drivers/gpu/drm/armada/armada_crtc.c | 23 ++++++------
drivers/gpu/drm/ast/ast_mode.c | 12 +++----
drivers/gpu/drm/bochs/bochs_kms.c | 4 +--
drivers/gpu/drm/cirrus/cirrus_mode.c | 10 +++---
drivers/gpu/drm/drm_crtc.c | 26 +++++++-------
drivers/gpu/drm/drm_crtc_helper.c | 20 +++++------
drivers/gpu/drm/drm_fb_helper.c | 6 ++--
drivers/gpu/drm/exynos/exynos_drm_crtc.c | 20 +++++------
drivers/gpu/drm/gma500/cdv_intel_display.c | 2 +-
drivers/gpu/drm/gma500/cdv_intel_dp.c | 2 +-
drivers/gpu/drm/gma500/cdv_intel_hdmi.c | 2 +-
drivers/gpu/drm/gma500/cdv_intel_lvds.c | 2 +-
drivers/gpu/drm/gma500/gma_display.c | 16 ++++-----
drivers/gpu/drm/gma500/mdfld_dsi_output.c | 2 +-
drivers/gpu/drm/gma500/mdfld_intel_display.c | 16 ++++-----
drivers/gpu/drm/gma500/oaktrail_crtc.c | 12 +++----
drivers/gpu/drm/gma500/psb_intel_display.c | 2 +-
drivers/gpu/drm/gma500/psb_intel_lvds.c | 2 +-
drivers/gpu/drm/gma500/psb_intel_sdvo.c | 2 +-
drivers/gpu/drm/i915/i915_debugfs.c | 4 +--
drivers/gpu/drm/i915/i915_irq.c | 4 +--
drivers/gpu/drm/i915/intel_display.c | 52 ++++++++++++++--------------
drivers/gpu/drm/i915/intel_dp.c | 4 +--
drivers/gpu/drm/i915/intel_overlay.c | 4 +--
drivers/gpu/drm/i915/intel_pm.c | 36 +++++++++----------
drivers/gpu/drm/mgag200/mgag200_mode.c | 26 +++++++-------
drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c | 28 +++++++--------
drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c | 22 ++++++------
drivers/gpu/drm/nouveau/dispnv04/crtc.c | 20 +++++------
drivers/gpu/drm/nouveau/dispnv04/dfp.c | 2 +-
drivers/gpu/drm/nouveau/nouveau_display.c | 8 ++---
drivers/gpu/drm/nouveau/nv50_display.c | 17 ++++-----
drivers/gpu/drm/omapdrm/omap_crtc.c | 13 +++----
drivers/gpu/drm/omapdrm/omap_fb.c | 2 +-
drivers/gpu/drm/qxl/qxl_display.c | 10 +++---
drivers/gpu/drm/radeon/atombios_crtc.c | 20 +++++------
drivers/gpu/drm/radeon/r100.c | 4 +--
drivers/gpu/drm/radeon/radeon_connectors.c | 2 +-
drivers/gpu/drm/radeon/radeon_device.c | 2 +-
drivers/gpu/drm/radeon/radeon_display.c | 4 +--
drivers/gpu/drm/radeon/radeon_legacy_crtc.c | 16 ++++-----
drivers/gpu/drm/rcar-du/rcar_du_crtc.c | 10 +++---
drivers/gpu/drm/shmobile/shmob_drm_crtc.c | 14 ++++----
drivers/gpu/drm/tegra/dc.c | 16 ++++-----
drivers/gpu/drm/tilcdc/tilcdc_crtc.c | 8 ++---
drivers/gpu/drm/udl/udl_modeset.c | 2 +-
drivers/gpu/drm/vmwgfx/vmwgfx_kms.c | 14 ++++----
drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c | 8 ++---
drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c | 8 ++---
drivers/staging/imx-drm/ipuv3-crtc.c | 6 ++--
50 files changed, 285 insertions(+), 282 deletions(-)
diff --git a/drivers/gpu/drm/armada/armada_crtc.c b/drivers/gpu/drm/armada/armada_crtc.c
index d8e3982..5831e41 100644
--- a/drivers/gpu/drm/armada/armada_crtc.c
+++ b/drivers/gpu/drm/armada/armada_crtc.c
@@ -478,11 +478,12 @@ static int armada_drm_crtc_mode_set(struct drm_crtc *crtc,
unsigned i;
bool interlaced;
- drm_framebuffer_reference(crtc->fb);
+ drm_framebuffer_reference(crtc->primary->fb);
interlaced = !!(adj->flags & DRM_MODE_FLAG_INTERLACE);
- i = armada_drm_crtc_calc_fb(dcrtc->crtc.fb, x, y, regs, interlaced);
+ i = armada_drm_crtc_calc_fb(dcrtc->crtc.primary->fb,
+ x, y, regs, interlaced);
rm = adj->crtc_hsync_start - adj->crtc_hdisplay;
lm = adj->crtc_htotal - adj->crtc_hsync_end;
@@ -567,10 +568,10 @@ static int armada_drm_crtc_mode_set(struct drm_crtc *crtc,
val = CFG_GRA_ENA | CFG_GRA_HSMOOTH;
- val |= CFG_GRA_FMT(drm_fb_to_armada_fb(dcrtc->crtc.fb)->fmt);
- val |= CFG_GRA_MOD(drm_fb_to_armada_fb(dcrtc->crtc.fb)->mod);
+ val |= CFG_GRA_FMT(drm_fb_to_armada_fb(dcrtc->crtc.primary->fb)->fmt);
+ val |= CFG_GRA_MOD(drm_fb_to_armada_fb(dcrtc->crtc.primary->fb)->mod);
- if (drm_fb_to_armada_fb(dcrtc->crtc.fb)->fmt > CFG_420)
+ if (drm_fb_to_armada_fb(dcrtc->crtc.primary->fb)->fmt > CFG_420)
val |= CFG_PALETTE_ENA;
if (interlaced)
@@ -608,7 +609,7 @@ static int armada_drm_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
struct armada_regs regs[4];
unsigned i;
- i = armada_drm_crtc_calc_fb(crtc->fb, crtc->x, crtc->y, regs,
+ i = armada_drm_crtc_calc_fb(crtc->primary->fb, crtc->x, crtc->y, regs,
dcrtc->interlaced);
armada_reg_queue_end(regs, i);
@@ -616,7 +617,7 @@ static int armada_drm_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
wait_event(dcrtc->frame_wait, !dcrtc->frame_work);
/* Take a reference to the new fb as we're using it */
/* Update the base in the CRTC */
armada_drm_crtc_update_regs(dcrtc, regs);
@@ -637,7 +638,7 @@ static void armada_drm_crtc_disable(struct drm_crtc *crtc)
struct armada_crtc *dcrtc = drm_to_armada_crtc(crtc);
armada_drm_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
- armada_drm_crtc_finish_fb(dcrtc, crtc->fb, true);
+ armada_drm_crtc_finish_fb(dcrtc, crtc->primary->fb, true);
/* Power down most RAMs and FIFOs */
writel_relaxed(CFG_PDWN256x32 | CFG_PDWN256x24 | CFG_PDWN256x8 |
@@ -904,7 +905,7 @@ static int armada_drm_crtc_page_flip(struct drm_crtc *crtc,
int ret;
/* We don't support changing the pixel format */
- if (fb->pixel_format != crtc->fb->pixel_format)
+ if (fb->pixel_format != crtc->primary->fb->pixel_format)
return -EINVAL;
work = kmalloc(sizeof(*work), GFP_KERNEL);
@@ -912,7 +913,7 @@ static int armada_drm_crtc_page_flip(struct drm_crtc *crtc,
return -ENOMEM;
work->event = event;
- work->old_fb = dcrtc->crtc.fb;
+ work->old_fb = dcrtc->crtc.primary->fb;
i = armada_drm_crtc_calc_fb(fb, crtc->x, crtc->y, work->regs,
dcrtc->interlaced);
@@ -941,7 +942,7 @@ static int armada_drm_crtc_page_flip(struct drm_crtc *crtc,
* will _not_ drop that reference on successful return from this
* function. Simply mark this new framebuffer as the current one.
- dcrtc->crtc.fb = fb;
+ dcrtc->crtc.primary->fb = fb;
* Finally, if the display is blanked, we won't receive an
diff --git a/drivers/gpu/drm/ast/ast_mode.c b/drivers/gpu/drm/ast/ast_mode.c
index cca063b..a4afdc8 100644
--- a/drivers/gpu/drm/ast/ast_mode.c
+++ b/drivers/gpu/drm/ast/ast_mode.c
@@ -81,7 +81,7 @@ static bool ast_get_vbios_mode_info(struct drm_crtc *crtc, struct drm_display_mo
u32 refresh_rate_index = 0, mode_id, color_index, refresh_rate;
u32 hborder, vborder;
- switch (crtc->fb->bits_per_pixel) {
+ switch (crtc->primary->fb->bits_per_pixel) {
case 8:
vbios_mode->std_table = &vbios_stdtable[VGAModeIndex];
color_index = VGAModeIndex - 1;
@@ -176,7 +176,7 @@ static bool ast_get_vbios_mode_info(struct drm_crtc *crtc, struct drm_display_mo
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x8e, mode_id & 0xff);
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x91, 0xa8);
- ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x92, crtc->fb->bits_per_pixel);
+ ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x92, crtc->primary->fb->bits_per_pixel);
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x93, adjusted_mode->clock / 1000);
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x94, adjusted_mode->crtc_hdisplay);
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x95, adjusted_mode->crtc_hdisplay >> 8);
@@ -340,7 +340,7 @@ static void ast_set_offset_reg(struct drm_crtc *crtc)
u16 offset;
- offset = crtc->fb->pitches[0] >> 3;
+ offset = crtc->primary->fb->pitches[0] >> 3;
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0x13, (offset & 0xff));
ast_set_index_reg(ast, AST_IO_CRTC_PORT, 0xb0, (offset >> 8) & 0x3f);
@@ -365,7 +365,7 @@ static void ast_set_ext_reg(struct drm_crtc *crtc, struct drm_display_mode *mode
struct ast_private *ast = crtc->dev->dev_private;
u8 jregA0 = 0, jregA3 = 0, jregA8 = 0;
case 8:
jregA0 = 0x70;
jregA3 = 0x01;
@@ -418,7 +418,7 @@ static void ast_set_sync_reg(struct drm_device *dev, struct drm_display_mode *mo
static bool ast_set_dac_reg(struct drm_crtc *crtc, struct drm_display_mode *mode,
struct ast_vbios_mode_info *vbios_mode)
case 8:
break;
default:
@@ -490,7 +490,7 @@ static int ast_crtc_do_set_base(struct drm_crtc *crtc,
ast_bo_unreserve(bo);
- ast_fb = to_ast_framebuffer(crtc->fb);
+ ast_fb = to_ast_framebuffer(crtc->primary->fb);
obj = ast_fb->obj;
bo = gem_to_ast_bo(obj);
diff --git a/drivers/gpu/drm/bochs/bochs_kms.c b/drivers/gpu/drm/bochs/bochs_kms.c
index 62ec7d4..dcf2e55 100644
--- a/drivers/gpu/drm/bochs/bochs_kms.c
+++ b/drivers/gpu/drm/bochs/bochs_kms.c
@@ -62,10 +62,10 @@ static int bochs_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
- if (WARN_ON(crtc->fb == NULL))
+ if (WARN_ON(crtc->primary->fb == NULL))
return -EINVAL;
- bochs_fb = to_bochs_framebuffer(crtc->fb);
+ bochs_fb = to_bochs_framebuffer(crtc->primary->fb);
bo = gem_to_bochs_bo(bochs_fb->obj);
ret = ttm_bo_reserve(&bo->bo, true, false, false, 0);
if (ret)
diff --git a/drivers/gpu/drm/cirrus/cirrus_mode.c b/drivers/gpu/drm/cirrus/cirrus_mode.c
index 530f78f..2d64aea 100644
--- a/drivers/gpu/drm/cirrus/cirrus_mode.c
+++ b/drivers/gpu/drm/cirrus/cirrus_mode.c
@@ -149,7 +149,7 @@ static int cirrus_crtc_do_set_base(struct drm_crtc *crtc,
cirrus_bo_unreserve(bo);
- cirrus_fb = to_cirrus_framebuffer(crtc->fb);
+ cirrus_fb = to_cirrus_framebuffer(crtc->primary->fb);
obj = cirrus_fb->obj;
bo = gem_to_cirrus_bo(obj);
@@ -268,7 +268,7 @@ static int cirrus_crtc_mode_set(struct drm_crtc *crtc,
sr07 = RREG8(SEQ_DATA);
sr07 &= 0xe0;
hdr = 0;
case 8:
sr07 |= 0x11;
break;
@@ -291,13 +291,13 @@ static int cirrus_crtc_mode_set(struct drm_crtc *crtc,
WREG_SEQ(0x7, sr07);
/* Program the pitch */
- tmp = crtc->fb->pitches[0] / 8;
+ tmp = crtc->primary->fb->pitches[0] / 8;
WREG_CRT(VGA_CRTC_OFFSET, tmp);
/* Enable extended blanking and pitch bits, and enable full memory */
tmp = 0x22;
- tmp |= (crtc->fb->pitches[0] >> 7) & 0x10;
- tmp |= (crtc->fb->pitches[0] >> 6) & 0x40;
+ tmp |= (crtc->primary->fb->pitches[0] >> 7) & 0x10;
+ tmp |= (crtc->primary->fb->pitches[0] >> 6) & 0x40;
WREG_CRT(0x1b, tmp);
/* Enable high-colour modes */
diff --git a/drivers/gpu/drm/drm_crtc.c b/drivers/gpu/drm/drm_crtc.c
index 110e5ce..18321fb 100644
--- a/drivers/gpu/drm/drm_crtc.c
+++ b/drivers/gpu/drm/drm_crtc.c
@@ -669,7 +669,7 @@ void drm_framebuffer_remove(struct drm_framebuffer *fb)
drm_modeset_lock_all(dev);
/* remove from any CRTC */
list_for_each_entry(crtc, &dev->mode_config.crtc_list, head) {
- if (crtc->fb == fb) {
+ if (crtc->primary->fb == fb) {
/* should turn off the crtc */
memset(&set, 0, sizeof(struct drm_mode_set));
set.crtc = crtc;
@@ -1714,8 +1714,8 @@ int drm_mode_getcrtc(struct drm_device *dev,
crtc_resp->x = crtc->x;
crtc_resp->y = crtc->y;
crtc_resp->gamma_size = crtc->gamma_size;
- if (crtc->fb)
- crtc_resp->fb_id = crtc->fb->base.id;
+ if (crtc->primary->fb)
+ crtc_resp->fb_id = crtc->primary->fb->base.id;
else
crtc_resp->fb_id = 0;
@@ -2222,7 +2222,7 @@ int drm_mode_set_config_internal(struct drm_mode_set *set)
* crtcs. Atomic modeset will have saner semantics ...
