drm/amdkfd: Remove unnecessary cast in kfree
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Remove an unnecassary cast in the argument to kfree.
Found using Coccinelle. The semantic patch used to find this is as follows:
type T;
expression *f;
- kfree((T *)(f));
+ kfree(f);
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Oded Gabbay
 drivers/gpu/drm/amd/amdkfd/kfd_process.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpu/drm/amd/amdkfd/kfd_process.c b/drivers/gpu/drm/amd/amdkfd/kfd_process.c
index 9be0070..a902ae0 100644
--- a/drivers/gpu/drm/amd/amdkfd/kfd_process.c
+++ b/drivers/gpu/drm/amd/amdkfd/kfd_process.c
@@ -194,7 +194,7 @@ static void kfd_process_wq_release(struct work_struct *work)
 	kfree(p);
-	kfree((void *)work);
+	kfree(work);
 static void kfd_process_destroy_delayed(struct rcu_head *rcu)
