drivers/video/savage/savagefb_driver.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Florian Tobias Schandinat
 drivers/video/savage/savagefb_driver.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/savage/savagefb_driver.c b/drivers/video/savage/savagefb_driver.c
index 0d0f52c..f4f53b0 100644
--- a/drivers/video/savage/savagefb_driver.c
+++ b/drivers/video/savage/savagefb_driver.c
@@ -2266,8 +2266,10 @@ static int __devinit savagefb_probe(struct pci_dev* dev,
 	lpitch = info->var.xres_virtual*((info->var.bits_per_pixel + 7) >> 3);
 	info->var.yres_virtual = info->fix.smem_len/lpitch;
-	if (info->var.yres_virtual < info->var.yres)
+	if (info->var.yres_virtual < info->var.yres) {
+		err = -ENOMEM;
 		goto failed;
 #if defined(CONFIG_FB_SAVAGE_ACCEL)
BtrLinux
Privacy Overview
