drm: Pass ‘name’ to drm_crtc_init_with_planes()
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Done with coccinelle for the most part. However, it thinks '...' is
part of the semantic patch, so I put an 'int DOTDOTDOT' placeholder
in its place and got rid of it with sed afterwards.
I didn't convert drm_crtc_init() since passing the varargs through
would mean either cpp macros or va_list, and I figured we don't
care about these legacy functions enough to warrant the extra pain.
identifier dev, crtc, primary, cursor, funcs;
 int drm_crtc_init_with_planes(struct drm_device *dev,
                               struct drm_crtc *crtc,
                               struct drm_plane *primary, struct drm_plane *cursor,
                               const struct drm_crtc_funcs *funcs
+                              ,const char *name, int DOTDOTDOT
expression E1, E2, E3, E4, E5;
 drm_crtc_init_with_planes(E1, E2, E3, E4, E5
+                          ,NULL
v2: Split crtc and plane changes apart
    Pass NULL for no-name instead of ""
    Leave drm_crtc_init() alone
v3: Add ', or NULL...' to @name kernel doc (Jani)
    Annotate the function with __printf() attribute (Jani)
Signed-off-by: Ville Syrjälä
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/1449670771-2751-1-git-send-email-ville.syrjala@linux.intel.com
 drivers/gpu/drm/armada/armada_crtc.c           |  2 +-
 drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_crtc.c |  2 +-
 drivers/gpu/drm/drm_crtc.c                     |  4 +++-
 drivers/gpu/drm/drm_plane_helper.c             |  3 ++-
 drivers/gpu/drm/exynos/exynos_drm_crtc.c       |  2 +-
 drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_crtc.c     |  2 +-
 drivers/gpu/drm/i915/intel_display.c           |  2 +-
 drivers/gpu/drm/imx/imx-drm-core.c             |  2 +-
 drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c       |  3 ++-
 drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c       |  3 ++-
 drivers/gpu/drm/omapdrm/omap_crtc.c            |  2 +-
 drivers/gpu/drm/rcar-du/rcar_du_crtc.c         |  2 +-
 drivers/gpu/drm/rockchip/rockchip_drm_vop.c    |  2 +-
 drivers/gpu/drm/sti/sti_crtc.c                 |  2 +-
 drivers/gpu/drm/tegra/dc.c                     |  2 +-
 drivers/gpu/drm/vc4/vc4_crtc.c                 |  2 +-
 drivers/gpu/drm/virtio/virtgpu_display.c       |  2 +-
 include/drm/drm_crtc.h                         | 12 +++++++-----
 18 files changed, 29 insertions(+), 22 deletions(-)
diff --git a/drivers/gpu/drm/armada/armada_crtc.c b/drivers/gpu/drm/armada/armada_crtc.c
index cebcab5..c3f3a70 100644
--- a/drivers/gpu/drm/armada/armada_crtc.c
+++ b/drivers/gpu/drm/armada/armada_crtc.c
@@ -1223,7 +1223,7 @@ static int armada_drm_crtc_create(struct drm_device *drm, struct device *dev,
 	ret = drm_crtc_init_with_planes(drm, &dcrtc->crtc, &primary->base, NULL,
-					&armada_crtc_funcs);
+					&armada_crtc_funcs, NULL);
 	if (ret)
 		goto err_crtc_init;
diff --git a/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_crtc.c b/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_crtc.c
index 9f6e234..468a14f 100644
--- a/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_crtc.c
+++ b/drivers/gpu/drm/atmel-hlcdc/atmel_hlcdc_crtc.c
@@ -344,7 +344,7 @@ int atmel_hlcdc_crtc_create(struct drm_device *dev)
 	ret = drm_crtc_init_with_planes(dev, &crtc->base,
 				&planes->primary->base,
 				planes->cursor ? &planes->cursor->base : NULL,
-				&atmel_hlcdc_crtc_funcs);
+				&atmel_hlcdc_crtc_funcs, NULL);
 	if (ret < 0)
 		goto fail;
diff --git a/drivers/gpu/drm/drm_crtc.c b/drivers/gpu/drm/drm_crtc.c
index 99e7efe..27922bb 100644
--- a/drivers/gpu/drm/drm_crtc.c
+++ b/drivers/gpu/drm/drm_crtc.c
@@ -657,6 +657,7 @@ DEFINE_WW_CLASS(crtc_ww_class);
  * @primary: Primary plane for CRTC
  * @cursor: Cursor plane for CRTC
  * @funcs: callbacks for the new CRTC
+ * @name: printf style format string for the CRTC name, or NULL for default name
  * Inits a new object created as base part of a driver crtc object.
