drivers/video: add kmalloc NULL tests
Check that the result of kmalloc is not NULL before passing it to other
functions.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
    when != x != NULL
    when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
[akpm@linux-foundation.org: convert to kstrdup() as well]
Signed-off-by: Julia Lawall
Cc: Ming Lei
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/video/au1100fb.c | 7 +++++--
 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/video/au1100fb.c b/drivers/video/au1100fb.c
index 378f277..a699aab 100644
--- a/drivers/video/au1100fb.c
+++ b/drivers/video/au1100fb.c
@@ -715,8 +715,11 @@ int au1100fb_setup(char *options)
 			/* Mode option (only option that start with digit) */
 			else if (isdigit(this_opt[0])) {
-				mode = kmalloc(strlen(this_opt) + 1, GFP_KERNEL);
-				strncpy(mode, this_opt, strlen(this_opt) + 1);
+				mode = kstrdup(this_opt, GFP_KERNEL);
+				if (!mode) {
+					print_err("memory allocation failed");
+					return -ENOMEM;
 			/* Unsupported option */
 			else {
BtrLinux
Privacy Overview
