d..51109ac 100644
--- a/drivers/gpu/drm/i915/intel_dsi.c
+++ b/drivers/gpu/drm/i915/intel_dsi.c
@@ -84,7 +84,7 @@ static void wait_for_dsi_fifo_empty(struct intel_dsi *intel_dsi, enum port port)
 	struct drm_encoder *encoder = &intel_dsi->base.base;
 	u32 mask;
 	mask = LP_CTRL_FIFO_EMPTY | HS_CTRL_FIFO_EMPTY |
@@ -131,7 +131,7 @@ static ssize_t intel_dsi_host_transfer(struct mipi_dsi_host *host,
 	struct intel_dsi_host *intel_dsi_host = to_intel_dsi_host(host);
 	struct drm_device *dev = intel_dsi_host->intel_dsi->base.base.dev;
 	enum port port = intel_dsi_host->port;
 	struct mipi_dsi_packet packet;
 	ssize_t ret;
@@ -260,7 +260,7 @@ static int dpi_send_cmd(struct intel_dsi *intel_dsi, u32 cmd, bool hs,
 	u32 mask;
 	/* XXX: pipe, hs */
@@ -314,7 +314,7 @@ static inline bool is_cmd_mode(struct intel_dsi *intel_dsi)
 static bool intel_dsi_compute_config(struct intel_encoder *encoder,
 	struct intel_dsi *intel_dsi = container_of(encoder, struct intel_dsi,
 						   base);
 	struct intel_connector *intel_connector = intel_dsi->attached_connector;
@@ -360,7 +360,7 @@ static bool intel_dsi_compute_config(struct intel_encoder *encoder,
 static void bxt_dsi_device_ready(struct intel_encoder *encoder)
 	struct intel_dsi *intel_dsi = enc_to_intel_dsi(&encoder->base);
 	enum port port;
 	u32 val;
@@ -399,7 +399,7 @@ static void bxt_dsi_device_ready(struct intel_encoder *encoder)
 static void vlv_dsi_device_ready(struct intel_encoder *encoder)
 	enum port port;
 	u32 val;
@@ -449,7 +449,7 @@ static void intel_dsi_device_ready(struct intel_encoder *encoder)
 static void intel_dsi_port_enable(struct intel_encoder *encoder)
 	enum port port;
@@ -490,7 +490,7 @@ static void intel_dsi_port_enable(struct intel_encoder *encoder)
 static void intel_dsi_port_disable(struct intel_encoder *encoder)
 	enum port port;
@@ -509,7 +509,7 @@ static void intel_dsi_port_disable(struct intel_encoder *encoder)
 static void intel_dsi_enable(struct intel_encoder *encoder)
 	enum port port;
@@ -540,7 +540,7 @@ static void intel_dsi_prepare(struct intel_encoder *intel_encoder);
 static void intel_dsi_pre_enable(struct intel_encoder *encoder)
 	enum port port;
@@ -614,7 +614,7 @@ static void intel_dsi_pre_disable(struct intel_encoder *encoder)
 static void intel_dsi_disable(struct intel_encoder *encoder)
 	enum port port;
 	u32 temp;
@@ -653,7 +653,7 @@ static void intel_dsi_disable(struct intel_encoder *encoder)
 static void intel_dsi_clear_device_ready(struct intel_encoder *encoder)
 	enum port port;
@@ -698,7 +698,7 @@ static void intel_dsi_clear_device_ready(struct intel_encoder *encoder)
 static void intel_dsi_post_disable(struct intel_encoder *encoder)
 	DRM_DEBUG_KMS("\n");
@@ -733,7 +733,7 @@ static void intel_dsi_post_disable(struct intel_encoder *encoder)
 static bool intel_dsi_get_hw_state(struct intel_encoder *encoder,
 				   enum pipe *pipe)
@@ -807,7 +807,7 @@ static void bxt_dsi_get_pipe_config(struct intel_encoder *encoder,
 	struct drm_display_mode *adjusted_mode_sw;
@@ -1026,7 +1026,7 @@ static void set_dsi_timings(struct drm_encoder *encoder,
 	struct intel_dsi *intel_dsi = enc_to_intel_dsi(encoder);
 	enum port port;
 	unsigned int bpp = mipi_dsi_pixel_format_to_bpp(intel_dsi->pixel_format);
@@ -1112,7 +1112,7 @@ static void intel_dsi_prepare(struct intel_encoder *intel_encoder)
 	struct intel_crtc *intel_crtc = to_intel_crtc(encoder->crtc);
@@ -1434,7 +1434,7 @@ void intel_dsi_init(struct drm_device *dev)
 	struct drm_display_mode *scan, *fixed_mode = NULL;
 	enum port port;
 	unsigned int i;
diff --git a/drivers/gpu/drm/i915/intel_dsi_dcs_backlight.c b/drivers/gpu/drm/i915/intel_dsi_dcs_backlight.c
index f0dc427..ac7c602 100644
--- a/drivers/gpu/drm/i915/intel_dsi_dcs_backlight.c
+++ b/drivers/gpu/drm/i915/intel_dsi_dcs_backlight.c
@@ -159,7 +159,7 @@ static int dcs_setup_backlight(struct intel_connector *connector,
 int intel_dsi_dcs_init_backlight_funcs(struct intel_connector *intel_connector)
 	struct intel_encoder *encoder = intel_connector->encoder;
 	struct intel_panel *panel = &intel_connector->panel;
diff --git a/drivers/gpu/drm/i915/intel_dsi_panel_vbt.c b/drivers/gpu/drm/i915/intel_dsi_panel_vbt.c
index 4a3da87..cd154ce 100644
--- a/drivers/gpu/drm/i915/intel_dsi_panel_vbt.c
+++ b/drivers/gpu/drm/i915/intel_dsi_panel_vbt.c
@@ -303,7 +303,7 @@ static void chv_exec_gpio(struct drm_i915_private *dev_priv,
 static const u8 *mipi_exec_gpio(struct intel_dsi *intel_dsi, const u8 *data)
 	struct drm_device *dev = intel_dsi->base.base.dev;
 	u8 gpio_source, gpio_index;
 	bool value;
@@ -469,7 +469,7 @@ static int vbt_panel_get_modes(struct drm_panel *panel)
 	struct vbt_panel *vbt_panel = to_vbt_panel(panel);
 	struct intel_dsi *intel_dsi = vbt_panel->intel_dsi;
 	if (!panel->connector)
@@ -497,7 +497,7 @@ static const struct drm_panel_funcs vbt_panel_funcs = {
 struct drm_panel *vbt_panel_init(struct intel_dsi *intel_dsi, u16 panel_id)
 	struct mipi_config *mipi_config = dev_priv->vbt.dsi.config;
 	struct mipi_pps_data *pps = dev_priv->vbt.dsi.pps;
 	struct drm_display_mode *mode = dev_priv->vbt.lfp_lvds_vbt_mode;
diff --git a/drivers/gpu/drm/i915/intel_dsi_pll.c b/drivers/gpu/drm/i915/intel_dsi_pll.c
index 1fcddeb..6ab58a0 100644
--- a/drivers/gpu/drm/i915/intel_dsi_pll.c
+++ b/drivers/gpu/drm/i915/intel_dsi_pll.c
@@ -114,7 +114,7 @@ static int dsi_calc_mnp(struct drm_i915_private *dev_priv,
 static int vlv_compute_dsi_pll(struct intel_encoder *encoder,
 			       struct intel_crtc_state *config)
 	int ret;
 	u32 dsi_clk;
@@ -325,7 +325,7 @@ static u32 bxt_dsi_get_pclk(struct intel_encoder *encoder, int pipe_bpp,
 	u32 dsi_clk;
 	u32 dsi_ratio;
 	/* Divide by zero */
 	if (!pipe_bpp) {
@@ -360,7 +360,7 @@ u32 intel_dsi_get_pclk(struct intel_encoder *encoder, int pipe_bpp,
 static void vlv_dsi_reset_clocks(struct intel_encoder *encoder, enum port port)
 	u32 temp;
