drm/amdgpu: use kmemdup rather than duplicating its implementation
Author: Andrzej Hajda <a.hajda@samsung.com>
The patch was generated using fixed coccinelle semantic patch
scripts/coccinelle/api/memdup.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2014320
Signed-off-by: Andrzej Hajda
Reviewed-by: Christian König
Signed-off-by: Alex Deucher
 drivers/gpu/drm/amd/amdgpu/amdgpu_object.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/gpu/drm/amd/amdgpu/amdgpu_object.c b/drivers/gpu/drm/amd/amdgpu/amdgpu_object.c
index f25cfed..1a7708f 100644
--- a/drivers/gpu/drm/amd/amdgpu/amdgpu_object.c
+++ b/drivers/gpu/drm/amd/amdgpu/amdgpu_object.c
@@ -536,12 +536,10 @@ int amdgpu_bo_set_metadata (struct amdgpu_bo *bo, void *metadata,
 	if (metadata == NULL)
 		return -EINVAL;
-	buffer = kzalloc(metadata_size, GFP_KERNEL);
+	buffer = kmemdup(metadata, metadata_size, GFP_KERNEL);
 	if (buffer == NULL)
 		return -ENOMEM;
-	memcpy(buffer, metadata, metadata_size);
 	kfree(bo->metadata);
 	bo->metadata_flags = flags;
 	bo->metadata = buffer;
BtrLinux
Privacy Overview
