drivers/video/ps3fb.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Florian Tobias Schandinat
 drivers/video/ps3fb.c | 7 ++++++-
 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/video/ps3fb.c b/drivers/video/ps3fb.c
index 213fbbc..26d321d 100644
--- a/drivers/video/ps3fb.c
+++ b/drivers/video/ps3fb.c
@@ -1035,6 +1035,7 @@ static int __devinit ps3fb_probe(struct ps3_system_bus_device *dev)
 	if (status) {
 		dev_err(&dev->core, "%s: lv1_gpu_memory_allocate failed: %d\n",
 			__func__, status);
+		retval = -ENOMEM;
 		goto err_close_device;
 	dev_dbg(&dev->core, "ddr:lpar:0x%llx\n", ddr_lpar);
@@ -1047,6 +1048,7 @@ static int __devinit ps3fb_probe(struct ps3_system_bus_device *dev)
 		dev_err(&dev->core,
 			"%s: lv1_gpu_context_allocate failed: %d\n", __func__,
 			status);
+		retval = -ENOMEM;
 		goto err_gpu_memory_free;
@@ -1054,6 +1056,7 @@ static int __devinit ps3fb_probe(struct ps3_system_bus_device *dev)
 	dinfo = (void __force *)ioremap(lpar_driver_info, 128 * 1024);
 	if (!dinfo) {
 		dev_err(&dev->core, "%s: ioremap failed\n", __func__);
+		retval = -ENOMEM;
 		goto err_gpu_context_free;
@@ -1122,8 +1125,10 @@ static int __devinit ps3fb_probe(struct ps3_system_bus_device *dev)
 	info = framebuffer_alloc(sizeof(struct ps3fb_par), &dev->core);
-	if (!info)
+	if (!info) {
+		retval = -ENOMEM;
 		goto err_context_fb_close;
 	par = info->par;
 	par->mode_id = ~ps3fb_mode;	/* != ps3fb_mode, to trigger change */
BtrLinux
Privacy Overview
