drivers/gpu/drm/drm_edid.c | 21 ++++++++++++---------
drivers/gpu/drm/sti/sti_vtac.c | 12 ++++++++++--
2 files changed, 22 insertions(+), 11 deletions(-)
diff --git a/drivers/gpu/drm/drm_edid.c b/drivers/gpu/drm/drm_edid.c
index f905c63..daf3cd8 100644
--- a/drivers/gpu/drm/drm_edid.c
+++ b/drivers/gpu/drm/drm_edid.c
@@ -2103,7 +2103,8 @@ static int
add_inferred_modes(struct drm_connector *connector, struct edid *edid)
struct detailed_mode_closure closure = {
- connector, edid, 0, 0, 0
+ .connector = connector,
+ .edid = edid,
if (version_greater(edid, 1, 0))
@@ -2169,7 +2170,8 @@ add_established_modes(struct drm_connector *connector, struct edid *edid)
((edid->established_timings.mfg_rsvd & 0x80) << 9);
int i, modes = 0;
+ .edid = edid,
for (i = 0; i <= EDID_EST_TIMINGS; i++) {
@@ -2227,7 +2229,8 @@ add_standard_modes(struct drm_connector *connector, struct edid *edid)
int i, modes = 0;
+ .edid = edid,
for (i = 0; i < EDID_STD_TIMINGS; i++) {
@@ -2313,7 +2316,8 @@ static int
add_cvt_modes(struct drm_connector *connector, struct edid *edid)
+ .edid = edid,
if (version_greater(edid, 1, 2))
@@ -2357,11 +2361,10 @@ add_detailed_modes(struct drm_connector *connector, struct edid *edid,
u32 quirks)
- connector,
- edid,
- 1,
- quirks,
- 0
+ .edid = edid,
+ .preferred = 1,
+ .quirks = quirks,
if (closure.preferred && !version_greater(edid, 1, 3))
diff --git a/drivers/gpu/drm/sti/sti_vtac.c b/drivers/gpu/drm/sti/sti_vtac.c
index 82a51d4..97bcdac 100644
--- a/drivers/gpu/drm/sti/sti_vtac.c
+++ b/drivers/gpu/drm/sti/sti_vtac.c
@@ -56,8 +56,16 @@ struct sti_vtac_mode {
u32 phyts_per_pixel;
-static const struct sti_vtac_mode vtac_mode_main = {0x2, 0x2, VTAC_5_PPP};
-static const struct sti_vtac_mode vtac_mode_aux = {0x1, 0x0, VTAC_17_PPP};
+static const struct sti_vtac_mode vtac_mode_main = {
+ .vid_in_width = 0x2,
+ .phyts_width = 0x2,
+ .phyts_per_pixel = VTAC_5_PPP,
+static const struct sti_vtac_mode vtac_mode_aux = {
+ .vid_in_width = 0x1,
+ .phyts_width = 0x0,
+ .phyts_per_pixel = VTAC_17_PPP,
* VTAC structure |