 	temp = I915_READ(MIPI_CTRL(port));
@@ -374,7 +374,7 @@ static void vlv_dsi_reset_clocks(struct intel_encoder *encoder, enum port port)
 static void bxt_dsi_program_clocks(struct drm_device *dev, enum port port,
 				   const struct intel_crtc_state *config)
 	u32 tmp;
 	u32 dsi_rate = 0;
 	u32 pll_ratio = 0;
@@ -469,7 +469,7 @@ static int bxt_compute_dsi_pll(struct intel_encoder *encoder,
 static void bxt_enable_dsi_pll(struct intel_encoder *encoder,
 	enum port port;
 	u32 val;
@@ -550,7 +550,7 @@ static void bxt_dsi_reset_clocks(struct intel_encoder *encoder, enum port port)
 	u32 tmp;
 	/* Clear old configurations */
 	tmp = I915_READ(BXT_MIPI_CLOCK_CTL);
diff --git a/drivers/gpu/drm/i915/intel_dvo.c b/drivers/gpu/drm/i915/intel_dvo.c
index 14b1d3f..47bdf9d 100644
--- a/drivers/gpu/drm/i915/intel_dvo.c
+++ b/drivers/gpu/drm/i915/intel_dvo.c
@@ -122,7 +122,7 @@ static struct intel_dvo *intel_attached_dvo(struct drm_connector *connector)
 static bool intel_dvo_connector_get_hw_state(struct intel_connector *connector)
 	struct drm_device *dev = connector->base.dev;
 	struct intel_dvo *intel_dvo = intel_attached_dvo(&connector->base);
 	u32 tmp;
@@ -138,7 +138,7 @@ static bool intel_dvo_get_hw_state(struct intel_encoder *encoder,
 				   enum pipe *pipe)
 	struct intel_dvo *intel_dvo = enc_to_dvo(encoder);
 	u32 tmp;
@@ -155,7 +155,7 @@ static bool intel_dvo_get_hw_state(struct intel_encoder *encoder,
 static void intel_dvo_get_config(struct intel_encoder *encoder,
 	u32 tmp, flags = 0;
@@ -176,7 +176,7 @@ static void intel_dvo_get_config(struct intel_encoder *encoder,
 static void intel_disable_dvo(struct intel_encoder *encoder)
 	i915_reg_t dvo_reg = intel_dvo->dev.dvo_reg;
 	u32 temp = I915_READ(dvo_reg);
@@ -188,7 +188,7 @@ static void intel_disable_dvo(struct intel_encoder *encoder)
 static void intel_enable_dvo(struct intel_encoder *encoder)
@@ -256,7 +256,7 @@ static bool intel_dvo_compute_config(struct intel_encoder *encoder,
 static void intel_dvo_pre_enable(struct intel_encoder *encoder)
@@ -305,7 +305,7 @@ intel_dvo_detect(struct drm_connector *connector, bool force)
 static int intel_dvo_get_modes(struct drm_connector *connector)
 	const struct drm_display_mode *fixed_mode =
 		to_intel_connector(connector)->panel.fixed_mode;
@@ -379,7 +379,7 @@ static struct drm_display_mode *
 intel_dvo_get_current_mode(struct drm_connector *connector)
 	struct intel_dvo *intel_dvo = intel_attached_dvo(connector);
 	uint32_t dvo_val = I915_READ(intel_dvo->dev.dvo_reg);
 	struct drm_display_mode *mode = NULL;
@@ -421,7 +421,7 @@ static char intel_dvo_port_name(i915_reg_t dvo_reg)
 void intel_dvo_init(struct drm_device *dev)
 	struct intel_dvo *intel_dvo;
diff --git a/drivers/gpu/drm/i915/intel_fbc.c b/drivers/gpu/drm/i915/intel_fbc.c
index 978d795..067b6f5 100644
--- a/drivers/gpu/drm/i915/intel_fbc.c
+++ b/drivers/gpu/drm/i915/intel_fbc.c
@@ -445,7 +445,7 @@ out:
 static void intel_fbc_schedule_activation(struct intel_crtc *crtc)
-	struct drm_i915_private *dev_priv = crtc->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(crtc->base.dev);
 	struct intel_fbc *fbc = &dev_priv->fbc;
 	struct intel_fbc_work *work = &fbc->work;
@@ -555,7 +555,7 @@ again:
 static int intel_fbc_alloc_cfb(struct intel_crtc *crtc)
 	struct drm_mm_node *uninitialized_var(compressed_llb);
 	int size, fb_cpp, ret;
@@ -686,7 +686,7 @@ static bool pixel_format_is_valid(struct drm_i915_private *dev_priv,
 static bool intel_fbc_hw_tracking_covers_screen(struct intel_crtc *crtc)
 	unsigned int effective_w, effective_h, max_w, max_h;
@@ -713,7 +713,7 @@ static void intel_fbc_update_state_cache(struct intel_crtc *crtc,
 					 struct intel_crtc_state *crtc_state,
 	struct intel_fbc_state_cache *cache = &fbc->state_cache;
@@ -746,7 +746,7 @@ static void intel_fbc_update_state_cache(struct intel_crtc *crtc,
 static bool intel_fbc_can_activate(struct intel_crtc *crtc)
@@ -818,7 +818,7 @@ static bool intel_fbc_can_activate(struct intel_crtc *crtc)
 static bool intel_fbc_can_choose(struct intel_crtc *crtc)
 	if (intel_vgpu_active(dev_priv)) {
@@ -847,7 +847,7 @@ static bool intel_fbc_can_choose(struct intel_crtc *crtc)
 static void intel_fbc_get_reg_params(struct intel_crtc *crtc,
 				     struct intel_fbc_reg_params *params)
@@ -880,7 +880,7 @@ void intel_fbc_pre_update(struct intel_crtc *crtc,
 	if (!fbc_supported(dev_priv))
@@ -906,7 +906,7 @@ unlock:
 static void __intel_fbc_post_update(struct intel_crtc *crtc)
 	struct intel_fbc_reg_params old_params;
@@ -939,7 +939,7 @@ static void __intel_fbc_post_update(struct intel_crtc *crtc)
 void intel_fbc_post_update(struct intel_crtc *crtc)
@@ -1085,7 +1085,7 @@ void intel_fbc_enable(struct intel_crtc *crtc,
@@ -1156,7 +1156,7 @@ static void __intel_fbc_disable(struct drm_i915_private *dev_priv)
 void intel_fbc_disable(struct intel_crtc *crtc)
diff --git a/drivers/gpu/drm/i915/intel_fbdev.c b/drivers/gpu/drm/i915/intel_fbdev.c
index 224180e4..5205afd 100644
--- a/drivers/gpu/drm/i915/intel_fbdev.c
+++ b/drivers/gpu/drm/i915/intel_fbdev.c
@@ -703,7 +703,7 @@ static void intel_fbdev_suspend_worker(struct work_struct *work)
 int intel_fbdev_init(struct drm_device *dev)
 	struct intel_fbdev *ifbdev;
 	int ret;
 	if (WARN_ON(INTEL_INFO(dev)->num_pipes == 0))
@@ -762,7 +762,7 @@ static void intel_fbdev_sync(struct intel_fbdev *ifbdev)
 void intel_fbdev_fini(struct drm_device *dev)
 	struct intel_fbdev *ifbdev = dev_priv->fbdev;
 	if (!ifbdev)
@@ -778,7 +778,7 @@ void intel_fbdev_fini(struct drm_device *dev)
 void intel_fbdev_set_suspend(struct drm_device *dev, int state, bool synchronous)
 	struct fb_info *info;
@@ -827,7 +827,7 @@ void intel_fbdev_set_suspend(struct drm_device *dev, int state, bool synchronous
 void intel_fbdev_output_poll_changed(struct drm_device *dev)
 	if (dev_priv->fbdev)
 		drm_fb_helper_hotplug_event(&dev_priv->fbdev->helper);