list_for_each_entry(tmp, &crtc->dev->mode_config.crtc_list, head)
- tmp->old_fb = tmp->fb;
+ tmp->old_fb = tmp->primary->fb;
fb = set->fb;
@@ -2231,12 +2231,12 @@ int drm_mode_set_config_internal(struct drm_mode_set *set)
crtc->primary->crtc = crtc;
/* crtc->fb must be updated by ->set_config, enforces this. */
- WARN_ON(fb != crtc->fb);
+ WARN_ON(fb != crtc->primary->fb);
list_for_each_entry(tmp, &crtc->dev->mode_config.crtc_list, head) {
- if (tmp->fb)
- drm_framebuffer_reference(tmp->fb);
+ if (tmp->primary->fb)
+ drm_framebuffer_reference(tmp->primary->fb);
if (tmp->old_fb)
drm_framebuffer_unreference(tmp->old_fb);
@@ -2340,12 +2340,12 @@ int drm_mode_setcrtc(struct drm_device *dev, void *data,
/* If we have a mode we need a framebuffer. */
/* If we pass -1, set the mode with the currently bound fb */
if (crtc_req->fb_id == -1) {
- if (!crtc->fb) {
+ if (!crtc->primary->fb) {
DRM_DEBUG_KMS("CRTC doesn't have current FB\n");
ret = -EINVAL;
goto out;
- fb = crtc->fb;
+ fb = crtc->primary->fb;
/* Make refcounting symmetric with the lookup path. */
drm_framebuffer_reference(fb);
} else {
@@ -4139,7 +4139,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
crtc = obj_to_crtc(obj);
mutex_lock(&crtc->mutex);
- if (crtc->fb == NULL) {
+ if (crtc->primary->fb == NULL) {
/* The framebuffer is currently unbound, presumably
* due to a hotplug event, that userspace has not
* yet discovered.
@@ -4161,7 +4161,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
if (ret)
goto out;
- if (crtc->fb->pixel_format != fb->pixel_format) {
+ if (crtc->primary->fb->pixel_format != fb->pixel_format) {
DRM_DEBUG_KMS("Page flip is not allowed to change frame buffer format.\n");
ret = -EINVAL;
goto out;
@@ -4194,7 +4194,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
(void (*) (struct drm_pending_event *)) kfree;
- old_fb = crtc->fb;
+ old_fb = crtc->primary->fb;
ret = crtc->funcs->page_flip(crtc, fb, e, page_flip->flags);
if (ret) {
if (page_flip->flags & DRM_MODE_PAGE_FLIP_EVENT) {
@@ -4212,7 +4212,7 @@ int drm_mode_page_flip_ioctl(struct drm_device *dev,
* Failing to do so will screw with the reference counting
* on framebuffers.
- WARN_ON(crtc->fb != fb);
+ WARN_ON(crtc->primary->fb != fb);
/* Unref only the old framebuffer. */
fb = NULL;
diff --git a/drivers/gpu/drm/drm_crtc_helper.c b/drivers/gpu/drm/drm_crtc_helper.c
index c0f2d62..2dd806b 100644
--- a/drivers/gpu/drm/drm_crtc_helper.c
+++ b/drivers/gpu/drm/drm_crtc_helper.c
@@ -309,7 +309,7 @@ static void __drm_helper_disable_unused_functions(struct drm_device *dev)
(*crtc_funcs->disable)(crtc);
else
(*crtc_funcs->dpms)(crtc, DRM_MODE_DPMS_OFF);
- crtc->fb = NULL;
+ crtc->primary->fb = NULL;
@@ -653,19 +653,19 @@ int drm_crtc_helper_set_config(struct drm_mode_set *set)
save_set.mode = &set->crtc->mode;
save_set.x = set->crtc->x;
save_set.y = set->crtc->y;
- save_set.fb = set->crtc->fb;
+ save_set.fb = set->crtc->primary->fb;
/* We should be able to check here if the fb has the same properties
* and then just flip_or_move it */
- if (set->crtc->fb != set->fb) {
+ if (set->crtc->primary->fb != set->fb) {
/* If we have no fb then treat it as a full mode set */
- if (set->crtc->fb == NULL) {
+ if (set->crtc->primary->fb == NULL) {
DRM_DEBUG_KMS("crtc has no fb, full mode set\n");
mode_changed = true;
} else if (set->fb == NULL) {
} else if (set->fb->pixel_format !=
- set->crtc->fb->pixel_format) {
+ set->crtc->primary->fb->pixel_format) {
} else
fb_changed = true;
@@ -766,13 +766,13 @@ int drm_crtc_helper_set_config(struct drm_mode_set *set)
DRM_DEBUG_KMS("attempting to set mode from"
" userspace\n");
drm_mode_debug_printmodeline(set->mode);
- set->crtc->fb = set->fb;
+ set->crtc->primary->fb = set->fb;
if (!drm_crtc_helper_set_mode(set->crtc, set->mode,
set->x, set->y,
save_set.fb)) {
DRM_ERROR("failed to set mode on [CRTC:%d]\n",
set->crtc->base.id);
- set->crtc->fb = save_set.fb;
+ set->crtc->primary->fb = save_set.fb;
ret = -EINVAL;
goto fail;
@@ -787,13 +787,13 @@ int drm_crtc_helper_set_config(struct drm_mode_set *set)
} else if (fb_changed) {
set->crtc->x = set->x;
set->crtc->y = set->y;
ret = crtc_funcs->mode_set_base(set->crtc,
set->x, set->y, save_set.fb);
if (ret != 0) {
set->crtc->x = save_set.x;
set->crtc->y = save_set.y;
goto fail;
@@ -990,7 +990,7 @@ void drm_helper_resume_force_mode(struct drm_device *dev)
continue;
ret = drm_crtc_helper_set_mode(crtc, &crtc->mode,
- crtc->x, crtc->y, crtc->fb);
+ crtc->x, crtc->y, crtc->primary->fb);
/* Restoring the old config should never fail! */
if (ret == false)
diff --git a/drivers/gpu/drm/drm_fb_helper.c b/drivers/gpu/drm/drm_fb_helper.c
index f30bf7b..9795c06 100644
--- a/drivers/gpu/drm/drm_fb_helper.c
+++ b/drivers/gpu/drm/drm_fb_helper.c
@@ -232,7 +232,7 @@ static struct drm_framebuffer *drm_mode_config_fb(struct drm_crtc *crtc)
list_for_each_entry(c, &dev->mode_config.crtc_list, head) {
if (crtc->base.id == c->base.id)
- return c->fb;
+ return c->primary->fb;
return NULL;
@@ -366,9 +366,9 @@ static bool drm_fb_helper_is_bound(struct drm_fb_helper *fb_helper)
return false;
- if (crtc->fb)
crtcs_bound++;
- if (crtc->fb == fb_helper->fb)
+ if (crtc->primary->fb == fb_helper->fb)
bound++;
diff --git a/drivers/gpu/drm/exynos/exynos_drm_crtc.c b/drivers/gpu/drm/exynos/exynos_drm_crtc.c
index 5c9afa1..e930d4f 100644
--- a/drivers/gpu/drm/exynos/exynos_drm_crtc.c
+++ b/drivers/gpu/drm/exynos/exynos_drm_crtc.c
@@ -132,19 +132,19 @@ exynos_drm_crtc_mode_set(struct drm_crtc *crtc, struct drm_display_mode *mode,
memcpy(&crtc->mode, adjusted_mode, sizeof(*adjusted_mode));
- crtc_w = crtc->fb->width - x;
- crtc_h = crtc->fb->height - y;
+ crtc_w = crtc->primary->fb->width - x;
+ crtc_h = crtc->primary->fb->height - y;
if (manager->ops->mode_set)
manager->ops->mode_set(manager, &crtc->mode);
- ret = exynos_plane_mode_set(plane, crtc, crtc->fb, 0, 0, crtc_w, crtc_h,
+ ret = exynos_plane_mode_set(plane, crtc, crtc->primary->fb, 0, 0, crtc_w, crtc_h,
x, y, crtc_w, crtc_h);
if (ret)
return ret;
plane->crtc = crtc;
- plane->fb = crtc->fb;
+ plane->fb = crtc->primary->fb;
return 0;
@@ -164,10 +164,10 @@ static int exynos_drm_crtc_mode_set_commit(struct drm_crtc *crtc, int x, int y,
return -EPERM;
if (ret)
return ret;
@@ -218,7 +218,7 @@ static int exynos_drm_crtc_page_flip(struct drm_crtc *crtc,
struct drm_device *dev = crtc->dev;
struct exynos_drm_private *dev_priv = dev->dev_private;
struct exynos_drm_crtc *exynos_crtc = to_exynos_crtc(crtc);
- struct drm_framebuffer *old_fb = crtc->fb;
+ struct drm_framebuffer *old_fb = crtc->primary->fb;
int ret = -EINVAL;
/* when the page flip is requested, crtc's dpms should be on */
@@ -249,11 +249,11 @@ static int exynos_drm_crtc_page_flip(struct drm_crtc *crtc,
atomic_set(&exynos_crtc->pending_flip, 1);
spin_unlock_irq(&dev->event_lock);
- crtc->fb = fb;
+ crtc->primary->fb = fb;
ret = exynos_drm_crtc_mode_set_commit(crtc, crtc->x, crtc->y,
NULL);
if (ret) {
- crtc->fb = old_fb;
+ crtc->primary->fb = old_fb;
spin_lock_irq(&dev->event_lock);
drm_vblank_put(dev, exynos_crtc->pipe);
diff --git a/drivers/gpu/drm/gma500/cdv_intel_display.c b/drivers/gpu/drm/gma500/cdv_intel_display.c
index 7ff91ce..6672732 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_display.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_display.c
@@ -469,7 +469,7 @@ static bool cdv_intel_pipe_enabled(struct drm_device *dev, int pipe)
crtc = dev_priv->pipe_to_crtc_mapping[pipe];
gma_crtc = to_gma_crtc(crtc);
- if (crtc->fb == NULL || !gma_crtc->active)
+ if (crtc->primary->fb == NULL || !gma_crtc->active)
return false;
return true;
diff --git a/drivers/gpu/drm/gma500/cdv_intel_dp.c b/drivers/gpu/drm/gma500/cdv_intel_dp.c
index 0490ce3..9ff30c2 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_dp.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_dp.c
