drm: i915: drop null test before destroy functions
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded NULL test.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@@ expression x; @@
-if (x != NULL)
\(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x);
Signed-off-by: Julia Lawall
Signed-off-by: Daniel Vetter
drivers/gpu/drm/i915/i915_dma.c | 19 ++++++-------------
1 file changed, 6 insertions(+), 13 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_dma.c b/drivers/gpu/drm/i915/i915_dma.c
index 817b05c..ae1ba47 100644
--- a/drivers/gpu/drm/i915/i915_dma.c
+++ b/drivers/gpu/drm/i915/i915_dma.c
@@ -1074,12 +1074,9 @@ out_freecsr:
put_bridge:
pci_dev_put(dev_priv->bridge_dev);
free_priv:
- if (dev_priv->requests)
- kmem_cache_destroy(dev_priv->requests);
- if (dev_priv->vmas)
- kmem_cache_destroy(dev_priv->vmas);
- if (dev_priv->objects)
- kmem_cache_destroy(dev_priv->objects);
+ kmem_cache_destroy(dev_priv->requests);
+ kmem_cache_destroy(dev_priv->vmas);
+ kmem_cache_destroy(dev_priv->objects);
kfree(dev_priv);
return ret;
@@ -1170,13 +1167,9 @@ int i915_driver_unload(struct drm_device *dev)
if (dev_priv->regs != NULL)
pci_iounmap(dev->pdev, dev_priv->regs);
kfree(dev_priv); |
put_bridge:
free_priv:
kfree(dev_priv);
return ret;
kfree(dev_priv);