@@ -835,7 +835,7 @@ void intel_fbdev_output_poll_changed(struct drm_device *dev)
 void intel_fbdev_restore_mode(struct drm_device *dev)
 	int ret;
 	struct drm_fb_helper *fb_helper;
diff --git a/drivers/gpu/drm/i915/intel_fifo_underrun.c b/drivers/gpu/drm/i915/intel_fifo_underrun.c
index 9be839a..3fca955 100644
--- a/drivers/gpu/drm/i915/intel_fifo_underrun.c
+++ b/drivers/gpu/drm/i915/intel_fifo_underrun.c
@@ -50,7 +50,7 @@
 static bool ivb_can_enable_err_int(struct drm_device *dev)
 	enum pipe pipe;
@@ -68,7 +68,7 @@ static bool ivb_can_enable_err_int(struct drm_device *dev)
 static bool cpt_can_enable_serr_int(struct drm_device *dev)
 	enum pipe pipe;
@@ -105,7 +105,7 @@ static void i9xx_set_fifo_underrun_reporting(struct drm_device *dev,
 					     enum pipe pipe,
 					     bool enable, bool old)
 	i915_reg_t reg = PIPESTAT(pipe);
 	u32 pipestat = I915_READ(reg) & 0xffff0000;
@@ -123,7 +123,7 @@ static void i9xx_set_fifo_underrun_reporting(struct drm_device *dev,
 static void ironlake_set_fifo_underrun_reporting(struct drm_device *dev,
 						 enum pipe pipe, bool enable)
 	uint32_t bit = (pipe == PIPE_A) ? DE_PIPEA_FIFO_UNDERRUN :
 					  DE_PIPEB_FIFO_UNDERRUN;
@@ -154,7 +154,7 @@ static void ivybridge_set_fifo_underrun_reporting(struct drm_device *dev,
 						  enum pipe pipe,
 	if (enable) {
 		I915_WRITE(GEN7_ERR_INT, ERR_INT_FIFO_UNDERRUN(pipe));
@@ -176,7 +176,7 @@ static void ivybridge_set_fifo_underrun_reporting(struct drm_device *dev,
 static void broadwell_set_fifo_underrun_reporting(struct drm_device *dev,
 	if (enable)
 		bdw_enable_pipe_irq(dev_priv, pipe, GEN8_PIPE_FIFO_UNDERRUN);
@@ -188,7 +188,7 @@ static void ibx_set_fifo_underrun_reporting(struct drm_device *dev,
 					    enum transcoder pch_transcoder,
 					    bool enable)
 	uint32_t bit = (pch_transcoder == TRANSCODER_A) ?
 		       SDE_TRANSA_FIFO_UNDER : SDE_TRANSB_FIFO_UNDER;
@@ -220,7 +220,7 @@ static void cpt_set_fifo_underrun_reporting(struct drm_device *dev,
 	if (enable) {
 		I915_WRITE(SERR_INT,
@@ -244,7 +244,7 @@ static void cpt_set_fifo_underrun_reporting(struct drm_device *dev,
 static bool __intel_set_cpu_fifo_underrun_reporting(struct drm_device *dev,
 	struct drm_crtc *crtc = dev_priv->pipe_to_crtc_mapping[pipe];
 	struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
 	bool old;
diff --git a/drivers/gpu/drm/i915/intel_guc_loader.c b/drivers/gpu/drm/i915/intel_guc_loader.c
index d80b617..7d8cc3e 100644
--- a/drivers/gpu/drm/i915/intel_guc_loader.c
+++ b/drivers/gpu/drm/i915/intel_guc_loader.c
@@ -413,7 +413,7 @@ static int i915_reset_guc(struct drm_i915_private *dev_priv)
 int intel_guc_setup(struct drm_device *dev)
 	struct intel_guc_fw *guc_fw = &dev_priv->guc.guc_fw;
 	const char *fw_path = guc_fw->guc_fw_path;
 	int retries, ret, err;
@@ -681,7 +681,7 @@ fail:
 void intel_guc_init(struct drm_device *dev)
 	const char *fw_path;
@@ -734,7 +734,7 @@ void intel_guc_init(struct drm_device *dev)
 void intel_guc_fini(struct drm_device *dev)
 	mutex_lock(&dev->struct_mutex);
diff --git a/drivers/gpu/drm/i915/intel_hdmi.c b/drivers/gpu/drm/i915/intel_hdmi.c
index 86e1fdb..4f4e4b5 100644
--- a/drivers/gpu/drm/i915/intel_hdmi.c
+++ b/drivers/gpu/drm/i915/intel_hdmi.c
@@ -47,7 +47,7 @@ static void
 assert_hdmi_port_disabled(struct intel_hdmi *intel_hdmi)
 	struct drm_device *dev = intel_hdmi_to_dev(intel_hdmi);
 	uint32_t enabled_bits;
 	enabled_bits = HAS_DDI(dev) ? DDI_BUF_CTL_ENABLE : SDVO_ENABLE;
@@ -138,7 +138,7 @@ static void g4x_write_infoframe(struct drm_encoder *encoder,
 	const uint32_t *data = frame;
 	struct drm_device *dev = encoder->dev;
 	u32 val = I915_READ(VIDEO_DIP_CTL);
 	int i;
@@ -192,7 +192,7 @@ static void ibx_write_infoframe(struct drm_encoder *encoder,
 	i915_reg_t reg = TVIDEO_DIP_CTL(intel_crtc->pipe);
 	u32 val = I915_READ(reg);
@@ -251,7 +251,7 @@ static void cpt_write_infoframe(struct drm_encoder *encoder,
@@ -308,7 +308,7 @@ static void vlv_write_infoframe(struct drm_encoder *encoder,
 	i915_reg_t reg = VLV_TVIDEO_DIP_CTL(intel_crtc->pipe);
@@ -366,7 +366,7 @@ static void hsw_write_infoframe(struct drm_encoder *encoder,
 	i915_reg_t ctl_reg = HSW_TVIDEO_DIP_CTL(cpu_transcoder);
@@ -508,7 +508,7 @@ static void g4x_set_infoframes(struct drm_encoder *encoder,
 			       bool enable,
 			       const struct drm_display_mode *adjusted_mode)
-	struct drm_i915_private *dev_priv = encoder->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(encoder->dev);
 	struct intel_digital_port *intel_dig_port = enc_to_dig_port(encoder);
 	struct intel_hdmi *intel_hdmi = &intel_dig_port->hdmi;
 	i915_reg_t reg = VIDEO_DIP_CTL;
@@ -629,7 +629,7 @@ static bool gcp_default_phase_possible(int pipe_bpp,
 static bool intel_hdmi_set_gcp_infoframe(struct drm_encoder *encoder)
 	struct intel_crtc *crtc = to_intel_crtc(encoder->crtc);
 	i915_reg_t reg;
 	u32 val = 0;
@@ -661,7 +661,7 @@ static void ibx_set_infoframes(struct drm_encoder *encoder,
 			       bool enable,
@@ -713,7 +713,7 @@ static void cpt_set_infoframes(struct drm_encoder *encoder,
 			       bool enable,
 	struct intel_hdmi *intel_hdmi = enc_to_intel_hdmi(encoder);
@@ -755,7 +755,7 @@ static void vlv_set_infoframes(struct drm_encoder *encoder,
 			       bool enable,
@@ -807,7 +807,7 @@ static void hsw_set_infoframes(struct drm_encoder *encoder,
 			       bool enable,
 	i915_reg_t reg = HSW_TVIDEO_DIP_CTL(intel_crtc->config->cpu_transcoder);
@@ -855,7 +855,7 @@ void intel_dp_dual_mode_set_tmds_output(struct intel_hdmi *hdmi, bool enable)
 static void intel_hdmi_prepare(struct intel_encoder *encoder)
 	struct drm_device *dev = encoder->base.dev;
 	struct intel_crtc *crtc = to_intel_crtc(encoder->base.crtc);
 	struct intel_hdmi *intel_hdmi = enc_to_intel_hdmi(&encoder->base);
 	const struct drm_display_mode *adjusted_mode = &crtc->config->base.adjusted_mode;
