drm: Move a dereference below a NULL test
If the NULL test is necessary, then the dereference should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: Dave Airlie
 drivers/gpu/drm/drm_stub.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/gpu/drm/drm_stub.c b/drivers/gpu/drm/drm_stub.c
index 155a5bb..55bb8a8 100644
--- a/drivers/gpu/drm/drm_stub.c
+++ b/drivers/gpu/drm/drm_stub.c
@@ -489,7 +489,7 @@ int drm_put_minor(struct drm_minor **minor_p)
 void drm_put_dev(struct drm_device *dev)
-	struct drm_driver *driver = dev->driver;
+	struct drm_driver *driver;
 	struct drm_map_list *r_list, *list_temp;
 	DRM_DEBUG("\n");
@@ -498,6 +498,7 @@ void drm_put_dev(struct drm_device *dev)
 		DRM_ERROR("cleanup called no dev\n");
 		return;
+	driver = dev->driver;
 	drm_vblank_cleanup(dev); |
 	DRM_DEBUG("\n");
 		return;
