drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc()
Author: Luis R. Rodriguez <mcgrof@suse.com>
This driver uses the same area for MTRR as for the ioremap().
Convert the driver from using the x86-specific MTRR code to the
architecture-agnostic arch_phys_wc_add(). It will avoid MTRRs if
write-combining is available. In order to take advantage of that
also ensure the ioremapped area is requested as write-combining.
There are a few motivations for this:
a) Take advantage of PAT when available.
b) Help bury MTRR code away, MTRR is architecture-specific and on
   x86 it is being replaced by PAT.
c) Help with the goal of eventually using _PAGE_CACHE_UC over
   _PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
   de33c442e titled "x86 PAT: fix performance drop for glx,
   use UC minus for ioremap(), ioremap_nocache() and
   pci_mmap_page_range()").
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the ifdeffery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get an
MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Signed-off-by: Luis R. Rodriguez
Signed-off-by: Borislav Petkov
Acked-by: Tomi Valkeinen
Cc: Andrew Morton
Cc: Andy Lutomirski
Cc: Antonino Daplas
Cc: Arnd Bergmann
Cc: Daniel Vetter
Cc: Dave Airlie
Cc: H. Peter Anvin
Cc: Jean-Christophe Plagniol-Villard
Cc: Jingoo Han
Cc: Juergen Gross
Cc: Lad, Prabhakar
Cc: Laurent Pinchart
Cc: Linus Torvalds
Cc: Peter Zijlstra
Cc: Rob Clark
Cc: Suresh Siddha
Cc: Thomas Gleixner
Cc: airlied@linux.ie
Cc: benh@kernel.crashing.org
Cc: bhelgaas@google.com
Cc: dan.j.williams@intel.com
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: mst@redhat.com
Cc: toshi.kani@hp.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1440443613-13696-9-git-send-email-mcgrof@do-not-panic.com
Signed-off-by: Ingo Molnar
 drivers/video/fbdev/vt8623fb.c | 31 ++++++-------------------------
 1 file changed, 6 insertions(+), 25 deletions(-)
diff --git a/drivers/video/fbdev/vt8623fb.c b/drivers/video/fbdev/vt8623fb.c
index 8bac309..dd0f18e 100644
--- a/drivers/video/fbdev/vt8623fb.c
+++ b/drivers/video/fbdev/vt8623fb.c
@@ -26,13 +26,9 @@
 #include <linux/console.h> /* Why should fb driver call console functions? because console_lock() */
 #include <video/vga.h>
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
 struct vt8623fb_info {
 	char __iomem *mmio_base;
-	int mtrr_reg;
+	int wc_cookie;
 	struct vgastate state;
 	struct mutex open_lock;
 	unsigned int ref_count;
@@ -99,10 +95,7 @@ static struct svga_timing_regs vt8623_timing_regs     = {
 /* Module parameters */
 static char *mode_option = "640x480-8@60";
-#ifdef CONFIG_MTRR
 static int mtrr = 1;
-#endif
 MODULE_AUTHOR("(c) 2006 Ondrej Zajicek <santiago@crfreenet.org>");
 MODULE_LICENSE("GPL");
@@ -112,11 +105,8 @@ module_param(mode_option, charp, 0644);
 MODULE_PARM_DESC(mode_option, "Default video mode ('640x480-8@60', etc)");
 module_param_named(mode, mode_option, charp, 0);
 MODULE_PARM_DESC(mode, "Default video mode e.g. '648x480-8@60' (deprecated)");
-#ifdef CONFIG_MTRR
 module_param(mtrr, int, 0444);
 MODULE_PARM_DESC(mtrr, "Enable write-combining with MTRR (1=enable, 0=disable, default=1)");
-#endif
@@ -710,7 +700,7 @@ static int vt8623_pci_probe(struct pci_dev *dev, const struct pci_device_id *id)
 	info->fix.mmio_len = pci_resource_len(dev, 1);
 	/* Map physical IO memory address into kernel space */
-	info->screen_base = pci_iomap(dev, 0, 0);
+	info->screen_base = pci_iomap_wc(dev, 0, 0);
 	if (! info->screen_base) {
 		rc = -ENOMEM;
 		dev_err(info->device, "iomap for framebuffer failed\n");
@@ -781,12 +771,9 @@ static int vt8623_pci_probe(struct pci_dev *dev, const struct pci_device_id *id)
 	/* Record a reference to the driver data */
 	pci_set_drvdata(dev, info);
-#ifdef CONFIG_MTRR
-	if (mtrr) {
-		par->mtrr_reg = -1;
-		par->mtrr_reg = mtrr_add(info->fix.smem_start, info->fix.smem_len, MTRR_TYPE_WRCOMB, 1);
-#endif
+	if (mtrr)
+		par->wc_cookie = arch_phys_wc_add(info->fix.smem_start,
+						  info->fix.smem_len);
 	return 0;
@@ -816,13 +803,7 @@ static void vt8623_pci_remove(struct pci_dev *dev)
 	if (info) {
 		struct vt8623fb_info *par = info->par;
-#ifdef CONFIG_MTRR
-		if (par->mtrr_reg >= 0) {
-			mtrr_del(par->mtrr_reg, 0, 0);
-#endif
+		arch_phys_wc_del(par->wc_cookie);
 		unregister_framebuffer(info);
 		fb_dealloc_cmap(&info->cmap);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
