drivers/video: release mutex in error handling code
The mutex is released on a successful return, so it would seem that it
should be released on an error return as well.
The semantic patch finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
expression l;
mutex_lock(l);
... when != mutex_unlock(l)
    when any
    when strict
if (...) { ... when != mutex_unlock(l)
+   mutex_unlock(l);
    return ...;
mutex_unlock(l);
Signed-off-by: Julia Lawall
Acked-by: Krzysztof Helt
Acked-by: Ondrej Zajicek
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/video/arkfb.c    | 9 +++------
 drivers/video/vt8623fb.c | 9 +++------
 2 files changed, 6 insertions(+), 12 deletions(-)
diff --git a/drivers/video/arkfb.c b/drivers/video/arkfb.c
index 5001bd4..38a1e83 100644
--- a/drivers/video/arkfb.c
+++ b/drivers/video/arkfb.c
@@ -1126,11 +1126,8 @@ static int ark_pci_resume (struct pci_dev* dev)
 	acquire_console_sem();
 	mutex_lock(&(par->open_lock));
-	if (par->ref_count == 0) {
-		mutex_unlock(&(par->open_lock));
-		release_console_sem();
-		return 0;
+	if (par->ref_count == 0)
+		goto fail;
 	pci_set_power_state(dev, PCI_D0);
 	pci_restore_state(dev);
@@ -1143,8 +1140,8 @@ static int ark_pci_resume (struct pci_dev* dev)
 	arkfb_set_par(info);
 	fb_set_suspend(info, 0);
 fail:
+	mutex_unlock(&(par->open_lock));
 	return 0;
diff --git a/drivers/video/vt8623fb.c b/drivers/video/vt8623fb.c
index 536ab11..4a484ee 100644
--- a/drivers/video/vt8623fb.c
+++ b/drivers/video/vt8623fb.c
@@ -853,11 +853,8 @@ static int vt8623_pci_resume(struct pci_dev* dev)
-		return 0;
+		goto fail;
@@ -870,8 +867,8 @@ static int vt8623_pci_resume(struct pci_dev* dev)
 	vt8623fb_set_par(info);
 fail:
 	return 0;
BtrLinux
Privacy Overview
