drm/i915: fix handling gen8_emit_flush_coherentl3_wa result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Reviewed-by: Jani Nikula
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/intel_lrc.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/gpu/drm/i915/intel_lrc.c b/drivers/gpu/drm/i915/intel_lrc.c
index fe06accb0..ff9a481 100644
--- a/drivers/gpu/drm/i915/intel_lrc.c
+++ b/drivers/gpu/drm/i915/intel_lrc.c
@@ -1254,9 +1254,10 @@ static int gen8_init_indirectctx_bb(struct intel_engine_cs *ring,
 	/* WaFlushCoherentL3CacheLinesAtContextSwitch:bdw */
 	if (IS_BROADWELL(ring->dev)) {
-		index = gen8_emit_flush_coherentl3_wa(ring, batch, index);
-		if (index < 0)
-			return index;
+		int rc = gen8_emit_flush_coherentl3_wa(ring, batch, index);
+		if (rc < 0)
+			return rc;
+		index = rc;
 	/* WaClearSlmSpaceAtContextSwitch:bdw,chv */
BtrLinux
Privacy Overview
