drivers/usb/gadget/lpc32xx_udc.c: adjust inconsistent IS_ERR and PTR_ERR
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Change the call to PTR_ERR to access the value just tested by IS_ERR.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression e,e1;
if (IS_ERR(e)) { ... PTR_ERR(e) ... }
if (IS_ERR(e=e1)) { ... PTR_ERR(e) ... }
*if (IS_ERR(e))
*  PTR_ERR(e1)
Signed-off-by: Julia Lawall
 drivers/usb/gadget/lpc32xx_udc.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/lpc32xx_udc.c b/drivers/usb/gadget/lpc32xx_udc.c
index f1ec99e..3a6cdd0 100644
--- a/drivers/usb/gadget/lpc32xx_udc.c
+++ b/drivers/usb/gadget/lpc32xx_udc.c
@@ -3208,7 +3208,7 @@ static int __init lpc32xx_udc_probe(struct platform_device *pdev)
 	udc->usb_otg_clk = clk_get(&pdev->dev, "ck_usb_otg");
 	if (IS_ERR(udc->usb_otg_clk)) {
 		dev_err(udc->dev, "failed to acquire USB otg clock\n");
-		retval = PTR_ERR(udc->usb_slv_clk);
+		retval = PTR_ERR(udc->usb_otg_clk);
 		goto usb_otg_clk_get_fail;
BtrLinux
Privacy Overview