@@ -894,7 +894,7 @@ static bool intel_hdmi_get_hw_state(struct intel_encoder *encoder,
 				    enum pipe *pipe)
 	enum intel_display_power_domain power_domain;
 	u32 tmp;
@@ -931,7 +931,7 @@ static void intel_hdmi_get_config(struct intel_encoder *encoder,
 	u32 tmp, flags = 0;
 	int dotclock;
@@ -988,7 +988,7 @@ static void intel_enable_hdmi_audio(struct intel_encoder *encoder)
 static void g4x_enable_hdmi(struct intel_encoder *encoder)
 	u32 temp;
@@ -1009,7 +1009,7 @@ static void g4x_enable_hdmi(struct intel_encoder *encoder)
 static void ibx_enable_hdmi(struct intel_encoder *encoder)
 	u32 temp;
@@ -1058,7 +1058,7 @@ static void ibx_enable_hdmi(struct intel_encoder *encoder)
 static void cpt_enable_hdmi(struct intel_encoder *encoder)
 	enum pipe pipe = crtc->pipe;
@@ -1115,7 +1115,7 @@ static void vlv_enable_hdmi(struct intel_encoder *encoder)
 static void intel_disable_hdmi(struct intel_encoder *encoder)
 	u32 temp;
@@ -1575,7 +1575,7 @@ intel_hdmi_set_property(struct drm_connector *connector,
 	struct intel_hdmi *intel_hdmi = intel_attached_hdmi(connector);
 		hdmi_to_dig_port(intel_hdmi);
-	struct drm_i915_private *dev_priv = connector->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(connector->dev);
 	int ret;
 	ret = drm_object_property_set_value(&connector->base, property, val);
@@ -1674,7 +1674,7 @@ static void vlv_hdmi_pre_enable(struct intel_encoder *encoder)
 	struct intel_hdmi *intel_hdmi = &dport->hdmi;
@@ -1722,7 +1722,7 @@ static void vlv_hdmi_post_disable(struct intel_encoder *encoder)
 static void chv_hdmi_post_disable(struct intel_encoder *encoder)
@@ -1737,7 +1737,7 @@ static void chv_hdmi_pre_enable(struct intel_encoder *encoder)
@@ -1807,7 +1807,7 @@ void intel_hdmi_init_connector(struct intel_digital_port *intel_dig_port,
 	enum port port = intel_dig_port->port;
 	uint8_t alternate_ddc_pin;
diff --git a/drivers/gpu/drm/i915/intel_i2c.c b/drivers/gpu/drm/i915/intel_i2c.c
index 6bc4c06..3c6f338 100644
--- a/drivers/gpu/drm/i915/intel_i2c.c
+++ b/drivers/gpu/drm/i915/intel_i2c.c
@@ -113,7 +113,7 @@ to_intel_gmbus(struct i2c_adapter *i2c)
 void
 intel_i2c_reset(struct drm_device *dev)
 	I915_WRITE(GMBUS0, 0);
 	I915_WRITE(GMBUS4, 0);
@@ -632,7 +632,7 @@ static const struct i2c_algorithm gmbus_algorithm = {
 int intel_setup_gmbus(struct drm_device *dev)
 	struct intel_gmbus *bus;
 	unsigned int pin;
 	int ret;
@@ -736,7 +736,7 @@ void intel_gmbus_force_bit(struct i2c_adapter *adapter, bool force_bit)
 void intel_teardown_gmbus(struct drm_device *dev)
 	unsigned int pin;
diff --git a/drivers/gpu/drm/i915/intel_lrc.c b/drivers/gpu/drm/i915/intel_lrc.c
index 2e66f31..676b532 100644
--- a/drivers/gpu/drm/i915/intel_lrc.c
+++ b/drivers/gpu/drm/i915/intel_lrc.c
@@ -823,7 +823,7 @@ int intel_execlists_submission(struct i915_execbuffer_params *params,
 	struct drm_device       *dev = params->dev;
 	struct intel_engine_cs *engine = params->engine;
 	struct intel_ringbuffer *ringbuf = params->ctx->engine[engine->id].ringbuf;
 	u64 exec_start;
 	int instp_mode;
@@ -2172,7 +2172,7 @@ logical_ring_setup(struct drm_i915_private *dev_priv, enum intel_engine_id id)
 int intel_logical_rings_init(struct drm_device *dev)
 	unsigned int mask = 0;
 	unsigned int i;
 	int ret;
diff --git a/drivers/gpu/drm/i915/intel_lvds.c b/drivers/gpu/drm/i915/intel_lvds.c
index 681c6fd..4955047 100644
--- a/drivers/gpu/drm/i915/intel_lvds.c
+++ b/drivers/gpu/drm/i915/intel_lvds.c
@@ -72,7 +72,7 @@ static bool intel_lvds_get_hw_state(struct intel_encoder *encoder,
 				    enum pipe *pipe)
 	struct intel_lvds_encoder *lvds_encoder = to_lvds_encoder(&encoder->base);
 	u32 tmp;
@@ -106,7 +106,7 @@ static void intel_lvds_get_config(struct intel_encoder *encoder,
 	u32 tmp, flags = 0;
@@ -140,7 +140,7 @@ static void intel_pre_enable_lvds(struct intel_encoder *encoder)
@@ -216,7 +216,7 @@ static void intel_enable_lvds(struct intel_encoder *encoder)
 		&lvds_encoder->attached_connector->base;
 	i915_reg_t ctl_reg, stat_reg;
 	if (HAS_PCH_SPLIT(dev)) {
@@ -241,7 +241,7 @@ static void intel_disable_lvds(struct intel_encoder *encoder)
@@ -442,7 +442,7 @@ static int intel_lid_notify(struct notifier_block *nb, unsigned long val,
 		container_of(nb, struct intel_lvds_connector, lid_notifier);
 	struct drm_connector *connector = &lvds_connector->base.base;
 	struct drm_device *dev = connector->dev;
 	if (dev->switch_power_state != DRM_SWITCH_POWER_ON)
 		return NOTIFY_OK;
@@ -833,7 +833,7 @@ static bool compute_is_dual_link_lvds(struct intel_lvds_encoder *lvds_encoder)
 	struct drm_device *dev = lvds_encoder->base.base.dev;
 	unsigned int val;
 	/* use the module option value if specified */
 	if (i915.lvds_channel_mode > 0)
@@ -883,7 +883,7 @@ static bool intel_lvds_supported(struct drm_device *dev)
 void intel_lvds_init(struct drm_device *dev)
 	struct intel_lvds_encoder *lvds_encoder;
 	struct intel_lvds_connector *lvds_connector;
diff --git a/drivers/gpu/drm/i915/intel_modes.c b/drivers/gpu/drm/i915/intel_modes.c
index 38a4c8c..f2584d0 100644
--- a/drivers/gpu/drm/i915/intel_modes.c
+++ b/drivers/gpu/drm/i915/intel_modes.c
@@ -82,7 +82,7 @@ void
 intel_attach_force_audio_property(struct drm_connector *connector)
 	struct drm_property *prop;
 	prop = dev_priv->force_audio_property;
@@ -109,7 +109,7 @@ void
 intel_attach_broadcast_rgb_property(struct drm_connector *connector)
 	prop = dev_priv->broadcast_rgb_property;
diff --git a/drivers/gpu/drm/i915/intel_overlay.c b/drivers/gpu/drm/i915/intel_overlay.c
index eb93f90..e9887d9 100644
--- a/drivers/gpu/drm/i915/intel_overlay.c
+++ b/drivers/gpu/drm/i915/intel_overlay.c
@@ -1084,7 +1084,7 @@ int intel_overlay_put_image_ioctl(struct drm_device *dev, void *data,
 				  struct drm_file *file_priv)
 	struct drm_intel_overlay_put_image *put_image_rec = data;
 	struct intel_overlay *overlay;
 	struct drm_crtc *drmmode_crtc;
