drm: Pass ‘name’ to drm_universal_plane_init()
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Done with coccinelle for the most part. It choked on
msm/mdp/mdp5/mdp5_plane.c like so:
"BAD:!!!!!  enum drm_plane_type type;"
No idea how to deal with that, so I just fixed that up
by hand.
Also it thinks '...' is part of the semantic patch, so I put an
'int DOTDOTDOT' placeholder in its place and got rid of it with
sed afterwards.
I didn't convert drm_plane_init() since passing the varargs through
would mean either cpp macros or va_list, and I figured we don't
care about these legacy functions enough to warrant the extra pain.
typedef uint32_t;
identifier dev, plane, possible_crtcs, funcs, formats, format_count, type;
 int drm_universal_plane_init(struct drm_device *dev,
                              struct drm_plane *plane,
                              unsigned long possible_crtcs,
                              const struct drm_plane_funcs *funcs,
                              const uint32_t *formats,
                              unsigned int format_count,
+                             ,const char *name, int DOTDOTDOT
expression E1, E2, E3, E4, E5, E6, E7;
 drm_universal_plane_init(E1, E2, E3, E4, E5, E6, E7
+                         ,NULL
v2: Split crtc and plane changes apart
    Pass NUL for no-name instead of ""
    Leave drm_plane_init() alone
v3: Add ', or NULL...' to @name kernel doc (Jani)
    Annotate the function with __printf() attribute (Jani)
Signed-off-by: Ville Syrjälä
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/1449670795-2853-1-git-send-email-ville.syrjala@linux.intel.com
 drivers/gpu/drm/armada/armada_crtc.c            |  2 +-
 drivers/gpu/drm/armada/armada_overlay.c         |  2 +-
 drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_plane.c |  2 +-
 drivers/gpu/drm/drm_crtc.c                      |  6 ++++--
 drivers/gpu/drm/drm_plane_helper.c              |  2 +-
 drivers/gpu/drm/exynos/exynos_drm_plane.c       |  2 +-
 drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_plane.c     |  2 +-
 drivers/gpu/drm/i915/intel_display.c            |  4 ++--
 drivers/gpu/drm/i915/intel_sprite.c             |  2 +-
 drivers/gpu/drm/imx/ipuv3-plane.c               |  3 ++-
 drivers/gpu/drm/msm/mdp/mdp4/mdp4_plane.c       |  3 ++-
 drivers/gpu/drm/msm/mdp/mdp5/mdp5_plane.c       |  2 +-
 drivers/gpu/drm/omapdrm/omap_plane.c            |  2 +-
 drivers/gpu/drm/rcar-du/rcar_du_plane.c         |  3 ++-
 drivers/gpu/drm/rockchip/rockchip_drm_vop.c     |  4 ++--
 drivers/gpu/drm/sti/sti_cursor.c                |  2 +-
 drivers/gpu/drm/sti/sti_gdp.c                   |  2 +-
 drivers/gpu/drm/sti/sti_hqvdp.c                 |  2 +-
 drivers/gpu/drm/tegra/dc.c                      |  9 ++++++---
 drivers/gpu/drm/vc4/vc4_plane.c                 |  2 +-
 drivers/gpu/drm/virtio/virtgpu_plane.c          |  2 +-
 include/drm/drm_crtc.h                          | 16 +++++++++-------
 22 files changed, 43 insertions(+), 33 deletions(-)
diff --git a/drivers/gpu/drm/armada/armada_crtc.c b/drivers/gpu/drm/armada/armada_crtc.c
index c3f3a70..9bdc28c 100644
--- a/drivers/gpu/drm/armada/armada_crtc.c
+++ b/drivers/gpu/drm/armada/armada_crtc.c
@@ -1216,7 +1216,7 @@ static int armada_drm_crtc_create(struct drm_device *drm, struct device *dev,
 				       &armada_primary_plane_funcs,
