drivers/video/exynos/exynos_mipi_dsi.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Acked-by: Donghwa Lee
Signed-off-by: Florian Tobias Schandinat
 drivers/video/exynos/exynos_mipi_dsi.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/drivers/video/exynos/exynos_mipi_dsi.c b/drivers/video/exynos/exynos_mipi_dsi.c
index ef68228..1f5de89 100644
--- a/drivers/video/exynos/exynos_mipi_dsi.c
+++ b/drivers/video/exynos/exynos_mipi_dsi.c
@@ -375,6 +375,7 @@ static int exynos_mipi_dsi_probe(struct platform_device *pdev)
 	dsim->clock = clk_get(&pdev->dev, "dsim0");
 	if (IS_ERR(dsim->clock)) {
 		dev_err(&pdev->dev, "failed to get dsim clock source\n");
+		ret = -ENODEV;
 		goto err_clock_get;
@@ -383,6 +384,7 @@ static int exynos_mipi_dsi_probe(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	if (!res) {
 		dev_err(&pdev->dev, "failed to get io memory region\n");
+		ret = -ENODEV;
 		goto err_platform_get;
@@ -407,6 +409,7 @@ static int exynos_mipi_dsi_probe(struct platform_device *pdev)
 	dsim_ddi = exynos_mipi_dsi_bind_lcd_ddi(dsim, dsim_pd->lcd_panel_name);
 	if (!dsim_ddi) {
 		dev_err(&pdev->dev, "mipi_dsim_ddi object not found.\n");
+		ret = -EINVAL;
 		goto err_bind;
BtrLinux
Privacy Overview
