drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc()
Author: Luis R. Rodriguez <mcgrof@suse.com>
This driver uses strong UC for the MMIO region, and ioremap_wc()
for the framebuffer to whitelist for the WC MTRR that can be
changed to WC. On PAT systems we don't need the MTRR call so
just use arch_phys_wc_add() there, this lets us remove all those
ifdefs. Let's also be consistent and use ioremap_wc() for ATARI
as well.
There are a few motivations for this:
  a) Take advantage of PAT when available.
  b) Help bury MTRR code away, MTRR is architecture specific and
     on x86 it is being replaced by PAT.
  c) Help with the goal of eventually using _PAGE_CACHE_UC over
     _PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
     de33c442e titled "x86 PAT: fix performance drop for glx,
     use UC minus for ioremap(), ioremap_nocache() and
     pci_mmap_page_range()").
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the ifdeffery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get an
MTRR:
	@ mtrr_found @
	expression index, base, size;
	-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
	+index = arch_phys_wc_add(base, size);
	@ mtrr_rm depends on mtrr_found @
	expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
	-mtrr_del(index, base, size);
	+arch_phys_wc_del(index);
	@ mtrr_rm_zero_arg depends on mtrr_found @
	expression mtrr_found.index;
	-mtrr_del(index, 0, 0);
	@ mtrr_rm_fb_info depends on mtrr_found @
	struct fb_info *info;
	-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
	@ ioremap_replace_nocache depends on mtrr_found @
	expression base, size;
	-info->screen_base = ioremap_nocache(base, size);
	+info->screen_base = ioremap_wc(base, size);
	@ ioremap_replace_default depends on mtrr_found @
	-info->screen_base = ioremap(base, size);
Signed-off-by: Luis R. Rodriguez
Signed-off-by: Borislav Petkov
Cc: Andrew Morton
Cc: Andrzej Hajda
Cc: Andy Lutomirski
Cc: Antonino Daplas
Cc: Daniel Vetter
Cc: Dave Airlie
Cc: Davidlohr Bueso
Cc: H. Peter Anvin
Cc: Jean-Christophe Plagniol-Villard
Cc: Juergen Gross
Cc: Linus Torvalds
Cc: Mathias Krause
Cc: Mel Gorman
Cc: Peter Zijlstra
Cc: Rob Clark
Cc: Suresh Siddha
Cc: Thomas Gleixner
Cc: Tomi Valkeinen
Cc: Toshi Kani
Cc: Ville Syrjälä
Cc: Vlastimil Babka
Cc: arnd@arndb.de
Cc: benh@kernel.crashing.org
Cc: dan.j.williams@intel.com
Cc: geert@linux-m68k.org
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: linux-fbdev@vger.kernel.org
Cc: linux-mm@kvack.org
Cc: linux-pci@vger.kernel.org
Cc: mpe@ellerman.id.au
Cc: mst@redhat.com
Cc: ralf@linux-mips.org
Cc: ross.zwisler@linux.intel.com
Cc: stefan.bader@canonical.com
Cc: tj@kernel.org
Cc: ville.syrjala@linux.intel.com
Link: http://lkml.kernel.org/r/1436491499-3289-5-git-send-email-mcgrof@do-not-panic.com
Signed-off-by: Ingo Molnar
 drivers/video/fbdev/aty/atyfb.h      |  4 +---
 drivers/video/fbdev/aty/atyfb_base.c | 36 +++++++-----------------------------
 2 files changed, 8 insertions(+), 32 deletions(-)
diff --git a/drivers/video/fbdev/aty/atyfb.h b/drivers/video/fbdev/aty/atyfb.h
index 89ec439..63c4842 100644
--- a/drivers/video/fbdev/aty/atyfb.h
+++ b/drivers/video/fbdev/aty/atyfb.h
@@ -182,9 +182,7 @@ struct atyfb_par {
 	unsigned long irq_flags;
 	unsigned int irq;
 	spinlock_t int_lock;
-#ifdef CONFIG_MTRR
-	int mtrr_aper;
-#endif
+	int wc_cookie;
 	u32 mem_cntl;
 	struct crtc saved_crtc;
 	union aty_pll saved_pll;
diff --git a/drivers/video/fbdev/aty/atyfb_base.c b/drivers/video/fbdev/aty/atyfb_base.c
index 7770a84..f34ed47f 100644
--- a/drivers/video/fbdev/aty/atyfb_base.c
+++ b/drivers/video/fbdev/aty/atyfb_base.c
@@ -98,9 +98,6 @@
 #ifdef CONFIG_PMAC_BACKLIGHT
 #include <asm/backlight.h>
 #endif
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
  * Debug flags.
