drivers/video/fsl-diu-fb.c: add missing of_node_put
of_node_put is needed before discarding a value received from
of_find_node_by_type, eg in error handling code.
The semantic patch that makes the change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
struct device_node *n;
struct device_node *n1;
struct device_node *n2;
statement S;
identifier f1,f2;
expression E1,E2;
constant C;
n = of_find_node_by_type(...)
if (!n) S
... when != of_node_put(n)
when != n1 = f1(n,...)
when != E1 = n
when any
when strict
+ of_node_put(n);
return -C;
of_node_put(n);
n2 = f2(n,...)
E2 = n
return ...;
Signed-off-by: Julia Lawall
Acked-by: Krzysztof Helt
Cc: Timur Tabi
Cc: York Sun
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/video/fsl-diu-fb.c | 8 ++++++--
1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/video/fsl-diu-fb.c b/drivers/video/fsl-diu-fb.c
index 9cd36c2..bd320a2 100644
--- a/drivers/video/fsl-diu-fb.c
+++ b/drivers/video/fsl-diu-fb.c
@@ -1649,8 +1649,10 @@ static int __init fsl_diu_init(void)
prop = of_get_property(np, "d-cache-size", NULL);
- if (prop == NULL)
+ if (prop == NULL) {
+ of_node_put(np);
return -ENODEV;
/* Freescale PLRU requires 13/8 times the cache size to do a proper
displacement flush
@@ -1659,8 +1661,10 @@ static int __init fsl_diu_init(void)
coherence_data_size /= 8;
prop = of_get_property(np, "d-cache-line-size", NULL);
- if (prop == NULL)
+ of_node_put(np);
return -ENODEV;
d_cache_line_size = *prop;
of_node_put(np); |
- if (prop == NULL)
+ of_node_put(np);
return -ENODEV;
displacement flush
- if (prop == NULL)
+ of_node_put(np);
return -ENODEV;
of_node_put(np);
