drivers/video/pxa168fb.c: add missing clk_put
Add a label for error-handling code in the case where only clk_get has
succeeded.  Rename the label failed to be consistent with the rest.
A simplified version of the semantic match that finds the missing clk_put
is as follows: (http://coccinelle.lip6.fr/)
@r exists@
expression e1,e2;
statement S;
e1 = clk_get@p1(...);
... when != e1 = e2
    when != clk_put(e1)
    when any
if (...) { ... when != clk_put(e1)
               when != if (...) { ... clk_put(e1) ... }
* return@p3 ...;
 } else S
Signed-off-by: Julia Lawall
Signed-off-by: Paul Mundt
 drivers/video/pxa168fb.c | 17 ++++++++++-------
 1 file changed, 10 insertions(+), 7 deletions(-)
diff --git a/drivers/video/pxa168fb.c b/drivers/video/pxa168fb.c
index 35f61dd..bb95ec5 100644
--- a/drivers/video/pxa168fb.c
+++ b/drivers/video/pxa168fb.c
@@ -623,19 +623,21 @@ static int __devinit pxa168fb_probe(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	if (res == NULL) {
 		dev_err(&pdev->dev, "no IO memory defined\n");
-		return -ENOENT;
+		ret = -ENOENT;
+		goto failed_put_clk;
 	irq = platform_get_irq(pdev, 0);
 	if (irq < 0) {
 		dev_err(&pdev->dev, "no IRQ defined\n");
-		return -ENOENT;
+		ret = -ENOENT;
 	info = framebuffer_alloc(sizeof(struct pxa168fb_info), &pdev->dev);
 	if (info == NULL) {
-		clk_put(clk);
-		return -ENOMEM;
+		ret = -ENOMEM;
 	/* Initialize private data */
@@ -671,7 +673,7 @@ static int __devinit pxa168fb_probe(struct platform_device *pdev)
 	fbi->reg_base = ioremap_nocache(res->start, resource_size(res));
 	if (fbi->reg_base == NULL) {
 		ret = -ENOMEM;
-		goto failed;
+		goto failed_free_info;
@@ -683,7 +685,7 @@ static int __devinit pxa168fb_probe(struct platform_device *pdev)
 						&fbi->fb_start_dma, GFP_KERNEL);
 	if (info->screen_base == NULL) {
 		ret = -ENOMEM;
-		goto failed;
 	info->fix.smem_start = (unsigned long)fbi->fb_start_dma;
@@ -772,8 +774,9 @@ failed_free_clk:
 failed_free_fbmem:
 	dma_free_coherent(fbi->dev, info->fix.smem_len,
 			info->screen_base, fbi->fb_start_dma);
-failed:
+failed_free_info:
 	kfree(info);
+failed_put_clk:
 	clk_put(clk);
 	dev_err(&pdev->dev, "frame buffer device init failed with %d\n", ret);
BtrLinux
Privacy Overview