@@ -1693,7 +1693,7 @@ done:
struct drm_crtc *crtc = encoder->base.crtc;
crtc->x, crtc->y,
- crtc->fb);
+ crtc->primary->fb);
return 0;
diff --git a/drivers/gpu/drm/gma500/cdv_intel_hdmi.c b/drivers/gpu/drm/gma500/cdv_intel_hdmi.c
index 968b42a..b99084b 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_hdmi.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_hdmi.c
@@ -192,7 +192,7 @@ static int cdv_hdmi_set_property(struct drm_connector *connector,
crtc->saved_mode.vdisplay != 0) {
if (centre) {
if (!drm_crtc_helper_set_mode(encoder->crtc, &crtc->saved_mode,
- encoder->crtc->x, encoder->crtc->y, encoder->crtc->fb))
+ encoder->crtc->x, encoder->crtc->y, encoder->crtc->primary->fb))
return -1;
} else {
struct drm_encoder_helper_funcs *helpers
diff --git a/drivers/gpu/drm/gma500/cdv_intel_lvds.c b/drivers/gpu/drm/gma500/cdv_intel_lvds.c
index 66a41c0..8ecc920 100644
--- a/drivers/gpu/drm/gma500/cdv_intel_lvds.c
+++ b/drivers/gpu/drm/gma500/cdv_intel_lvds.c
@@ -494,7 +494,7 @@ static int cdv_intel_lvds_set_property(struct drm_connector *connector,
&crtc->saved_mode,
encoder->crtc->x,
encoder->crtc->y,
- encoder->crtc->fb))
+ encoder->crtc->primary->fb))
return -1;
} else if (!strcmp(property->name, "backlight") && encoder) {
diff --git a/drivers/gpu/drm/gma500/gma_display.c b/drivers/gpu/drm/gma500/gma_display.c
index d45476b..9bb9bdd 100644
--- a/drivers/gpu/drm/gma500/gma_display.c
+++ b/drivers/gpu/drm/gma500/gma_display.c
@@ -59,7 +59,7 @@ int gma_pipe_set_base(struct drm_crtc *crtc, int x, int y,
struct drm_psb_private *dev_priv = dev->dev_private;
struct gma_crtc *gma_crtc = to_gma_crtc(crtc);
- struct psb_framebuffer *psbfb = to_psb_fb(crtc->fb);
+ struct psb_framebuffer *psbfb = to_psb_fb(crtc->primary->fb);
int pipe = gma_crtc->pipe;
const struct psb_offset *map = &dev_priv->regmap[pipe];
unsigned long start, offset;
@@ -70,7 +70,7 @@ int gma_pipe_set_base(struct drm_crtc *crtc, int x, int y,
return 0;
/* no fb bound */
- if (!crtc->fb) {
dev_err(dev->dev, "No FB bound\n");
goto gma_pipe_cleaner;
@@ -81,19 +81,19 @@ int gma_pipe_set_base(struct drm_crtc *crtc, int x, int y,
if (ret < 0)
goto gma_pipe_set_base_exit;
start = psbfb->gtt->offset;
- offset = y * crtc->fb->pitches[0] + x * (crtc->fb->bits_per_pixel / 8);
+ offset = y * crtc->primary->fb->pitches[0] + x * (crtc->primary->fb->bits_per_pixel / 8);
- REG_WRITE(map->stride, crtc->fb->pitches[0]);
+ REG_WRITE(map->stride, crtc->primary->fb->pitches[0]);
dspcntr = REG_READ(map->cntr);
dspcntr &= ~DISPPLANE_PIXFORMAT_MASK;
case 8:
dspcntr |= DISPPLANE_8BPP;
break;
case 16:
- if (crtc->fb->depth == 15)
+ if (crtc->primary->fb->depth == 15)
dspcntr |= DISPPLANE_15_16BPP;
else
dspcntr |= DISPPLANE_16BPP;
@@ -518,8 +518,8 @@ void gma_crtc_disable(struct drm_crtc *crtc)
crtc_funcs->dpms(crtc, DRM_MODE_DPMS_OFF);
- if (crtc->fb) {
- gt = to_psb_fb(crtc->fb)->gtt;
+ if (crtc->primary->fb) {
+ gt = to_psb_fb(crtc->primary->fb)->gtt;
psb_gtt_unpin(gt);
diff --git a/drivers/gpu/drm/gma500/mdfld_dsi_output.c b/drivers/gpu/drm/gma500/mdfld_dsi_output.c
index 860a4ee..6e91b20 100644
--- a/drivers/gpu/drm/gma500/mdfld_dsi_output.c
+++ b/drivers/gpu/drm/gma500/mdfld_dsi_output.c
@@ -287,7 +287,7 @@ static int mdfld_dsi_connector_set_property(struct drm_connector *connector,
&gma_crtc->saved_mode,
encoder->crtc->x,
encoder->crtc->y,
goto set_prop_error;
} else {
struct drm_encoder_helper_funcs *funcs =
diff --git a/drivers/gpu/drm/gma500/mdfld_intel_display.c b/drivers/gpu/drm/gma500/mdfld_intel_display.c
index 321c00a..8cc8a5a 100644
--- a/drivers/gpu/drm/gma500/mdfld_intel_display.c
+++ b/drivers/gpu/drm/gma500/mdfld_intel_display.c
@@ -166,7 +166,7 @@ static int mdfld__intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
@@ -178,12 +178,12 @@ static int mdfld__intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
dev_dbg(dev->dev, "pipe = 0x%x.\n", pipe);
/* no fb bound */
- if (!crtc->fb) {
dev_dbg(dev->dev, "No FB bound\n");
return 0;
- ret = check_fb(crtc->fb);
+ ret = check_fb(crtc->primary->fb);
if (ret)
return ret;
@@ -196,18 +196,18 @@ static int mdfld__intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
return 0;
case 8:
break;
case 16:
else
@@ -700,7 +700,7 @@ static int mdfld_crtc_mode_set(struct drm_crtc *crtc,
#endif
if (ret)
return ret;
diff --git a/drivers/gpu/drm/gma500/oaktrail_crtc.c b/drivers/gpu/drm/gma500/oaktrail_crtc.c
index 8195e85..2de216c 100644
--- a/drivers/gpu/drm/gma500/oaktrail_crtc.c
+++ b/drivers/gpu/drm/gma500/oaktrail_crtc.c
@@ -599,7 +599,7 @@ static int oaktrail_pipe_set_base(struct drm_crtc *crtc,
@@ -608,7 +608,7 @@ static int oaktrail_pipe_set_base(struct drm_crtc *crtc,
int ret = 0;
/* no fb bound */
- if (!crtc->fb) {
return 0;
@@ -617,19 +617,19 @@ static int oaktrail_pipe_set_base(struct drm_crtc *crtc,
return 0;
case 8:
break;
case 16:
else
diff --git a/drivers/gpu/drm/gma500/psb_intel_display.c b/drivers/gpu/drm/gma500/psb_intel_display.c
index 21aed85..87b50ba 100644
--- a/drivers/gpu/drm/gma500/psb_intel_display.c
+++ b/drivers/gpu/drm/gma500/psb_intel_display.c
@@ -120,7 +120,7 @@ static int psb_intel_crtc_mode_set(struct drm_crtc *crtc,
const struct gma_limit_t *limit;
/* No scan out no play */
crtc_funcs->mode_set_base(crtc, x, y, old_fb);
return 0;
diff --git a/drivers/gpu/drm/gma500/psb_intel_lvds.c b/drivers/gpu/drm/gma500/psb_intel_lvds.c
index 891a028..d7778d0 100644
--- a/drivers/gpu/drm/gma500/psb_intel_lvds.c
+++ b/drivers/gpu/drm/gma500/psb_intel_lvds.c
@@ -614,7 +614,7 @@ int psb_intel_lvds_set_property(struct drm_connector *connector,
&crtc->saved_mode,
encoder->crtc->x,
encoder->crtc->y,
} else if (!strcmp(property->name, "backlight")) {
diff --git a/drivers/gpu/drm/gma500/psb_intel_sdvo.c b/drivers/gpu/drm/gma500/psb_intel_sdvo.c
index 681efec..deeb082 100644
--- a/drivers/gpu/drm/gma500/psb_intel_sdvo.c
+++ b/drivers/gpu/drm/gma500/psb_intel_sdvo.c
@@ -1844,7 +1844,7 @@ done:
if (psb_intel_sdvo->base.base.crtc) {
struct drm_crtc *crtc = psb_intel_sdvo->base.base.crtc;
drm_crtc_helper_set_mode(crtc, &crtc->mode, crtc->x,
- crtc->y, crtc->fb);
+ crtc->y, crtc->primary->fb);
return 0;
diff --git a/drivers/gpu/drm/i915/i915_debugfs.c b/drivers/gpu/drm/i915/i915_debugfs.c
index a90d31c..cacd497 100644
--- a/drivers/gpu/drm/i915/i915_debugfs.c
+++ b/drivers/gpu/drm/i915/i915_debugfs.c
@@ -2172,8 +2172,8 @@ static void intel_crtc_info(struct seq_file *m, struct intel_crtc *intel_crtc)
struct intel_encoder *intel_encoder;
seq_printf(m, "\tfb: %d, pos: %dx%d, size: %dx%d\n",
- crtc->fb->base.id, crtc->x, crtc->y,
- crtc->fb->width, crtc->fb->height);
+ crtc->primary->fb->base.id, crtc->x, crtc->y,
+ crtc->primary->fb->width, crtc->primary->fb->height);
for_each_encoder_on_crtc(dev, crtc, intel_encoder)
intel_encoder_info(m, intel_crtc, intel_encoder);
diff --git a/drivers/gpu/drm/i915/i915_irq.c b/drivers/gpu/drm/i915/i915_irq.c
index be2713f..15d5e61 100644
--- a/drivers/gpu/drm/i915/i915_irq.c
+++ b/drivers/gpu/drm/i915/i915_irq.c
@@ -2367,8 +2367,8 @@ static void __always_unused i915_pageflip_stall_check(struct drm_device *dev, in
} else {
int dspaddr = DSPADDR(intel_crtc->plane);
stall_detected = I915_READ(dspaddr) == (i915_gem_obj_ggtt_offset(obj) +
- crtc->y * crtc->fb->pitches[0] +
- crtc->x * crtc->fb->bits_per_pixel/8);
+ crtc->y * crtc->primary->fb->pitches[0] +
+ crtc->x * crtc->primary->fb->bits_per_pixel/8);
spin_unlock_irqrestore(&dev->event_lock, flags);
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index ea66dc2..3ffe5a6 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -744,7 +744,7 @@ bool intel_crtc_active(struct drm_crtc *crtc)
* We can ditch the crtc->fb check as soon as we can
* properly reconstruct framebuffers.
