drivers/video/mb862xx/mb862xxfbdrv.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Florian Tobias Schandinat
 drivers/video/mb862xx/mb862xxfbdrv.c | 10 +++++++---
 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/video/mb862xx/mb862xxfbdrv.c b/drivers/video/mb862xx/mb862xxfbdrv.c
index 57d940b..d68e332 100644
--- a/drivers/video/mb862xx/mb862xxfbdrv.c
+++ b/drivers/video/mb862xx/mb862xxfbdrv.c
@@ -1052,12 +1052,14 @@ static int __devinit mb862xx_pci_probe(struct pci_dev *pdev,
 		break;
 	default:
 		/* should never occur */
+		ret = -EIO;
 		goto rel_reg;
 	par->fb_base = ioremap(par->fb_base_phys, par->mapped_vram);
 	if (par->fb_base == NULL) {
 		dev_err(dev, "Cannot map framebuffer\n");
+		ret = -EIO;
 		goto rel_reg;
@@ -1073,11 +1075,13 @@ static int __devinit mb862xx_pci_probe(struct pci_dev *pdev,
 	dev_dbg(dev, "mmio phys 0x%llx 0x%lx\n",
 		(unsigned long long)par->mmio_base_phys, (ulong)par->mmio_len);
-	if (mb862xx_pci_gdc_init(par))
+	ret = mb862xx_pci_gdc_init(par);
+	if (ret)
 		goto io_unmap;
-	if (request_irq(par->irq, mb862xx_intr, IRQF_SHARED,
-			DRV_NAME, (void *)par)) {
+	ret = request_irq(par->irq, mb862xx_intr, IRQF_SHARED,
+			  DRV_NAME, (void *)par);
+	if (ret) {
 		dev_err(dev, "Cannot request irq\n");
 		goto io_unmap;
BtrLinux
Privacy Overview
