drm/i915: fix simple_return.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/gpu/drm/i915/intel_ringbuffer.c:435:1-4: WARNING: end returns can be simpified
 Simplify a trivial if-return sequence.  Possibly combine with a
 preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
CC: Paulo Zanoni
Signed-off-by: Fengguang Wu
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/intel_ringbuffer.c | 6 +-----
 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.c b/drivers/gpu/drm/i915/intel_ringbuffer.c
index e9858d2..441e250 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.c
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.c
@@ -432,11 +432,7 @@ gen8_render_ring_flush(struct intel_engine_cs *ring,
 			return ret;
-	ret = gen8_emit_pipe_control(ring, flags, scratch_addr);
-	if (ret)
-		return ret;
-	return 0;
+	return gen8_emit_pipe_control(ring, flags, scratch_addr);
 static void ring_write_tail(struct intel_engine_cs *ring,
BtrLinux
Privacy Overview