@@ -1282,7 +1282,7 @@ int intel_overlay_attrs_ioctl(struct drm_device *dev, void *data,
 	struct drm_intel_overlay_attrs *attrs = data;
 	struct overlay_registers __iomem *regs;
 	int ret;
diff --git a/drivers/gpu/drm/i915/intel_panel.c b/drivers/gpu/drm/i915/intel_panel.c
index 3c0b97f..a8b4733 100644
--- a/drivers/gpu/drm/i915/intel_panel.c
+++ b/drivers/gpu/drm/i915/intel_panel.c
@@ -377,7 +377,7 @@ out:
 enum drm_connector_status
 intel_panel_detect(struct drm_device *dev)
 	/* Assume that the BIOS does not lie through the OpRegion... */
 	if (!i915.panel_ignore_lid && dev_priv->opregion.lid_state) {
@@ -1142,7 +1142,7 @@ static int intel_backlight_device_get_brightness(struct backlight_device *bd)
 	struct intel_connector *connector = bl_get_data(bd);
 	u32 hw_level;
 	int ret;
@@ -1316,7 +1316,7 @@ static u32 i9xx_hz_to_pwm(struct intel_connector *connector, u32 pwm_freq_hz)
 static u32 i965_hz_to_pwm(struct intel_connector *connector, u32 pwm_freq_hz)
 	int clock;
 	if (IS_G4X(dev_priv))
diff --git a/drivers/gpu/drm/i915/intel_pm.c b/drivers/gpu/drm/i915/intel_pm.c
index 814b0df..0560b7c 100644
--- a/drivers/gpu/drm/i915/intel_pm.c
+++ b/drivers/gpu/drm/i915/intel_pm.c
@@ -57,7 +57,7 @@
 static void gen9_init_clock_gating(struct drm_device *dev)
 	/* See Bspec note for PSR2_CTL bit 31, Wa#828:skl,bxt,kbl */
 	I915_WRITE(CHICKEN_PAR1_1,
@@ -83,7 +83,7 @@ static void gen9_init_clock_gating(struct drm_device *dev)
 static void bxt_init_clock_gating(struct drm_device *dev)
 	gen9_init_clock_gating(dev);
@@ -109,7 +109,7 @@ static void bxt_init_clock_gating(struct drm_device *dev)
 static void i915_pineview_get_mem_freq(struct drm_device *dev)
 	u32 tmp;
 	tmp = I915_READ(CLKCFG);
@@ -148,7 +148,7 @@ static void i915_pineview_get_mem_freq(struct drm_device *dev)
 static void i915_ironlake_get_mem_freq(struct drm_device *dev)
 	u16 ddrpll, csipll;
 	ddrpll = I915_READ16(DDRMPLL1);
@@ -375,7 +375,7 @@ static const int pessimal_latency_ns = 5000;
 static int vlv_get_fifo_size(struct drm_device *dev,
 			      enum pipe pipe, int plane)
 	int sprite0_start, sprite1_start, size;
 	switch (pipe) {
@@ -426,7 +426,7 @@ static int vlv_get_fifo_size(struct drm_device *dev,
 static int i9xx_get_fifo_size(struct drm_device *dev, int plane)
 	uint32_t dsparb = I915_READ(DSPARB);
 	int size;
@@ -442,7 +442,7 @@ static int i9xx_get_fifo_size(struct drm_device *dev, int plane)
 static int i830_get_fifo_size(struct drm_device *dev, int plane)
 	int size;
@@ -459,7 +459,7 @@ static int i830_get_fifo_size(struct drm_device *dev, int plane)
 static int i845_get_fifo_size(struct drm_device *dev, int plane)
 	int size;
@@ -637,7 +637,7 @@ static struct drm_crtc *single_enabled_crtc(struct drm_device *dev)
 static void pineview_update_wm(struct drm_crtc *unused_crtc)
 	struct drm_device *dev = unused_crtc->dev;
 	const struct cxsr_latency *latency;
 	u32 reg;
@@ -934,7 +934,7 @@ static unsigned int vlv_wm_method2(unsigned int pixel_rate,
 static void vlv_setup_wm_latency(struct drm_device *dev)
 	/* all latencies in usec */
 	dev_priv->wm.pri_latency[VLV_WM_LEVEL_PM2] = 3;
@@ -1325,7 +1325,7 @@ static void vlv_merge_wm(struct drm_device *dev,
 static void vlv_update_wm(struct drm_crtc *crtc)
 	struct drm_device *dev = crtc->dev;
 	struct vlv_wm_values wm = {};
@@ -1381,7 +1381,7 @@ static void g4x_update_wm(struct drm_crtc *crtc)
 	static const int sr_latency_ns = 12000;
 	int planea_wm, planeb_wm, cursora_wm, cursorb_wm;
 	int plane_sr, cursor_sr;
 	unsigned int enabled = 0;
@@ -1438,7 +1438,7 @@ static void g4x_update_wm(struct drm_crtc *crtc)
 static void i965_update_wm(struct drm_crtc *unused_crtc)
 	int srwm = 1;
 	int cursor_sr = 16;
@@ -1512,7 +1512,7 @@ static void i965_update_wm(struct drm_crtc *unused_crtc)
 static void i9xx_update_wm(struct drm_crtc *unused_crtc)
 	const struct intel_watermark_params *wm_info;
 	uint32_t fwater_lo;
 	uint32_t fwater_hi;
@@ -1642,7 +1642,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
 static void i845_update_wm(struct drm_crtc *unused_crtc)
 	const struct drm_display_mode *adjusted_mode;
 	uint32_t fwater_lo;
@@ -2070,7 +2070,7 @@ hsw_compute_linetime_wm(const struct intel_crtc_state *cstate)
 static void intel_read_wm_latency(struct drm_device *dev, uint16_t wm[8])
 	if (IS_GEN9(dev)) {
 		uint32_t val;
@@ -2250,7 +2250,7 @@ static bool ilk_increase_wm_latency(struct drm_i915_private *dev_priv,
 static void snb_wm_latency_quirk(struct drm_device *dev)
 	bool changed;
@@ -2272,7 +2272,7 @@ static void snb_wm_latency_quirk(struct drm_device *dev)
 static void ilk_setup_wm_latency(struct drm_device *dev)
 	intel_read_wm_latency(dev, dev_priv->wm.pri_latency);
@@ -2294,7 +2294,7 @@ static void ilk_setup_wm_latency(struct drm_device *dev)
 static void skl_setup_wm_latency(struct drm_device *dev)
 	intel_read_wm_latency(dev, dev_priv->wm.skl_latency);
 	intel_print_wm_latency(dev, "Gen9 Plane", dev_priv->wm.skl_latency);
@@ -2330,7 +2330,7 @@ static int ilk_compute_pipe_wm(struct intel_crtc_state *cstate)
 	struct intel_crtc *intel_crtc = to_intel_crtc(cstate->base.crtc);
 	struct intel_pipe_wm *pipe_wm;
-	const struct drm_i915_private *dev_priv = dev->dev_private;
+	const struct drm_i915_private *dev_priv = to_i915(dev);
 	struct intel_plane *intel_plane;
 	struct intel_plane_state *pristate = NULL;
 	struct intel_plane_state *sprstate = NULL;
@@ -2505,7 +2505,7 @@ static void ilk_wm_merge(struct drm_device *dev,
 			 const struct ilk_wm_maximums *max,
 			 struct intel_pipe_wm *merged)
 	int level, max_level = ilk_wm_max_level(dev);
 	int last_enabled_level = max_level;
@@ -2565,7 +2565,7 @@ static int ilk_wm_lp_to_level(int wm_lp, const struct intel_pipe_wm *pipe_wm)
 /* The value we need to program into the WM_LPx latency field */
 static unsigned int ilk_wm_lp_latency(struct drm_device *dev, int level)
 	if (IS_HASWELL(dev) || IS_BROADWELL(dev))
 		return 2 * level;