 				       armada_primary_formats,
 				       ARRAY_SIZE(armada_primary_formats),
-				       DRM_PLANE_TYPE_PRIMARY);
+				       DRM_PLANE_TYPE_PRIMARY, NULL);
 	if (ret) {
 		kfree(primary);
 		return ret;
diff --git a/drivers/gpu/drm/armada/armada_overlay.c b/drivers/gpu/drm/armada/armada_overlay.c
index 5c22b38..148e8a4 100644
--- a/drivers/gpu/drm/armada/armada_overlay.c
+++ b/drivers/gpu/drm/armada/armada_overlay.c
@@ -460,7 +460,7 @@ int armada_overlay_plane_create(struct drm_device *dev, unsigned long crtcs)
 				       &armada_ovl_plane_funcs,
 				       armada_ovl_formats,
 				       ARRAY_SIZE(armada_ovl_formats),
-				       DRM_PLANE_TYPE_OVERLAY);
+				       DRM_PLANE_TYPE_OVERLAY, NULL);
 	if (ret) {
 		kfree(dplane);
 		return ret;
diff --git a/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_plane.c b/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_plane.c
index d0299ae..1ffe9c3 100644
--- a/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_plane.c
+++ b/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_plane.c
@@ -941,7 +941,7 @@ atmel_hlcdc_plane_create(struct drm_device *dev,
 	ret = drm_universal_plane_init(dev, &plane->base, 0,
 				       &layer_plane_funcs,
 				       desc->formats->formats,
-				       desc->formats->nformats, type);
+				       desc->formats->nformats, type, NULL);
 	if (ret)
 		return ERR_PTR(ret);
diff --git a/drivers/gpu/drm/drm_crtc.c b/drivers/gpu/drm/drm_crtc.c
index 27922bb..20d67a0 100644
--- a/drivers/gpu/drm/drm_crtc.c
+++ b/drivers/gpu/drm/drm_crtc.c
@@ -1152,6 +1152,7 @@ EXPORT_SYMBOL(drm_encoder_cleanup);
  * @formats: array of supported formats (%DRM_FORMAT_*)
  * @format_count: number of elements in @formats
  * @type: type of plane (overlay, primary, cursor)
+ * @name: printf style format string for the plane name, or NULL for default name
  * Initializes a plane object of type @type.
@@ -1162,7 +1163,8 @@ int drm_universal_plane_init(struct drm_device *dev, struct drm_plane *plane,
 			     const uint32_t *formats, unsigned int format_count,
-			     enum drm_plane_type type)
+			     enum drm_plane_type type,
+			     const char *name, ...)
 	struct drm_mode_config *config = &dev->mode_config;
 	int ret;
@@ -1242,7 +1244,7 @@ int drm_plane_init(struct drm_device *dev, struct drm_plane *plane,
 	type = is_primary ? DRM_PLANE_TYPE_PRIMARY : DRM_PLANE_TYPE_OVERLAY;
 	return drm_universal_plane_init(dev, plane, possible_crtcs, funcs,
-					formats, format_count, type);
+					formats, format_count, type, NULL);
 EXPORT_SYMBOL(drm_plane_init);
diff --git a/drivers/gpu/drm/drm_plane_helper.c b/drivers/gpu/drm/drm_plane_helper.c
index f5a4273..369d2898 100644
--- a/drivers/gpu/drm/drm_plane_helper.c
+++ b/drivers/gpu/drm/drm_plane_helper.c
@@ -375,7 +375,7 @@ static struct drm_plane *create_primary_plane(struct drm_device *dev)
 				       &drm_primary_helper_funcs,
 				       safe_modeset_formats,
 				       ARRAY_SIZE(safe_modeset_formats),
 	if (ret) {
 		kfree(primary);
 		primary = NULL;
diff --git a/drivers/gpu/drm/exynos/exynos_drm_plane.c b/drivers/gpu/drm/exynos/exynos_drm_plane.c
index 1793117..383ee1e 100644
--- a/drivers/gpu/drm/exynos/exynos_drm_plane.c
+++ b/drivers/gpu/drm/exynos/exynos_drm_plane.c
@@ -228,7 +228,7 @@ int exynos_plane_init(struct drm_device *dev,