@@ -666,7 +667,8 @@ DEFINE_WW_CLASS(crtc_ww_class);
 int drm_crtc_init_with_planes(struct drm_device *dev, struct drm_crtc *crtc,
-			      const struct drm_crtc_funcs *funcs)
+			      const struct drm_crtc_funcs *funcs,
+			      const char *name, ...)
 	struct drm_mode_config *config = &dev->mode_config;
 	int ret;
diff --git a/drivers/gpu/drm/drm_plane_helper.c b/drivers/gpu/drm/drm_plane_helper.c
index 8455e99..f5a4273 100644
--- a/drivers/gpu/drm/drm_plane_helper.c
+++ b/drivers/gpu/drm/drm_plane_helper.c
@@ -402,7 +402,8 @@ int drm_crtc_init(struct drm_device *dev, struct drm_crtc *crtc,
 	struct drm_plane *primary;
 	primary = create_primary_plane(dev);
-	return drm_crtc_init_with_planes(dev, crtc, primary, NULL, funcs);
+	return drm_crtc_init_with_planes(dev, crtc, primary, NULL, funcs,
+					 NULL);
 EXPORT_SYMBOL(drm_crtc_init);
diff --git a/drivers/gpu/drm/exynos/exynos_drm_crtc.c b/drivers/gpu/drm/exynos/exynos_drm_crtc.c
index b3ba27f..9d30a0f 100644
--- a/drivers/gpu/drm/exynos/exynos_drm_crtc.c
+++ b/drivers/gpu/drm/exynos/exynos_drm_crtc.c
@@ -150,7 +150,7 @@ struct exynos_drm_crtc *exynos_drm_crtc_create(struct drm_device *drm_dev,
 	private->crtc[pipe] = crtc;
 	ret = drm_crtc_init_with_planes(drm_dev, crtc, plane, NULL,
-					&exynos_crtc_funcs);
+					&exynos_crtc_funcs, NULL);
 	if (ret < 0)
 		goto err_crtc;
diff --git a/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_crtc.c b/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_crtc.c
index 82a3d31..d8ab8f0 100644
--- a/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_crtc.c
+++ b/drivers/gpu/drm/fsl-dcu/fsl_dcu_drm_crtc.c
@@ -175,7 +175,7 @@ int fsl_dcu_drm_crtc_create(struct fsl_dcu_drm_device *fsl_dev)
 	primary = fsl_dcu_drm_primary_create_plane(fsl_dev->drm);
 	ret = drm_crtc_init_with_planes(fsl_dev->drm, crtc, primary, NULL,
-					&fsl_dcu_drm_crtc_funcs);
+					&fsl_dcu_drm_crtc_funcs, NULL);
 	if (ret < 0)
 		return ret;
diff --git a/drivers/gpu/drm/i915/intel_display.c b/drivers/gpu/drm/i915/intel_display.c
index 696f754..5a33707 100644
--- a/drivers/gpu/drm/i915/intel_display.c
+++ b/drivers/gpu/drm/i915/intel_display.c
@@ -14120,7 +14120,7 @@ static void intel_crtc_init(struct drm_device *dev, int pipe)
 		goto fail;
 	ret = drm_crtc_init_with_planes(dev, &intel_crtc->base, primary,
-					cursor, &intel_crtc_funcs);
+					cursor, &intel_crtc_funcs, NULL);
 	if (ret)
 		goto fail;
diff --git a/drivers/gpu/drm/imx/imx-drm-core.c b/drivers/gpu/drm/imx/imx-drm-core.c
index 882cf3d..09e20ea 100644
--- a/drivers/gpu/drm/imx/imx-drm-core.c
+++ b/drivers/gpu/drm/imx/imx-drm-core.c
@@ -373,7 +373,7 @@ int imx_drm_add_crtc(struct drm_device *drm, struct drm_crtc *crtc,
 			imx_drm_crtc->imx_drm_helper_funcs.crtc_helper_funcs);
