drivers/usb/host/isp1760-if.c: introduce missing kfree
drvdata needds to be freed before leaving the function in an error case.
A simplified version of the semantic match that finds the problem is as
follows: (http://coccinelle.lip6.fr)
@r exists@
local idexpression x;
statement S;
identifier f1;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
 drivers/usb/host/isp1760-if.c | 13 +++++++++----
 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/isp1760-if.c b/drivers/usb/host/isp1760-if.c
index b605224..61de62c 100644
--- a/drivers/usb/host/isp1760-if.c
+++ b/drivers/usb/host/isp1760-if.c
@@ -56,14 +56,18 @@ static int of_isp1760_probe(struct platform_device *dev)
 		return -ENOMEM;
 	ret = of_address_to_resource(dp, 0, &memory);
-	if (ret)
-		return -ENXIO;
+	if (ret) {
+		ret = -ENXIO;
+		goto free_data;
 	res_len = resource_size(&memory);
 	res = request_mem_region(memory.start, res_len, dev_name(&dev->dev));
-	if (!res)
-		return -EBUSY;
+	if (!res) {
+		ret = -EBUSY;
+		goto free_data;
 	if (of_irq_map_one(dp, 0, &oirq)) {
 		ret = -ENODEV;
@@ -125,6 +129,7 @@ free_gpio:
 		gpio_free(drvdata->rst_gpio);
 release_reg:
 	release_mem_region(memory.start, res_len);
+free_data:
 	kfree(drvdata);
 	return ret;
BtrLinux
Privacy Overview
