drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar()
Author: Luis R. Rodriguez <mcgrof@suse.com>
Convert the driver from using the x86-specific MTRR code to the
architecture-agnostic arch_phys_wc_add(). It will avoid MTRR if
write-combining is available, in order to take advantage of that
also ensure the ioremapped area is requested as write-combining.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture-specific and on
   x86 it is being replaced by PAT.
c) Help with the goal of eventually using _PAGE_CACHE_UC over
   _PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
   de33c442e titled "x86 PAT: fix performance drop for glx,
   use UC minus for ioremap(), ioremap_nocache() and
   pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the ifdeffery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get an
MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Signed-off-by: Luis R. Rodriguez
Signed-off-by: Borislav Petkov
Acked-by: Tomi Valkeinen
Cc: Andrew Morton
Cc: Andy Lutomirski
Cc: Antonino Daplas
Cc: Arnd Bergmann
Cc: Daniel Vetter
Cc: Dave Airlie
Cc: Geert Uytterhoeven
Cc: H. Peter Anvin
Cc: Jean-Christophe Plagniol-Villard
Cc: Jingoo Han
Cc: Juergen Gross
Cc: Laurent Pinchart
Cc: Linus Torvalds
Cc: Peter Zijlstra
Cc: Suresh Siddha
Cc: Thomas Gleixner
Cc: airlied@linux.ie
Cc: benh@kernel.crashing.org
Cc: bhelgaas@google.com
Cc: dan.j.williams@intel.com
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: mst@redhat.com
Cc: toshi.kani@hp.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1440443613-13696-4-git-send-email-mcgrof@do-not-panic.com
Signed-off-by: Ingo Molnar
 drivers/video/fbdev/kyro/fbdev.c | 33 +++++++++++----------------------
 include/video/kyro.h             |  4 +---
 2 files changed, 12 insertions(+), 25 deletions(-)
diff --git a/drivers/video/fbdev/kyro/fbdev.c b/drivers/video/fbdev/kyro/fbdev.c
index 65041e1..5bb0153 100644
--- a/drivers/video/fbdev/kyro/fbdev.c
+++ b/drivers/video/fbdev/kyro/fbdev.c
@@ -22,9 +22,6 @@
 #include <linux/pci.h>
 #include <asm/io.h>
 #include <linux/uaccess.h>
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
 #include <video/kyro.h>
@@ -84,9 +81,7 @@ static device_info_t deviceInfo;
 static char *mode_option = NULL;
 static int nopan = 0;
 static int nowrap = 1;
-#ifdef CONFIG_MTRR
 static int nomtrr = 0;
-#endif
 /* PCI driver prototypes */
 static int kyrofb_probe(struct pci_dev *pdev, const struct pci_device_id *ent);
@@ -570,10 +565,8 @@ static int __init kyrofb_setup(char *options)
 			nopan = 1;
 		} else if (strcmp(this_opt, "nowrap") == 0) {
 			nowrap = 1;
-#ifdef CONFIG_MTRR
 		} else if (strcmp(this_opt, "nomtrr") == 0) {
 			nomtrr = 1;
-#endif
 		} else {
 			mode_option = this_opt;
@@ -691,17 +684,16 @@ static int kyrofb_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	currentpar->regbase = deviceInfo.pSTGReg =
 		ioremap_nocache(kyro_fix.mmio_start, kyro_fix.mmio_len);
+	if (!currentpar->regbase)
+		goto out_free_fb;
-	info->screen_base = ioremap_nocache(kyro_fix.smem_start,
-					    kyro_fix.smem_len);
+	info->screen_base = pci_ioremap_wc_bar(pdev, 0);
+	if (!info->screen_base)
+		goto out_unmap_regs;
-#ifdef CONFIG_MTRR
 	if (!nomtrr)
-		currentpar->mtrr_handle =
-			mtrr_add(kyro_fix.smem_start,
-				 kyro_fix.smem_len,
-				 MTRR_TYPE_WRCOMB, 1);
-#endif
+		currentpar->wc_cookie = arch_phys_wc_add(kyro_fix.smem_start,
+							 kyro_fix.smem_len);
 	kyro_fix.ypanstep	= nopan ? 0 : 1;
 	kyro_fix.ywrapstep	= nowrap ? 0 : 1;
@@ -745,8 +737,10 @@ static int kyrofb_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	return 0;
 out_unmap:
-	iounmap(currentpar->regbase);
 	iounmap(info->screen_base);
+out_unmap_regs:
+	iounmap(currentpar->regbase);
+out_free_fb:
 	framebuffer_release(info);
 	return -EINVAL;
@@ -770,12 +764,7 @@ static void kyrofb_remove(struct pci_dev *pdev)
 	iounmap(par->regbase);
-#ifdef CONFIG_MTRR
-	if (par->mtrr_handle)
-		mtrr_del(par->mtrr_handle,
-			 info->fix.smem_start,
-			 info->fix.smem_len);
-#endif
+	arch_phys_wc_del(par->wc_cookie);
 	unregister_framebuffer(info);
diff --git a/include/video/kyro.h b/include/video/kyro.h
index c563968..b958c2e 100644
--- a/include/video/kyro.h
+++ b/include/video/kyro.h
@@ -35,9 +35,7 @@ struct kyrofb_info {
 	/* Useful to hold depth here for Linux */
 	u8 PIXDEPTH;
-#ifdef CONFIG_MTRR
-	int mtrr_handle;
-#endif
+	int wc_cookie;
 extern int kyro_dev_init(void);
BtrLinux
Privacy Overview
