drivers/video/backlight/da9052_bl.c: drop devm_kfree of devm_kzalloc’d data
Author: Julia Lawall <Julia.Lawall@lip6.fr>
devm_kfree should not have to be explicitly used.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x,d;
x = devm_kzalloc(...)
?-devm_kfree(d,x);
Signed-off-by: Julia Lawall
Acked-by: Jingoo Han
Signed-off-by: Florian Tobias Schandinat
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/video/backlight/da9052_bl.c | 2 --
1 file changed, 2 deletions(-)
diff --git a/drivers/video/backlight/da9052_bl.c b/drivers/video/backlight/da9052_bl.c
index 10485c9..ac19618 100644
--- a/drivers/video/backlight/da9052_bl.c
+++ b/drivers/video/backlight/da9052_bl.c
@@ -129,7 +129,6 @@ static int da9052_backlight_probe(struct platform_device *pdev)
&da9052_backlight_ops, &props);
if (IS_ERR(bl)) {
dev_err(&pdev->dev, "Failed to register backlight\n");
- devm_kfree(&pdev->dev, wleds);
return PTR_ERR(bl);
@@ -149,7 +148,6 @@ static int da9052_backlight_remove(struct platform_device *pdev)
wleds->state = DA9052_WLEDS_OFF;
da9052_adjust_wled_brightness(wleds);
backlight_device_unregister(bl);
return 0;
if (IS_ERR(bl)) {
return PTR_ERR(bl);
return 0;