- return intel_crtc->active && crtc->fb &&
+ return intel_crtc->active && crtc->primary->fb &&
intel_crtc->config.adjusted_mode.crtc_clock;
@@ -2291,8 +2291,8 @@ void intel_display_handle_reset(struct drm_device *dev)
* disabling them without disabling the entire crtc) allow again
* a NULL crtc->fb.
- if (intel_crtc->active && crtc->fb)
- dev_priv->display.update_plane(crtc, crtc->fb,
+ if (intel_crtc->active && crtc->primary->fb)
+ dev_priv->display.update_plane(crtc, crtc->primary->fb,
crtc->x, crtc->y);
mutex_unlock(&crtc->mutex);
@@ -2417,8 +2417,8 @@ intel_pipe_set_base(struct drm_crtc *crtc, int x, int y,
return ret;
- crtc->fb = fb;
crtc->x = x;
crtc->y = y;
@@ -3009,7 +3009,7 @@ static void intel_crtc_wait_for_pending_flips(struct drm_crtc *crtc)
struct drm_i915_private *dev_priv = dev->dev_private;
return;
WARN_ON(waitqueue_active(&dev_priv->pending_flip_queue));
@@ -3018,7 +3018,7 @@ static void intel_crtc_wait_for_pending_flips(struct drm_crtc *crtc)
!intel_crtc_has_pending_flip(crtc));
mutex_lock(&dev->struct_mutex);
- intel_finish_fb(crtc->fb);
+ intel_finish_fb(crtc->primary->fb);
mutex_unlock(&dev->struct_mutex);
@@ -4466,11 +4466,11 @@ static void intel_crtc_disable(struct drm_crtc *crtc)
assert_cursor_disabled(dev_priv, to_intel_crtc(crtc)->pipe);
assert_pipe_disabled(dev->dev_private, to_intel_crtc(crtc)->pipe);
- if (crtc->fb) {
- intel_unpin_fb_obj(to_intel_framebuffer(crtc->fb)->obj);
+ intel_unpin_fb_obj(to_intel_framebuffer(crtc->primary->fb)->obj);
- crtc->fb = NULL;
/* Update computed state. */
@@ -8249,7 +8249,7 @@ void intel_mark_idle(struct drm_device *dev)
goto out;
- if (!crtc->fb)
continue;
intel_decrease_pllclock(crtc);
@@ -8272,10 +8272,10 @@ void intel_mark_fb_busy(struct drm_i915_gem_object *obj,
return;
- if (!crtc->fb)
continue;
- if (to_intel_framebuffer(crtc->fb)->obj != obj)
+ if (to_intel_framebuffer(crtc->primary->fb)->obj != obj)
continue;
intel_increase_pllclock(crtc);
@@ -8703,7 +8703,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
struct drm_i915_gem_object *obj = to_intel_framebuffer(fb)->obj;
struct intel_crtc *intel_crtc = to_intel_crtc(crtc);
struct intel_unpin_work *work;
@@ -8711,7 +8711,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
int ret;
/* Can't change pixel format via MI display flips. */
return -EINVAL;
@@ -8719,8 +8719,8 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
* Note that pitch changes could also affect these register.
if (INTEL_INFO(dev)->gen > 3 &&
- (fb->offsets[0] != crtc->fb->offsets[0] ||
- fb->pitches[0] != crtc->fb->pitches[0]))
+ (fb->offsets[0] != crtc->primary->fb->offsets[0] ||
+ fb->pitches[0] != crtc->primary->fb->pitches[0]))
return -EINVAL;
if (i915_terminally_wedged(&dev_priv->gpu_error))
@@ -8763,7 +8763,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
drm_gem_object_reference(&work->old_fb_obj->base);
drm_gem_object_reference(&obj->base);
- crtc->fb = fb;
work->pending_flip_obj = obj;
@@ -8786,7 +8786,7 @@ static int intel_crtc_page_flip(struct drm_crtc *crtc,
cleanup_pending:
atomic_dec(&intel_crtc->unpin_work_count);
drm_gem_object_unreference(&work->old_fb_obj->base);
drm_gem_object_unreference(&obj->base);
@@ -9803,7 +9803,7 @@ static int intel_set_mode(struct drm_crtc *crtc,
void intel_crtc_restore_mode(struct drm_crtc *crtc)
- intel_set_mode(crtc, &crtc->mode, crtc->x, crtc->y, crtc->fb);
+ intel_set_mode(crtc, &crtc->mode, crtc->x, crtc->y, crtc->primary->fb);
#undef for_each_intel_crtc_masked
@@ -9927,9 +9927,9 @@ intel_set_config_compute_mode_changes(struct drm_mode_set *set,
if (is_crtc_connector_off(set)) {
config->mode_changed = true;
- } else if (set->crtc->fb != set->fb) {
+ } else if (set->crtc->primary->fb != set->fb) {
to_intel_crtc(set->crtc);
@@ -9943,7 +9943,7 @@ intel_set_config_compute_mode_changes(struct drm_mode_set *set,
} else {
config->fb_changed = true;
@@ -10156,7 +10156,7 @@ static int intel_crtc_set_config(struct drm_mode_set *set)
/* Compute whether we need a full modeset, only an fb base update or no
* change at all. In the future we might also check whether only the
@@ -11473,7 +11473,7 @@ void intel_modeset_setup_hw_state(struct drm_device *dev,
__intel_set_mode(crtc, &crtc->mode, crtc->x, crtc->y,
- crtc->fb);
} else {
intel_modeset_update_staged_output_state(dev);
@@ -11522,7 +11522,7 @@ void intel_modeset_cleanup(struct drm_device *dev)
/* Skip inactive CRTCs */
- if (!crtc->fb)
continue;
diff --git a/drivers/gpu/drm/i915/intel_dp.c b/drivers/gpu/drm/i915/intel_dp.c
index f2833de..f2fedc0 100644
--- a/drivers/gpu/drm/i915/intel_dp.c
+++ b/drivers/gpu/drm/i915/intel_dp.c
@@ -1744,7 +1744,7 @@ static bool intel_edp_psr_match_conditions(struct intel_dp *intel_dp)
struct drm_crtc *crtc = dig_port->base.base.crtc;
- struct drm_i915_gem_object *obj = to_intel_framebuffer(crtc->fb)->obj;
+ struct drm_i915_gem_object *obj = to_intel_framebuffer(crtc->primary->fb)->obj;
struct intel_encoder *intel_encoder = &dp_to_dig_port(intel_dp)->base;
dev_priv->psr.source_ok = false;
@@ -1777,7 +1777,7 @@ static bool intel_edp_psr_match_conditions(struct intel_dp *intel_dp)
return false;
- obj = to_intel_framebuffer(crtc->fb)->obj;
+ obj = to_intel_framebuffer(crtc->primary->fb)->obj;
if (obj->tiling_mode != I915_TILING_X ||
obj->fence_reg == I915_FENCE_REG_NONE) {
DRM_DEBUG_KMS("PSR condition failed: fb not tiled or fenced\n");
diff --git a/drivers/gpu/drm/i915/intel_overlay.c b/drivers/gpu/drm/i915/intel_overlay.c
index 312961a..623cd32 100644
--- a/drivers/gpu/drm/i915/intel_overlay.c
+++ b/drivers/gpu/drm/i915/intel_overlay.c
@@ -606,14 +606,14 @@ static void update_colorkey(struct intel_overlay *overlay,
u32 key = overlay->color_key;
- switch (overlay->crtc->base.fb->bits_per_pixel) {
+ switch (overlay->crtc->base.primary->fb->bits_per_pixel) {
case 8:
iowrite32(0, ®s->DCLRKV);
iowrite32(CLK_RGB8I_MASK | DST_KEY_ENABLE, ®s->DCLRKM);
break;
case 16:
- if (overlay->crtc->base.fb->depth == 15) {
+ if (overlay->crtc->base.primary->fb->depth == 15) {
iowrite32(RGB15_TO_COLORKEY(key), ®s->DCLRKV);
iowrite32(CLK_RGB15_MASK | DST_KEY_ENABLE,
®s->DCLRKM);
diff --git a/drivers/gpu/drm/i915/intel_pm.c b/drivers/gpu/drm/i915/intel_pm.c
index 66f9565..f070d5d 100644
--- a/drivers/gpu/drm/i915/intel_pm.c
+++ b/drivers/gpu/drm/i915/intel_pm.c
@@ -92,7 +92,7 @@ static void i8xx_enable_fbc(struct drm_crtc *crtc)
- struct drm_framebuffer *fb = crtc->fb;
+ struct drm_framebuffer *fb = crtc->primary->fb;
struct intel_framebuffer *intel_fb = to_intel_framebuffer(fb);
struct drm_i915_gem_object *obj = intel_fb->obj;
@@ -149,7 +149,7 @@ static void g4x_enable_fbc(struct drm_crtc *crtc)
@@ -221,7 +221,7 @@ static void ironlake_enable_fbc(struct drm_crtc *crtc)
@@ -277,7 +277,7 @@ static void gen7_enable_fbc(struct drm_crtc *crtc)
@@ -336,11 +336,11 @@ static void intel_fbc_work_fn(struct work_struct *__work)
/* Double check that we haven't switched fb without cancelling
* the prior work.
- if (work->crtc->fb == work->fb) {
+ if (work->crtc->primary->fb == work->fb) {
dev_priv->display.enable_fbc(work->crtc);
dev_priv->fbc.plane = to_intel_crtc(work->crtc)->plane;
- dev_priv->fbc.fb_id = work->crtc->fb->base.id;
+ dev_priv->fbc.fb_id = work->crtc->primary->fb->base.id;
dev_priv->fbc.y = work->crtc->y;
@@ -393,7 +393,7 @@ static void intel_enable_fbc(struct drm_crtc *crtc)
work->crtc = crtc;
- work->fb = crtc->fb;
+ work->fb = crtc->primary->fb;
INIT_DELAYED_WORK(&work->work, intel_fbc_work_fn);
dev_priv->fbc.fbc_work = work;
@@ -499,14 +499,14 @@ void intel_update_fbc(struct drm_device *dev)
- if (!crtc || crtc->fb == NULL) {
+ if (!crtc || crtc->primary->fb == NULL) {
if (set_no_fbc_reason(dev_priv, FBC_NO_OUTPUT))
DRM_DEBUG_KMS("no output, disabling\n");
goto out_disable;
- fb = crtc->fb;
adjusted_mode = &intel_crtc->config.adjusted_mode;
@@ -1041,7 +1041,7 @@ static void pineview_update_wm(struct drm_crtc *unused_crtc)
crtc = single_enabled_crtc(dev);
if (crtc) {
const struct drm_display_mode *adjusted_mode;
- int pixel_size = crtc->fb->bits_per_pixel / 8;
+ int pixel_size = crtc->primary->fb->bits_per_pixel / 8;
int clock;
adjusted_mode = &to_intel_crtc(crtc)->config.adjusted_mode;
@@ -1121,7 +1121,7 @@ static bool g4x_compute_wm0(struct drm_device *dev,
clock = adjusted_mode->crtc_clock;
htotal = adjusted_mode->crtc_htotal;
hdisplay = to_intel_crtc(crtc)->config.pipe_src_w;
- pixel_size = crtc->fb->bits_per_pixel / 8;
+ pixel_size = crtc->primary->fb->bits_per_pixel / 8;
/* Use the small buffer method to calculate plane watermark */
entries = ((clock * pixel_size / 1000) * display_latency_ns) / 1000;
@@ -1208,7 +1208,7 @@ static bool g4x_compute_srwm(struct drm_device *dev,
line_time_us = max(htotal * 1000 / clock, 1);
line_count = (latency_ns / line_time_us + 1000) / 1000;
@@ -1247,7 +1247,7 @@ static bool vlv_compute_drain_latency(struct drm_device *dev,
return false;
clock = to_intel_crtc(crtc)->config.adjusted_mode.crtc_clock;
- pixel_size = crtc->fb->bits_per_pixel / 8; /* BPP */
+ pixel_size = crtc->primary->fb->bits_per_pixel / 8; /* BPP */
entries = (clock / 1000) * pixel_size;
*plane_prec_mult = (entries > 256) ?