 	err = drm_universal_plane_init(dev, &exynos_plane->base, possible_crtcs,
 				       &exynos_plane_funcs, formats, fcount,
-				       type);
+				       type, NULL);
 	if (err) {
 		DRM_ERROR("failed to initialize plane\n");
 		return err;
diff --git a/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_plane.c b/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_plane.c
index 51daaea..4b13cf9 100644
--- a/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_plane.c
+++ b/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_plane.c
@@ -249,7 +249,7 @@ struct drm_plane *fsl_dcu_drm_primary_create_plane(struct drm_device *dev)
 				       &fsl_dcu_drm_plane_funcs,
 				       fsl_dcu_drm_plane_formats,
 				       ARRAY_SIZE(fsl_dcu_drm_plane_formats),
 	if (ret) {
 		kfree(primary);
 		primary = NULL;
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index 5a33707..fc0d53a 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -13904,7 +13904,7 @@ static struct drm_plane *intel_primary_plane_create(struct drm_device *dev,
 	drm_universal_plane_init(dev, &primary->base, 0,
 				 &intel_plane_funcs,
 				 intel_primary_formats, num_formats,
 	if (INTEL_INFO(dev)->gen >= 4)
 		intel_create_rotation_property(dev, primary);
@@ -14043,7 +14043,7 @@ static struct drm_plane *intel_cursor_plane_create(struct drm_device *dev,
 				 &intel_plane_funcs,
 				 intel_cursor_formats,
 				 ARRAY_SIZE(intel_cursor_formats),
-				 DRM_PLANE_TYPE_CURSOR);
+				 DRM_PLANE_TYPE_CURSOR, NULL);
 	if (INTEL_INFO(dev)->gen >= 4) {
 		if (!dev->mode_config.rotation_property)
diff --git a/drivers/gpu/drm/i915/intel_sprite.c b/drivers/gpu/drm/i915/intel_sprite.c
index 2b96f33..dbf4213 100644
--- a/drivers/gpu/drm/i915/intel_sprite.c
+++ b/drivers/gpu/drm/i915/intel_sprite.c
@@ -1123,7 +1123,7 @@ intel_plane_init(struct drm_device *dev, enum pipe pipe, int plane)
 	ret = drm_universal_plane_init(dev, &intel_plane->base, possible_crtcs,
 				       &intel_plane_funcs,
 				       plane_formats, num_plane_formats,
 	if (ret) {
 		kfree(intel_plane);
 		goto out;
diff --git a/drivers/gpu/drm/imx/ipuv3-plane.c b/drivers/gpu/drm/imx/ipuv3-plane.c
index e2ff410..591ba2f 100644
--- a/drivers/gpu/drm/imx/ipuv3-plane.c
+++ b/drivers/gpu/drm/imx/ipuv3-plane.c
@@ -401,7 +401,8 @@ struct ipu_plane *ipu_plane_init(struct drm_device *dev, struct ipu_soc *ipu,
 	ret = drm_universal_plane_init(dev, &ipu_plane->base, possible_crtcs,
 				       &ipu_plane_funcs, ipu_plane_formats,
-				       ARRAY_SIZE(ipu_plane_formats), type);
+				       ARRAY_SIZE(ipu_plane_formats), type,
+				       NULL);
 	if (ret) {
 		kfree(ipu_plane);
diff --git a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_plane.c b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_plane.c
index 30d57e7..9f96dfe 100644
--- a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_plane.c
+++ b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_plane.c
@@ -397,7 +397,8 @@ struct drm_plane *mdp4_plane_init(struct drm_device *dev,
 	type = private_plane ? DRM_PLANE_TYPE_PRIMARY : DRM_PLANE_TYPE_OVERLAY;
 	ret = drm_universal_plane_init(dev, plane, 0xff, &mdp4_plane_funcs,
-				 mdp4_plane->formats, mdp4_plane->nformats, type);
+				 mdp4_plane->formats, mdp4_plane->nformats,
+				 type, NULL);
 	if (ret)
 		goto fail;
