drivers/tty/serial/sirfsoc_uart.c: drop frees of devm_ alloc’d data
Author: Julia Lawall <Julia.Lawall@lip6.fr>
devm free functions should not have to be explicitly used.
A semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
* devm_kfree(...);
* devm_free_irq(...);
* devm_iounmap(...);
* devm_release_region(...);
* devm_release_mem_region(...);
Signed-off-by: Julia Lawall
drivers/tty/serial/sirfsoc_uart.c | 8 ++------
1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/tty/serial/sirfsoc_uart.c b/drivers/tty/serial/sirfsoc_uart.c
index 5b3eda2..a9e2bd1 100644
--- a/drivers/tty/serial/sirfsoc_uart.c
+++ b/drivers/tty/serial/sirfsoc_uart.c
@@ -668,7 +668,7 @@ int sirfsoc_uart_probe(struct platform_device *pdev)
if (res == NULL) {
dev_err(&pdev->dev, "Insufficient resources.\n");
ret = -EFAULT;
- goto irq_err;
+ goto err;
port->irq = res->start;
@@ -676,7 +676,7 @@ int sirfsoc_uart_probe(struct platform_device *pdev)
sirfport->p = pinctrl_get_select_default(&pdev->dev);
ret = IS_ERR(sirfport->p);
if (ret)
- goto pin_err;
+ goto err;
port->ops = &sirfsoc_uart_ops;
@@ -695,9 +695,6 @@ port_err:
platform_set_drvdata(pdev, NULL);
if (sirfport->hw_flow_ctrl)
pinctrl_put(sirfport->p);
-pin_err:
-irq_err:
- devm_iounmap(&pdev->dev, port->membase);
err:
return ret;
@@ -709,7 +706,6 @@ static int sirfsoc_uart_remove(struct platform_device *pdev)
uart_remove_one_port(&sirfsoc_uart_drv, port);
return 0;
if (res == NULL) {
ret = -EFAULT;
- goto irq_err;
+ goto err;
if (ret)
- goto pin_err;
+ goto err;
-pin_err:
-irq_err:
err:
return ret;
return 0;