 	drm_crtc_init_with_planes(drm, crtc, primary_plane, NULL,
-			imx_drm_crtc->imx_drm_helper_funcs.crtc_funcs);
+			imx_drm_crtc->imx_drm_helper_funcs.crtc_funcs, NULL);
 	return 0;
diff --git a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
index 6ac9aa1..28df397 100644
--- a/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
+++ b/drivers/gpu/drm/msm/mdp/mdp4/mdp4_crtc.c
@@ -678,7 +678,8 @@ struct drm_crtc *mdp4_crtc_init(struct drm_device *dev,
 	drm_flip_work_init(&mdp4_crtc->unref_cursor_work,
 			"unref cursor", unref_cursor_worker);
-	drm_crtc_init_with_planes(dev, crtc, plane, NULL, &mdp4_crtc_funcs);
+	drm_crtc_init_with_planes(dev, crtc, plane, NULL, &mdp4_crtc_funcs,
+				  NULL);
 	drm_crtc_helper_add(crtc, &mdp4_crtc_helper_funcs);
 	plane->crtc = crtc;
diff --git a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
index 7f9f4ac..20cee5c 100644
--- a/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
+++ b/drivers/gpu/drm/msm/mdp/mdp5/mdp5_crtc.c
@@ -797,7 +797,8 @@ struct drm_crtc *mdp5_crtc_init(struct drm_device *dev,
 	snprintf(mdp5_crtc->name, sizeof(mdp5_crtc->name), "%s:%d",
 			pipe2name(mdp5_plane_pipe(plane)), id);
-	drm_crtc_init_with_planes(dev, crtc, plane, NULL, &mdp5_crtc_funcs);
+	drm_crtc_init_with_planes(dev, crtc, plane, NULL, &mdp5_crtc_funcs,
+				  NULL);
 	drm_flip_work_init(&mdp5_crtc->unref_cursor_work,
diff --git a/drivers/gpu/drm/omapdrm/omap_crtc.c b/drivers/gpu/drm/omapdrm/omap_crtc.c
index ad09590..2ed0754 100644
--- a/drivers/gpu/drm/omapdrm/omap_crtc.c
+++ b/drivers/gpu/drm/omapdrm/omap_crtc.c
@@ -524,7 +524,7 @@ struct drm_crtc *omap_crtc_init(struct drm_device *dev,
 	omap_crtc->mgr = omap_dss_get_overlay_manager(channel);
 	ret = drm_crtc_init_with_planes(dev, crtc, plane, NULL,
-					&omap_crtc_funcs);
+					&omap_crtc_funcs, NULL);
 	if (ret < 0) {
 		kfree(omap_crtc);
 		return NULL;
diff --git a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
index 48cb199..88a4b70 100644
--- a/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
+++ b/drivers/gpu/drm/rcar-du/rcar_du_crtc.c
@@ -613,7 +613,7 @@ int rcar_du_crtc_create(struct rcar_du_group *rgrp, unsigned int index)
 	ret = drm_crtc_init_with_planes(rcdu->ddev, crtc,
 					&rgrp->planes[index % 2].plane,
-					NULL, &crtc_funcs);
+					NULL, &crtc_funcs, NULL);
 	if (ret < 0)
 		return ret;
diff --git a/drivers/gpu/drm/rockchip/rockchip_drm_vop.c b/drivers/gpu/drm/rockchip/rockchip_drm_vop.c
index 03c47ee..8e89e80 100644
--- a/drivers/gpu/drm/rockchip/rockchip_drm_vop.c
+++ b/drivers/gpu/drm/rockchip/rockchip_drm_vop.c
@@ -1492,7 +1492,7 @@ static int vop_create_crtc(struct vop *vop)
 	ret = drm_crtc_init_with_planes(drm_dev, crtc, primary, cursor,
-					&vop_crtc_funcs);
+					&vop_crtc_funcs, NULL);
 	if (ret)
