drivers/vlynq/vlynq.c: fix resource size off by 1 error
In this case, the calls to request_mem_region, ioremap, and
release_mem_region all have a consistent length argument, len, but since
in other files (res->end - res->start) + 1, equivalent to
resource_size(res), is used for a resource-typed structure res, one could
consider whether the same should be done here.
The problem was found using the following semantic patch:
(http://www.emn.fr/x-info/coccinelle/)
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
- res->end - res->start
+ BAD(resource_size(res))
Signed-off-by: Julia Lawall
Acked-by: Florian Fainelli
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/vlynq/vlynq.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/vlynq/vlynq.c b/drivers/vlynq/vlynq.c
index ba3d71f..9554ad5 100644
--- a/drivers/vlynq/vlynq.c
+++ b/drivers/vlynq/vlynq.c
@@ -702,7 +702,7 @@ static int vlynq_probe(struct platform_device *pdev)
 	dev->mem_start = mem_res->start;
 	dev->mem_end = mem_res->end;
-	len = regs_res->end - regs_res->start;
+	len = resource_size(regs_res);
 	if (!request_mem_region(regs_res->start, len, dev_name(&dev->dev))) {
 		printk(KERN_ERR "%s: Can't request vlynq registers\n",
 		       dev_name(&dev->dev));
BtrLinux
Privacy Overview
