drivers/video/sm501fb.c: Convert release_resource to release_mem_region
Request_mem_region should be used with release_mem_region, not
release_resource.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@s exists@
expression e1,e2,e3,e4,e;
*e4 = request_mem_region(e1,e2,e3)
... when != e4 = e
*release_resource(e4);
Signed-off-by: Julia Lawall
Signed-off-by: Paul Mundt
 drivers/video/sm501fb.c | 24 ++++++++++++------------
 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/video/sm501fb.c b/drivers/video/sm501fb.c
index 56ef6b3..87f0be1 100644
--- a/drivers/video/sm501fb.c
+++ b/drivers/video/sm501fb.c
@@ -1625,22 +1625,22 @@ static int sm501fb_start(struct sm501fb_info *info,
 	return 0; /* everything is setup */
  err_mem_res:
-	release_resource(info->fbmem_res);
-	kfree(info->fbmem_res);
+	release_mem_region(info->fbmem_res->start,
+			   resource_size(info->fbmem_res));
  err_regs2d_map:
 	iounmap(info->regs2d);
  err_regs2d_res:
-	release_resource(info->regs2d_res);
-	kfree(info->regs2d_res);
+	release_mem_region(info->regs2d_res->start,
+			   resource_size(info->regs2d_res));
  err_regs_map:
 	iounmap(info->regs);
  err_regs_res:
-	release_resource(info->regs_res);
-	kfree(info->regs_res);
+	release_mem_region(info->regs_res->start,
+			   resource_size(info->regs_res));
  err_release:
 	return ret;
@@ -1652,16 +1652,16 @@ static void sm501fb_stop(struct sm501fb_info *info)
 	sm501_unit_power(info->dev->parent, SM501_GATE_DISPLAY, 0);
 	iounmap(info->fbmem);
 static int sm501fb_init_fb(struct fb_info *fb,