@@ -2840,7 +2840,7 @@ static void ilk_write_wm_values(struct drm_i915_private *dev_priv,
 bool ilk_disable_lp_wm(struct drm_device *dev)
 	return _ilk_disable_lp_wm(dev_priv, WM_DIRTY_LP_ALL);
@@ -3595,7 +3595,7 @@ static int skl_build_pipe_wm(struct intel_crtc_state *cstate,
 			     struct skl_pipe_wm *pipe_wm)
 	struct drm_device *dev = cstate->base.crtc->dev;
 	int ret;
@@ -4015,7 +4015,7 @@ static void skl_update_wm(struct drm_crtc *crtc)
-	struct drm_i915_private *dev_priv = dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(dev);
 	struct skl_wm_values *results = &dev_priv->wm.skl_results;
 	struct intel_crtc_state *cstate = to_intel_crtc_state(crtc->state);
 	struct skl_pipe_wm *pipe_wm = &cstate->wm.skl.optimal;
@@ -4158,7 +4158,7 @@ static void skl_pipe_wm_active_state(uint32_t val,
 static void skl_pipe_wm_get_hw_state(struct drm_crtc *crtc)
 	struct skl_wm_values *hw = &dev_priv->wm.skl_hw;
@@ -4212,7 +4212,7 @@ static void skl_pipe_wm_get_hw_state(struct drm_crtc *crtc)
 void skl_wm_get_hw_state(struct drm_device *dev)
 	struct skl_ddb_allocation *ddb = &dev_priv->wm.skl_hw.ddb;
@@ -4232,7 +4232,7 @@ void skl_wm_get_hw_state(struct drm_device *dev)
 static void ilk_pipe_wm_get_hw_state(struct drm_crtc *crtc)
 	struct ilk_wm_values *hw = &dev_priv->wm.hw;
@@ -4436,7 +4436,7 @@ void vlv_wm_get_hw_state(struct drm_device *dev)
 void ilk_wm_get_hw_state(struct drm_device *dev)
@@ -4498,7 +4498,7 @@ void ilk_wm_get_hw_state(struct drm_device *dev)
 void intel_update_watermarks(struct drm_crtc *crtc)
-	struct drm_i915_private *dev_priv = crtc->dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(crtc->dev);
 	if (dev_priv->display.update_wm)
 		dev_priv->display.update_wm(crtc);
@@ -6713,7 +6713,7 @@ void intel_reset_gt_powersave(struct drm_i915_private *dev_priv)
 static void ibx_init_clock_gating(struct drm_device *dev)
 	 * On Ibex Peak and Cougar Point, we need to disable clock
@@ -6725,7 +6725,7 @@ static void ibx_init_clock_gating(struct drm_device *dev)
 static void g4x_disable_trickle_feed(struct drm_device *dev)
 	enum pipe pipe;
 	for_each_pipe(dev_priv, pipe) {
@@ -6740,7 +6740,7 @@ static void g4x_disable_trickle_feed(struct drm_device *dev)
 static void ilk_init_lp_watermarks(struct drm_device *dev)
 	I915_WRITE(WM3_LP_ILK, I915_READ(WM3_LP_ILK) & ~WM1_LP_SR_EN);
 	I915_WRITE(WM2_LP_ILK, I915_READ(WM2_LP_ILK) & ~WM1_LP_SR_EN);
@@ -6754,7 +6754,7 @@ static void ilk_init_lp_watermarks(struct drm_device *dev)
 static void ironlake_init_clock_gating(struct drm_device *dev)
 	uint32_t dspclk_gate = ILK_VRHUNIT_CLOCK_GATE_DISABLE;
@@ -6828,7 +6828,7 @@ static void ironlake_init_clock_gating(struct drm_device *dev)
 static void cpt_init_clock_gating(struct drm_device *dev)
 	int pipe;
 	uint32_t val;
@@ -6865,7 +6865,7 @@ static void cpt_init_clock_gating(struct drm_device *dev)
 static void gen6_check_mch_setup(struct drm_device *dev)
 	uint32_t tmp;
 	tmp = I915_READ(MCH_SSKPD);
@@ -6876,7 +6876,7 @@ static void gen6_check_mch_setup(struct drm_device *dev)
 static void gen6_init_clock_gating(struct drm_device *dev)
 	I915_WRITE(ILK_DSPCLK_GATE_D, dspclk_gate);
@@ -6991,7 +6991,7 @@ static void gen7_setup_fixed_func_scheduler(struct drm_i915_private *dev_priv)
 static void lpt_init_clock_gating(struct drm_device *dev)
 	 * TODO: this bit should only be enabled when really needed, then
@@ -7010,7 +7010,7 @@ static void lpt_init_clock_gating(struct drm_device *dev)
 static void lpt_suspend_hw(struct drm_device *dev)
 	if (HAS_PCH_LPT_LP(dev)) {
 		uint32_t val = I915_READ(SOUTH_DSPCLK_GATE_D);
@@ -7045,7 +7045,7 @@ static void gen8_set_l3sqc_credits(struct drm_i915_private *dev_priv,
 static void kabylake_init_clock_gating(struct drm_device *dev)
@@ -7066,7 +7066,7 @@ static void kabylake_init_clock_gating(struct drm_device *dev)
 static void skylake_init_clock_gating(struct drm_device *dev)
@@ -7081,7 +7081,7 @@ static void skylake_init_clock_gating(struct drm_device *dev)
 static void broadwell_init_clock_gating(struct drm_device *dev)
 	enum pipe pipe;
 	ilk_init_lp_watermarks(dev);
@@ -7132,7 +7132,7 @@ static void broadwell_init_clock_gating(struct drm_device *dev)
 static void haswell_init_clock_gating(struct drm_device *dev)
@@ -7188,7 +7188,7 @@ static void haswell_init_clock_gating(struct drm_device *dev)
 static void ivybridge_init_clock_gating(struct drm_device *dev)
 	uint32_t snpcr;
@@ -7286,7 +7286,7 @@ static void ivybridge_init_clock_gating(struct drm_device *dev)
 static void valleyview_init_clock_gating(struct drm_device *dev)
 	/* WaDisableEarlyCull:vlv */
 	I915_WRITE(_3D_CHICKEN3,
@@ -7368,7 +7368,7 @@ static void valleyview_init_clock_gating(struct drm_device *dev)
 static void cherryview_init_clock_gating(struct drm_device *dev)
 	/* WaVSRefCountFullforceMissDisable:chv */
 	/* WaDSRefCountFullforceMissDisable:chv */
@@ -7404,7 +7404,7 @@ static void cherryview_init_clock_gating(struct drm_device *dev)
 static void g4x_init_clock_gating(struct drm_device *dev)
 	uint32_t dspclk_gate;
 	I915_WRITE(RENCLK_GATE_D1, 0);
@@ -7431,7 +7431,7 @@ static void g4x_init_clock_gating(struct drm_device *dev)
 static void crestline_init_clock_gating(struct drm_device *dev)
 	I915_WRITE(RENCLK_GATE_D1, I965_RCC_CLOCK_GATE_DISABLE);
 	I915_WRITE(RENCLK_GATE_D2, 0);
@@ -7447,7 +7447,7 @@ static void crestline_init_clock_gating(struct drm_device *dev)
 static void broadwater_init_clock_gating(struct drm_device *dev)
 	I915_WRITE(RENCLK_GATE_D1, I965_RCZ_CLOCK_GATE_DISABLE |
 		   I965_RCC_CLOCK_GATE_DISABLE |
@@ -7464,7 +7464,7 @@ static void broadwater_init_clock_gating(struct drm_device *dev)
 static void gen3_init_clock_gating(struct drm_device *dev)
 	u32 dstate = I915_READ(D_STATE);
 	dstate |= DSTATE_PLL_D3_OFF | DSTATE_GFX_CLOCK_GATING |
@@ -7489,7 +7489,7 @@ static void gen3_init_clock_gating(struct drm_device *dev)
