drm/bridge: ptn3460: Fix coccinelle warnings
Author: kbuild test robot <fengguang.wu@intel.com>
The platform_no_drv_owner.cocci coccinelle script generates the
following warning:
	drivers/gpu/drm/bridge/nxp-ptn3460.c:403:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically. Patch
generated by scripts/coccinelle/api/platform_no_drv_owner.cocci.
Signed-off-by: Fengguang Wu
Signed-off-by: Thierry Reding
 drivers/gpu/drm/bridge/nxp-ptn3460.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/gpu/drm/bridge/nxp-ptn3460.c b/drivers/gpu/drm/bridge/nxp-ptn3460.c
index 1b1bf23..0ffa3a6 100644
--- a/drivers/gpu/drm/bridge/nxp-ptn3460.c
+++ b/drivers/gpu/drm/bridge/nxp-ptn3460.c
@@ -400,7 +400,6 @@ static struct i2c_driver ptn3460_driver = {
 	.remove		= ptn3460_remove,
 	.driver		= {
 		.name	= "nxp,ptn3460",
-		.owner	= THIS_MODULE,
 		.of_match_table = ptn3460_match,
BtrLinux
Privacy Overview
