drivers/video/via: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Cc: Joseph Chan
Cc: Scott Fang
Cc: Florian Tobias Schandinat
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/video/via/viafbdev.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/video/via/viafbdev.c b/drivers/video/via/viafbdev.c
index 2bc40e6..1082541 100644
--- a/drivers/video/via/viafbdev.c
+++ b/drivers/video/via/viafbdev.c
@@ -578,14 +578,9 @@ static int viafb_ioctl(struct fb_info *info, u_int cmd, u_long arg)
 		break;
 	case VIAFB_SET_GAMMA_LUT:
-		viafb_gamma_table = kmalloc(256 * sizeof(u32), GFP_KERNEL);
-		if (!viafb_gamma_table)
-			return -ENOMEM;
-		if (copy_from_user(viafb_gamma_table, argp,
-				256 * sizeof(u32))) {
-			kfree(viafb_gamma_table);
-			return -EFAULT;
+		viafb_gamma_table = memdup_user(argp, 256 * sizeof(u32));
+		if (IS_ERR(viafb_gamma_table))
+			return PTR_ERR(viafb_gamma_table);
 		viafb_set_gamma_table(viafb_bpp, viafb_gamma_table);
 		break;
BtrLinux
Privacy Overview
