drivers/video/sunxvr2500.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize return variable before exiting on an error path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Florian Tobias Schandinat
 drivers/video/sunxvr2500.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/sunxvr2500.c b/drivers/video/sunxvr2500.c
index 5848436..7fbcba8 100644
--- a/drivers/video/sunxvr2500.c
+++ b/drivers/video/sunxvr2500.c
@@ -181,8 +181,10 @@ static int __devinit s3d_pci_register(struct pci_dev *pdev,
 	sp->fb_size = info->fix.line_length * sp->height;
 	sp->fb_base = ioremap(sp->fb_base_phys, sp->fb_size);
-	if (!sp->fb_base)
+	if (!sp->fb_base) {
+		err = -ENOMEM;
 		goto err_release_pci;
 	err = s3d_set_fbinfo(sp);
 	if (err)
BtrLinux
Privacy Overview