diff --git a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_plane.c b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_plane.c
index 81cd490..432c098 100644
--- a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_plane.c
+++ b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_plane.c
@@ -904,7 +904,7 @@ struct drm_plane *mdp5_plane_init(struct drm_device *dev,
 	ret = drm_universal_plane_init(dev, plane, 0xff, &mdp5_plane_funcs,
 				 mdp5_plane->formats, mdp5_plane->nformats,
-				 type);
+				 type, NULL);
 	if (ret)
 		goto fail;
diff --git a/drivers/gpu/drm/omapdrm/omap_plane.c b/drivers/gpu/drm/omapdrm/omap_plane.c
index 3054bda..d5ecabd 100644
--- a/drivers/gpu/drm/omapdrm/omap_plane.c
+++ b/drivers/gpu/drm/omapdrm/omap_plane.c
@@ -366,7 +366,7 @@ struct drm_plane *omap_plane_init(struct drm_device *dev,
 	ret = drm_universal_plane_init(dev, plane, (1 << priv->num_crtcs) - 1,
 				       &omap_plane_funcs, omap_plane->formats,
-				       omap_plane->nformats, type);
+				       omap_plane->nformats, type, NULL);
 	if (ret < 0)
 		goto error;
diff --git a/drivers/gpu/drm/rcar-du/rcar_du_plane.c b/drivers/gpu/drm/rcar-du/rcar_du_plane.c
index ffa5837..c3ed952 100644
--- a/drivers/gpu/drm/rcar-du/rcar_du_plane.c
+++ b/drivers/gpu/drm/rcar-du/rcar_du_plane.c
@@ -410,7 +410,8 @@ int rcar_du_planes_init(struct rcar_du_group *rgrp)
 		ret = drm_universal_plane_init(rcdu->ddev, &plane->plane, crtcs,
 					       &rcar_du_plane_funcs, formats,
-					       ARRAY_SIZE(formats), type);
+					       ARRAY_SIZE(formats), type,
+					       NULL);
 		if (ret < 0)
 			return ret;
diff --git a/drivers/gpu/drm/rockchip/rockchip_drm_vop.c b/drivers/gpu/drm/rockchip/rockchip_drm_vop.c
index 8e89e80..dd8e086 100644
--- a/drivers/gpu/drm/rockchip/rockchip_drm_vop.c
+++ b/drivers/gpu/drm/rockchip/rockchip_drm_vop.c
@@ -1478,7 +1478,7 @@ static int vop_create_crtc(struct vop *vop)
 					       0, &vop_plane_funcs,
 					       win_data->phy->data_formats,
 					       win_data->phy->nformats,
-					       win_data->type);
+					       win_data->type, NULL);
 		if (ret) {
 			goto err_cleanup_planes;
@@ -1515,7 +1515,7 @@ static int vop_create_crtc(struct vop *vop)
 					       &vop_plane_funcs,
-					       win_data->type);
 		if (ret) {
 			DRM_ERROR("failed to initialize overlay plane\n");
 			goto err_cleanup_crtc;
diff --git a/drivers/gpu/drm/sti/sti_cursor.c b/drivers/gpu/drm/sti/sti_cursor.c
index dd10321..8078631 100644
--- a/drivers/gpu/drm/sti/sti_cursor.c
+++ b/drivers/gpu/drm/sti/sti_cursor.c
@@ -272,7 +272,7 @@ struct drm_plane *sti_cursor_create(struct drm_device *drm_dev,
 				       &sti_plane_helpers_funcs,
 				       cursor_supported_formats,
 				       ARRAY_SIZE(cursor_supported_formats),
 	if (res) {
 		DRM_ERROR("Failed to initialize universal plane\n");
 		goto err_plane;
diff --git a/drivers/gpu/drm/sti/sti_gdp.c b/drivers/gpu/drm/sti/sti_gdp.c
index c85dc7d..f9a1d92 100644
--- a/drivers/gpu/drm/sti/sti_gdp.c
+++ b/drivers/gpu/drm/sti/sti_gdp.c
@@ -630,7 +630,7 @@ struct drm_plane *sti_gdp_create(struct drm_device *drm_dev,
 				       gdp_supported_formats,
 				       ARRAY_SIZE(gdp_supported_formats),
-				       type);
+				       type, NULL);
 	if (res) {
 		goto err;
diff --git a/drivers/gpu/drm/sti/sti_hqvdp.c b/drivers/gpu/drm/sti/sti_hqvdp.c
index ea0690b..43861b5 100644
