drm/edid: Deletion of an unnecessary check before the function call “release_firmware”
Author: Markus Elfring <elfring@users.sourceforge.net>
The release_firmware() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Reviewed-by: Thierry Reding
Signed-off-by: Dave Airlie
 drivers/gpu/drm/drm_edid_load.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/drm_edid_load.c b/drivers/gpu/drm/drm_edid_load.c
index 0a235fe..732cb6f 100644
--- a/drivers/gpu/drm/drm_edid_load.c
+++ b/drivers/gpu/drm/drm_edid_load.c
@@ -254,8 +254,7 @@ static void *edid_load(struct drm_connector *connector, const char *name,
 	    name, connector_name);
 out:
-	if (fw)
-		release_firmware(fw);
+	release_firmware(fw);
 	return edid;
BtrLinux
Privacy Overview