 		return ret;
diff --git a/drivers/gpu/drm/sti/sti_crtc.c b/drivers/gpu/drm/sti/sti_crtc.c
index 3ae09dc..de11c7c 100644
--- a/drivers/gpu/drm/sti/sti_crtc.c
+++ b/drivers/gpu/drm/sti/sti_crtc.c
@@ -367,7 +367,7 @@ int sti_crtc_init(struct drm_device *drm_dev, struct sti_mixer *mixer,
 	int res;
 	res = drm_crtc_init_with_planes(drm_dev, crtc, primary, cursor,
-					&sti_crtc_funcs);
+					&sti_crtc_funcs, NULL);
 	if (res) {
 		DRM_ERROR("Can't initialze CRTC\n");
 		return -EINVAL;
diff --git a/drivers/gpu/drm/tegra/dc.c b/drivers/gpu/drm/tegra/dc.c
index e9f24a8..be89410 100644
--- a/drivers/gpu/drm/tegra/dc.c
+++ b/drivers/gpu/drm/tegra/dc.c
@@ -1732,7 +1732,7 @@ static int tegra_dc_init(struct host1x_client *client)
 	err = drm_crtc_init_with_planes(drm, &dc->base, primary, cursor,
-					&tegra_crtc_funcs);
+					&tegra_crtc_funcs, NULL);
 	if (err < 0)
 		goto cleanup;
diff --git a/drivers/gpu/drm/vc4/vc4_crtc.c b/drivers/gpu/drm/vc4/vc4_crtc.c
index 265064c..2168a99 100644
--- a/drivers/gpu/drm/vc4/vc4_crtc.c
+++ b/drivers/gpu/drm/vc4/vc4_crtc.c
@@ -606,7 +606,7 @@ static int vc4_crtc_bind(struct device *dev, struct device *master, void *data)
 	drm_crtc_init_with_planes(drm, crtc, primary_plane, cursor_plane,
-				  &vc4_crtc_funcs);
+				  &vc4_crtc_funcs, NULL);
 	drm_crtc_helper_add(crtc, &vc4_crtc_helper_funcs);
 	primary_plane->crtc = crtc;
 	cursor_plane->crtc = crtc;
diff --git a/drivers/gpu/drm/virtio/virtgpu_display.c b/drivers/gpu/drm/virtio/virtgpu_display.c
index 623c98c..ef4cef0 100644
--- a/drivers/gpu/drm/virtio/virtgpu_display.c
+++ b/drivers/gpu/drm/virtio/virtgpu_display.c
@@ -431,7 +431,7 @@ static int vgdev_output_init(struct virtio_gpu_device *vgdev, int index)
 	if (IS_ERR(plane))
 		return PTR_ERR(plane);
-				  &virtio_gpu_crtc_funcs);
+				  &virtio_gpu_crtc_funcs, NULL);
 	drm_mode_crtc_set_gamma_size(crtc, 256);
 	drm_crtc_helper_add(crtc, &virtio_gpu_crtc_helper_funcs);
 	plane->crtc = crtc;
diff --git a/include/drm/drm_crtc.h b/include/drm/drm_crtc.h
index 4f587a5..f0127e7 100644
--- a/include/drm/drm_crtc.h
+++ b/include/drm/drm_crtc.h
@@ -2144,11 +2144,13 @@ struct drm_prop_enum_list {
 	char *name;
-extern int drm_crtc_init_with_planes(struct drm_device *dev,
-				     struct drm_crtc *crtc,
-				     struct drm_plane *primary,
-				     struct drm_plane *cursor,
-				     const struct drm_crtc_funcs *funcs);
+extern __printf(6, 7)
+int drm_crtc_init_with_planes(struct drm_device *dev,
+			      struct drm_crtc *crtc,
+			      struct drm_plane *primary,
+			      struct drm_plane *cursor,
+			      const char *name, ...);
 extern void drm_crtc_cleanup(struct drm_crtc *crtc);
 extern unsigned int drm_crtc_index(struct drm_crtc *crtc);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