--- a/drivers/gpu/drm/sti/sti_hqvdp.c
+++ b/drivers/gpu/drm/sti/sti_hqvdp.c
@@ -973,7 +973,7 @@ static struct drm_plane *sti_hqvdp_create(struct drm_device *drm_dev,
 				       hqvdp_supported_formats,
 				       ARRAY_SIZE(hqvdp_supported_formats),
 	if (res) {
 		return NULL;
diff --git a/drivers/gpu/drm/tegra/dc.c b/drivers/gpu/drm/tegra/dc.c
index be89410..1f5cb68 100644
--- a/drivers/gpu/drm/tegra/dc.c
+++ b/drivers/gpu/drm/tegra/dc.c
@@ -660,7 +660,8 @@ static struct drm_plane *tegra_dc_primary_plane_create(struct drm_device *drm,
 	err = drm_universal_plane_init(drm, &plane->base, possible_crtcs,
 				       &tegra_primary_plane_funcs, formats,
-				       num_formats, DRM_PLANE_TYPE_PRIMARY);
+				       num_formats, DRM_PLANE_TYPE_PRIMARY,
+				       NULL);
 	if (err < 0) {
 		kfree(plane);
 		return ERR_PTR(err);
@@ -827,7 +828,8 @@ static struct drm_plane *tegra_dc_cursor_plane_create(struct drm_device *drm,
 	err = drm_universal_plane_init(drm, &plane->base, 1 << dc->pipe,
 				       &tegra_cursor_plane_funcs, formats,
-				       num_formats, DRM_PLANE_TYPE_CURSOR);
+				       num_formats, DRM_PLANE_TYPE_CURSOR,
+				       NULL);
 	if (err < 0) {
 		kfree(plane);
@@ -890,7 +892,8 @@ static struct drm_plane *tegra_dc_overlay_plane_create(struct drm_device *drm,
 				       &tegra_overlay_plane_funcs, formats,
-				       num_formats, DRM_PLANE_TYPE_OVERLAY);
+				       num_formats, DRM_PLANE_TYPE_OVERLAY,
+				       NULL);
 	if (err < 0) {
 		kfree(plane);
diff --git a/drivers/gpu/drm/vc4/vc4_plane.c b/drivers/gpu/drm/vc4/vc4_plane.c
index 887f3ca..f34c422 100644
--- a/drivers/gpu/drm/vc4/vc4_plane.c
+++ b/drivers/gpu/drm/vc4/vc4_plane.c
@@ -317,7 +317,7 @@ struct drm_plane *vc4_plane_init(struct drm_device *dev,
 				       &vc4_plane_funcs,
 				       formats, ARRAY_SIZE(formats),
-				       type);
+				       type, NULL);
 	drm_plane_helper_add(plane, &vc4_plane_helper_funcs);
diff --git a/drivers/gpu/drm/virtio/virtgpu_plane.c b/drivers/gpu/drm/virtio/virtgpu_plane.c
index 4a74129..572fb35 100644
--- a/drivers/gpu/drm/virtio/virtgpu_plane.c
+++ b/drivers/gpu/drm/virtio/virtgpu_plane.c
@@ -107,7 +107,7 @@ struct drm_plane *virtio_gpu_plane_init(struct virtio_gpu_device *vgdev,
 				       &virtio_gpu_plane_funcs,
 				       virtio_gpu_formats,
 				       ARRAY_SIZE(virtio_gpu_formats),
 	if (ret)
 		goto err_plane_init;
diff --git a/include/drm/drm_crtc.h b/include/drm/drm_crtc.h
index f0127e7..a6f0e25 100644
--- a/include/drm/drm_crtc.h
+++ b/include/drm/drm_crtc.h
@@ -2214,13 +2214,15 @@ static inline bool drm_encoder_crtc_ok(struct drm_encoder *encoder,
 	return !!(encoder->possible_crtcs & drm_crtc_mask(crtc));
-extern int drm_universal_plane_init(struct drm_device *dev,
-				    struct drm_plane *plane,
-				    unsigned long possible_crtcs,
-				    const struct drm_plane_funcs *funcs,
-				    const uint32_t *formats,
-				    unsigned int format_count,
-				    enum drm_plane_type type);
+extern __printf(8, 9)
+int drm_universal_plane_init(struct drm_device *dev,
+			     struct drm_plane *plane,
+			     unsigned long possible_crtcs,
+			     const struct drm_plane_funcs *funcs,
+			     const uint32_t *formats,
+			     unsigned int format_count,
+			     const char *name, ...);
 extern int drm_plane_init(struct drm_device *dev,
BtrLinux
Privacy Overview