@@ -1439,7 +1439,7 @@ static void i965_update_wm(struct drm_crtc *unused_crtc)
int clock = adjusted_mode->crtc_clock;
int htotal = adjusted_mode->crtc_htotal;
int hdisplay = to_intel_crtc(crtc)->config.pipe_src_w;
unsigned long line_time_us;
int entries;
@@ -1512,7 +1512,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
crtc = intel_get_crtc_for_plane(dev, 0);
if (intel_crtc_active(crtc)) {
- int cpp = crtc->fb->bits_per_pixel / 8;
+ int cpp = crtc->primary->fb->bits_per_pixel / 8;
if (IS_GEN2(dev))
cpp = 4;
@@ -1528,7 +1528,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
crtc = intel_get_crtc_for_plane(dev, 1);
if (IS_GEN2(dev))
cpp = 4;
@@ -1565,7 +1565,7 @@ static void i9xx_update_wm(struct drm_crtc *unused_crtc)
int hdisplay = to_intel_crtc(enabled)->config.pipe_src_w;
- int pixel_size = enabled->fb->bits_per_pixel / 8;
+ int pixel_size = enabled->primary->fb->bits_per_pixel / 8;
int entries;
@@ -2117,7 +2117,7 @@ static void ilk_compute_wm_parameters(struct drm_crtc *crtc,
if (p->active) {
p->pipe_htotal = intel_crtc->config.adjusted_mode.crtc_htotal;
p->pixel_rate = ilk_pipe_pixel_rate(dev, crtc);
- p->pri.bytes_per_pixel = crtc->fb->bits_per_pixel / 8;
+ p->pri.bytes_per_pixel = crtc->primary->fb->bits_per_pixel / 8;
p->cur.bytes_per_pixel = 4;
p->pri.horiz_pixels = intel_crtc->config.pipe_src_w;
p->cur.horiz_pixels = 64;
diff --git a/drivers/gpu/drm/mgag200/mgag200_mode.c b/drivers/gpu/drm/mgag200/mgag200_mode.c
index 9683747..a034ed4 100644
--- a/drivers/gpu/drm/mgag200/mgag200_mode.c
+++ b/drivers/gpu/drm/mgag200/mgag200_mode.c
@@ -29,7 +29,7 @@ static void mga_crtc_load_lut(struct drm_crtc *crtc)
struct mga_crtc *mga_crtc = to_mga_crtc(crtc);
struct mga_device *mdev = dev->dev_private;
int i;
if (!crtc->enabled)
@@ -742,7 +742,7 @@ static int mga_crtc_do_set_base(struct drm_crtc *crtc,
mgag200_bo_unreserve(bo);
- mga_fb = to_mga_framebuffer(crtc->fb);
+ mga_fb = to_mga_framebuffer(crtc->primary->fb);
obj = mga_fb->obj;
bo = gem_to_mga_bo(obj);
@@ -805,7 +805,7 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
/* 0x48: */ 0, 0, 0, 0, 0, 0, 0, 0
- bppshift = mdev->bpp_shifts[(crtc->fb->bits_per_pixel >> 3) - 1];
+ bppshift = mdev->bpp_shifts[(crtc->primary->fb->bits_per_pixel >> 3) - 1];
switch (mdev->type) {
case G200_SE_A:
@@ -843,12 +843,12 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
break;
case 8:
dacvalue[MGA1064_MUL_CTL] = MGA1064_MUL_CTL_8bits;
break;
case 16:
dacvalue[MGA1064_MUL_CTL] = MGA1064_MUL_CTL_15bits;
else
dacvalue[MGA1064_MUL_CTL] = MGA1064_MUL_CTL_16bits;
@@ -896,8 +896,8 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
WREG_SEQ(3, 0);
WREG_SEQ(4, 0xe);
- pitch = crtc->fb->pitches[0] / (crtc->fb->bits_per_pixel / 8);
- if (crtc->fb->bits_per_pixel == 24)
+ pitch = crtc->primary->fb->pitches[0] / (crtc->primary->fb->bits_per_pixel / 8);
+ if (crtc->primary->fb->bits_per_pixel == 24)
pitch = (pitch * 3) >> (4 - bppshift);
else
pitch = pitch >> (4 - bppshift);
@@ -974,7 +974,7 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
((vdisplay & 0xc00) >> 7) |
((vsyncstart & 0xc00) >> 5) |
((vdisplay & 0x400) >> 3);
ext_vga[3] = (((1 << bppshift) * 3) - 1) | 0x80;
else
ext_vga[3] = ((1 << bppshift) - 1) | 0x80;
@@ -1034,9 +1034,9 @@ static int mga_crtc_mode_set(struct drm_crtc *crtc,
u32 bpp;
u32 mb;
- if (crtc->fb->bits_per_pixel > 16)
+ if (crtc->primary->fb->bits_per_pixel > 16)
bpp = 32;
- else if (crtc->fb->bits_per_pixel > 8)
+ else if (crtc->primary->fb->bits_per_pixel > 8)
bpp = 16;
else
bpp = 8;
@@ -1277,8 +1277,8 @@ static void mga_crtc_disable(struct drm_crtc *crtc)
int ret;
DRM_DEBUG_KMS("\n");
mga_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
- if (crtc->fb) {
- struct mga_framebuffer *mga_fb = to_mga_framebuffer(crtc->fb);
+ struct mga_framebuffer *mga_fb = to_mga_framebuffer(crtc->primary->fb);
struct drm_gem_object *obj = mga_fb->obj;
struct mgag200_bo *bo = gem_to_mga_bo(obj);
ret = mgag200_bo_reserve(bo, false);
@@ -1287,7 +1287,7 @@ static void mga_crtc_disable(struct drm_crtc *crtc)
mgag200_bo_push_sysram(bo);
- crtc->fb = NULL;
/* These provide the minimum set of functions required to handle a CRTC */
diff --git a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
index fc1cdfa..3e6c0f3 100644
--- a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
+++ b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
@@ -120,7 +120,7 @@ static void update_fb(struct drm_crtc *crtc, struct drm_framebuffer *new_fb)
/* grab reference to incoming scanout fb: */
drm_framebuffer_reference(new_fb);
- mdp4_crtc->base.fb = new_fb;
+ mdp4_crtc->base.primary->fb = new_fb;
mdp4_crtc->fb = new_fb;
if (old_fb)
@@ -182,7 +182,7 @@ static void pageflip_cb(struct msm_fence_cb *cb)
struct mdp4_crtc *mdp4_crtc =
container_of(cb, struct mdp4_crtc, pageflip_cb);
struct drm_crtc *crtc = &mdp4_crtc->base;
if (!fb)
return;
@@ -348,14 +348,14 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
mode->type, mode->flags);
/* grab extra ref for update_scanout() */
- ret = mdp4_plane_mode_set(mdp4_crtc->plane, crtc, crtc->fb,
+ ret = mdp4_plane_mode_set(mdp4_crtc->plane, crtc, crtc->primary->fb,
0, 0, mode->hdisplay, mode->vdisplay,
x << 16, y << 16,
mode->hdisplay << 16, mode->vdisplay << 16);
if (ret) {
- drm_framebuffer_unreference(crtc->fb);
+ drm_framebuffer_unreference(crtc->primary->fb);
dev_err(crtc->dev->dev, "%s: failed to set mode on plane: %d\n",
mdp4_crtc->name, ret);
return ret;
@@ -368,7 +368,7 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
/* take data from pipe: */
mdp4_write(mdp4_kms, REG_MDP4_DMA_SRC_BASE(dma), 0);
mdp4_write(mdp4_kms, REG_MDP4_DMA_SRC_STRIDE(dma),
- crtc->fb->pitches[0]);
+ crtc->primary->fb->pitches[0]);
mdp4_write(mdp4_kms, REG_MDP4_DMA_DST_SIZE(dma),
MDP4_DMA_DST_SIZE_WIDTH(0) |
MDP4_DMA_DST_SIZE_HEIGHT(0));
@@ -378,7 +378,7 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
MDP4_OVLP_SIZE_WIDTH(mode->hdisplay) |
MDP4_OVLP_SIZE_HEIGHT(mode->vdisplay));
mdp4_write(mdp4_kms, REG_MDP4_OVLP_STRIDE(ovlp),
mdp4_write(mdp4_kms, REG_MDP4_OVLP_CFG(ovlp), 1);
@@ -388,8 +388,8 @@ static int mdp4_crtc_mode_set(struct drm_crtc *crtc,
mdp4_write(mdp4_kms, REG_MDP4_DMA_E_QUANT(2), 0x00ff0000);
- update_fb(crtc, crtc->fb);
- update_scanout(crtc, crtc->fb);
+ update_fb(crtc, crtc->primary->fb);
+ update_scanout(crtc, crtc->primary->fb);
return 0;
@@ -420,19 +420,19 @@ static int mdp4_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
int ret;
- ret = mdp4_plane_mode_set(plane, crtc, crtc->fb,
+ ret = mdp4_plane_mode_set(plane, crtc, crtc->primary->fb,
x << 16, y << 16,
if (ret) {
return ret;
return 0;
diff --git a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
index 54afdb2..6ea10bd 100644
--- a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
+++ b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
@@ -102,7 +102,7 @@ static void update_fb(struct drm_crtc *crtc, struct drm_framebuffer *new_fb)
- mdp5_crtc->base.fb = new_fb;
+ mdp5_crtc->base.primary->fb = new_fb;
mdp5_crtc->fb = new_fb;
if (old_fb)
@@ -289,14 +289,14 @@ static int mdp5_crtc_mode_set(struct drm_crtc *crtc,
- ret = mdp5_plane_mode_set(mdp5_crtc->plane, crtc, crtc->fb,
+ ret = mdp5_plane_mode_set(mdp5_crtc->plane, crtc, crtc->primary->fb,
x << 16, y << 16,
if (ret) {
mdp5_crtc->name, ret);
return ret;
@@ -306,8 +306,8 @@ static int mdp5_crtc_mode_set(struct drm_crtc *crtc,
MDP5_LM_OUT_SIZE_WIDTH(mode->hdisplay) |
MDP5_LM_OUT_SIZE_HEIGHT(mode->vdisplay));
return 0;
@@ -338,19 +338,19 @@ static int mdp5_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
int ret;
- ret = mdp5_plane_mode_set(plane, crtc, crtc->fb,
+ ret = mdp5_plane_mode_set(plane, crtc, crtc->primary->fb,
x << 16, y << 16,
if (ret) {
return ret;
return 0;
diff --git a/drivers/gpu/drm/nouveau/dispnv04/crtc.c b/drivers/gpu/drm/nouveau/dispnv04/crtc.c
index 1caef1f..41be342 100644
--- a/drivers/gpu/drm/nouveau/dispnv04/crtc.c
+++ b/drivers/gpu/drm/nouveau/dispnv04/crtc.c
@@ -239,7 +239,7 @@ nv_crtc_mode_set_vga(struct drm_crtc *crtc, struct drm_display_mode *mode)
struct nouveau_crtc *nv_crtc = nouveau_crtc(crtc);
struct nv04_crtc_reg *regp = &nv04_display(dev)->mode_reg.crtc_reg[nv_crtc->index];
/* Calculate our timings */
int horizDisplay = (mode->crtc_hdisplay >> 3) - 1;
@@ -574,7 +574,7 @@ nv_crtc_mode_set_regs(struct drm_crtc *crtc, struct drm_display_mode * mode)
regp->CRTC[NV_CIO_CRE_86] = 0x1;
- regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] = (crtc->fb->depth + 1) / 8;
+ regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] = (crtc->primary->fb->depth + 1) / 8;
/* Enable slaved mode (called MODE_TV in nv4ref.h) */
if (lvds_output || tmds_output || tv_output)
regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] |= (1 << 7);
@@ -588,7 +588,7 @@ nv_crtc_mode_set_regs(struct drm_crtc *crtc, struct drm_display_mode * mode)
regp->ramdac_gen_ctrl = NV_PRAMDAC_GENERAL_CONTROL_BPC_8BITS |
NV_PRAMDAC_GENERAL_CONTROL_VGA_STATE_SEL |
NV_PRAMDAC_GENERAL_CONTROL_PIXMIX_ON;
- if (crtc->fb->depth == 16)
+ if (crtc->primary->fb->depth == 16)
regp->ramdac_gen_ctrl |= NV_PRAMDAC_GENERAL_CONTROL_ALT_MODE_SEL;
if (nv_device(drm->device)->chipset >= 0x11)
regp->ramdac_gen_ctrl |= NV_PRAMDAC_GENERAL_CONTROL_PIPE_LONG;
@@ -609,7 +609,7 @@ static int
nv_crtc_swap_fbs(struct drm_crtc *crtc, struct drm_framebuffer *old_fb)
struct nv04_display *disp = nv04_display(crtc->dev);
- struct nouveau_framebuffer *nvfb = nouveau_framebuffer(crtc->fb);
+ struct nouveau_framebuffer *nvfb = nouveau_framebuffer(crtc->primary->fb);
int ret;
@@ -808,7 +808,7 @@ nv_crtc_gamma_set(struct drm_crtc *crtc, u16 *r, u16 *g, u16 *b, uint32_t start,
* mark the lut values as dirty by setting depth==0, and it'll be
* uploaded on the first mode_set_base()
- if (!nv_crtc->base.fb) {
+ if (!nv_crtc->base.primary->fb) {
nv_crtc->lut.depth = 0;
return;
@@ -832,7 +832,7 @@ nv04_crtc_do_mode_set_base(struct drm_crtc *crtc,
NV_DEBUG(drm, "index %d\n", nv_crtc->index);
/* no fb bound */
- if (!atomic && !crtc->fb) {
+ if (!atomic && !crtc->primary->fb) {
NV_DEBUG(drm, "No FB bound\n");
return 0;
@@ -844,8 +844,8 @@ nv04_crtc_do_mode_set_base(struct drm_crtc *crtc,
drm_fb = passed_fb;
fb = nouveau_framebuffer(passed_fb);
} else {
- drm_fb = crtc->fb;
- fb = nouveau_framebuffer(crtc->fb);
+ drm_fb = crtc->primary->fb;
+ fb = nouveau_framebuffer(crtc->primary->fb);
nv_crtc->fb.offset = fb->nvbo->bo.offset;
@@ -857,9 +857,9 @@ nv04_crtc_do_mode_set_base(struct drm_crtc *crtc,
/* Update the framebuffer format. */
regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] &= ~3;
- regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] |= (crtc->fb->depth + 1) / 8;
+ regp->CRTC[NV_CIO_CRE_PIXEL_INDEX] |= (crtc->primary->fb->depth + 1) / 8;
regp->ramdac_gen_ctrl &= ~NV_PRAMDAC_GENERAL_CONTROL_ALT_MODE_SEL;
crtc_wr_cio_state(crtc, regp, NV_CIO_CRE_PIXEL_INDEX);
NVWriteRAMDAC(dev, nv_crtc->index, NV_PRAMDAC_GENERAL_CONTROL,
diff --git a/drivers/gpu/drm/nouveau/dispnv04/dfp.c b/drivers/gpu/drm/nouveau/dispnv04/dfp.c
index 7fdc51e..a2d669b 100644
--- a/drivers/gpu/drm/nouveau/dispnv04/dfp.c
+++ b/drivers/gpu/drm/nouveau/dispnv04/dfp.c
@@ -415,7 +415,7 @@ static void nv04_dfp_mode_set(struct drm_encoder *encoder,
/* Output property. */
if ((nv_connector->dithering_mode == DITHERING_MODE_ON) ||
(nv_connector->dithering_mode == DITHERING_MODE_AUTO &&
- encoder->crtc->fb->depth > connector->display_info.bpc * 3)) {
+ encoder->crtc->primary->fb->depth > connector->display_info.bpc * 3)) {
if (nv_device(drm->device)->chipset == 0x11)
regp->dither = savep->dither | 0x00010000;
else {
diff --git a/drivers/gpu/drm/nouveau/nouveau_display.c b/drivers/gpu/drm/nouveau/nouveau_display.c
index b1547b0..3ff030d 100644
--- a/drivers/gpu/drm/nouveau/nouveau_display.c
+++ b/drivers/gpu/drm/nouveau/nouveau_display.c
@@ -571,7 +571,7 @@ nouveau_display_suspend(struct drm_device *dev)
struct nouveau_framebuffer *nouveau_fb;
- nouveau_fb = nouveau_framebuffer(crtc->fb);
+ nouveau_fb = nouveau_framebuffer(crtc->primary->fb);
if (!nouveau_fb || !nouveau_fb->nvbo)
continue;
@@ -598,7 +598,7 @@ nouveau_display_repin(struct drm_device *dev)
continue;
@@ -695,7 +695,7 @@ nouveau_crtc_page_flip(struct drm_crtc *crtc, struct drm_framebuffer *fb,
const int swap_interval = (flags & DRM_MODE_PAGE_FLIP_ASYNC) ? 0 : 1;
struct nouveau_drm *drm = nouveau_drm(dev);
- struct nouveau_bo *old_bo = nouveau_framebuffer(crtc->fb)->nvbo;
+ struct nouveau_bo *old_bo = nouveau_framebuffer(crtc->primary->fb)->nvbo;
struct nouveau_bo *new_bo = nouveau_framebuffer(fb)->nvbo;
struct nouveau_page_flip_state *s;
struct nouveau_channel *chan = drm->channel;
@@ -769,7 +769,7 @@ nouveau_crtc_page_flip(struct drm_crtc *crtc, struct drm_framebuffer *fb,
goto fail_unreserve;
/* Update the crtc struct and cleanup */
- crtc->fb = fb;
nouveau_bo_fence(old_bo, fence);
ttm_bo_unreserve(&old_bo->bo);
diff --git a/drivers/gpu/drm/nouveau/nv50_display.c b/drivers/gpu/drm/nouveau/nv50_display.c
index 2dccafc..58af547 100644
--- a/drivers/gpu/drm/nouveau/nv50_display.c
+++ b/drivers/gpu/drm/nouveau/nv50_display.c
@@ -651,7 +651,7 @@ nv50_crtc_set_dither(struct nouveau_crtc *nv_crtc, bool update)
nv_connector = nouveau_crtc_connector_get(nv_crtc);
connector = &nv_connector->base;
if (nv_connector->dithering_mode == DITHERING_MODE_AUTO) {
- if (nv_crtc->base.fb->depth > connector->display_info.bpc * 3)
+ if (nv_crtc->base.primary->fb->depth > connector->display_info.bpc * 3)
mode = DITHERING_MODE_DYNAMIC2X2;
} else {
mode = nv_connector->dithering_mode;
@@ -785,7 +785,8 @@ nv50_crtc_set_scale(struct nouveau_crtc *nv_crtc, bool update)
if (update) {
nv50_display_flip_stop(crtc);
- nv50_display_flip_next(crtc, crtc->fb, NULL, 1);
+ nv50_display_flip_next(crtc, crtc->primary->fb,
+ NULL, 1);
@@ -1028,7 +1029,7 @@ nv50_crtc_commit(struct drm_crtc *crtc)
nv50_crtc_cursor_show_hide(nv_crtc, nv_crtc->cursor.visible, true);
+ nv50_display_flip_next(crtc, crtc->primary->fb, NULL, 1);
static bool
@@ -1042,7 +1043,7 @@ nv50_crtc_mode_fixup(struct drm_crtc *crtc, const struct drm_display_mode *mode,
static int
nv50_crtc_swap_fbs(struct drm_crtc *crtc, struct drm_framebuffer *old_fb)
struct nv50_head *head = nv50_head(crtc);
int ret;
@@ -1139,7 +1140,7 @@ nv50_crtc_mode_set(struct drm_crtc *crtc, struct drm_display_mode *umode,
nv50_crtc_set_dither(nv_crtc, false);
nv50_crtc_set_scale(nv_crtc, false);
nv50_crtc_set_color_vibrance(nv_crtc, false);
- nv50_crtc_set_image(nv_crtc, crtc->fb, x, y, false);
+ nv50_crtc_set_image(nv_crtc, crtc->primary->fb, x, y, false);
return 0;
@@ -1151,7 +1152,7 @@ nv50_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
int ret;
- if (!crtc->fb) {
return 0;
@@ -1161,8 +1162,8 @@ nv50_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
return ret;
- nv50_crtc_set_image(nv_crtc, crtc->fb, x, y, true);
+ nv50_crtc_set_image(nv_crtc, crtc->primary->fb, x, y, true);
return 0;
diff --git a/drivers/gpu/drm/omapdrm/omap_crtc.c b/drivers/gpu/drm/omapdrm/omap_crtc.c
index 4313bb0..355157e 100644
--- a/drivers/gpu/drm/omapdrm/omap_crtc.c
+++ b/drivers/gpu/drm/omapdrm/omap_crtc.c
@@ -245,7 +245,7 @@ static int omap_crtc_mode_set(struct drm_crtc *crtc,
copy_timings_drm_to_omap(&omap_crtc->timings, mode);
omap_crtc->full_update = true;
- return omap_plane_mode_set(omap_crtc->plane, crtc, crtc->fb,
+ return omap_plane_mode_set(omap_crtc->plane, crtc, crtc->primary->fb,
x << 16, y << 16,
mode->hdisplay << 16, mode->vdisplay << 16,
@@ -273,7 +273,7 @@ static int omap_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
struct drm_plane *plane = omap_crtc->plane;
struct drm_display_mode *mode = &crtc->mode;
- return omap_plane_mode_set(plane, crtc, crtc->fb,
+ return omap_plane_mode_set(plane, crtc, crtc->primary->fb,
x << 16, y << 16,
@@ -308,14 +308,14 @@ static void page_flip_worker(struct work_struct *work)
struct drm_gem_object *bo;
- omap_plane_mode_set(omap_crtc->plane, crtc, crtc->fb,
+ omap_plane_mode_set(omap_crtc->plane, crtc, crtc->primary->fb,
crtc->x << 16, crtc->y << 16,
vblank_cb, crtc);
- bo = omap_framebuffer_bo(crtc->fb, 0);
+ bo = omap_framebuffer_bo(crtc->primary->fb, 0);
drm_gem_object_unreference_unlocked(bo);
@@ -336,9 +336,10 @@ static int omap_crtc_page_flip_locked(struct drm_crtc *crtc,
struct omap_crtc *omap_crtc = to_omap_crtc(crtc);
+ struct drm_plane *primary = crtc->primary;
- DBG("%d -> %d (event=%p)", crtc->fb ? crtc->fb->base.id : -1,
+ DBG("%d -> %d (event=%p)", primary->fb ? primary->fb->base.id : -1,
fb->base.id, event);
if (omap_crtc->old_fb) {
@@ -347,7 +348,7 @@ static int omap_crtc_page_flip_locked(struct drm_crtc *crtc,
omap_crtc->event = event;
- crtc->fb = fb;
+ primary->fb = fb;
* Hold a reference temporarily until the crtc is updated
diff --git a/drivers/gpu/drm/omapdrm/omap_fb.c b/drivers/gpu/drm/omapdrm/omap_fb.c
index f466c4a..0d5e9b7 100644
--- a/drivers/gpu/drm/omapdrm/omap_fb.c
+++ b/drivers/gpu/drm/omapdrm/omap_fb.c
@@ -312,7 +312,7 @@ struct drm_connector *omap_framebuffer_get_next_connector(
if (connector != from) {
struct drm_encoder *encoder = connector->encoder;
struct drm_crtc *crtc = encoder ? encoder->crtc : NULL;
- if (crtc && crtc->fb == fb)
+ if (crtc && crtc->primary->fb == fb)
return connector;
diff --git a/drivers/gpu/drm/qxl/qxl_display.c b/drivers/gpu/drm/qxl/qxl_display.c
index 798bde2..41bdd17 100644
--- a/drivers/gpu/drm/qxl/qxl_display.c
