drm/arcpgu: Delete an unnecessary check before drm_fbdev_cma_hotplug_event()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_fbdev_cma_hotplug_event() function tests whether its argument
is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/dd9a16b1-234c-6776-e6d9-943a8457334e@users.sourceforge.net
drivers/gpu/drm/arc/arcpgu_drv.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/arc/arcpgu_drv.c b/drivers/gpu/drm/arc/arcpgu_drv.c
index 0226ec0..20a5f2c 100644
--- a/drivers/gpu/drm/arc/arcpgu_drv.c
+++ b/drivers/gpu/drm/arc/arcpgu_drv.c
@@ -28,8 +28,7 @@ static void arcpgu_fb_output_poll_changed(struct drm_device *dev)
struct arcpgu_drm_private *arcpgu = dev->dev_private;
- if (arcpgu->fbdev)
- drm_fbdev_cma_hotplug_event(arcpgu->fbdev);
+ drm_fbdev_cma_hotplug_event(arcpgu->fbdev);
static struct drm_mode_config_funcs arcpgu_drm_modecfg_funcs = { |