 static void i85x_init_clock_gating(struct drm_device *dev)
 	I915_WRITE(RENCLK_GATE_D1, SV_CLOCK_GATE_DISABLE);
@@ -7503,7 +7503,7 @@ static void i85x_init_clock_gating(struct drm_device *dev)
 static void i830_init_clock_gating(struct drm_device *dev)
 	I915_WRITE(DSPCLK_GATE_D, OVRUNIT_CLOCK_GATE_DISABLE);
@@ -7514,7 +7514,7 @@ static void i830_init_clock_gating(struct drm_device *dev)
 void intel_init_clock_gating(struct drm_device *dev)
 	dev_priv->display.init_clock_gating(dev);
@@ -7582,7 +7582,7 @@ void intel_init_clock_gating_hooks(struct drm_i915_private *dev_priv)
 /* Set up chip specific power management-related functions */
 void intel_init_pm(struct drm_device *dev)
 	intel_fbc_init(dev_priv);
@@ -7812,7 +7812,7 @@ void intel_queue_rps_boost_for_request(struct drm_i915_gem_request *req)
 void intel_pm_setup(struct drm_device *dev)
 	mutex_init(&dev_priv->rps.hw_lock);
 	spin_lock_init(&dev_priv->rps.client_lock);
diff --git a/drivers/gpu/drm/i915/intel_psr.c b/drivers/gpu/drm/i915/intel_psr.c
index 8d25c45..68bd0bb 100644
--- a/drivers/gpu/drm/i915/intel_psr.c
+++ b/drivers/gpu/drm/i915/intel_psr.c
@@ -63,7 +63,7 @@ static bool is_edp_psr(struct intel_dp *intel_dp)
 static bool vlv_is_psr_active_on_pipe(struct drm_device *dev, int pipe)
 	uint32_t val;
 	val = I915_READ(VLV_PSRSTAT(pipe)) &
@@ -77,7 +77,7 @@ static void intel_psr_write_vsc(struct intel_dp *intel_dp,
 	struct intel_crtc *crtc = to_intel_crtc(dig_port->base.base.crtc);
 	enum transcoder cpu_transcoder = crtc->config->cpu_transcoder;
@@ -107,7 +107,7 @@ static void vlv_psr_setup_vsc(struct intel_dp *intel_dp)
 	struct drm_crtc *crtc = intel_dig_port->base.base.crtc;
 	enum pipe pipe = to_intel_crtc(crtc)->pipe;
 	uint32_t val;
@@ -173,7 +173,7 @@ static void hsw_psr_enable_sink(struct intel_dp *intel_dp)
 	i915_reg_t aux_ctl_reg;
 	static const uint8_t aux_msg[] = {
@@ -220,7 +220,7 @@ static void vlv_psr_enable_source(struct intel_dp *intel_dp)
@@ -235,7 +235,7 @@ static void vlv_psr_activate(struct intel_dp *intel_dp)
@@ -252,7 +252,7 @@ static void hsw_psr_enable_source(struct intel_dp *intel_dp)
 	uint32_t max_sleep_time = 0x1f;
 	/* Lately it was identified that depending on panel idle frame count
@@ -324,7 +324,7 @@ static bool intel_psr_match_conditions(struct intel_dp *intel_dp)
@@ -378,7 +378,7 @@ static void intel_psr_activate(struct intel_dp *intel_dp)
 	WARN_ON(I915_READ(EDP_PSR_CTL) & EDP_PSR_ENABLE);
 	WARN_ON(dev_priv->psr.active);
@@ -407,7 +407,7 @@ void intel_psr_enable(struct intel_dp *intel_dp)
 	if (!HAS_PSR(dev)) {
@@ -494,7 +494,7 @@ static void vlv_psr_disable(struct intel_dp *intel_dp)
 	uint32_t val;
@@ -524,7 +524,7 @@ static void hsw_psr_disable(struct intel_dp *intel_dp)
 	if (dev_priv->psr.active) {
 		I915_WRITE(EDP_PSR_CTL,
@@ -554,7 +554,7 @@ void intel_psr_disable(struct intel_dp *intel_dp)
 	mutex_lock(&dev_priv->psr.lock);
 	if (!dev_priv->psr.enabled) {
@@ -630,7 +630,7 @@ unlock:
 static void intel_psr_exit(struct drm_device *dev)
 	struct intel_dp *intel_dp = dev_priv->psr.enabled;
 	struct drm_crtc *crtc = dp_to_dig_port(intel_dp)->base.base.crtc;
@@ -685,7 +685,7 @@ static void intel_psr_exit(struct drm_device *dev)
 void intel_psr_single_frame_update(struct drm_device *dev,
 	struct drm_crtc *crtc;
 	enum pipe pipe;
 	u32 val;
@@ -733,7 +733,7 @@ void intel_psr_single_frame_update(struct drm_device *dev,
 void intel_psr_invalidate(struct drm_device *dev,
 	enum pipe pipe;
@@ -771,7 +771,7 @@ void intel_psr_invalidate(struct drm_device *dev,
 void intel_psr_flush(struct drm_device *dev,
 		     unsigned frontbuffer_bits, enum fb_op_origin origin)
 	enum pipe pipe;
@@ -807,7 +807,7 @@ void intel_psr_flush(struct drm_device *dev,
 void intel_psr_init(struct drm_device *dev)
 	dev_priv->psr_mmio_base = IS_HASWELL(dev_priv) ?
 		HSW_EDP_PSR_BASE : BDW_EDP_PSR_BASE;
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.c b/drivers/gpu/drm/i915/intel_ringbuffer.c
index 3fafc35..428ed62 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.c
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.c
@@ -2837,7 +2837,7 @@ static void intel_ring_default_vfuncs(struct drm_i915_private *dev_priv,
 int intel_init_render_ring_buffer(struct drm_device *dev)
 	struct intel_engine_cs *engine = &dev_priv->engine[RCS];
 	int ret;
@@ -2899,7 +2899,7 @@ int intel_init_render_ring_buffer(struct drm_device *dev)
 int intel_init_bsd_ring_buffer(struct drm_device *dev)
 	struct intel_engine_cs *engine = &dev_priv->engine[VCS];
 	engine->name = "bsd ring";
@@ -2937,7 +2937,7 @@ int intel_init_bsd_ring_buffer(struct drm_device *dev)
 int intel_init_bsd2_ring_buffer(struct drm_device *dev)
 	struct intel_engine_cs *engine = &dev_priv->engine[VCS2];
 	engine->name = "bsd2 ring";
@@ -2957,7 +2957,7 @@ int intel_init_bsd2_ring_buffer(struct drm_device *dev)
 int intel_init_blt_ring_buffer(struct drm_device *dev)
 	struct intel_engine_cs *engine = &dev_priv->engine[BCS];
 	engine->name = "blitter ring";
@@ -2980,7 +2980,7 @@ int intel_init_blt_ring_buffer(struct drm_device *dev)
 int intel_init_vebox_ring_buffer(struct drm_device *dev)
 	struct intel_engine_cs *engine = &dev_priv->engine[VECS];
 	engine->name = "video enhancement ring";
diff --git a/drivers/gpu/drm/i915/intel_sdvo.c b/drivers/gpu/drm/i915/intel_sdvo.c
index ba28f51..321121e 100644
--- a/drivers/gpu/drm/i915/intel_sdvo.c
+++ b/drivers/gpu/drm/i915/intel_sdvo.c
@@ -240,7 +240,7 @@ intel_sdvo_create_enhance_property(struct intel_sdvo *intel_sdvo,
 static void intel_sdvo_write_sdvox(struct intel_sdvo *intel_sdvo, u32 val)
 	struct drm_device *dev = intel_sdvo->base.base.dev;
 	u32 bval = val, cval = val;
 	int i;
@@ -1195,7 +1195,7 @@ static bool intel_sdvo_compute_config(struct intel_encoder *encoder,
 static void intel_sdvo_pre_enable(struct intel_encoder *intel_encoder)
 	struct intel_crtc *crtc = to_intel_crtc(intel_encoder->base.crtc);
