drivers/usb/chipidea/core.c: adjust duplicate test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive tests to the same location.  In this case res has already
been tested for being NULL, and calling devm_request_and_ioremap will not
make it NULL.  On the other hand, devm_request_and_ioremap can return NULL
on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
 { ... when forall
   return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
    when != \(XT_GETPAGE(...,y)\|WMI_CMD_BUF(...)\)
 { ... when forall
   return ...; }
Signed-off-by: Julia Lawall
Cc: Alexander Shishkin
 drivers/usb/chipidea/core.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/chipidea/core.c b/drivers/usb/chipidea/core.c
index aebf695..57cae1f 100644
--- a/drivers/usb/chipidea/core.c
+++ b/drivers/usb/chipidea/core.c
@@ -411,7 +411,7 @@ static int ci_hdrc_probe(struct platform_device *pdev)
 	base = devm_request_and_ioremap(dev, res);
-	if (!res) {
+	if (!base) {
 		dev_err(dev, "can't request and ioremap resource\n");
 		return -ENOMEM;
BtrLinux
Privacy Overview
