drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar()
Author: Luis R. Rodriguez <mcgrof@suse.com>
Convert the driver from using the x86-specific MTRR code to the
architecture-agnostic arch_phys_wc_add(). It will avoid MTRR if
write-combining is available, in order to take advantage of that
also ensure the ioremapped area is requested as write-combining.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture-specific and
on    x86 it is being replaced by PAT.
c) Help with the goal of eventually using _PAGE_CACHE_UC over
   _PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
   de33c442e titled "x86 PAT: fix performance drop for glx,
   use UC minus for ioremap(), ioremap_nocache() and
   pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the ifdeffery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get an
MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Signed-off-by: Luis R. Rodriguez
Signed-off-by: Borislav Petkov
Acked-by: Tomi Valkeinen
Cc: Andrew Morton
Cc: Andy Lutomirski
Cc: Antonino Daplas
Cc: Arnd Bergmann
Cc: Benoit Taine
Cc: Bjorn Helgaas
Cc: Daniel Vetter
Cc: Dave Airlie
Cc: Geert Uytterhoeven
Cc: H. Peter Anvin
Cc: Jean-Christophe Plagniol-Villard
Cc: Jingoo Han
Cc: Juergen Gross
Cc: Linus Torvalds
Cc: Peter Zijlstra
Cc: Rob Clark
Cc: Suresh Siddha
Cc: Thomas Gleixner
Cc: airlied@linux.ie
Cc: benh@kernel.crashing.org
Cc: dan.j.williams@intel.com
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: mst@redhat.com
Cc: toshi.kani@hp.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1440443613-13696-3-git-send-email-mcgrof@do-not-panic.com
Signed-off-by: Ingo Molnar
 drivers/video/fbdev/i740fb.c | 35 ++++++-----------------------------
 1 file changed, 6 insertions(+), 29 deletions(-)
diff --git a/drivers/video/fbdev/i740fb.c b/drivers/video/fbdev/i740fb.c
index a2b4204..452e116 100644
--- a/drivers/video/fbdev/i740fb.c
+++ b/drivers/video/fbdev/i740fb.c
@@ -27,24 +27,15 @@
 #include <linux/console.h>
 #include <video/vga.h>
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
 #include "i740_reg.h"
 static char *mode_option;
-#ifdef CONFIG_MTRR
 static int mtrr = 1;
-#endif
 struct i740fb_par {
 	unsigned char __iomem *regs;
 	bool has_sgram;
-#ifdef CONFIG_MTRR
-	int mtrr_reg;
-#endif
+	int wc_cookie;
 	bool ddc_registered;
 	struct i2c_adapter ddc_adapter;
 	struct i2c_algo_bit_data ddc_algo;
@@ -1040,7 +1031,7 @@ static int i740fb_probe(struct pci_dev *dev, const struct pci_device_id *ent)
 		goto err_request_regions;
-	info->screen_base = pci_ioremap_bar(dev, 0);
+	info->screen_base = pci_ioremap_wc_bar(dev, 0);
 	if (!info->screen_base) {
 		dev_err(info->device, "error remapping base\n");
 		ret = -ENOMEM;
@@ -1144,13 +1135,9 @@ static int i740fb_probe(struct pci_dev *dev, const struct pci_device_id *ent)
 	fb_info(info, "%s frame buffer device\n", info->fix.id);
 	pci_set_drvdata(dev, info);
-#ifdef CONFIG_MTRR
-	if (mtrr) {
-		par->mtrr_reg = -1;
-		par->mtrr_reg = mtrr_add(info->fix.smem_start,
-				info->fix.smem_len, MTRR_TYPE_WRCOMB, 1);
-#endif
+	if (mtrr)
+		par->wc_cookie = arch_phys_wc_add(info->fix.smem_start,
+						  info->fix.smem_len);
 	return 0;
 err_reg_framebuffer:
@@ -1177,13 +1164,7 @@ static void i740fb_remove(struct pci_dev *dev)
 	if (info) {
 		struct i740fb_par *par = info->par;
-#ifdef CONFIG_MTRR
-		if (par->mtrr_reg >= 0) {
-			mtrr_del(par->mtrr_reg, 0, 0);
-#endif
+		arch_phys_wc_del(par->wc_cookie);
 		unregister_framebuffer(info);
 		fb_dealloc_cmap(&info->cmap);
 		if (par->ddc_registered)
@@ -1287,10 +1268,8 @@ static int  __init i740fb_setup(char *options)
 	while ((opt = strsep(&options, ",")) != NULL) {
 		if (!*opt)
 			continue;
-#ifdef CONFIG_MTRR
 		else if (!strncmp(opt, "mtrr:", 5))
 			mtrr = simple_strtoul(opt + 5, NULL, 0);
-#endif
 		else
 			mode_option = opt;
@@ -1327,7 +1306,5 @@ MODULE_DESCRIPTION("fbdev driver for Intel740");
 module_param(mode_option, charp, 0444);
 MODULE_PARM_DESC(mode_option, "Default video mode ('640x480-8@60', etc)");
-#ifdef CONFIG_MTRR
 module_param(mtrr, int, 0444);
 MODULE_PARM_DESC(mtrr, "Enable write-combining with MTRR (1=enable, 0=disable, default=1)");
-#endif
BtrLinux
Privacy Overview
