drm/hdlcd: Delete an unnecessary check before drm_fbdev_cma_hotplug_event()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_fbdev_cma_hotplug_event() function tests whether its argument
is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/c2b0f310-fa06-f4cc-0014-ea7f40564d26@users.sourceforge.net
 drivers/gpu/drm/arm/hdlcd_drv.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/arm/hdlcd_drv.c b/drivers/gpu/drm/arm/hdlcd_drv.c
index 74279be..d83b46a 100644
--- a/drivers/gpu/drm/arm/hdlcd_drv.c
+++ b/drivers/gpu/drm/arm/hdlcd_drv.c
@@ -102,8 +102,7 @@ static void hdlcd_fb_output_poll_changed(struct drm_device *drm)
 	struct hdlcd_drm_private *hdlcd = drm->dev_private;
-	if (hdlcd->fbdev)
-		drm_fbdev_cma_hotplug_event(hdlcd->fbdev);
+	drm_fbdev_cma_hotplug_event(hdlcd->fbdev);
 static const struct drm_mode_config_funcs hdlcd_mode_config_funcs = { |
-	if (hdlcd->fbdev)
