drm/bridge: ps8622: Fix coccinelle warnings
Author: kbuild test robot <fengguang.wu@intel.com>
The platform_no_drv_owner.cocci coccinelle script generates the
following warning:
	drivers/gpu/drm/bridge/parade-ps8622.c:671:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically. Patch
generated by scripts/coccinelle/api/platform_no_drv_owner.cocci.
Signed-off-by: Fengguang Wu
Signed-off-by: Thierry Reding
 drivers/gpu/drm/bridge/parade-ps8622.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/gpu/drm/bridge/parade-ps8622.c b/drivers/gpu/drm/bridge/parade-ps8622.c
index 1a6607b..be881e9 100644
--- a/drivers/gpu/drm/bridge/parade-ps8622.c
+++ b/drivers/gpu/drm/bridge/parade-ps8622.c
@@ -668,7 +668,6 @@ static struct i2c_driver ps8622_driver = {
 	.remove		= ps8622_remove,
 	.driver		= {
 		.name	= "ps8622",
-		.owner	= THIS_MODULE,
 		.of_match_table = ps8622_devices,
BtrLinux
Privacy Overview