+++ b/drivers/gpu/drm/qxl/qxl_display.c
@@ -527,7 +527,7 @@ static int qxl_crtc_mode_set(struct drm_crtc *crtc,
bool recreate_primary = false;
int ret;
int surf_id;
- if (!crtc->fb) {
DRM_DEBUG_KMS("No FB bound\n");
return 0;
@@ -536,7 +536,7 @@ static int qxl_crtc_mode_set(struct drm_crtc *crtc,
qfb = to_qxl_framebuffer(old_fb);
old_bo = gem_to_qxl_bo(qfb->obj);
- qfb = to_qxl_framebuffer(crtc->fb);
+ qfb = to_qxl_framebuffer(crtc->primary->fb);
if (!m)
/* and do we care? */
@@ -609,14 +609,14 @@ static void qxl_crtc_disable(struct drm_crtc *crtc)
struct qxl_crtc *qcrtc = to_qxl_crtc(crtc);
struct qxl_device *qdev = dev->dev_private;
- if (crtc->fb) {
- struct qxl_framebuffer *qfb = to_qxl_framebuffer(crtc->fb);
+ struct qxl_framebuffer *qfb = to_qxl_framebuffer(crtc->primary->fb);
struct qxl_bo *bo = gem_to_qxl_bo(qfb->obj);
int ret;
ret = qxl_bo_reserve(bo, false);
qxl_bo_unpin(bo);
qxl_bo_unreserve(bo);
- crtc->fb = NULL;
qxl_monitors_config_set(qdev, qcrtc->index, 0, 0, 0, 0, 0);
diff --git a/drivers/gpu/drm/radeon/atombios_crtc.c b/drivers/gpu/drm/radeon/atombios_crtc.c
index daa4dd3..fb187c7 100644
--- a/drivers/gpu/drm/radeon/atombios_crtc.c
+++ b/drivers/gpu/drm/radeon/atombios_crtc.c
@@ -1106,7 +1106,7 @@ static int dce4_crtc_do_set_base(struct drm_crtc *crtc,
int r;
/* no fb bound */
return 0;
@@ -1116,8 +1116,8 @@ static int dce4_crtc_do_set_base(struct drm_crtc *crtc,
target_fb = fb;
else {
- radeon_fb = to_radeon_framebuffer(crtc->fb);
- target_fb = crtc->fb;
+ radeon_fb = to_radeon_framebuffer(crtc->primary->fb);
+ target_fb = crtc->primary->fb;
/* If atomic, assume fb object is pinned & idle & fenced and
@@ -1316,7 +1316,7 @@ static int dce4_crtc_do_set_base(struct drm_crtc *crtc,
/* set pageflip to happen anywhere in vblank interval */
WREG32(EVERGREEN_MASTER_UPDATE_MODE + radeon_crtc->crtc_offset, 0);
- if (!atomic && fb && fb != crtc->fb) {
+ if (!atomic && fb && fb != crtc->primary->fb) {
radeon_fb = to_radeon_framebuffer(fb);
rbo = gem_to_radeon_bo(radeon_fb->obj);
r = radeon_bo_reserve(rbo, false);
@@ -1350,7 +1350,7 @@ static int avivo_crtc_do_set_base(struct drm_crtc *crtc,
int r;
/* no fb bound */
return 0;
@@ -1360,8 +1360,8 @@ static int avivo_crtc_do_set_base(struct drm_crtc *crtc,
target_fb = fb;
else {
obj = radeon_fb->obj;
@@ -1485,7 +1485,7 @@ static int avivo_crtc_do_set_base(struct drm_crtc *crtc,
WREG32(AVIVO_D1MODE_MASTER_UPDATE_MODE + radeon_crtc->crtc_offset, 0);
@@ -1972,12 +1972,12 @@ static void atombios_crtc_disable(struct drm_crtc *crtc)
int i;
atombios_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
- if (crtc->fb) {
int r;
struct radeon_framebuffer *radeon_fb;
struct radeon_bo *rbo;
if (unlikely(r))
diff --git a/drivers/gpu/drm/radeon/r100.c b/drivers/gpu/drm/radeon/r100.c
index 030f8e4..b6c3264 100644
--- a/drivers/gpu/drm/radeon/r100.c
+++ b/drivers/gpu/drm/radeon/r100.c
@@ -3220,12 +3220,12 @@ void r100_bandwidth_update(struct radeon_device *rdev)
if (rdev->mode_info.crtcs[0]->base.enabled) {
mode1 = &rdev->mode_info.crtcs[0]->base.mode;
- pixel_bytes1 = rdev->mode_info.crtcs[0]->base.fb->bits_per_pixel / 8;
+ pixel_bytes1 = rdev->mode_info.crtcs[0]->base.primary->fb->bits_per_pixel / 8;
if (!(rdev->flags & RADEON_SINGLE_CRTC)) {
if (rdev->mode_info.crtcs[1]->base.enabled) {
mode2 = &rdev->mode_info.crtcs[1]->base.mode;
- pixel_bytes2 = rdev->mode_info.crtcs[1]->base.fb->bits_per_pixel / 8;
+ pixel_bytes2 = rdev->mode_info.crtcs[1]->base.primary->fb->bits_per_pixel / 8;
diff --git a/drivers/gpu/drm/radeon/radeon_connectors.c b/drivers/gpu/drm/radeon/radeon_connectors.c
index ec958e86..c566b48 100644
--- a/drivers/gpu/drm/radeon/radeon_connectors.c
+++ b/drivers/gpu/drm/radeon/radeon_connectors.c
@@ -89,7 +89,7 @@ static void radeon_property_change_mode(struct drm_encoder *encoder)
if (crtc && crtc->enabled) {
diff --git a/drivers/gpu/drm/radeon/radeon_device.c b/drivers/gpu/drm/radeon/radeon_device.c
index 2e72dcd..15f954c 100644
--- a/drivers/gpu/drm/radeon/radeon_device.c
+++ b/drivers/gpu/drm/radeon/radeon_device.c
@@ -1424,7 +1424,7 @@ int radeon_suspend_kms(struct drm_device *dev, bool suspend, bool fbcon)
/* unpin the front buffers */
- struct radeon_framebuffer *rfb = to_radeon_framebuffer(crtc->fb);
+ struct radeon_framebuffer *rfb = to_radeon_framebuffer(crtc->primary->fb);
struct radeon_bo *robj;
if (rfb == NULL || rfb->obj == NULL) {
diff --git a/drivers/gpu/drm/radeon/radeon_display.c b/drivers/gpu/drm/radeon/radeon_display.c
index fbd8b93..5701fbb 100644
--- a/drivers/gpu/drm/radeon/radeon_display.c
+++ b/drivers/gpu/drm/radeon/radeon_display.c
@@ -369,7 +369,7 @@ static int radeon_crtc_page_flip(struct drm_crtc *crtc,
work->rdev = rdev;
work->crtc_id = radeon_crtc->crtc_id;
- old_radeon_fb = to_radeon_framebuffer(crtc->fb);
+ old_radeon_fb = to_radeon_framebuffer(crtc->primary->fb);
new_radeon_fb = to_radeon_framebuffer(fb);
/* schedule unpin of the old buffer */
obj = old_radeon_fb->obj;
@@ -460,7 +460,7 @@ static int radeon_crtc_page_flip(struct drm_crtc *crtc,
/* update crtc fb */
- crtc->fb = fb;
r = drm_vblank_get(dev, radeon_crtc->crtc_id);
if (r) {
diff --git a/drivers/gpu/drm/radeon/radeon_legacy_crtc.c b/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
index 0b158f9..cafb1cc 100644
--- a/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
+++ b/drivers/gpu/drm/radeon/radeon_legacy_crtc.c
@@ -385,7 +385,7 @@ int radeon_crtc_do_set_base(struct drm_crtc *crtc,
/* no fb bound */
return 0;
@@ -395,8 +395,8 @@ int radeon_crtc_do_set_base(struct drm_crtc *crtc,
target_fb = fb;
else {
switch (target_fb->bits_per_pixel) {
@@ -444,7 +444,7 @@ retry:
* We don't shutdown the display controller because new buffer
* will end up in same spot.
struct radeon_bo *old_rbo;
unsigned long nsize, osize;
@@ -555,7 +555,7 @@ retry:
WREG32(RADEON_CRTC_OFFSET + radeon_crtc->crtc_offset, crtc_offset);
WREG32(RADEON_CRTC_PITCH + radeon_crtc->crtc_offset, crtc_pitch);
@@ -599,7 +599,7 @@ static bool radeon_set_crtc_timing(struct drm_crtc *crtc, struct drm_display_mod
case 8:
format = 2;
break;
@@ -1087,12 +1087,12 @@ static void radeon_crtc_commit(struct drm_crtc *crtc)
static void radeon_crtc_disable(struct drm_crtc *crtc)
radeon_crtc_dpms(crtc, DRM_MODE_DPMS_OFF);
- if (crtc->fb) {
int r;
if (unlikely(r))
diff --git a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
index fbf4be3..299267d 100644
--- a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
+++ b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
@@ -299,7 +299,7 @@ static void rcar_du_crtc_update_base(struct rcar_du_crtc *rcrtc)
struct drm_crtc *crtc = &rcrtc->crtc;
- rcar_du_plane_compute_base(rcrtc->plane, crtc->fb);
+ rcar_du_plane_compute_base(rcrtc->plane, crtc->primary->fb);
rcar_du_plane_update_base(rcrtc->plane);
@@ -358,10 +358,10 @@ static int rcar_du_crtc_mode_set(struct drm_crtc *crtc,
const struct rcar_du_format_info *format;
int ret;
- format = rcar_du_format_info(crtc->fb->pixel_format);
+ format = rcar_du_format_info(crtc->primary->fb->pixel_format);
if (format == NULL) {
dev_dbg(rcdu->dev, "mode_set: unsupported format %08x\n",
- crtc->fb->pixel_format);
+ crtc->primary->fb->pixel_format);
ret = -EINVAL;
goto error;
@@ -377,7 +377,7 @@ static int rcar_du_crtc_mode_set(struct drm_crtc *crtc,
rcrtc->plane->width = mode->hdisplay;
rcrtc->plane->height = mode->vdisplay;
rcrtc->outputs = 0;
@@ -510,7 +510,7 @@ static int rcar_du_crtc_page_flip(struct drm_crtc *crtc,
- crtc->fb = fb;
rcar_du_crtc_update_base(rcrtc);
if (event) {
diff --git a/drivers/gpu/drm/shmobile/shmob_drm_crtc.c b/drivers/gpu/drm/shmobile/shmob_drm_crtc.c
index ea543b4..e9e5e6d 100644
--- a/drivers/gpu/drm/shmobile/shmob_drm_crtc.c
+++ b/drivers/gpu/drm/shmobile/shmob_drm_crtc.c
@@ -173,7 +173,7 @@ static void shmob_drm_crtc_start(struct shmob_drm_crtc *scrtc)
if (scrtc->started)
return;
- format = shmob_drm_format_info(crtc->fb->pixel_format);
+ format = shmob_drm_format_info(crtc->primary->fb->pixel_format);
if (WARN_ON(format == NULL))
return;
@@ -303,7 +303,7 @@ static void shmob_drm_crtc_compute_base(struct shmob_drm_crtc *scrtc,
int x, int y)
struct drm_crtc *crtc = &scrtc->crtc;
struct shmob_drm_device *sdev = crtc->dev->dev_private;
struct drm_gem_cma_object *gem;
unsigned int bpp;
@@ -382,15 +382,15 @@ static int shmob_drm_crtc_mode_set(struct drm_crtc *crtc,
const struct shmob_drm_format_info *format;
void *cache;
dev_dbg(sdev->dev, "mode_set: unsupported format %08x\n",
return -EINVAL;
scrtc->format = format;
- scrtc->line_size = crtc->fb->pitches[0];
+ scrtc->line_size = crtc->primary->fb->pitches[0];
if (sdev->meram) {
/* Enable MERAM cache if configured. We need to de-init
