drivers/usb/host/ohci-nxp.c: adjust inconsistent IS_ERR and PTR_ERR
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Change the call to PTR_ERR to access the value just tested by IS_ERR.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e,e1;
if (IS_ERR(e)) { ... PTR_ERR(e) ... }
if (IS_ERR(e=e1)) { ... PTR_ERR(e) ... }
*if (IS_ERR(e))
*  PTR_ERR(e1)
Signed-off-by: Julia Lawall
Acked-by: Alan Stern
 drivers/usb/host/ohci-nxp.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/ohci-nxp.c b/drivers/usb/host/ohci-nxp.c
index a446386..c60066a 100644
--- a/drivers/usb/host/ohci-nxp.c
+++ b/drivers/usb/host/ohci-nxp.c
@@ -355,7 +355,7 @@ static int __devinit usb_hcd_nxp_probe(struct platform_device *pdev)
 	usb_otg_clk = clk_get(&pdev->dev, "ck_usb_otg");
 	if (IS_ERR(usb_otg_clk)) {
 		dev_err(&pdev->dev, "failed to acquire USB DEV Clock\n");
-		ret = PTR_ERR(usb_dev_clk);
+		ret = PTR_ERR(usb_otg_clk);
 		goto out6;
BtrLinux
Privacy Overview