 	struct drm_display_mode *mode = &crtc->config->base.mode;
@@ -1330,7 +1330,7 @@ static bool intel_sdvo_get_hw_state(struct intel_encoder *encoder,
 				    enum pipe *pipe)
 	struct intel_sdvo *intel_sdvo = to_sdvo(encoder);
 	u16 active_outputs = 0;
 	u32 tmp;
@@ -1353,7 +1353,7 @@ static void intel_sdvo_get_config(struct intel_encoder *encoder,
 				  struct intel_crtc_state *pipe_config)
 	struct intel_sdvo_dtd dtd;
 	int encoder_pixel_multiplier = 0;
@@ -1436,7 +1436,7 @@ static void intel_sdvo_get_config(struct intel_encoder *encoder,
 static void intel_disable_sdvo(struct intel_encoder *encoder)
-	struct drm_i915_private *dev_priv = encoder->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(encoder->base.dev);
 	u32 temp;
@@ -1489,7 +1489,7 @@ static void pch_post_disable_sdvo(struct intel_encoder *encoder)
 static void intel_enable_sdvo(struct intel_encoder *encoder)
 	struct intel_crtc *intel_crtc = to_intel_crtc(encoder->base.crtc);
 	u32 temp;
@@ -1633,7 +1633,7 @@ intel_sdvo_get_edid(struct drm_connector *connector)
 static struct edid *
 intel_sdvo_get_analog_edid(struct drm_connector *connector)
 	return drm_get_edid(connector,
 			    intel_gmbus_get_adapter(dev_priv,
@@ -1916,7 +1916,7 @@ static void intel_sdvo_get_tv_modes(struct drm_connector *connector)
 static void intel_sdvo_get_lvds_modes(struct drm_connector *connector)
 	struct intel_sdvo *intel_sdvo = intel_attached_sdvo(connector);
 	struct drm_display_mode *newmode;
 	DRM_DEBUG_KMS("[CONNECTOR:%d:%s]\n",
@@ -2001,7 +2001,7 @@ intel_sdvo_set_property(struct drm_connector *connector,
 	struct intel_sdvo_connector *intel_sdvo_connector = to_intel_sdvo_connector(connector);
 	uint16_t temp_value;
 	uint8_t cmd;
 	int ret;
@@ -2338,7 +2338,7 @@ intel_sdvo_is_hdmi_connector(struct intel_sdvo *intel_sdvo, int device)
 static u8
 intel_sdvo_get_slave_addr(struct drm_device *dev, struct intel_sdvo *sdvo)
 	struct sdvo_device_mapping *my_mapping, *other_mapping;
 	if (sdvo->port == PORT_B) {
@@ -2952,7 +2952,7 @@ static void assert_sdvo_port_valid(const struct drm_i915_private *dev_priv,
 bool intel_sdvo_init(struct drm_device *dev,
 		     i915_reg_t sdvo_reg, enum port port)
 	struct intel_encoder *intel_encoder;
 	struct intel_sdvo *intel_sdvo;
 	int i;
diff --git a/drivers/gpu/drm/i915/intel_sprite.c b/drivers/gpu/drm/i915/intel_sprite.c
index fc65417..0de935a 100644
--- a/drivers/gpu/drm/i915/intel_sprite.c
+++ b/drivers/gpu/drm/i915/intel_sprite.c
@@ -199,7 +199,7 @@ skl_update_plane(struct drm_plane *drm_plane,
 		 const struct intel_plane_state *plane_state)
 	struct drm_device *dev = drm_plane->dev;
 	struct intel_plane *intel_plane = to_intel_plane(drm_plane);
 	struct drm_framebuffer *fb = plane_state->base.fb;
 	struct drm_i915_gem_object *obj = intel_fb_obj(fb);
 skl_disable_plane(struct drm_plane *dplane, struct drm_crtc *crtc)
 	struct drm_device *dev = dplane->dev;
 	struct intel_plane *intel_plane = to_intel_plane(dplane);
 	const int pipe = intel_plane->pipe;
 	const int plane = intel_plane->plane + 1;
@@ -317,7 +317,7 @@ skl_disable_plane(struct drm_plane *dplane, struct drm_crtc *crtc)
 static void
 chv_update_csc(struct intel_plane *intel_plane, uint32_t format)
-	struct drm_i915_private *dev_priv = intel_plane->base.dev->dev_private;
+	struct drm_i915_private *dev_priv = to_i915(intel_plane->base.dev);
 	int plane = intel_plane->plane;
 	/* Seems RGB data bypasses the CSC always */
@@ -359,7 +359,7 @@ vlv_update_plane(struct drm_plane *dplane,
@@ -485,7 +485,7 @@ static void
 vlv_disable_plane(struct drm_plane *dplane, struct drm_crtc *crtc)
@@ -502,7 +502,7 @@ ivb_update_plane(struct drm_plane *plane,
 	struct drm_device *dev = plane->dev;
 	struct intel_plane *intel_plane = to_intel_plane(plane);
@@ -624,7 +624,7 @@ static void
 ivb_disable_plane(struct drm_plane *plane, struct drm_crtc *crtc)
@@ -643,7 +643,7 @@ ilk_update_plane(struct drm_plane *plane,
@@ -753,7 +753,7 @@ static void
 ilk_disable_plane(struct drm_plane *plane, struct drm_crtc *crtc)
diff --git a/drivers/gpu/drm/i915/intel_tv.c b/drivers/gpu/drm/i915/intel_tv.c
index 1531904..49136ad 100644
--- a/drivers/gpu/drm/i915/intel_tv.c
+++ b/drivers/gpu/drm/i915/intel_tv.c
@@ -826,7 +826,7 @@ static bool
 intel_tv_get_hw_state(struct intel_encoder *encoder, enum pipe *pipe)
 	u32 tmp = I915_READ(TV_CTL);
 	if (!(tmp & TV_ENC_ENABLE))
@@ -841,7 +841,7 @@ static void
 intel_enable_tv(struct intel_encoder *encoder)
 	/* Prevents vblank waits from timing out in intel_tv_detect_type() */
 	intel_wait_for_vblank(encoder->base.dev,
@@ -854,7 +854,7 @@ static void
 intel_disable_tv(struct intel_encoder *encoder)
 	I915_WRITE(TV_CTL, I915_READ(TV_CTL) & ~TV_ENC_ENABLE);
@@ -1013,7 +1013,7 @@ static void set_color_conversion(struct drm_i915_private *dev_priv,
 static void intel_tv_pre_enable(struct intel_encoder *encoder)
 	struct intel_tv *intel_tv = enc_to_tv(encoder);
 	const struct tv_mode *tv_mode = intel_tv_mode_find(intel_tv);
@@ -1173,7 +1173,7 @@ intel_tv_detect_type(struct intel_tv *intel_tv,
 	struct drm_crtc *crtc = connector->state->crtc;
 	u32 tv_ctl, save_tv_ctl;
 	u32 tv_dac, save_tv_dac;
 	int type;
@@ -1523,7 +1523,7 @@ static const struct drm_encoder_funcs intel_tv_enc_funcs = {
 void
 intel_tv_init(struct drm_device *dev)
 	struct drm_connector *connector;
 	struct intel_tv *intel_tv;
diff --git a/drivers/gpu/drm/i915/intel_uncore.c b/drivers/gpu/drm/i915/intel_uncore.c
index 19d759e..1d65209 100644
--- a/drivers/gpu/drm/i915/intel_uncore.c
+++ b/drivers/gpu/drm/i915/intel_uncore.c
@@ -1409,7 +1409,7 @@ static const struct register_whitelist {
 int i915_reg_read_ioctl(struct drm_device *dev,
 			void *data, struct drm_file *file)
 	struct drm_i915_reg_read *reg = data;
 	struct register_whitelist const *entry = whitelist;
 	unsigned size;
BtrLinux
Privacy Overview