@@ -402,7 +402,7 @@ static int shmob_drm_crtc_mode_set(struct drm_crtc *crtc,
cache = sh_mobile_meram_cache_alloc(sdev->meram, mdata,
- crtc->fb->pitches[0],
+ crtc->primary->fb->pitches[0],
adjusted_mode->vdisplay,
format->meram,
&scrtc->line_size);
@@ -489,7 +489,7 @@ static int shmob_drm_crtc_page_flip(struct drm_crtc *crtc,
- crtc->fb = fb;
shmob_drm_crtc_update_base(scrtc);
if (event) {
diff --git a/drivers/gpu/drm/tegra/dc.c b/drivers/gpu/drm/tegra/dc.c
index 9336006..36c717a 100644
--- a/drivers/gpu/drm/tegra/dc.c
+++ b/drivers/gpu/drm/tegra/dc.c
@@ -235,14 +235,14 @@ static void tegra_dc_finish_page_flip(struct tegra_dc *dc)
if (!dc->event)
return;
- bo = tegra_fb_get_plane(crtc->fb, 0);
+ bo = tegra_fb_get_plane(crtc->primary->fb, 0);
/* check if new start address has been latched */
tegra_dc_writel(dc, READ_MUX, DC_CMD_STATE_ACCESS);
base = tegra_dc_readl(dc, DC_WINBUF_START_ADDR);
tegra_dc_writel(dc, 0, DC_CMD_STATE_ACCESS);
- if (base == bo->paddr + crtc->fb->offsets[0]) {
+ if (base == bo->paddr + crtc->primary->fb->offsets[0]) {
spin_lock_irqsave(&drm->event_lock, flags);
drm_send_vblank_event(drm, dc->pipe, dc->event);
drm_vblank_put(drm, dc->pipe);
@@ -284,7 +284,7 @@ static int tegra_dc_page_flip(struct drm_crtc *crtc, struct drm_framebuffer *fb,
tegra_dc_set_base(dc, 0, 0, fb);
- crtc->fb = fb;
return 0;
@@ -645,7 +645,7 @@ static int tegra_crtc_mode_set(struct drm_crtc *crtc,
struct drm_display_mode *adjusted,
int x, int y, struct drm_framebuffer *old_fb)
- struct tegra_bo *bo = tegra_fb_get_plane(crtc->fb, 0);
+ struct tegra_bo *bo = tegra_fb_get_plane(crtc->primary->fb, 0);
struct tegra_dc *dc = to_tegra_dc(crtc);
struct tegra_dc_window window;
unsigned long div, value;
@@ -682,9 +682,9 @@ static int tegra_crtc_mode_set(struct drm_crtc *crtc,
window.dst.y = 0;
window.dst.w = mode->hdisplay;
window.dst.h = mode->vdisplay;
- window.format = tegra_dc_format(crtc->fb->pixel_format);
- window.bits_per_pixel = crtc->fb->bits_per_pixel;
- window.stride[0] = crtc->fb->pitches[0];
+ window.format = tegra_dc_format(crtc->primary->fb->pixel_format);
+ window.bits_per_pixel = crtc->primary->fb->bits_per_pixel;
+ window.stride[0] = crtc->primary->fb->pitches[0];
window.base[0] = bo->paddr;
err = tegra_dc_setup_window(dc, 0, &window);
@@ -699,7 +699,7 @@ static int tegra_crtc_mode_set_base(struct drm_crtc *crtc, int x, int y,
- return tegra_dc_set_base(dc, x, y, crtc->fb);
+ return tegra_dc_set_base(dc, x, y, crtc->primary->fb);
static void tegra_crtc_prepare(struct drm_crtc *crtc)
diff --git a/drivers/gpu/drm/tilcdc/tilcdc_crtc.c b/drivers/gpu/drm/tilcdc/tilcdc_crtc.c
index d36efc1..d642d4a 100644
--- a/drivers/gpu/drm/tilcdc/tilcdc_crtc.c
+++ b/drivers/gpu/drm/tilcdc/tilcdc_crtc.c
@@ -74,7 +74,7 @@ static void set_scanout(struct drm_crtc *crtc, int n)
drm_flip_work_queue(&tilcdc_crtc->unref_work, tilcdc_crtc->scanout[n]);
drm_flip_work_commit(&tilcdc_crtc->unref_work, priv->wq);
- tilcdc_crtc->scanout[n] = crtc->fb;
+ tilcdc_crtc->scanout[n] = crtc->primary->fb;
drm_framebuffer_reference(tilcdc_crtc->scanout[n]);
tilcdc_crtc->dirty &= ~stat[n];
pm_runtime_put_sync(dev->dev);
@@ -84,7 +84,7 @@ static void update_scanout(struct drm_crtc *crtc)
struct tilcdc_crtc *tilcdc_crtc = to_tilcdc_crtc(crtc);
unsigned int depth, bpp;
@@ -159,7 +159,7 @@ static int tilcdc_crtc_page_flip(struct drm_crtc *crtc,
return -EBUSY;
- crtc->fb = fb;
tilcdc_crtc->event = event;
update_scanout(crtc);
@@ -339,7 +339,7 @@ static int tilcdc_crtc_mode_set(struct drm_crtc *crtc,
if (priv->rev == 2) {
- drm_fb_get_bpp_depth(crtc->fb->pixel_format, &depth, &bpp);
+ drm_fb_get_bpp_depth(crtc->primary->fb->pixel_format, &depth, &bpp);
switch (bpp) {
case 16:
break;
diff --git a/drivers/gpu/drm/udl/udl_modeset.c b/drivers/gpu/drm/udl/udl_modeset.c
index 2ae1eb7..cddc4fc 100644
--- a/drivers/gpu/drm/udl/udl_modeset.c
+++ b/drivers/gpu/drm/udl/udl_modeset.c
@@ -310,7 +310,7 @@ static int udl_crtc_mode_set(struct drm_crtc *crtc,
- struct udl_framebuffer *ufb = to_udl_fb(crtc->fb);
+ struct udl_framebuffer *ufb = to_udl_fb(crtc->primary->fb);
struct udl_device *udl = dev->dev_private;
char *buf;
char *wrptr;
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c b/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c
index 159af7e..a2dde5a 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_kms.c
@@ -468,7 +468,7 @@ static int do_surface_dirty_sou(struct vmw_private *dev_priv,
num_units = 0;
list_for_each_entry(crtc, &dev_priv->dev->mode_config.crtc_list,
head) {
- if (crtc->fb != &framebuffer->base)
+ if (crtc->primary->fb != &framebuffer->base)
continue;
units[num_units++] = vmw_crtc_to_du(crtc);
@@ -882,7 +882,7 @@ static int do_dmabuf_dirty_sou(struct drm_file *file_priv,
num_units = 0;
list_for_each_entry(crtc, &dev_priv->dev->mode_config.crtc_list, head) {
continue;
@@ -1243,7 +1243,7 @@ int vmw_kms_present(struct vmw_private *dev_priv,
num_units = 0;
- if (crtc->fb != &vfb->base)
+ if (crtc->primary->fb != &vfb->base)
continue;
@@ -1380,7 +1380,7 @@ int vmw_kms_readback(struct vmw_private *dev_priv,
num_units = 0;
continue;
@@ -1723,7 +1723,7 @@ int vmw_du_page_flip(struct drm_crtc *crtc,
uint32_t page_flip_flags)
struct vmw_private *dev_priv = vmw_priv(crtc->dev);
struct vmw_framebuffer *vfb = vmw_framebuffer_to_vfb(fb);
struct drm_file *file_priv ;
struct vmw_fence_obj *fence = NULL;
@@ -1741,7 +1741,7 @@ int vmw_du_page_flip(struct drm_crtc *crtc,
if (!vmw_kms_screen_object_flippable(dev_priv, crtc))
return -EINVAL;
- crtc->fb = fb;
/* do a full screen dirty update */
clips.x1 = clips.y1 = 0;
@@ -1781,7 +1781,7 @@ int vmw_du_page_flip(struct drm_crtc *crtc,
return ret;
out_no_fence:
return ret;
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c b/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c
index a055a26..b2b9bd2 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_ldu.c
@@ -93,7 +93,7 @@ static int vmw_ldu_commit_list(struct vmw_private *dev_priv)
if (crtc == NULL)
return 0;
- fb = entry->base.crtc.fb;
+ fb = entry->base.crtc.primary->fb;
return vmw_kms_write_svga(dev_priv, w, h, fb->pitches[0],
fb->bits_per_pixel, fb->depth);
@@ -101,7 +101,7 @@ static int vmw_ldu_commit_list(struct vmw_private *dev_priv)
if (!list_empty(&lds->active)) {
entry = list_entry(lds->active.next, typeof(*entry), active);
vmw_kms_write_svga(dev_priv, fb->width, fb->height, fb->pitches[0],
@@ -259,7 +259,7 @@ static int vmw_ldu_crtc_set_config(struct drm_mode_set *set)
connector->encoder = NULL;
encoder->crtc = NULL;
- crtc->fb = NULL;
crtc->enabled = false;
vmw_ldu_del_active(dev_priv, ldu);
@@ -280,7 +280,7 @@ static int vmw_ldu_crtc_set_config(struct drm_mode_set *set)
vmw_fb_off(dev_priv);
- crtc->fb = fb;
encoder->crtc = crtc;
connector->encoder = encoder;
crtc->x = set->x;
diff --git a/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c b/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c
index 22406c8..a95d3a0 100644
--- a/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c
+++ b/drivers/gpu/drm/vmwgfx/vmwgfx_scrn.c
@@ -307,7 +307,7 @@ static int vmw_sou_crtc_set_config(struct drm_mode_set *set)
- crtc->fb = NULL;
crtc->x = 0;
crtc->y = 0;
@@ -368,7 +368,7 @@ static int vmw_sou_crtc_set_config(struct drm_mode_set *set)
- crtc->fb = NULL;
crtc->x = 0;
crtc->y = 0;
@@ -381,7 +381,7 @@ static int vmw_sou_crtc_set_config(struct drm_mode_set *set)
crtc->mode = *mode;
- crtc->fb = fb;
crtc->x = set->x;
crtc->y = set->y;
crtc->enabled = true;
@@ -572,5 +572,5 @@ void vmw_kms_screen_object_update_implicit_fb(struct vmw_private *dev_priv,
BUG_ON(!sou->base.is_implicit);
dev_priv->sou_priv->implicit_fb =
- vmw_framebuffer_to_vfb(sou->base.crtc.fb);
+ vmw_framebuffer_to_vfb(sou->base.crtc.primary->fb);
diff --git a/drivers/staging/imx-drm/ipuv3-crtc.c b/drivers/staging/imx-drm/ipuv3-crtc.c
index 22be104..39a7519 100644
--- a/drivers/staging/imx-drm/ipuv3-crtc.c
+++ b/drivers/staging/imx-drm/ipuv3-crtc.c
@@ -120,7 +120,7 @@ static int ipu_page_flip(struct drm_crtc *crtc,
ipu_crtc->newfb = fb;
ipu_crtc->page_flip_event = event;
- crtc->fb = fb;
return 0;
@@ -192,7 +192,7 @@ static int ipu_crtc_mode_set(struct drm_crtc *crtc,
return ret;
- return ipu_plane_mode_set(ipu_crtc->plane[0], crtc, mode, crtc->fb,
+ return ipu_plane_mode_set(ipu_crtc->plane[0], crtc, mode, crtc->primary->fb,
x, y, mode->hdisplay, mode->vdisplay);
@@ -218,7 +218,7 @@ static irqreturn_t ipu_irq_handler(int irq, void *dev_id)
if (ipu_crtc->newfb) {
ipu_crtc->newfb = NULL;
- ipu_plane_set_base(ipu_crtc->plane[0], ipu_crtc->base.fb,
+ ipu_plane_set_base(ipu_crtc->plane[0], ipu_crtc->base.primary->fb,
ipu_crtc->plane[0]->x, ipu_crtc->plane[0]->y);
ipu_crtc_handle_pageflip(ipu_crtc);
