drm/i915: Acquire dpio_lock for VLV sideband programming in DP/HDMI
Author: Chris Wilson <chris@chris-wilson.co.uk>
Otherwise we get flooded by the kernel warning us that we are doing
long sequences of IO without serialisation. For example,
 WARNING: CPU: 0 PID: 11136 at drivers/gpu/drm/i915/intel_sideband.c:40 vlv_sideband_rw+0x48/0x1ef()
 Modules linked in:
 CPU: 0 PID: 11136 Comm: kworker/u2:0 Tainted: G        W    3.11.0-rc2+ #4
 Call Trace:
  [] ?  warn_slowpath_common+0x63/0x78
  [] ?  vlv_sideband_rw+0x48/0x1ef
  [] ?  warn_slowpath_null+0xf/0x13
  [] ?  vlv_dpio_write+0x1c/0x21
  [] ?  intel_dp_set_signal_levels+0x24a/0x385
  [] ?  intel_dp_complete_link_train+0x25/0x1d1
  [] ?  intel_dp_check_link_status+0xf7/0x106
  [] ?  i915_hotplug_work_func+0x17b/0x221
  [] ?  process_one_work+0x12e/0x210
  [] ?  worker_thread+0x116/0x1ad
  [] ?  rescuer_thread+0x1cb/0x1cb
  [] ?  kthread+0x67/0x6c
  [] ?  ret_from_kernel_thread+0x1b/0x30
  [] ?  init_completion+0x18/0x18
v2: Retire the locking in vlv_crtc_enable() and do it close to the meat.
Signed-off-by: Chris Wilson
Reviewed-by: Jani Nikula
[danvet: Squash in a s/mutex_lock/mutex_unlock/ fixup spotted by the 0
day kernel build/coccinelle and reported by Dan Carpenter.]
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/i915/intel_display.c | 4 ----
 drivers/gpu/drm/i915/intel_dp.c      | 6 ++++++
 drivers/gpu/drm/i915/intel_hdmi.c    | 4 ++++
 3 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index dc7ad2a..9c59b42 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -3652,8 +3652,6 @@ static void valleyview_crtc_enable(struct drm_crtc *crtc)
 	intel_crtc->active = true;
 	intel_update_watermarks(dev);
-	mutex_lock(&dev_priv->dpio_lock);
 	for_each_encoder_on_crtc(dev, crtc, encoder)
 		if (encoder->pre_pll_enable)
 			encoder->pre_pll_enable(encoder);
@@ -3678,8 +3676,6 @@ static void valleyview_crtc_enable(struct drm_crtc *crtc)
 	intel_crtc_update_cursor(crtc, true);
 	intel_update_fbc(dev);
-	mutex_unlock(&dev_priv->dpio_lock);
 static void i9xx_crtc_enable(struct drm_crtc *crtc)
diff --git a/drivers/gpu/drm/i915/intel_dp.c b/drivers/gpu/drm/i915/intel_dp.c
index e5eeec3..d96360d 100644
--- a/drivers/gpu/drm/i915/intel_dp.c
+++ b/drivers/gpu/drm/i915/intel_dp.c
@@ -1727,6 +1727,7 @@ static void intel_pre_enable_dp(struct intel_encoder *encoder)
 		int pipe = intel_crtc->pipe;
 		u32 val;
+		mutex_lock(&dev_priv->dpio_lock);
 		val = vlv_dpio_read(dev_priv, DPIO_DATA_LANE_A(port));
 		val = 0;
 		if (pipe)
@@ -1740,6 +1741,7 @@ static void intel_pre_enable_dp(struct intel_encoder *encoder)
 				 0x00760018);
 		vlv_dpio_write(dev_priv, DPIO_PCS_CLOCKBUF8(port),
 				 0x00400888);
+		mutex_unlock(&dev_priv->dpio_lock);
@@ -1754,6 +1756,7 @@ static void intel_dp_pre_pll_enable(struct intel_encoder *encoder)
 		return;
 	/* Program Tx lane resets to default */
 	vlv_dpio_write(dev_priv, DPIO_PCS_TX(port),
 			 DPIO_PCS_TX_LANE2_RESET |
 			 DPIO_PCS_TX_LANE1_RESET);
@@ -1767,6 +1770,7 @@ static void intel_dp_pre_pll_enable(struct intel_encoder *encoder)
 	vlv_dpio_write(dev_priv, DPIO_PCS_STAGGER1(port), 0x00750f00);
 	vlv_dpio_write(dev_priv, DPIO_TX_CTL(port), 0x00001500);
 	vlv_dpio_write(dev_priv, DPIO_TX_LANE(port), 0x40400000);
@@ -1978,6 +1982,7 @@ static uint32_t intel_vlv_signal_levels(struct intel_dp *intel_dp)
 		return 0;
 	vlv_dpio_write(dev_priv, DPIO_TX_OCALINIT(port), 0x00000000);
 	vlv_dpio_write(dev_priv, DPIO_TX_SWING_CTL4(port), demph_reg_value);
 	vlv_dpio_write(dev_priv, DPIO_TX_SWING_CTL2(port),
@@ -1986,6 +1991,7 @@ static uint32_t intel_vlv_signal_levels(struct intel_dp *intel_dp)
 	vlv_dpio_write(dev_priv, DPIO_PCS_STAGGER0(port), 0x00030000);
 	vlv_dpio_write(dev_priv, DPIO_PCS_CTL_OVER1(port), preemph_reg_value);
 	vlv_dpio_write(dev_priv, DPIO_TX_OCALINIT(port), 0x80000000);
 	return 0;
diff --git a/drivers/gpu/drm/i915/intel_hdmi.c b/drivers/gpu/drm/i915/intel_hdmi.c
index c16fb34..847ff20 100644
--- a/drivers/gpu/drm/i915/intel_hdmi.c
+++ b/drivers/gpu/drm/i915/intel_hdmi.c
@@ -1019,6 +1019,7 @@ static void intel_hdmi_pre_enable(struct intel_encoder *encoder)
 		return;
 	/* Enable clock channels for this port */
 	val = 0;
 	if (pipe)
@@ -1049,6 +1050,7 @@ static void intel_hdmi_pre_enable(struct intel_encoder *encoder)
 			 0x00760018);
 			 0x00400888);
 static void intel_hdmi_pre_pll_enable(struct intel_encoder *encoder)
@@ -1062,6 +1064,7 @@ static void intel_hdmi_pre_pll_enable(struct intel_encoder *encoder)
 		return;
@@ -1080,6 +1083,7 @@ static void intel_hdmi_pre_pll_enable(struct intel_encoder *encoder)
 			 0x00002000);
 			 DPIO_TX_OCALINIT_EN);
 static void intel_hdmi_post_disable(struct intel_encoder *encoder)