@@ -303,9 +300,7 @@ static struct fb_ops atyfb_ops = {
 static bool noaccel;
-#ifdef CONFIG_MTRR
 static bool nomtrr;
-#endif
 static int vram;
 static int pll;
 static int mclk;
@@ -2628,17 +2623,13 @@ static int aty_init(struct fb_info *info)
 		aty_st_le32(BUS_CNTL, aty_ld_le32(BUS_CNTL, par) |
 			    BUS_APER_REG_DIS, par);
-#ifdef CONFIG_MTRR
-	par->mtrr_aper = -1;
-	if (!nomtrr) {
+	if (!nomtrr)
 		 * Only the ioremap_wc()'d area will get WC here
 		 * since ioremap_uc() was used on the entire PCI BAR.
-		par->mtrr_aper = mtrr_add(par->res_start, par->res_size,
-					  MTRR_TYPE_WRCOMB, 1);
-#endif
+		par->wc_cookie = arch_phys_wc_add(par->res_start,
+						  par->res_size);
 	info->fbops = &atyfb_ops;
 	info->pseudo_palette = par->pseudo_palette;
@@ -2766,13 +2757,8 @@ aty_init_exit:
 	/* restore video mode */
 	aty_set_crtc(par, &par->saved_crtc);
 	par->pll_ops->set_pll(info, &par->saved_pll);
+	arch_phys_wc_del(par->wc_cookie);
-#ifdef CONFIG_MTRR
-	if (par->mtrr_aper >= 0) {
-		mtrr_del(par->mtrr_aper, 0, 0);
-#endif
 	return ret;
@@ -3672,7 +3658,8 @@ static int __init atyfb_atari_probe(void)
 		 * Map the video memory (physical address given)
 		 * to somewhere in the kernel address space.
-		info->screen_base = ioremap(phys_vmembase[m64_num], phys_size[m64_num]);
+		info->screen_base = ioremap_wc(phys_vmembase[m64_num],
+					       phys_size[m64_num]);
 		info->fix.smem_start = (unsigned long)info->screen_base; /* Fake! */
 		par->ati_regbase = ioremap(phys_guiregbase[m64_num], 0x10000) +
 						0xFC00ul;
@@ -3738,13 +3725,8 @@ static void atyfb_remove(struct fb_info *info)
 	if (M64_HAS(MOBIL_BUS))
 		aty_bl_exit(info->bl_dev);
 #endif
-#ifdef CONFIG_MTRR
-#endif
 #ifndef __sparc__
 	if (par->ati_regbase)
 		iounmap(par->ati_regbase);
@@ -3860,10 +3842,8 @@ static int __init atyfb_setup(char *options)
 	while ((this_opt = strsep(&options, ",")) != NULL) {
 		if (!strncmp(this_opt, "noaccel", 7)) {
 			noaccel = 1;
-#ifdef CONFIG_MTRR
 		} else if (!strncmp(this_opt, "nomtrr", 6)) {
 			nomtrr = 1;
-#endif
 		} else if (!strncmp(this_opt, "vram:", 5))
 			vram = simple_strtoul(this_opt + 5, NULL, 0);
 		else if (!strncmp(this_opt, "pll:", 4))
@@ -4033,7 +4013,5 @@ module_param(comp_sync, int, 0);
 MODULE_PARM_DESC(comp_sync, "Set composite sync signal to low (0) or high (1)");
 module_param(mode, charp, 0);
 MODULE_PARM_DESC(mode, "Specify resolution as \"<xres>x<yres>[-<bpp>][@<refresh>]\" ");
-#ifdef CONFIG_MTRR
 module_param(nomtrr, bool, 0);
 MODULE_PARM_DESC(nomtrr, "bool: disable use of MTRR registers");
-#endif
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
